View Full Version : 1st Gen Dakota Tech
- HELP! i need an answer to get my spindle!
- My dodge
- Dakota won't start - fuel pump?
- EGR Delete?
- Dodge Dakota Auto Transmission Slipping Still..
- Overdrive Intermittent, Running Out of Options...
- Winter traction-sandbags-tires
- Cummins 10 speed?
- Front Hitch?
- 95 Dakota Weak spark
- Gauge needles. How to replace them?
- 5.9 Track Times
- 1989 Dakota Convertible... brake restoration
- Ignition timing on the 2.5?
- My Dakota
- 5.2 thermostat bypass improvement
- Single Stack on a 2.5 gasser, opinions?
- 1992 dodge dakota crank no start
- 1990 Convertible 18,000 miles
- Chrysler LSD Swap?
- Leak in Blower Motor Box (interior)
- 5 speed swap
- Interior cab light will not turn off
- Fog lights under hood...?
- advice needed
- Removing torque converter???
- 2 in spacers/adapters
- Having Troubles: Low Voltage
- Need Help
- New guy. Storm Chase Vehicle Project
- D-Ring/Tow hook mount up and Hi-Lift jack "Pics"
- Is There a Temp Sensor on my Transmission?
- Have really bad shaking when braking from high speeds Help!!!
- 93 Dakota-Rough Idle
- 91 dakota error codes
- Running issues on my 90 3.9L automatic
- First real nig bump in the road :(
- White Foam (Seal) on Blower Motor Box
- 1995 Dodge Dakota - Ballast Resistor Plug Melted
- Needing help with dakota
- Just wanted to share.
- 96 dakota strange noise when dropping into gear
- Fuel pump/sending unit.
- Ignition problem, 92 Dakota
- transfer case grinds in 2wd but fine in 4
- Mystery Bushing 92 Dako wiper arm link
- So I have this 46re..
- Door lock help
- Making a junkyard run
- Cold Weather Blues
- Over tow rating? Nah.
- Need help with transfer case
- 94 Dakota Pre Runner Plans!
- Computer Reset Symptoms!?
- body mounts
- im stumped
- power chip
- Upgrading Stereo with newer stock radio... or ???
- gauge lights dont work??
- 96 gauges
- 92 dodge dakota cutting off while driving
- Gen 1 Bed lengths and bolt pattern
- Rewire sending unit?
- 1996 Dakota Sport 3.9L Upgrades
- Lowering
- More rotm votes please
- Trouble code 41 1990 3.9
- dodge cranks but wont start
- 1995 Dakota Differential help needed!
- Hello All
- 12 second dakota =)
- ways to make my dakota a little faster??
- Modified Shift Rod
- Need advice on 1990 dakota sport
- Retrofitting Dakota Gauge Cluster
- A/c recharge port
- Has anyone done this?
- Replacing my driver side control arm
- what do you think !
- Transmission trouble with parts in pan
- transmission slippage
- need some diagnosing '90 3.9L
- 3" body lift
- Hello
- beer cap headliner
- im thinking its a fuel problem but need help
- 2wd sagging front coil springs?
- need help on pulling engine...91 dakota 4x4
- New To This Site
- Sub Box
- bumper questions
- investing more cash before winter
- in need of drop spindles.
- 95 Dakota transmission not shifting
- Transfer Case Gone !!
- Battery charging gauge in dash
- what clutch ?
- dodge dakota wont crank
- Bed Drain Holes?
- Not a Dakota? But please help if possible..
- 1996 fuel pump harness
- output shaft seals
- engine harness swap starts, runs, dies, no start
- My Truck....
- add a leafs
- New Transmission or Get it Rebuilt?
- Rollover Valve/ Fuel vapor valve-Yes the one you just broke changing your fuel pump
- 4x4 to 2x4, possible?...
- code 27
- 96 Dashboard gauges!
- trans whine
- Valve lash or adjusting
- New truck. New user. Old trim.
- Fuel gauge readings erratic at rest, opinion/knowledge requested
- 94 Dakota has a Strange Hiss/Moan Noise when brake pedal is applied or released
- oil pressure gauge
- Need Help with Coolant Temperature Sensor
- raising front of 1988 dakota
- Prothane bushings
- hello everyone
- New Over head console install with pics.
- control arm bushings
- Not my area of knowledge- Camshaft.
- Replacing TC rear retainer... Bolt size?
- Cowl Drain = Fender Rust Spot?
- Cruise Control Vacuum leak?
- Dodge Dakota's 318 carb leaking from everywhere
- New Sending Unit
- Windshield wiper problem 1990
- transfer case removal
- Need some help with 1996 Dakota
- Heat/Air Conditioning System Changes To The Defrost Mode When Accelerating
- Show and Tell
- New truck, need some input...swap/lowering.
- Actual likelyhood of damage due to cranking torsion bars/lift keys
- paid and ordered
- Can I mix ATF +4 with Dexron?
- Lifting question
- 1996 Dodge Dakota sport
- Electrical problems
- Locking CAD !!!
- Help finding Interior Trim Parts 94 Dakota snd much more. Thanks
- low fuel light 1996 3.1
- Little Sound Clip of My Truck
- Fuel injector cleaning.
- Oil pressure sensor problems
- 3.9 tick n more...advice??
- Conversion time?
- 1992 4x4 steering shaft
- new mechanical fuel pump not working
- some questions
- key lifts
- How to: Dakota Gen 1 4x4 Lower Control Arm Bushings
- 1995 Dodge Dakota Radiator/Leaking problems. Help anyone?
- Which Shocks Should I Buy ?
- Bed box lock question
- Truck running lean??
- Only High Beams work on 96 Dakota
- ignition lock cylinder removal?
- How much should I ask for my truck?
- 95 Dakota won't crank
- 1988 Dodge Dakota, Swapping gauge clusters for one with a tach?
- No Lock-Up Til 65mph?
- Possible Headgasket Failure?
- Help! It keeps dying!
- gas tank wont line up
- check engine light only comes on in the afternoon
- 2.02 heads on a 318?
- 92 dakota need help with problem
- Front Axle Swap
- More power from the 2.5?
- options for a 2wd lift
- 4WD Actuator (CAD) 92 dakota
- 87-96 Aftermarket Side Mirrors?
- 1995 Dakota dies
- Need a new radiator, any upgrades available?
- brake help
- nv3500 ?
- 89 Dodge Dakota 4x4 *Express* 1 Owner! Only 300 Made! Very Rare!
- 2 or 4 wheel ABS?
- Rear Window Leak?
- Chatter at 45mph need ideas
- 91 dakota 4x4- pull engine with or without tranny?
- getting the dakota back on the road
- Squeaking Bed/Tailgate while driving
- Question about some gauges.
- 2inch suspension lift
- Dakota mudding
- 93 Octane vs 87? Upgraded Parts..
- 93 Dakota LE Where is the headlight relay?
- 93 V8 4WD Automatic Low Idle
- few questions
- 1992 speed sensor wires
- 89 dakota sport 3.9 no spark
- Abs and parking brake lights
- 1988 2WD Load Sensing Brake Pressure Valve
- How do I know?
- Replacing (re instating) electric fuel pump over mechanical?
- new truck
- 18" MB motoring wheels on craigslist.
- Box bolts
- gas leak fixed
- pitted timing cover
- 3.9L Air Filter Idea
- want my track fixed
- STRANDED on side of the road - need urgent answers
- 87-96 Dakota Tailgate Net
- Steering column shifts while braking. Mer?
- 94 Dakota DTC
- headers
- R/T Wheels
- Anti Freeze Leak When Truck if Off
- Bad MAP sensor? Engine surging while coasting in neutral.
- healp need ancers
- Finally!!!
- HELP - 1995 Dodge Dakota Stalling Out
- How to remove the back window?
- bad half shaft
- just got paid 2k wat to do????
- 1987 3.9 dakoka holly carb.
- 92 Dakota 4WD odd
- wheel spacers for 33" tires
- 1990 Dodge Dakota Sport fuel pump issues
- Help me identify this plug.
- clock spring broken?
- Double Roller Timing Chain?
- can i just get a third party gas gauge?
- What's the best/easiest way to pull the oil pan on a 93 V8 4WD?
- running cold ?
- 96 5.2 stalled suddenly and would not start again
- ive replaced all parts an my 1994 dakota stiil no pedal
- Pass. side door hinges broke.
- Headlights going out while driving
- 92 2.5 electric fan runs all the time.
- 1994 Dakota No Start
- door question
- Need help with my 92 Dakota.
- Need help with my 92 dakota
- What to do???
- Code 37
- Magnum engine builds
- gas taank
- 1989 Dakota V6 runs then bogs down. Start it up and it runs again.
- key problem
- power steering coolers
- Bed Liner Paint Job !!!
- 95' Dodge Dakota Sport 2WD Owner - Needing Help with Lifting Options
- Engine adapter bracket torque specs
- Help, feeling dumb, ? about 4wd, transmission, neutral
- 95 Dakota transfer case detent plug.
