View Full Version : 1st Gen Dakota Tech
- lil red dakota
- 1996 dodge dakota sport door will not open
- 87 Dakota TopEnd Rebuild.. YAY :/
- Is there a floor shifter?
- gearing
- 87 Dakota engine change
- transmission kicks out of gear when warmed up
- 87 Dakota Holly Carbs
- o/d in & out
- Starting issue
- 1991 dodge dakota project....
- Bypassing fuel relays
- electrical problem!
- Is it this worth the effort
- Band adjustment specs '95 Dakota
- Please help!hi
- Code 37
- Accessory bracketry
- 5.2L air cleaner size?
- forum newbie
- De-body lifting
- What driveshafts can I use?
- Need some Advice.
- Leaf Kit
- Need help!
- NEED help with my 2 dakotas - 94/95
- 92 dakota start/idle prob
- Shifting Issue while hot
- Another front rotor question
- Fuel Lines at Tank
- Sometimes starts, sometimes not so much...
- Alright, I give up searching!!!
- tune up problem
- Interchangable parts???
- gas pedal , throttle problem or nromal?
- how do i know if i have a differential?
- Bent Valve?
- Shovel mount and Plastic "Skid" plate off jeep
- Question about ebay torsion keys
- Brake system help
- Dakota with a Vortec
- George's Fix It up Thread.
- Temp sensors
- Newer parts that fits my 1990 dakota?
- remove backseat padding
- Wiper linkage problem
- looking for accessory lights
- Front Brake Issue
- Milage comparison! V6 or V8
- check this site out
- Electrical issues coming in waves all of a sudden
- jack of a suspension 3 inch
- 2"/4" drop
- adding rear sway bar to Gen 1
- need some help
- Help! Bolt threads in Steering Knuckle Stripped
- camber issue?
- my 4x4 dakota
- Inner Tie Rod
- help with down shift problems
- ignition coil
- Wont up shift! Need advice please!
- Selling my front bumper
- Just ordered lift for my Dak!
- weird 4x4 "rubbing" noise
- Fuel Pump
- 318 with 7.25 rear
- VIN G and VIN K 2.5 L engines
- Vibration Rearend?
- what suspension...advice
- OBD 1 and engine leans out then dies.
- lsd locker open posi. whats your poison.
- 96 Dakota fuel pump pinout?
- Engine shakes
- 94 Dakota 318 Magnum Issue Help
- Need help despiratly and quickly please!
- need some help again.....
- hesitation at low throttle
- Trailer towing question
- crankshaft position sensor bolts
- Wipers stopped working 94 Dakota
- A500 Shifter
- Best all around tires for these trucks.....
- Posi??? Where!!!
- Pro Comp ES9000 shocks
- U-bolts and blocks
- 94 2.5l lost compression
- Can't Find
- 94 3.9 EGR removal
- v6 to v8 torsin bar help
- 89 dakota axle help
- Battery cables
- Transfer Case Question
- 1993 Dodge Dakota Transfer Case Swap
- Need help with dakota blower problem
- It's been a while. Looking for advice.
- Insert money every few weeks...
- Dash lights fuse keeps blowing
- Took the truck to the shop
- New Lights
- Steering wheel adapter for a 92.
- Got some problems and need help
- 95 dodge dakota wiper linkage please help!!
- T-case question
- Have some problems that need remedies
- Steering column replacement question
- Fire just not to the Starter
- question about 96 dak
- Tires fitting wheels/front torsion bar lift
- Speedometer not working, bad gas milage 95 2.5 liter
- 92 3.9 fan clutch
- classifies??
- 518 Trans Pan
- Will this work?
- Electrical Problem
- Allignment
- 93 3.6 Dakota Starting Issue
- Ball Joint ?
- Brake help please...
- No Start
- Question about Ax15 Trans
- old Dakota parts lists 86-96
- Engines dakota 2.5 L
- aftermarket speakers
- found the problem with my fuel gauge...
- Hid headlights
- no oil pressure on hills
- 95 Dakota Sport suddenly refuses to start
- Transmission/Transfer case Preparation
- 93 dodge dakota steerting
- Beefing up my '96 5.2?
- need help with 89 dakota
- 1987 Dakota
- replace 93 oil pump?
- abs light and park brake light
- quick question
- swapping motors
- 93 dodge dakota
- why is my oil temp so high
- Tire advice plz
- Suspention fought me
- Moving the steering column
- New Dakota owner.
- 31x10.5x15 on stock wheels with no lift
- rack/pinion replacement problem
- Transmission OD solenoid circuit/ TCC replacement
- Fuel pump buying questions
- no power to radio
- Lift and engine Advice
- Locating new torsion bar
- Bed Rail Caps
- Anyone know This Transmission Video Site?
- Tonneau Cover and bed differences...
- o/d mpg question for 91 318
- 94 dakota wont start
- Changing Transmission and Transfer case
- Push bar question...
- Rear drums
- new 1st gen Dakota owner :D
- front end grind
- Oil capacity.
- Transmission front seal
- Gas filler tube rubber seal
- ok guys have some questions, lets talk gear reduction
- Getting ready to replace timing chain - any advice?
- Transmission Grinding
- Need Trans Mount Crossmember
- What is this, and why is it connected to my throttle body?
- Gas in Cylinder
- Dana 44 Solid Axle Swap. Tons of pics. Discussion thread
- Dana 44 Solid Axle Swap. Tons of pics. Build thread
- 1993 Dakota fuse box diagram
- 1996 Dakota 318 won't stay running?
- Fair Deal?
- wont fire
- timing chain on a 3.9L
- Lifts: show me whatcha got
- egr leak
- Comin back to a Dakota....:-)
- Custom tow hooks
- 1989 Dakota LONGBED base model to Sport but keep Long bed?
- 1993 Dakota no power to fuel pump
- 93 dodge dakota
- Dead spot on acceleration
- Extended cab subwoofer placement?
- info on a few mods
- gas tank size?
- Truck dies randomly on the road
- 2wd lift SOA
- Short?
- Club window
- Benefits on an electric fan?
- left bank lean 96 dakota 3.9 running lean
- 4wd not working
- fuel pump assembley vent hose question
- finally got it
- Iac
- Light "metal-on-metal" sound almost all the time.
- Stock speaker size is 5x7, but I should be able to fit 6x9's right?
- 93 Dakota Motor HOT - Heater Blows ICE
- Painting brush guard
- Quick question about my new fuel pump
- 94 Dak 3.9 with A518 Trans
- 9.25 rear end?
- Steering wheel of doom (Steering Wheel/Rack Issue)
- Brake pettal is getting silly on me
- A few problems
- 3.9l V6 Increasing MPG???
- Gas Gauge sending unit
- no reverse lights
- Was at the salvage yard yesterday
- its beeen a whiiiiile....
- 1995 Dakota - Headlights on, Buzzer on, Gauges Gie
- Tail pipe exit before rear wheel
- Weird feeling under hard acceleration...Kind of perplexing
- Crankshaft Pulley
- Clear turn signal lights
- Torsion Key lift problems
- can any1 help im new at this
- 95 dakota 5.2 firing troubles please helpp!!
- 1989 Sport Convertible questions - decals and body lift
- Weak fuel pump?
- Engine Swap Questions For a Newbie
- 31's
- Steering rack mount bushings
- Tires?
- Got it running, but rough
- 89 dakota torsin key help
- Hard starting/stalling-not the splice!!
- Can't get transmission cooler lines disconnected
- Posi/Lockers question
- 93 Dakota 318 Auto 4x4 No Overdrive
- Rust on 96 Dakota
- Modifications for 1996 First Gen Dakota
- Need some input on my exhaust
- Noise with 5.9L engines?
- towing/trailer/limits
- 94-95 transfercase
- NV231 Transfer Case
- Putting back together
- Exhaust & Cat Issues
- Wind/Rain Coming Through Door Seal on 1995 Dakota
- what to fix? code 34
- Engine Interchange Question?
- intake plenum repair
- daggum bird under my 93!!!
- O2 codes P1032 and 1035
- What is a good Spark Plug for 94' Dakota w/ a 318?
- Misfire 5 and 6 cylinder
- Loss of acceleration power, shaking, and dies
