View Full Version : 1st Gen Dakota Tech
- polyurethane bushing kit
- how to change front brakes on 91 dakota 4x4 5.2l
- what are these worth?
- Dead Engine
- lowering
- no radio or turn signals
- Installing Stereo, no original
- Butterfly valve in exaust manifold?
- 94 Dakota - Heater Motor Resistor
- just bought a 94 markIII
- Weird clicking
- just sayin thanks
- 91 dakota 5.2 air pump removal
- Tires suspension
- Vehicle Speed Sensor
- steering issues
- How to check vaccum on cruise control?
- Need help on dakota frame
- New poster looking for help !!
- check engine light codes
- superchips
- Hello
- hello and help
- 3" exhaust kit for 1995 318 Dakota
- are magnum and la blocks the same?
- mystery clicking
- 9.25 rear axle widths
- newest addition
- '94 cruise control surges going up hills
- mystery fans
- parts truck
- 1987 Dakota 3.9L 2BBL/v6 Carburated swap
- lift kit
- front limited slip
- And onto the fluids...
- weak point
- Charging system
- Windsheild wipers quit
- computer codes
- 1987 3.9L Looking For Solutions
- engine life
- engine whine
- New member... Just saying hi...
- limited slip question
- starting issues
- Fix fora sagging headliner
- Computer compatibility question
- whats the difference between the 3.9L & 3.9L Magnum
- Steering gear/pump replacement
- back to my cam question??
- questions about magnums????
- Does not start, no check engine light
- lowering?!?!
- good bore guage?
- Got the new tires
- can antilock be bypassed??
- Want to replace air filter to K&N
- difference between 91 5.2 roller cam and r/t 5.8 roller cam?
- compression ratio?gasket thickness
- aftermarket tbi intake?is there any?
- What is this problem???
- Carburated 1987 3.9 V6
- Idle problem with a 96.
- problem with transmission
- Truck running much better, more power
- 94 dakota 5.2 4x4 needs help!
- roller cam in a 91 5.2???
- whats a good cam for my 5.2
- fuel injection or carb?
- how can I get more power??? 91 5.2
- headers for my 91 5.2?
- Everyone, Please Look Inside, And Help Out
- opinions needed
- Torsion Bar Swivel
- erractic cruise control
- How does a body lift affect manual transmission?
- Flex Pics (just for fun)
- one front tire wearing unevenly
- shifting issues
- Official DIY Body work thread
- Engine shuts down
- Hello help
- Sway bar diameters?
- Where should i start?
- first 4wd clutch repair(help)PLEASE
- Front axle ideas
- Dakota transfer case inner change with Ram
- The Better differential gear oil
- Truck rides "top heavy"?
- 318 air exhuast pump
- wheel and tire weight compare
- 89 dakota sport 3.9 convert to 5.2
- cranking up torsion bars?
- Custom Bumper Design
- New fender flares
- need help with 94 dakota 4x4 trans
- Random Sh*t
- computer question
- 3" lift but need more
- front axle weaknesses???
- Dakota Build
- Computer issues after the trans swap
- what did i just break?
- What do you use for high performance distributor cap, wires, etc?
- Painted the dash
- turbo setup ideas. (plz post yours)
- A Gift
- Instrument Cluster-gear selector
- thermostat or me?
- Control Arm... Brake questions
- Plenum reinforcement kit?
- How long does it take you to change a plenum?
- 92 Dakota problems in gear
- DIY Feeding and Burping a cooling system
- VAC hose diagram needed
- DIY EZ HD head lamp harness upgrade
- 89 Dakota, 3.9l, idles ok, revs ok, runs like bogging down
- surging while idleing
- for any 3.9 1st genners out there...
- Bleeding the clutch
- stalling w/o sputtering
- 87 Front Wheel Bearing question
- miss? too much fuel?
- Diy multi-meter 101
- Interesting info on transfer cases
- HOWDY New Dakota guy here
- U bolt flip
- Lifting/lowering rear without blocks
- Tighten up steering?
- Looking to do some body work...need advise
- windsheild R+R
- whats the best head(s) to get?
- Looking at a 94 dodge dakota. I have some questions....
- Factory Service Manual
- Quick Question 1991 Dakota LE
- Transmission Advice!
- Axle Specs
- 46rh to NV3500 Swap (5.2L 4x4)
- new with a 92
- my 87 dak
- Auto Repair Reference Center password...
- If you have Power Windows in your dak pls help
- My 87 Dak Project is almost complete pics up what do you think??
- Hows this for irony...
- No brakes!
- service manual sites are down
- Synthetic and regular transmission fluid
- Seat Belt Retracting.
- help
- Things to watch out for
- How do I fill the 231 transfer case
- speed sensor
- 4x4 major problems
- getting rid of all the emmissions junk?
- Marti Report?
- Where to get an Air Dam/bumper spoiler for my 94 dak Sport
- crank sensor R+R
- Rebuild
- 2x4 to 4x4 question
- Is anyone here from Minnesota or North Dakota?
- Painting interior
- After Market Temp Gauge
- computer
- 89 3.9 back firing please help???
- Frame repair help.
- Automatic to manual conversion.
- Transmission parts
- Black cap on Injector..
- Can I weld to the frame?
- im back
- Trans pan question.
- thermometer sensor?
- crank questions
- 1993 5.2 Dakota Transmission
- coolant temp sensor HELP
- no way to switch where the heat comes from... Any vaccuum diagrams?
- Does swapping computers mean re-titling truck
- temp gauge doesn't ever move.
- Replace Water Pump
- Will more air help the 4 ?
- E3 spark plugs
- Piston Compatibility
- Wierd issue
- 93 Dodge Dakota Heat issue
- 1995 dodge dakota speedometer doesn't work
- 1991 dakota sport 3.9 liter 4x4 wiring diagram. Does anyone have one ?
- fuel pressure and power loss
- 5.9 Cam in a 5.2
- 4" trailmaster lift for sale!
- Replaced knuckle, now bigger problem
- A little help needed
- 1992 dakota 318 idles weird
- New problem... no fuel?
- Ignition relay and coil ?
- 1991 Dakota stalling
- Winshield Washer
- Help with 1990 3.9L 4X4
- 1992 dodge dakota oil pump
- New headers
- transmission change questions
- key stuck in ignition
- motor swap help please
- will a V8 out of an 84 Diplomat fit in my 91 Dakota?
- So, I screwed up!
- Plenum, correct diagnosis
- Question for those of you who understand the finer points of o2 sensors
- Truck failed CA smog! They said it failed the EVAP test?
- throttle body
- Exhaust??
- help!!!!
- Torque Converter
- 1.7:1 Lifters for my 1992 dodge dakota
- Issues....92 dak likes to cut itself off
- cold air intake (pics?)
- Steerin Knuckle/Ball Joints
- Valve Spring Selection
- Dakota Rack and Pinion steering
- busted rear end
- Can someone tell me what this is ??
- Body Lift
- power programmer
- Universal joint questions
- trans swap help please
- Is this Crazy4x4RT?
- Ball joints
- 95 sport
- Bigger Tires?
- For anyone in NC looking for R/T wheels...
- ~~~~~~~~~~~~Late and Hard Shift Problem~~~~~~~~~~
- 1993 dakota for sale
- Camshaft
- 91 dakota... switching injection to carburation
- Weird clunk sound... I feel something is loose
- Murphy's law
- Code 32 on Non CA truck - EGR issues?
- Rear Shock Bolt
- Before and After
- Good News
- New guy / new truck
- 1990 Dakota hesitation/sputtering problems??????
- Ball joint issue
- big effin military tires :D
- wtb 92 dakota center console,
- slow 4 normal or not?
- New Tires and Wheels
- is my block the same?
- Fault Codes--more info please?
- Think she is finally road worthy
- 91 dakota fuel gauge problem
- need help
