PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. flickering headlights,no dashlights or interior light
  2. No power
  3. How to clean throttle body 88 Dakota
  4. Headlight issues
  5. 91 dakota 3.9 coil question
  6. The 5.2, with headers and other mods
  7. 88 3.9 V6 kinda jerks when giving gas
  8. Bad washer fluid pump?
  9. What engine do I have?
  10. Should my IAC be sucking in air like category 5 hurricane?
  11. Replacement Thermostat Housing
  12. 7.25" IFS mods
  13. New to forum but have question for you all
  14. Hissing noise coming from near/under throttle body.
  15. 1st Gen Thanks1giving
  16. Sluggish dakooter.
  17. slow start after sitting all night
  18. 1987 Dakota Intake Manifold Wanted
  19. Installing a 8.8 explorer rear in a dakota
  20. Shifting cable might be going out
  21. No power, to anything
  22. wiring harness
  23. Brake light
  24. Truck won't idle when warm
  25. 2 wheel drive wheel bearings
  26. 2inch body lift
  27. What Brands Do Your Rec For Trans Rbld Kit?
  28. Collector value on 88 with low miles?
  29. Carrier Bearing
  30. Check out these rims!!
  31. Backfire
  32. New forum user.. Here is My 93 5.2 Dakota
  33. still wont start no 12v to coil
  34. What the heck is this squealing sound?!
  35. 1991 3.9 power at coil and squirting fuel but no spark
  36. Anyone have exh manifold stud part numbers?
  37. 1993 Dodge Dakota steering shaft
  38. increse engine temp?
  39. conversion u-joints
  40. 3.9 to 5.2 project
  41. 89 dakota 4x4 tie rod end and idler arm torque specs?
  42. What are these vents for on my 1995 Dak?
  43. Block heater, pan heater pad, tank heater?
  44. Death of my '93 Dakota LE 5.2l..
  45. No Overdrive
  46. Wipers not working
  47. difference in pcms ?
  48. New to the forum and back into a Dakota
  49. 1st gen 4x4 front lift problems
  50. Need help finding Parking Brake Pedal Pad
  51. 1995 Dodge Dakota 4 x 4, 3.9, 6 cylinder
  52. 91 v8 dakota 4x4 overdrive not engaging
  53. Pcm death can't find new one help plz
  54. Walker Y pipe available on RA site again
  55. 92 Dakota: no spark, no fuel, starter activates
  56. Lean/Tilt
  57. Fuel, Spark, but no start
  58. Bolt on hp
  59. Higher oil pressure
  60. Speedo gauge
  61. 46re problems
  62. Hello! new to the forum... with some truck issues.
  63. Help!!! Trying to fix heat before winter
  64. Looking for shocks that fit my 3in lifted 95 Dakotasport
  65. 2004 stratus heat
  66. Transmission line at radiator leaks
  67. 94 Dodge Dakota will not stat need help
  68. 94 dakota wont start need major help
  69. Is there an Arcive on OVERHEATING issues?
  70. Diagnosing ignition vs fuel
  71. 95 Dakota no start.... I need help
  72. New vapor canister ?
  73. Tow hooks
  74. 1989 Dakota ABS module...
  75. 2nd Gen Truck Rack on a 1st Gen
  76. 42RE/A500 behind a 5.2
  77. Door Window Fitment Question
  78. 1992 Dakota club cab seat swap
  79. Excessive oil use
  80. 1993 dakota won't start
  81. Battery cable source
  82. cam timing
  83. Gear oil recommendation
  84. Rust removal by electrolysis
  85. Still won’t start...
  86. Need help with taillights!
  87. 88 Dakota custom build
  88. mopar performance computer 1993
  89. Transmission passing gear, abs brake light
  90. Changing speakers in a '93
  91. Oil Pressure Gauge dropping to zero Help!!!
  92. Steering help
  93. Shelby Dakota Performance Kit Muffler
  94. Nv3500 from 2001 dakota
  95. 90 Side Lights
  96. 4x4 94 Dakota rear coilovers
  97. Head bolt replacement recommended?
  98. Upper control arm/ball joint 4x4
  99. Need serious help...2.5 L 1990 5 speed
  100. Engine shudder
  101. How do I disconnect the trans lines from radiator 1994?
  102. evaporust or metal rescue?
  103. No spark... help!
  104. no power to radio/cassett player or clock
  105. exhaust question
  106. fuel tank shield
  107. Engine swap
  108. 1st gen Dak 4th gen in the family!
  109. 1991: Wtf is the AC control?
  110. New here, got a pile here.
  111. 93 Dodge Dakota LE
  112. Cheap Turbo Dakota 3.9l
  113. removing frame rivets
  114. Leaking Thermostat Housing?
  115. Running terrible after timing chain catastrophe
  116. Clutch pedal noise
  117. Door unlocked constantly
  118. 94 dodge Dakota starting and running problems
  119. OBD2 3.9 into a 92 3.9?
  120. 91 dakota transfer case stuck in 4 low
  121. For those needing wiring diagrams
  122. 91 dodge Dakota no start
  123. Temporarily replacing my 96 Dakota hopefully
  124. How do I run down this short?
  125. 1995 dodge Dakota
  126. poly for leaf springs
  127. Front bump stops
  128. Timing
  129. Frame rivets
  130. Windshield washer nozzles
  131. No horn?!
  132. Starter wires replacment?
  133. overdrive solonoid?
  134. Interior door panels
  135. remanufactured ECU issues 95 Dakota 318 automatic
  136. In Need of Some New Rubber
  137. Brake lines
  138. Took the bed off yesterday.
  139. Is this guy nuts or what?
  140. Console options for Gen 1
  141. Brush/Grill Guard for a 94...
  142. Torque converter replacement. 1996 Dakota slt
  143. Help! SYE Kit
  144. 1990 Dakota SE: Brakes Squeel When Not Applied
  145. New First Gen Owner. Need Help With Sourcing Part
  146. Adjusting the PRNDL indicator
  147. 94 dakota front turn signal issue
  148. Replacing Headlight Switch/Connector
  149. 96 Dakota 4x4 transmission
  150. Another question I'm not sure of
  151. NC State Inspection - No dash illumination on '93
  152. Front Suspension Rebuild
  153. Tires and rims
  154. 2nd Gen Sway Bar/Crossmember fitting 1st Gen
  155. Drive shaft question
  156. Motor Swap
  157. Mirrors. I Hate Them!!!
  158. New Member & new (to me) 88 3.9
  159. Lift blocks
  160. Calling Ralph
  161. Steering Rack Cross member Hole
  162. 93 dodge dakota running light problems
  163. rear slider replacement
  164. Wiper Linkage
  165. No more cab, plus a nice surprise!
  166. 93 Dodge Dakota tranny issues.
  167. Interchangeable parts
  168. Brain fart question
  169. 92/94 dodge Dakota(no fire)
  170. Clutch pedal rod removal
  171. 88 3.9 electric fan
  172. P5249546 Engine Controller
  173. Parking brake release handle replacement 93 Dakota
  174. Last time running
  175. Parking lights shorting out somewhere
  176. Couple swap questions (not transmission)
  177. Got me a v8 5 speed 4x4 dakota today
  178. Oil pressure gauge:Idle & Driving
  179. Body Kit
  180. Front parking brake retainer
  181. 90 Dakota Steering Rack Bushings
  182. Post-Rebuild Help
  183. '93 5.2 suddenly dying
  184. need oil dipstick
  185. Help please
  186. Driving in 4th gear
  187. Schematic needed: 1991 5.2/318 auto 4x4
  188. 88' Trans Problem Symptoms - Torque Converter?
  189. Found this Y pipe
  190. New moog upper control arm shaft bushings
  191. over drive wont hold?
  192. Timing chain broken?
  193. Adding brake controller
  194. '91 5.2 TBI suddenly stumbling/stalling
  195. wrong ECU injectors = low MPG?
  196. Oops I did it again..
  197. Blower fan 1 speed only
  198. 89 manual transmission oil question.
  199. Looking for 93 dakota buzzer/chime module
  200. Interchangeable ECU
  201. Front suspension rust
  202. Front brake upgrades ?
  203. Full on beast mode!
  204. Won't stay running
  205. Leaf springs energy suspension?
  206. Radiator
  207. 1993 5.2 No fire getting to the #3 injector?
  208. Antenna Replacement
  209. Power steering fluid?
  210. What Engine and tranny options do I have?
  211. Brakes on a 93
  212. 1st Gen - Grille Guard/Push Bar
  213. 96 4x4 body bushings
  214. Clutch issues 92 dakota
  215. Stock body mount sizes and length?
  216. 1st Gen Towing Reliability
  217. Removed an A 500 transmission not sure what I installed
  218. Front Lift Kit
  219. Power steering pump replacement
  220. NP231 Transfer case questions
  221. transfer carse rear half cracked
  222. 2nd Dakota In my life
  223. Aftermarket Stereo
  224. 94 dodge Dakota 3.9 2x2 standard ext.
  225. 89 dakota
  226. Considering just throwing money at my existing truck
  227. Idling high
  228. Just test drove a 4wd Dakota, have questions
  229. Another Repair thread
  230. 95 Dakota 3.9 Starter Totally out there question
  231. 3.9 heads
  232. Air filter assembly 88 Dakota 3.9
  233. New tow hooks on the HD bumper
  234. 42rh transmission differences
  235. 96 4x4 control. Arms
  236. Looking at another dakota, lol
  237. Transmission filter 88 3.9 V6 32RH transmission
  238. Solved my cooling issues
  239. To much red interior
  240. My bumper cracked in half towing my boat yesterday
  241. Reuse cat with new headers?
  242. code clearing
  243. Just a pic of getting a little muddy.
  244. "Pop" sound coming from right front, when turning
  245. Throttle Body Cleaning
  246. Radiator Suggestions
  247. 93 Dakota, 5.2L Wont Start In Park
  248. Getting the 46RH overdrive to work without the PCM
  249. Tips on mountain driving?
  250. Leveling the rear to match the front
