PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Time to get some long due work done!
  2. Headlight Clean up
  3. Engine help
  4. 1995 Dakota Mark III oil pan removal help
  5. instrument panel light bulbs
  6. just bought a 1990 dodge dakota 4x4
  7. got me some goodies
  8. Need help finding this part
  9. Body lift question
  10. EGR system failure
  11. differential help needed
  12. Lift Question
  13. Shocking question
  14. Custom interior part 1
  15. Cruise control testing
  16. Won't start unless Check engine light is on.
  17. Question about my Kota!
  18. Anyone else have a...
  19. Join the TX Truck Club!
  20. header questions
  21. Towing question
  22. Wheel Alignment....
  23. Shifter Question. Need Help!!
  24. paint for rim
  25. Going from 6 bolt to 5 bolt, not spacers, hub swap?
  26. 88 Dakota shuts down after 10 min. driving
  27. ow long would you say?
  28. need a ? answered
  29. HD Half Ton Suspension
  30. I know its a 2nd gen but.....
  31. inner fender rubber
  32. 3.9 to 5.2
  33. Coolant leak?
  34. '92 Dakota won't start sometimes
  35. tire time
  36. not your typical headlight issue.
  37. Removing sway bar??
  38. some info i have put together from the mark III
  39. Radio Issue
  40. dash replacement
  41. out with the old, in with the new (subs/amp)
  42. Clutch acting up
  43. Differential Question
  44. Underdrive pulleys question
  45. Transpak - Auto Trans Shift Kit
  46. i think i found me some new wheels
  47. DIY LED gauge conversion for less than $20! Part 1
  48. 88 dakota 2wd transplant v6 to v8
  49. question on throttle body
  50. question about lift kit
  51. trans issues
  52. To splice or not to splice
  53. Odometer stoped working?
  54. looking for remote start
  55. 93 dakota rear end questions ?
  56. headlight-on reminder NOT working
  57. Oil Pump?
  58. Sorta Hard Shifting, Need some Input
  59. Shelby Electric Fans
  60. Clutch disengagment
  61. replacing motor mounts?
  62. Need Opinions...
  63. Please HELP!!
  64. the list of Q's about my 93 dakota
  65. NV3500 diversity
  66. Single Slider VS Dual Slider Rear Window?
  67. Remove "cushions"????
  68. 1990-1991 Dodge Dakota Not Shifting
  69. Any Florida residents?
  70. New Used Motor Dead
  71. Rear axle?!?!?!
  72. What do you guys got for performance?
  73. What's different on LE trim?
  74. 3.9 to 5.9 swap
  75. Winches
  76. Mopar Action Magizine#2
  77. trans help
  78. Engine swap need info
  79. Shop manual
  80. 93 Dakota jerks
  81. click no start sometimes
  82. got a annoying buzin sound
  83. anyone know who's truck this is?
  84. Cowl hood
  85. Tightening the 6x9" mirrors...
  86. electrical issue
  87. Things that make ya go ****
  88. Strange Problem.. please help
  89. rusty shocks
  90. fan clutch - electric fan
  91. 2nd or 3rd gen nerf bars on a 1st gen
  92. aceleration hesitation! 94 Dakota V-6 3.9L
  93. NV3500 question
  94. What the hell is it?!
  95. Replacing front CV axle
  96. Good buy dakota 1993 with 150 000miles?
  97. in need of a little help
  98. 93 3.9l mods
  99. spit, sputter, vroommmm
  100. just outta curiosity
  101. Can I get more "Juice?" Electrical help...
  102. Mike's Dakota
  103. 87 2.2 Carb Dakota...
  104. 94 Dakota won't idle cold
  105. help..manual transmision
  106. Chrome Smoothies?
  107. boredom+spare parts=
  108. Some Questions!
  109. weird problem and upper rad hose.
  110. Diagnotic Do or do NOT!
  111. Fuel Problem
  112. truck update
  113. Removing the A/C condenser?
  114. Tire/Wheel Opinions
  115. Unrelated questions
  116. 6-bolt to 5-bolt
  117. TBI or MPI???
  118. New stuff
  119. '92 electrical problem or low oil pressure?
  120. almost outta daylight need answer quick lolz....!!!!
  121. tranny rebuild kit for 91 dakota
  122. an update on my markIII
  123. starter issues
  124. Cruise control and manual trans
  125. New here, Need some help too
  126. Easiest way to pull engine
  127. 93' steering shaft/rod?
  128. 89 Dakota rear differential abs sensor
  129. Headlights out.....again...
  130. total performance 2" lift
  131. Transmission questions
  132. 93 V6 Fuel pump prob
  133. Fuel Issue
  134. Need help?
  135. Chrome Valve Covers
  136. leaf springs
  137. 95 Dak 5.2 ltr - now power at fuel pump
  138. 94 dakota
  139. brake job questions
  140. Emergency brake light on
  141. 1989 Dakota
  142. Possible to remove Gen 1 - 3.9 and auto tranny as 1 piece ?
  143. Whats on your list
  144. For those like me who are curious
  145. woes of the dakota
  146. What is needed for a 3.9V6 to 318 Swapp
  147. Replaced the stock horn
  148. Factory Amp?
  149. will it bolt up?
  150. 1990 Dakota - Stalls out at 40 mph - trouble starting
  151. another rough idle/stall prob
  152. Ecm...
  153. help
  154. Brakes-92-Dodge Dakota
  155. Fan speeds up
  156. 96 dakota decals
  157. tranny
  158. 89 3.9L will not start when hot
  159. temperature gauge and fuel guage not working
  160. Eletric Fan?
  161. New guy with a problem
  162. Setting radio presets
  163. mystery code...????
  164. Engine Swap or replacement
  165. Dual Snorkel Air Cleaner
  166. 1995 Dakota Sport problem!
  167. Dodge Dakota 1996 Evaporater Replacement
  168. 222,000 miles on 3.9
  169. Fuel gauge not working after new pump
  170. LA 318's
  171. Need Help
  172. OBD I to OBD II conversion...
  173. Smog Pump
  174. Renting out my tools :)
  175. how to remove shackle hanger?
  176. Anyone running a 408 as daily driver?
  177. Replacing 3.9 oil pan... Help!
  178. 5.2 dakota camshaft ?'s
  179. radio replacement
  180. loose tailgate
  181. power speed chip
  182. How bad is it?
  183. trouble starting
  184. I hate...
  185. wont run under 1000 rpms?
  186. pics
  187. lift ideas ???
  188. here some pics of my new dak
  189. Backfires when downshifting and no gas
  190. I got a 2001 Quad Cab, so torn
  191. wheels
  192. engine starts then shuts off
  193. New Gen 1 Dakota Ground Effects
  194. Dreaming of my truck while in Iraq
  195. HELP! 318 engine noise/problem
  196. Muddin Q!
  197. Power to manual steering
  198. 1987 dakota 2.2 OHC timing adjustment
  199. 95 dakota tie downs
  200. rpm ?'s
  201. Yes another Mopar CPU thread. Help Pls!
  202. Durango rims same as dakota?
  203. 18 inch wheels for a '96
  204. no spark
  205. 94 dakota
  206. Urgent please help me!!!
  207. head lamp lense restorer
  208. Ball Joint Weld
  209. 1990 dodge dakota fuel pump issues
  210. odd missing
  211. a518 valve body
  212. please help!
  213. Part or fix?
  214. '91 dakota tranny question...
  215. 93 dakota leaking tranny fluid
  216. 3.9 difference between 94 and 97
  217. Body Kits and Ground Effects
  218. Fuel Pump Problems
  219. 93 Dakota Refrigerant Refill?
  220. Making your own brake lines...
  221. Headlights out
  222. Good starter not working!
  223. Weird Squeaking Sound
  224. Soldier needs advice
  225. 89 vacuum questions any missed tweaks or tsbs
  226. valve cover torque?
  227. '95 SLT 318 turns over, won't start.
  228. Carburated 1987 3.9 V6 #2
  229. cruise control won't shut off
  230. Oil Pressure
  231. How to identify engine?
  232. you gotta be kidding me ...
  233. External clutch Slave Cylinder
  234. urgent!!!!!
  235. 1996 dodge dakota 5.2l 318 4x4
  236. EGR valve removal
  237. New and full of questions
  238. 92-96 grille
  239. Pinion Bearing
  240. radiators
  241. Wiring Help
  242. Dual shocks!
  243. 1989 Hose Diagram (6V 3.9L)
  244. bed size and wheel base
  245. Clutch fan dissassembly
  246. Looking for larger wiring harness for new spark plug wires
  247. Replacement oil pan
  248. Installing front crankshaft oil seal question
  249. Rear end making a noise
  250. Wheel Question
