PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. engine runs hot only when working it....
  2. He may have the toughest Dodge...
  3. Possible to use lift plate with 318?
  4. Rear Diff
  5. Prepped NV4500HD for swap
  6. "Why are you fixing that old truck?"
  7. Who's working on AC?
  8. request for help with an 89 3.9 "miss"
  9. Need some help with ASD Relay
  10. Headlights/Tail lights
  11. 1987 Dodge Dakota 3.9L dip stick
  12. 1996 dakota AX-15 tranny
  13. 1996 Dakota A500
  14. tires
  15. Fuel pressure in 97 318 Dakota?
  16. cooling woes
  17. Check it out!!! 3.9 headers cheap!
  18. 92 Dakota-lifter
  19. tachometer trouble
  20. Power Brake Booster Question
  21. v6 throttle bodies and v8
  22. shock mounts for rear
  23. Stroker
  24. Differences between 318 magnum block over the years?
  25. Truck quits running on its own
  26. Altinator
  27. Type of oil used and recomended
  28. For any of you who don't spend time in offtopic, make this your start...
  29. camping
  30. Poll: What color to paint my truck?!?!
  31. TOTM Voting
  32. 318 engine from a Ram being sold in Chicagoland
  33. 3.9l oil drain bolt torque?
  34. 318 to 360 questions
  35. make it loud
  36. Stereo issues
  37. Trail ride (minor battle damage)
  38. FS: 5.9L K&N intake
  39. Transmission mount replacement
  40. 95 Dakota still not starting
  41. 3.9L Mods
  42. yo crank sensor mod!!!
  43. New radiator / cooling system flush
  44. Throw out bearing replacement
  45. Diesel swap into a 94 Dakota.
  46. What to expect with second gen computer vs. first gen?
  47. Anyone ever remove spark plug shieldS?
  48. My "new" 92 C/C 4x4
  49. R.i.p. V6
  50. JBA headers for 3.9
  51. 91 2.5 dakota no spark, please look
  52. Weather Stripping
  53. Turns over won't start
  54. Looking for rear wheel hub assembly
  55. Manual ECM
  56. Fusible Link Problem
  57. 3.9L Mag Help?
  58. WTB 3.9L magnum harness and ECM
  59. Building a 390 stroker
  60. A535/ np2500
  61. 318engine, tranny, & Tcase
  62. I want honest opinons...
  63. 1990 2.5 I-4 engine trouble
  64. Code 12 and 21 help
  65. Viabrations
  66. Could really use you help!
  67. got some codes from my truck....
  68. Engine start up questions
  69. mopar performance comuter
  70. Fuel pump going out?
  71. Found Engine and tranny what do ya think?
  72. Need a photoshop done guys....
  73. Engine & Tranny swap questions
  74. Truck died and won't start back...
  75. calling all 2.5 gurus
  76. just a dumbass question...!!!
  77. If you had time and had your motor out...
  78. Best way to clean fuel injectors?
  79. Divorced transfer case
  80. My Paint Job
  81. Dead radio in '96 Dakota Sport.
  82. Hughes plenum fix
  83. WTB A good 318 with a good Transmission
  84. Converting NV3500 from 2WD to 4WD
  85. 1995 dodge dakota engine problems
  86. Dodge Dakota Engine Problems
  87. Brake Controller on 1996?
  88. Noises & New to Dodge!!!
  89. Fuse diagram
  90. Cruise control
  91. 4x4 issues
  92. Help!!
  93. Show me some lift 2wd's PLEASE!!
  94. DFW Dakotas MAY MEET!
  95. Replacing head gasket, photo
  96. wont start
  97. transmission question
  98. suspension...
  99. Head Bolts?
  100. Pea Sized Sludge
  101. Junkyard Disaster
  102. Electric water pump conversion
  103. 93 2.5 4cyl to 92 5.2 v8 magnum
  104. Help??? IAC Valve
  105. signal lamps
  106. Got my 318 with everything. Christmas came early...
  107. 8.25" to 9.25" swap
  108. Front end creaking
  109. wacked guages
  110. Random Loss of Power?!
  111. Need mint original dakota for photo shoot near jersey
  112. Motor mounts in 2nd Gen vs. 1st Gen
  113. 318 strocker kit info needed
  114. Need help nameing a gasket
  115. 89 Dakota project
  116. New Gen1 Dak owner needing a little assistance
  117. Map sensor voltage too low... ???
  118. 6x9" Side View Mirror Issue
  119. NV3500 2WD trans to 4WD?
  120. CL fuel rails for V8 Magnum
  121. Weird question about slowing down.
  122. Ac system problems, who has some.
  123. 1995 Dodge Dakato V6
  124. Big problems, stuck 400 miles from home
  125. Autolite 3923 Gap?
  126. mopar computer
  127. A engine or B engine?
  128. 3.9L performance parts
  129. intake
  130. Fill plug on trans stuck
  131. 1987 4x4 engine mounts?
  132. Electric fans
  133. Coolant temp. sensor causing erratic idle?
  134. More pics
  135. useable rims for dakota?
  136. What are you Thoughts??
  137. Changing an oil pump on a 4x4
  138. mag heads on 89 3.9
  139. IGNITION is pissing me off!!!!!
  140. Front diff. Help
  141. 3.9 exhaust systems... what u running?
  142. Can someone with a 5 speed please tel me...
  143. Carb help
  144. v-6 exhaust??
  145. Bore a 318
  146. Thoughts on tranny
  147. Full length headers
  148. Will It Fit ???
  149. A few questions
  150. 87 Dakota want to swap in a LA 318
  151. Low Idle 94 Dodge Dakota Sport
  152. New truck
  153. HELP what engine should i get?
  154. leak!!!
  155. 3.9L to 5.2L mag swap
  156. Coolant temp / IAT sensor
  157. Zimmer Dakota?
  158. 1995 dakota 4x4 to 2x4 conversion
  159. dodge 318 ?'s
  160. TBI vs Carburated???
  161. trans gear ratio
  162. Parking Brake Issues
  163. Accessing radio
  164. solid axel swap
  165. Anyone with buckets?
  166. My official 408 stroker build thread...
  167. '94 radio, tape player, and radio work off and on
  168. ggrrr.. still slipping in reverse
  169. Too much in tranfercase
  170. Would like some input...
  171. front diff?
  172. Straight Hood
  173. ball joints
  174. miles per gallon
  175. Intake Part?
  176. hood trubble
  177. Emergency please help quick call or text or something!!
  178. Hooking up a Tachometer
  179. 1987 Dakota 2.2L wire diagram PLEASE HELP!
  180. Grill guard
  181. Tearing into my 318... gonna need advice!!
  182. Explanation of the notorious plenum gasket problem...
  183. Oil burning
  184. Power Windows
  185. well I went and did it.
  186. code 3294
  187. Dies at stops
  188. Question about toppers
  189. fan clutch needs replacing
  190. Seal between inner joint housing and diff
  191. EGR questions
  192. I've searched but i need some answers PLEASE!
  193. Seals and bearings during clutch replacement
  194. what should i get at the junkyard?
  195. Cause of miss over 55mph?
  196. Got a brush guard to modify
  197. Glaspak anyone?
  198. '95 dakota 2.5L
  199. new super bright headlight bulbs & dakota
  200. what fuel tank do i have?
  201. intake gasket question
  202. Rear end pain in the butt!
  203. 94 dodge dakota wont start
  204. IFS vs Solid Axle (swap)? what to do?
  205. intake
  206. 92 Dakota 3.9L Dipstick
  207. Body lift kits becoming less available
  208. Transfer Case Swap??
  209. My Ideas
  210. 96 dakota trans
  211. 6x9 speakers
  212. pushrod/valve clearance
  213. Plans for military paint
  214. tranny on 90 v6
  215. 93 Dak - Water on the floor!
  216. race blocks on clearance
  217. Looked at the Lucas Products today
  218. Looking to wire up some lights
  219. Axle fluid change for '94 2x4 Dakota
  220. What to buy?
  221. question on throttle body
  222. 94 Dakota Coolant Issue
  223. Jolting and Rumbling
  224. scary problem
  225. Tow truck push bar?
  226. Looking to Buy 1995 Dodge Dakota
  227. Euro lights
  228. 3.9 tb upgades
  229. 1992 3.9L Auto won't drive or run right
  230. useful information on rims
  231. what jack to use
  232. 1994 Dakota Projector/Angel headlamps?
  233. oil pressure and idle question
  234. I am really hurting for some help :(
  235. Pvc
  236. please help! will a short bed drive tran work with a ext cab
  237. Weird idling problem
  238. climate control question
  239. no reverse:(
  240. polyurethane bushing kit
  241. how to change front brakes on 91 dakota 4x4 5.2l
  242. what are these worth?
  243. Dead Engine
  244. lowering
  245. no radio or turn signals
  246. Installing Stereo, no original
  247. Butterfly valve in exaust manifold?
  248. 94 Dakota - Heater Motor Resistor
  249. just bought a 94 markIII
  250. Weird clicking
