PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59
  1. 94 Dak needs mid-grade fuel?
  2. 95 Dakota electrical/tach problems
  3. Need help for 1992 Dodge Dakota
  4. 4 cylinder to 5.2 engine swap
  5. Starting Trouble: Ignition issue
  6. 1992 dakota charging problem,
  7. adding transfer case to 2wd
  8. Pinion nut removal. HELP!
  9. NEW to Dodge: Thinking about buying a Dakota
  10. o2 sensor eliminator?
  11. convert 87 to tb
  12. aftermarket posi
  13. Front Wheels
  14. engine running a little hot
  15. Back...this time with a truck
  16. Electric fan conversion
  17. horrible shudder/vibration
  18. need help 92 dakota, codes
  19. Starter issues
  20. tie rod ends/ball joints
  21. Engine Cleaning
  22. need a transfercase, 94 dakota
  23. Does anyone know where to get a phantom Grill fo 87 Dakota
  24. What is SE PACKAGE model under Dodge Dakota
  25. 1st gen. frames
  26. Help
  27. Battery & distubuter cables
  28. Rims, Tires
  29. gen 1 and gen 2 ifs
  30. 95 dak 3.9
  31. well shes gone...
  32. Does anyone have an answer?
  33. sometimes won't start
  34. 4 years in the making 89 dak
  35. No Go
  36. blower motor loaction
  37. oil leak
  38. Newbie here with 87 Dakota
  39. rear end options
  40. transmission mount
  41. Ball joint cover situation. 1992 dakota 5.2 4x4
  42. power programmer?
  43. lug pattern
  44. Tail Lights Issue
  45. Painting the dak (lots o' pics)
  46. **FAQ2 ------Lift kits, Performance, Engine Swaps, Modiftcation Ideas**
  47. front diff bearing replacement
  48. neutral start safety switch
  49. Rod knocking?
  50. radiator done??
  51. 1995 Dodge Dakota dies
  52. Long Posts, It DOES WORK!!
  53. largest tires that fit on a stock 4x4
  54. torsion bar question
  55. stock y pipe
  56. 1996 Dodge Dakota 5.2l A/T 2wd
  57. Transmission Problem on 93 Dakota
  58. 95 Dakota OD and AC problems
  59. Smell of Gas
  60. O2 sensor
  61. suspension liftq
  62. Front End Lift.
  63. no back brakes
  64. RPM/Speedometer/Fuel Gauges gone crazy?
  65. temp guage question
  66. 3.9L to 2.5L engine swap
  67. Can't get the trans pan off
  68. 91 3.9L swap to a 360?
  69. Trans. question
  70. Gutting the Catalytic Converter
  71. will headlights from and 88 fit a 91
  72. flowmaster muffler installed backwards?
  73. 89 dakota rear end needed
  74. Clear corners
  75. 89 dakota
  76. Tranny Swaps
  77. Dirty rear end
  78. fuel gauge fix?
  79. steering stabilizer
  80. 90 dakota 440 install ??s
  81. Front diff problem. correction BIG PROBLEM
  82. hockey puck suspension
  83. brake light issue (never seen b4)
  84. Truck won't start in park
  85. Tranny Problem - 96 2wd
  86. Ground Strap on 96 Dakota firewall w/3.9
  87. 89 dakota drive shaft
  88. Front bumper
  89. 1996 headlight switch "H" wire
  90. Quarter mile times?
  91. IAt adjuster mod and crank sensor mod
  92. 87 distributor
  93. For Sale 96 extended cab
  94. Fuel filter
  95. Check out this video!
  96. 89 2WD Dak odd problem
  97. Diesel 1st Gen
  98. ac line interchange?
  99. rebuilding the A500?
  100. 1st gen solid axle
  101. oil pressure sending unit
  102. dakota 5.2 overheating
  103. stalling in water
  104. 1988 Dakota 4x4, no electric to coil, etc.
  105. transmission noise: slight,irregular ratcheting
  106. 92 dak 3 spoke horn pad or strg whl
  107. tranny slipping
  108. gas lines
  109. wiring a roadgear radio
  110. Wiper Bushing Help
  111. Which fan to choose...
  112. Lowering my 4x4
  113. 93 Dakota V8 Tranny Problems
  114. 1987 Engine Swap Compatability
  115. does not start right away
  116. long tube headers
  117. h i d headlights
  118. Headers
  119. Poor idle then stall
  120. question with paint
  121. Looking for a transfer case
  122. Random Not Starting.... Help Please....
  123. Assistance needed or just advice needed yet again
  124. 91 Dakota Manual Transmission
  125. Need Help on Engine Swap
  126. power locks
  127. '94 dakota codes
  128. 318 oil pressure
  129. abs
  130. Air Conditioner on 93 Dakota V8
  131. 1993 Dodge Dakota. 4X4, 318 5.2L
  132. Dakota Guys
  133. lowering my dakota
  134. 94 Dodge Dak. 4X4, 318 5.2L
  135. Need help, sick of woodgrain dash
  136. for sale
  137. Check Engine light
  138. 1992 Dakota "what model?"
  139. odd engine "tick"?
  140. Electrical probs, Head, tail and brake lights
  141. burns oil at hi-speeds
  142. need ta know
  143. question about supercharger
  144. my 1995 dakota keeps leaking all the R34a out
  145. Pressure Release Valve/ Plug + Grommet
  146. How much is it worth?
  147. No fuel problem
  148. 94 Dakota, rough idle...stall
  149. moog problem solver balljoints?
  150. 5.2 heads
  151. motor for my 99 ram...
  152. Front engine Seal
  153. Won't start
  154. Brake pedal all of the sudden can be pushed to the floor...
  155. testing horn and clockspring on a 1996 dakota
  156. Are the 1st gen Dakotas any better than the newer Chrysler products?
  157. Anyone else have low oil pressure?
  158. Need parts advice, and tools
  159. Transmission removal tips/tricks
  160. Problem with headlights
  161. question about cats...
  162. fuel tank
  163. How can i enhance the sound of my thrush Glass Packed
  164. Sputtering
  165. Service manuals?
  166. Just bought a 92 Dakota V8 - has some issues
  167. new the form with a tired dakota
  168. Speedo quit working...common problem?
  169. My Dakota has a sticker that says charge ac on higher pressure side??
  170. suspension
  171. trip odometer stop working
  172. better mpg and horsepower......
  173. door handle
  174. hay guys need ta know how to add better gas milage and add horsepower....!!!!!!
  175. Need 1994 Door
  176. speed signal
  177. Leather interior for sale
  178. Seat Hinges
  179. July TOTM
  180. alternator ?
  181. question with amp
  182. Dakota runnin on water?
  183. Is there supposed to be one?
  184. turns but no fire!!
  185. stalling issue w/ codes 11 and 12
  186. Mud FLaps
  187. Aftermarket Ammeter
  188. 92 3.9 Dak dieseling?
  189. ABS and Brake light on
  190. Dodge Dakota
  191. Tell me wat ya'll think
  192. 318 swap advise on a 91 dakota
  193. A/C problem
  194. Timing issue
  195. whos hurtin for the gas prices
  196. update
  197. F*** not sure if i messed up or not..
  198. Low Oil Pressure - Engine Swap?a
  199. Durango Rims on a 1st Gen
  200. question about torsion bars
  201. read a bunch of thread but couldnt find what i wanted...
  202. 95 Dakota
  203. cant wrap my head around this tire thing..
  204. 92 4x4 lower ball joint help
  205. how to put in a regular carb need help
  206. Rear spring Q
  207. Time for some pics! MUD
  208. aftermarket antena
  209. '88 Won't start - ideas, please!Hi all:
  210. AIC or distributor?
  211. belltech
  212. Air cleaner for sale
  213. crank pos. sensor question
  214. Fires but wont run
  215. Dakota of the month VOTE!
  216. Questions about 1st gen Dak...
  217. got my flatbed done finally
  218. Clear coat peeling
  219. Differential oil
  220. Dak newb here!
  221. trannny question
  222. anyone with a sunroof like mine?
  223. OE Speedometer
  224. Help! Weird electrical problems
  225. new here, tranny questions
  226. driving along and truck just died HELP!
  227. rear main seal question
  228. 1989 3.9 to 2000 3.9?
  229. Dak of the month nom's are open!
  230. New silly question!
  231. 96 with 5.2L poor gas mileage
  232. rollbar?
  233. removing steering wheel
  234. bagging 94 dakota
  235. Quick question for you all...
  236. Need help ASAP please 88 dakota
  237. 89 3.9L Overheating hellp!
  238. can i have help with these codes please
  239. rolll/light bar
  240. 91 Dakota wont start
  241. Muffler shop put in different size pipe and muffler...
  242. brake problems
  243. Tail Light Tint
  244. thinking about lifting my 4x4
  245. Vibration damper installtion
  246. brake upgrade
  247. Suggestions for the future
  248. racing fuel ?
  249. Fog light pics, take a look
  250. new exhaust
