PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. 92 Magnum TPS testing
  2. OBD 1 no talkie
  3. Seat belts
  4. help with mods !!!!!
  5. 93 Dakota 5.2L ABS/BRAKE Light problem
  6. jim1993dakota
  7. 87-96 Dakota Cab Bolt Removal
  8. *EGR delete plate for a 3.9l LA block?
  9. Opinions on best rolling chassis.
  10. 94 by-pass anit-lock unit/anyone done this?
  11. Speaker help 93 dodge dakota
  12. 96 dakota 5.7 hemi swap?
  13. And on a sad note... this happened
  14. Just bought 95 dakota slt
  15. T-case removal
  16. changing tire's need help
  17. brake interlock
  18. 1993 dakota error codes
  19. temp gauge sending unit.
  20. PTU Solenoid
  21. Knocking sound
  22. MSD Timing Help
  23. help needed on truck
  24. Just died on the highway when I was doing 65mph
  25. Help ! Rodents ate my wiring harness 1996 Dakota 318V8
  26. Transmission interchange help
  27. V6 Cams
  28. My heater stopped working......Help!
  29. Overhead Console
  30. Gauges going crazy. Wiring or bad cluster?
  31. cowl hood
  32. 02 sensor Code 21 blues
  33. 92 dakota will not start, sometimes
  34. engine choices
  35. Transfer Case Replacement
  36. Dakota Speed Sensor..
  37. v6 with 35s
  38. 95 dakota wiring issue, no power in cab
  39. how do i identify a magnum motor
  40. body mounts
  41. 92 Dak sport 3.9 4x4
  42. lowering an 87
  43. 1990 3.9L, stalls in gear when cold, whirring noise at speed
  44. 1993 3.9l auto 13mpg...
  45. Cab lights for a '96
  46. Help with 94 dodge dakota
  47. 91 5.2L Magnum AC delete
  48. Tax Check...
  49. Transmission help?
  50. not getting full 12v at coil
  51. auto to manual kit?
  52. Dakota leaking
  53. Transmission upgrade for 2.2L
  54. serpentine belt comes off
  55. 93 dodge dakota brake fail help!!
  56. 93 3.9l kegger mod?
  57. Brakes! Please help!
  58. whats happenin yall
  59. Would you fix it?
  60. ford taurus electric fan install with volvo 2 speed controller.
  61. 2002 throttle body.
  62. Yoke?
  63. My 3.9L is finished!
  64. First Truck Project
  65. Rear diff Swap
  66. 95 dakota slt 4x4 318 parting out
  67. What RPM should a 1991 Automatic 3.9 shift at at full throttle??
  68. 1990 Dakota cranks but will not run
  69. Craigslist find
  70. aftermarket coolant temp gauge
  71. Intake help!
  72. 79 dollar pioneer bundle to replace stock paper cone speakers.
  73. very disappointed with auto custom carpets.
  74. New to the site
  75. Retrofitting a 91 gauge Cluster to a 93 Cluster??
  76. 95 automatic cruise control and overdrive
  77. FAQ ain't working
  78. Washington state need 93 3.9l block
  79. Exhaust manifold to pipe leak
  80. Ignition Switched 12v circuit??
  81. Speaker wiring 93 sport
  82. feels and sounds like something binding
  83. How to fix these codes
  84. 1993 Dakota 5.2 V8 - vacumn line for vent selector
  85. fuel system swap
  86. tranny swap question
  87. When do I call it quits?
  88. Heavy duty flasher question
  89. 95 Dakota shifting problems. Advice?
  90. Can I delete the smog system on my 1991 3.9 Dakota??
  91. 89 Dak with a v8 and solid axle
  92. 93 3.9l exhaust diameter.
  93. 75/90amp and 120amp alternator interchange.
  94. New Fuel Pump/No Fuel
  95. Oil pressure sensor 1991 3.9 Dakota?
  96. Code 34
  97. '89 differential in a '94?
  98. dakota problems need help
  99. egr?
  100. Steering Stabilizers
  101. Steering Play '93 Dakota 4wd
  102. tire size?
  103. Bilstein Shock Install help?
  104. 4.10 gear ratio
  105. A998 Pump reaction Shaft
  106. Transmission Rebuild Progress
  107. 95 4x4
  108. Compatible Solenoids
  109. Bucking and a Popin
  110. how to reset check engine light on 1991 3.9L??
  111. 1991 Dakota 3.9L throttle response at idle question.
  112. 1995 dakota 4x4
  113. catalytic converter options.
  114. Alignment and steering issues. Help!
  115. flywheel question
  116. Blown Radiator, now check engine.
  117. When does it end? Water problems
  118. Best was to clean/flush the cooling system?
  119. Starting problem when warm
  120. clutch size??
  121. TrailMaster Shocks and lift kit
  122. Ignition lock cylinder switch key replacement on a 1989 1990
  123. New to the site had a question about frames
  124. I have a question about frames if someone could help
  125. 1990 Dakota Convertible 4wd wheel swap
  126. Dak Convertible Frame off Build Thread
  127. Compatible distributors?
  128. 87 4wd motor swap questions
  129. Best late model seat to swap
  130. The Victim Build Thread -- Featuring frame replacement
  131. 96 Dakota Question
  132. '94 Dakota won't go in gear
  133. Wacky Tach, pegged all the way to the right.
  134. 94 stalls when out in any gear
  135. 93 3.9 Occasional hot running AND cluster electrical gremlins!
  136. Engine won't warm up!
  137. No ABS
  138. heater mod
  139. Jedpole
  140. Dakota wont heat up
  141. signal lights
  142. Questions for fuel filter replacement: Hose, clamps
  143. Describing tranny gas pedal response issue
  144. Desperately Searching for an Obsolete Part
  145. 1999 dodge dakota heater core
  146. 93 dakota won"t start
  147. % speed Manual transmission lost 1,2,3,5 and reverse
  148. Electric fan gone wrong.
  149. Dakota 1995 trans what interchanges
  150. 5 speed swap?
  151. Weird noise when putting 1995 Dodge Dakota SLT into reverse?
  152. Spitting and sputtering plus code 22
  153. 94 3.9l to 5.2l swap please help
  154. At a loss with this squeaking belt
  155. Radio stopped working
  156. fUEL gauge??
  157. Shift kit?
  158. Ran fine for idle
  159. no start after cold front..
  160. Sudden overheating
  161. window sales paper
  162. Low growl sound ?
  163. Disconnect Battery
  164. Turbo400 GM transmission
  165. Me '93 3.9 in hospital...
  166. 92 with 5.2L - Oxygen Sensor? O2S Harness Length?
  167. stalls then no start
  168. could use a little help here
  169. squealing/squeaking sound in 94 dakota
  170. A couple of transfer case questions
  171. front end problems
  172. Is a new water pump the answer?
  173. Headlight lens renewing
  174. 94 Dakota Questions
  175. 1996 dakota horn not working
  176. Tranny/TV Cable issue
  177. heat problem
  178. Double check on fuel overflow.....
  179. 1990 Dakota Fuel pump cap replacement?
  180. Drive line out of phase?
  181. !992 Dakota sets code 27
  182. Advice for Engine Swap 4cyl to 360
  183. no fuel pressure
  184. Long tube headers
  185. trans fluid leaking from inspection plate?
  186. wow in major need of new trans mounts.
  187. upper ball joints
  188. Burning oil
  189. Boost and T400 GM trans
  190. Shudder/Shake at 35-55 mph
  191. Brake issue???
  192. snow plow on dakota?
  193. Wheel Spacers ..
  194. glass numbers?
  195. Advice for tune-up on 318 magnum 96´
  196. Help! Defrost/blend door issue
  197. 93 front end lifts on take off
  198. H4 upgraded headlights?
  199. electric fan gas saver???
  200. Bringin' her back to stock.
  201. 92 part confirmation
  202. trading tool box for bed cap
  203. Proper Oil Weight for 1990 Dodge Dakota
  204. ox sensor respond to intake manifold and heads upgrate
  205. OBD1 and the dealers computer reader
  206. New here. Front Crank Seal Question.
  207. Wont stay in 4x4
  208. Front wheels jump
  209. Front drive shaft 92 4x4
  210. Any of use guys got subs?
  211. seat belt retraction assembley
  212. nothing says mopar like honeycomb mesh grilles
  213. electric windows without the ugly first gen dak switches.
  214. Upgraded brakes?
  215. 1989 3.9 LA to 360 magnum
  216. suggestions on stripping paint
  217. is the 5 speed strong enough for v8?
  218. Transmission cooling lines? hi or low pressure
  219. no lights
  220. performance fule pump ?
  221. Need some input
  222. Larger muffler on 3.9L now less acceleration?
  223. Help with 1994 Dakota Transfer case
  224. What parts do I change on the front end?
  225. swappable 360 parts on a 318
  226. Dead battery?????
  227. What is necessary for a suspension lift?
  228. 94 Dakota, climate issues with wiper
  229. Error 21 and alternator problems
  230. 14 MPG in a V6? Sounds a bit low to me
  231. A998 rebuild kit
  232. Preformance PCM
  233. Shelby Fastback Restoration
  234. use 91 carb on a 87 dakota
  235. best 318 magnum ?
  236. overheating problem
  237. Block Heater
  238. Just another NV4500 swap
  239. truck started on fire
  240. filling grooves on caliper brackets with weld???
  241. Smog pump/Emission system
  242. So I'm looking for fender flares
  243. A998 Output shaft support
  244. Air pump pulley sticking out? Only thing preventing me from getting running.
  245. Rear bearing replacement?
  246. 93 dakota/s ABS and P-brake on
  247. Edelbrock/HughesIntake manifold replacement
  248. Driver's side exhaust glowing cherry red
  249. 1988 fuel pump quit
  250. blower motor not running
