PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59
  1. 96 5.2L Magnum V8 Gas mileage??????
  2. 180* Tstat question
  3. want to buy an engine
  4. Torshion Bars?
  5. 3.9 ?
  6. transmission yolk
  7. 93 dakota fusible link
  8. New to the forum and have some questions..
  9. Electrical Problem! Please Help
  10. 94 dakota reliability...
  11. 1st Gen Burnouts SHOW US SOME SMOKE!
  12. PLEASE HELP
  13. Gauges?
  14. 3.9l mag to 5.2l mag swap
  15. 92 dakota cluster
  16. looking for lowering coil
  17. PERFORMANCE PRODUCTS?
  18. New here, gotta problem
  19. winshield wiper ailments
  20. A cracked head
  21. cant find drl module
  22. Plow ideas what works - what doesn't
  23. wont start HELP
  24. 1996 Dak 3.9...big day tomorrow
  25. Disconnected coolant temp sensor?
  26. my 89' dakota and the net
  27. 94 leak in dash
  28. not even a check engine light
  29. i'm stumped....anyone help out?
  30. v8 Throttle body question?
  31. HELP
  32. got a real mind boggler
  33. Changing Fuel Filter 1993 Dakota
  34. Used 1996 Dakota CC
  35. pulleys and belts
  36. missing connectors
  37. New Mods Pictures (NOW POSTED!!!)
  38. adding some power to v6
  39. Hard starting when hot
  40. oil pressure problem
  41. billet grille insert
  42. painting chrome
  43. H.I.D headlights
  44. No brakes with ABS and brake light.
  45. Couple odd problems that are pissing me off
  46. HELP!!!!!
  47. Fan Blower does not work
  48. Car Craft!!!!!
  49. New to the forum!!
  50. so i want to put a 5.2L in my dakota
  51. fuse panel question
  52. Weird electrical problems.
  53. brake problem
  54. Bigger Alternator????
  55. replacing my 89 engine with a 94...
  56. Idling Problem
  57. Where is your C.B. mounted?
  58. headlights
  59. Stright Axle Conversion
  60. Fender removal
  61. help finding roll cage for dakota
  62. looking to buy one, do they make lift kits for them?
  63. hidden hitch?
  64. 95 dakota question
  65. looking for 4 inch lowering blocks
  66. Interior cuztomization.
  67. Shocks for an old 95' sport
  68. suspension questions
  69. bogs under load
  70. Leaky Tranmission Fluid... on my Automatic 1995 Dodge Dakota Sport
  71. Heat Selector Cable.........??
  72. rims...
  73. Hurst Shifter debacle
  74. Hurst Shifter debacle
  75. oil,oil treatment
  76. 360 heads on 318
  77. will my 318 beat a 5.0
  78. Electrical Problem. Help Plz
  79. electric fan
  80. v-8 Dakota
  81. OBD1 ECT Trouble Code
  82. 1993 2wd dakota want a 440ci
  83. problems..
  84. water pump
  85. i want a cowl hood for my 93
  86. where do you get parts for 93 dakota
  87. radiator leaking into oil
  88. Tranny Interchange on 3.9L
  89. power loss and poor fuel mi.
  90. tranny slipping
  91. Items for sale
  92. Replacing old bench seat in an 88, any suggestions?
  93. x-cab back seat
  94. Retainer Assembly
  95. 1991 Dakota Project
  96. where is the IAC
  97. seat belt recoil
  98. PRE Fuel Pump Strainer (filter)
  99. Low Oil Pressure and Light Issue
  100. Headlight Buzzer question
  101. Grill guard
  102. Dash Gauges Question
  103. Helping a buddy
  104. I Know This Is A Members Truck...
  105. 96' 3.9 Wont idle no matter what I do..
  106. lift kit
  107. lower blocks
  108. The super bee Magnum Engine
  109. Limited Slip
  110. Fuel Tank Size
  111. 95 dakota lift kit?
  112. Need Gas Mileage Help
  113. 92 dakota issue
  114. Is This a problem?
  115. what about this truck deal?
  116. Front Bumper & Lower Valance with Fog Lights
  117. runs rich and wonts to die
  118. Euro taillight for 87-96 dakota
  119. stupid question...
  120. Need info on axle assembly swap
  121. Trans leak
  122. Free repair info
  123. Tranny vibration
  124. location of crank sensor on 1990 dakota?
  125. code reading???
  126. Fuel Gauge Problem (Broken)
  127. 1990 dakota 3.9L wont start(need help asap)
  128. 1st gen trucks
  129. '94 3.9 misfiring
  130. How do you test OverDrive Solenoid 42RH
  131. pics of hood scoops
  132. doesnt blow hot, blows warm??
  133. HID Conversion Trouble
  134. Replacing Fuel Line/ What size /Type
  135. Dual exhuast on a 1996 dakota
  136. Wanna Trade?!!
  137. odd code and wont run
  138. 95 Dakota, doesn't shift right(automatic)
  139. 3.9l to 5.2l in a 88 dakota have ?
  140. is this a good deal?
  141. couple 89 questions
  142. motor for 95 dakota 2.5
  143. DRB II Is There an OBD that will do the same
  144. "Check Engine" flashes 18 times
  145. Bad throttle cable
  146. Input shaft sleeve?
  147. 95' Dakota
  148. 3.9 to 5.2l conversion
  149. '92 or '93 Van engine into an '87 Dakota
  150. Rear end ratio for towing capacity
  151. Voting is going on now!
  152. towing a 5th wheel with a 5.9 Dakota
  153. idler pulley substitute for air pump
  154. stalling issues
  155. What size Wheel/Tires can I fit 2WD
  156. Part number 4338854
  157. drop pics
  158. burnt distributor rotor
  159. headlights..
  160. Windshield Wipers Quit...
  161. Tune up help
  162. 13 No change in MAP from start to run (help truck wont start)
  163. Hard to find Parts
  164. 89 Dodge Dakota Clutch Problems
  165. Regional Sections!!
  166. What is going on with my door?
  167. Whats the best solution guys?!?!
  168. 3.9 conversion to 5.2l 318
  169. 98 seats in a 93
  170. Rain leak, pass. side under dash.
  171. What tool manual tranny drain plug 1991?
  172. Fuse box diagram
  173. Transmission trouble
  174. 318 dodge carburetor choice
  175. 92 dakota
  176. 17inch tire size 2/4 drop
  177. Heater Fan Power Plug
  178. aftermarket antena
  179. Doors
  180. Slipping Backwards in Park
  181. 89 3.9L Throttle Body Fuel Injector Problem?
  182. Dakota dies after running for short time
  183. Oil Pressure
  184. Dakota Headlights
  185. lossing coolent?
  186. Will any year 3.9 work?
  187. whats the differnece
  188. 1993 Dakota LE transfer case question
  189. nsg 370 in a dakota?
  190. Underpowered 89
  191. Seats???
  192. converting 3.9 V6 auto to 5.2 V8 Manual
  193. front driveshaft
  194. 89 dakota mopar express package?
  195. rear end q's
  196. 4 banger 2 hot
  197. Relay question
  198. O.D. Button/Trans. issues?
  199. Grill cover??
  200. need a push
  201. Headlights
  202. Opinions?
  203. May have wrong tranny fluid? Weird problem
  204. 91 5.2l dies when stopping
  205. '87 Dakota will not start
  206. Radiator
  207. dakota
  208. Help with a 318 problem
  209. Windshield wiper switch/turn signal installation
  210. exhaust system question
  211. Possible Lift Kit
  212. About my 96 DAK
  213. auto and manual trannys
  214. Parts Lists!
  215. Transmission Support Bracket
  216. spark plugs
  217. Trans swap
  218. lowering rear of 94 dakota
  219. Clutch fluid leaking at clutch housing
  220. F'ING T-CASE!
  221. best fuel injectors for 93 5.2
  222. lights
  223. lowering rear of 94 dakota
  224. 92 Swap. Beating a dead horse.
  225. v6 magnum engine?
  226. 96 3.9 does not want to idle
  227. making a flatbed *PIX*
  228. Eh!!!! Wants to stall.
  229. pics of my new dak
  230. OEM parts manual
  231. 89 dakota codes
  232. my 94 dodge dakota
  233. where can i buy an extension housing
  234. turn signals stopped working
  235. Whole new front end?
  236. throttle and/or cruise ctrl cables.
  237. I forgot...
  238. stalling 88
  239. lower shackles
  240. rim and tire Q
  241. Heater and Dash
  242. remove radiator?
  243. cheap lift
  244. 92 Dakota dies
  245. A Free 360!!!
  246. Phantom Short - steering column??
  247. Camshaft specs
  248. Selling on ebay!
  249. 1996 DODGE DAKOTA SPORTS HELP
  250. step bars and push bars...
