View Full Version : 1st Gen Dakota Tech
- Dual exhaust question
- 1995 3.9L 5-speed 4wd 4x4 wont engage
- What is the leather splash shield called
- Getting ready for headers.. And got a surprise...
- 1st Gen Fuel Cut-Off Switch
- Rarest of the Rare for sale
- Relay panel suggestions
- Wrong driveshaft?
- Check Engine Code 27, '93 Dakota 4x4
- '92 with code 15 and 17
- Mouldings and window trim
- Broken timing cover - causes?
- Giving some serious thought to a front end swap on the vert build
- yargh no more Jeep back to a Dodge :O
- 93 dak, rough shifts,no power,
- '89 Tailgate won't open
- Shorty Headers
- First post here
- 94 3.9L EVAP canister
- 96 Dakota no power under load
- 96 dakota grinding
- 93 Dakota top dash pad pulling.
- '91 Has a Bad Cough
- Thanks to..................
- 88 dakota rim offset and back spacing recomendations
- 90 Column Shift linkage to Transmission
- EGR code
- Plug wire looms or trees
- '92 4x4 door emblems
- 93 dakota distributor wiring harness
- 96 dakota 3.9 4x2 auto A/C compressor kicking in and out
- How do I turn on my '95 Dodge Dakota's headlights?
- Proper Timing Advance
- Looking to upgrade to lsd
- 1993 Dakota LE 3.9 V6 auto - STEERING SHAFT
- Radiator question
- AX15 interchangeability with NV3500
- Air Conditioner not cold
- Transmission Stuck in 1/2nd
- clutch fork and throw out bearing extended with engine out?
- Charcoal Canister Help on Engine Swap
- Fender flares
- Trail master upper control arm bushings
- Vacuum hose mystery,
- '93 Dakota LE transfer case issues
- 1996 dodge Dakota v6 3.9L
- Radiator Swap problems....solution?
- Any AX-15 trans changes from 92-95 ?
- Rear Axle question - Noob
- Pdc box question(picture)
- Header interference....options?
- brand or serpentine belt
- difficulty of a 2.5L to 3.9L swap
- 91 dakota xfercase and engine issue
- Transfer case chain width
- phone camera - great for troubleshooting leak
- 3.9L performance upgrades??
- 1988 Dodge Dakota 3.9 V6 Bad Oil Leak
- MT 2500 Question
- Transfer case/front end very loud clunking
- 1992 Owner Manual
- distributor problem
- 88 3.9 stumble off idle
- efi to carb swap
- Towing Questions for a 1992 V8 4x4
- Does the np 2500 and Ax-15 have same bolt pattern ?
- fuel pump run with key on or engine cranking/running?
- 91 318 LA to 99 318 mag swap questions
- Manual Trans Compatibility
- Dodge dakota engine swap
- ABS & Brake warning lights, No Codes?
- Correct dust cover for swap combo
- Will a 97 jeep 2.5 drop into a 92 dakota?
- Chirping while driving, stops when I push in the clutch?
- New member with manual trans question
- La v8 318 to magnum 318 swap
- Transmission replacement advice
- 1991 Dakota v8 smog pump elimination
- 1995 Dakota 5.2 V8 which flexplate is in here?
- Stubborn screw
- power sterring pump swap ?
- New fuel lines
- 89 speedometer / odometer not working
- Gas mileage dropoff
- 1989 Dodge Dakota 2.5l won't start.
- three things i have learned about tps
- Crankshaft position sensor bolts.
- Improved headlights, early Gen1's
- Brake Proportioning Valve Rebuild Help
- No cat and passed emissions?
- MOPAR perfomrance PCM
- 1996 dakota, alternator issues
- ECU "learn" time
- Torque converter help on 360 swap
- Issues on switch to carbed engine Dakota
- Hard stumble off idle, 93 Dakota
- 360 swap
- Door mouldings
- New Fuel Pump and Fuel Filter still no fuel pressure
- Sometimes has no spark...
- 1994 Dakota - wipers not working.
- 1993 dodge dakota steering shaft help
- picked up a 231d transfer case
- OE Radio
- Weird issue
- Name that picture - Parts help
- irractic idle and stalls when stopping
- Spectre Dual Plenum Cold Air Intake on a 1993 Dodge Dakota?
- Stalling in Idle - 96 Dakota
- 16 inch tires
- Axle repair bearings
- vaccum shift problems
- My project truck... Help me save her from the crusher please!
- 24 Code??
- 96 dakota transmission mount issues
- '92 RWAL Hydraulic Valve Removal Help Please
- 46RH behind a 3.9L
- Transfer case and Manual tranny fluid?
- Don't Know if you guys have seen this...
- Removing Differential Locking Pin Nut
- in and out of gear too much
- 93 - 3.9L to 5.9L Build Thread
- Engine Hesitating and Stuttering
- '94 ASD problem
- 88 v6 trouble starting in warm weather
- Transfer case question
- Substitute Rims
- Need some help guys
- OBDII Engine in an OBDII Dak
- 1993 4x4 club 5.2L needing a auto tranny
- V8 swap info - 96 5.2L into 93 3.9L
- Ball Joints
- 96 Dakota and its fussy 42RE
- Lowering my 88' suggestion for rim of set and tire size
- New 9.25 rear end swap problems
- 1988 Dakota no start!!!
- '93 needs rear main seal
- Lowering and v8swap questions
- Instrument cluster barely working
- 93 extended cab 5.2 4x4 trans will it fit a 95 slt
- 1996 Dakota 3.9 4x4 Durability?
- Wiring diagram tachometer for 1994 Dodge Dakota
- WHITE SMOKE on CAT beak in.????
- Importance of exhaust hnager???
- 89 dakota fuel system
- NV3500 Junkyard pull - missing anything?
- Motor Mount options on magnum swap
- 96 dodge Dakota transfer case
- wheels and tires
- 93 Dakota Transfer Case Replacement
- Cheap way to test exhaust mani for cracks?
- 46rh to NV3500
- Transmission Help - 42rh
- Constantly High Oil Pressure Gauge
- Water in the oil
- Abs/parking brake light on
- RPM gauge reads low 94 5.2l
- 94 5.2l Truck runs cold....i think
- 360 Magnum auto trans advice
- 1993 Dakota Electrical Issue
- 92 Dakota Running Hot 318
- 50 1991 Dakota No SDegrees outside, it go's into ASD? Please HELP!
- 1988 Dakota 4wd lower control arm bushing
- Cv axle binding
- 1989 Dodge Dakota
- Upgrade to intermittent wipers
- Coolant leak!!?
- No first gear - 3.9 Auto
- Removing Bed
- Cooling issues
- Removing viscous clutch from water pump
- Tourque Converter problems!
- 91 Dakota 5.2L Won't Start After Water Pump Changeout
- Control Arm Bolts???
- Truck will want to die P- D/R. N-D/R
- 95 Dakota 2.5 carb conversion
- Help with my headlights
- Headlight issues
- 91 Dak strange fuel pump problem
- 88 been sitting for a while
- Need help identifiying bracket from 89/90 Dakota 3.9 Auto ?
- 2nd Gen hubs?
- Seat covers
- Loose windshield wiper, 1993 Dakota
- 95 3.9 std transmission need some help if you have one please
- rear end
- Back half kit
- 93 Motor in 88 Dakota
- 87 Dakota 4g Swap
- Lifting My 4x4?
- Manual steering rack conversion
- front driveline
- Inconsistent oil pressure
- Contol arm bushings...again
- Dakota 92 3.9L 2X2 Lift Options Plz
- Headlight Upgrades
- Help -Engine installation
- What's leaking?
- New Guy just did a body lift need some help
- On-line fuel filter
- RWABS Causing New Wheel Cylinder Blowout?
- 1990 transmission help
- New here, new 1st Gen owner lookibg for help
- 32 code?
- LA accessories on a magnum engine
- Camshaft
- 3.9L info
- A518 - How much power will this thing tolerate?
- Help
- Car-Part search help
- Auto Tran vs. Manual
- 93 Dakota V6 Defroster Only
- vague electrical problems
- Rear Brake Drag
- Little update. Leveling kit, 31s & more
- '93 electrical nightmare.
- question about a part number
- my truck sounds and feels like a kitten under a wool blanket
- '94 - ASD relay splice
- bucket seats
- 1991 dakota manual transmission or clutch noise
- 1993 Dakota 2wd 3.9 engine code27. PLEEASE HELP!!
- ASD Relay removed, but has voltage on #87 when "on"?
- 5 & 6 Lug Swaps
- Sqeaking tensioner pulley
- Replacing heater core
- Desparate for Help. Car does absolutely nothing when i turn the key.
- 88 Dakota Brake problems
- Dealing with the inevitable rust
- 92 dakota lift
- Technical Question Related to EGR Manifold and Keg Mod
- 1992 Dakota Stalls Runs Rough and will not Idle
- Fuel pump check valve?
- Gauge help 1990 3.9 Dakota
- How to price my 89 convertible
- 31's tires
- Vacuum Hose Spaghetti
- Broke something, need help
- Plenum gasket help needed fast
- stereo replacement
- 1995 dakota engine swap
- 91 Dakota - Overdrive turns itself off for a few days, then on again for a few days.
- pillar gauge pod
- Need exhaust advice
- Need help asap please and thank you!
- Dodge Dakota - Won't stay running
- Upper control arm mount
- 1993 dakota headlights
- intense fuel smell
- Dually rear end swap?
