PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. rear axle
  2. now what. spitting n spudder
  3. toggle on fuel pump??
  4. Junkyard Lift
  5. Window Guides 1992 Dakota
  6. fuel pump
  7. Truck "shudders" a little at decelerating
  8. What are these called and can you buy them?
  9. 1994 Dodge Dakota 4x4
  10. Got some work done on the new '95
  11. The things you find on used cars...
  12. 5.2 magnum turns won't start.
  13. No spark! CAM or CRANK sensor. Code 54
  14. 93 dodge Dakota no spark. Crank or Cam sensor?
  15. Truck stalls on restart issue
  16. 95 dakota 2.5l cuts out and died while driving
  17. 8-1/4 rebuild
  18. Where to find new upper control arms? (4x4)
  19. 93 dakota 2wd front a arm geometry
  20. rear end
  21. Timing chain install difficulty...
  22. hooking up nitrous to my 1995 dakota.
  23. Gen 1A door handles
  24. 87 Dodge Dakota v6 transmission fit a 94 automatics
  25. Timing Cover Bolts Pattern
  26. oil pessure sender wiring question
  27. !992 dodge dakota wire burnt
  28. 1993 dodge Dakota 5.2 swap 4x4 5 speed
  29. 95 dakota 5.9 magnum running rough when warm
  30. Dakota Hood Rod Clip
  31. Convertible top replacement
  32. ac/ heater control bulb and socket for 95 dakota
  33. Best option clutch wise
  34. Headlights or taillights, I can't get both... Brake lights work
  35. What is this?
  36. Pitman arm replacement
  37. Seized lug nuts
  38. in a 1994 dodge dakota, can I install a 1995 transmission with the electronic control
  39. Does this have to come from a 1st gen truck?
  40. Front suspension questions
  41. New to me Dakota problems
  42. 94 dodge truck wont move in neutral ,engine on or off
  43. Resonating "Sound" While Not Braking
  44. Y exhaust pipe for 93 Dakota 3.9
  45. Dash Light Issues
  46. Blower motor 1995 dodge dakota.
  47. No heat in my 96 dakota
  48. speedo
  49. "chassis-works" on Ebay is not a good company to work with
  50. 95 Dakota v6 5speed ECU question
  51. Electrical Conversion
  52. 89 dakota looking to modify.
  53. 89 dakota looking to modify.
  54. 89 Won't Start
  55. Seatbelt bolts...
  56. Auto mechanic labor time
  57. Has no power now after starter replacement
  58. windshield wipers
  59. 1987 Dakpta 3.9 no fire from distributor
  60. Need help. I am an idiot. switched jumper cables
  61. Pro Comp Tires
  62. Belltech drop spindles
  63. 93 dakota 5.2 LE... where to find a 2 inch lift?
  64. 91 Dakota 5.2 Headers?
  65. Thermostat housing leak after replacement
  66. Frame Swap
  67. '92 Dakota Wheel Center Cap
  68. Bucket seat install
  69. 1991 Dakota wants to stall coming out of a stop
  70. wheel noise
  71. Dual phoney factory exhaust?
  72. Starter quest
  73. seat change
  74. fender interchange?
  75. retractor sticks when below 40
  76. fuel pump install problem
  77. Truck dies occasionally, starts right back up; 02 Sensor replacement
  78. 360 swap is in the making
  79. Sugar in tank, need some advice
  80. 4X4 Lower control arm bushings
  81. ciglighter 96 dakota
  82. Truck stalling while driving. Then won't restart.
  83. Biggest tire size?
  84. 4x4 very loud around turns
  85. 1994 Dakota computer issue
  86. Rough cold start, oil in intake
  87. where to get Light/roll bar?
  88. Swapping 94 3.9 to 98 5.2 from a GC to Dak
  89. transmission problems
  90. '93 Dakota motor 318
  91. 1993 4wd Itermediate Steering Shaft
  92. Over heat
  93. 91 Dakota
  94. shift indicator is one space off of shfiter position
  95. Battery
  96. door problems
  97. I just bought a 1994 dodge dakota and plan on lifting it
  98. manual to power windows
  99. Fumes in cab
  100. What size
  101. Transmission replacement
  102. where do I find them?
  103. Surging at idle and not stay running after warmup
  104. Transmission Questions
  105. Headlights
  106. Adjustable Shocks - 1992 4x4
  107. Where are they?
  108. What part is this?
  109. what have I gotten myself into
  110. 1993 possible buy
  111. exhaust manifold removal
  112. Painting tips and experience
  113. Custom Led Taillights or ideas 87-96.
  114. No brake lights....
  115. 318 swap wiring
  116. 1993 transfer case
  117. Parking Brake issue?
  118. Smog pump help please
  119. 1988 Intermediate Shaft
  120. Help! Hvac control removal
  121. Backing plates for rear drums?
  122. Gen 1 with Gen 2 interior?
  123. 318's Got Back!
  124. Seat Belt Question
  125. Popular bluff Missouri
  126. Fluids
  127. V6 clutch question
  128. Ram Tow Mirrors on First gen Dakota
  129. This is for ralph p!!!
  130. Rough running and idle, no codes
  131. What Tire width will fit?
  132. Clutch springs
  133. '92 Dakota 4x4 Wheel Specs
  134. 92 Dakota 5.2L no high end power
  135. 1993 Dakota
  136. Hemi in a Dakota
  137. '95 46RH Tranny return line
  138. 95 dakota heater
  139. 3.9 to 5.2 swap
  140. Not bad for free
  141. front suspension
  142. Burning up the Egr transducer
  143. Mmm.. That's nice!
  144. Need a spark plug reading
  145. Interior
  146. Blue smoke at start up and after long idle
  147. 92-93 vs 94-95 performance PCM
  148. 92 5.2 5speed swap problems
  149. oil consumption??
  150. I need help.
  151. Got a Rotted Rear Bumper?
  152. 1990 2x4 auto 3.9
  153. Exhaust recommendations
  154. fender liners ?
  155. Someone recently asked me about manually setting fuel sync
  156. Torque Converter or Transmission?
  157. Cardboard in Front of Radiator in the Winter
  158. Transmission upgrade to a 3550?
  159. Cross member question
  160. Nv3500 fluid type
  161. Nv3500 update
  162. NV3500 Questions
  163. Clear Turn Signals
  164. Grape scented?
  165. Shifter options
  166. Engine wont crank
  167. timing/ignition problems
  168. Coil spacer lift..
  169. 1996 - Light green exterior color - factory?
  170. Help finding torque shaft bushing
  171. 96 dodge Dakota engine storage
  172. Good deal you think?
  173. Help identifying interior parts
  174. 95 dakota frame strengthening/mods
  175. 87 dakota rear lamps: change to EU version
  176. Plastic Gas Tank For Free
  177. 1st Gen headers?
  178. No acceleration, wont go into gear
  179. Rims
  180. Service Manual Needed
  181. 92 Dakota buying advice
  182. 1994 passenger door needs to com off
  183. faded interior trim and door panels.
  184. 96 Dakota nv3500 or ax15
  185. Suspected timing chain wore out
  186. 2.2 Turbo Swap?
  187. so i need some advice please
  188. How freakin beautiful
  189. Back to Sq. 1 (Again)
  190. 96 dakota 3.9 4x2 auto .Cruise control stopped working immediately after undercar was
  191. Was at the junkyard today...
  192. Prepare for winter...
  193. Like or dislike?
  194. Flames out exhaust!?
  195. headlights will not come on 1989 dodge dakota
  196. lifting or tilting the cab questions
  197. Frame rust
  198. 360 la to magnum efi
  199. 96 dakota 3.9 AC/heater blower motor intermittently stops working
  200. 1992 Dakota Ignition Problem: Ghost in the Machine
  201. Locking tailgate
  202. '94 Dakota Wiring Dilemma; Please Advise
  203. Rear axles end-play
  204. 1990 Dakota Fuel pump sending unit
  205. seat belts
  206. 95 transmission issue
  207. Cabin Air Control Module
  208. On Board Diagnostics not showing any codes
  209. Has anyone got oil in the plenum after a plenum kit?
  210. Body bushings help
  211. 1991 v8 rcsb fuel mileage drop
  212. idle mixture screws
  213. Cool interiors
  214. Watch what you put in your tranny! (manual)
  215. Plenum kit on its way!
  216. Too good to scrap
  217. 94 DD door broke on bottom hinge
  218. 1st Gen AFM Headlights?
  219. pick up coil etc.
  220. 1993 dakota 5.2 not running right questions?
  221. Need help please, 8.25 to 9.25
  222. What's your favorite tool?
  223. Tie rod / front suspension help
  224. 1993 Dakota having starting issue
  225. 4x4 shock options
  226. World's worst heater...
  227. must read: 96 v6 dodge Dakota stalling problem fixed!! easy fix!!
  228. No headers for me
  229. Game: name that sensor plug (help)
  230. '88 Bench Seat
  231. 95 dak intermittent no start
  232. 96 Dakota Manual Flywheel question
  233. Running boards
  234. New owner having issue with 46rh
  235. Looking for stock torsion keys for 91 4x4 dakota
  236. Hughes plenum kit really worth it for me?
  237. Overheating problems, 1990 3.9
  238. Dual exhaust question
  239. 1995 3.9L 5-speed 4wd 4x4 wont engage
  240. What is the leather splash shield called
  241. Getting ready for headers.. And got a surprise...
  242. 1st Gen Fuel Cut-Off Switch
  243. Rarest of the Rare for sale
  244. Relay panel suggestions
  245. Wrong driveshaft?
  246. Check Engine Code 27, '93 Dakota 4x4
  247. '92 with code 15 and 17
  248. Mouldings and window trim
  249. Broken timing cover - causes?
  250. Giving some serious thought to a front end swap on the vert build
