PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. 95 Lower Instrument Panel Module Removal?
  2. Another hard/no-start issue...
  3. Parts for sale
  4. Ram guy got some dakota questions
  5. ring gear bolt question
  6. '92 4x4 Sport 5.2 kickin' my butt
  7. TCASE Output Seal
  8. Wont start hot. Please help!!!
  9. cv joint boots
  10. Some random questions???
  11. How hard is it to change motor in a 96' 3.9
  12. a535, ax15 conversion
  13. 4" lift for my 94 dakota
  14. 93 3.9 transmisiom shakes
  15. Another Exhaust question
  16. Dome Light & Headliner & Water Leak
  17. lookin for a new exhaust
  18. AC compressor
  19. how to lift my 89 dakota 4x4
  20. New Member- many problems
  21. new member 8 dakota 4x4
  22. Suspension/Height issues
  23. need help with t case
  24. Getting Ready
  25. 1993 Dodge Dakota water leak
  26. 1994 dakota no spark
  27. 318 Swap Done.. almost
  28. tag for gear ratio missing Please help.
  29. Shifting issues
  30. Searched&searched no answers. Headlight issue
  31. Winter around the corner...
  32. Good Starter not working!
  33. 95 318 dakota trans swap. flywheel?
  34. Looking for a 46RH core
  35. Dodge Dakota V8 and transmission swap
  36. Dakota Brake Operation?
  37. normal gas mileage?
  38. quick qustion asap
  39. front springs
  40. Tow story too?
  41. Need a console cover
  42. Re Indexed Torsion Bar Keys
  43. new member new truck
  44. 1991 dodge dakota blower motor
  45. 96 Dakota Electrical issues
  46. power at coil plug
  47. 94 heater issue
  48. Tranny Fluid
  49. A/C pulley
  50. trans help
  51. Tq converter to Flexplate Issue
  52. 91 Dakota Starter Relay?
  53. Transmission Delay
  54. Battery cable. NEG
  55. Peculiar vibration when driving...
  56. Brakes and Headliner question
  57. CPS ring neccessity?
  58. Did something stupid, Need help!
  59. 94 Dakota code 27
  60. 94 Dak 3.9 - shuts down after 1st start of the day
  61. Dead cylinder?
  62. Mopar Action Dakota #3
  63. 33x1250x15
  64. Silly question
  65. 22 gallon tank? yeah right!!!!
  66. Just an Update on the Project
  67. fuel pump not running... voltage?
  68. Gen 1, Suspension Lift by frame stacking, anyone else tried this?
  69. Removing Trany without the tranfer case
  70. Dakota PSA
  71. Whine from behind
  72. Guages dont work when the headlights are on
  73. question about front diff.
  74. starter on 95 dakota 3.9L won't turn off
  75. fuel pump and reg
  76. Interior Trim
  77. Headlight Problem
  78. Steering Question
  79. Steering wheel trim removal (pic)
  80. WTF hating this Dodge that's Jeep Powered
  81. Need help ASAP
  82. New Guy
  83. Oops, i messed up bad!!(pics inside)
  84. Clutch!!
  85. No start - fuel pump not getting power
  86. Painting my 1988 Dakota
  87. The Latest...
  88. How to fill AX15 5-spd with fluid?
  89. Changed IAC, Stalls Immediately
  90. Gas in crankcase??
  91. hesitat
  92. Bad Trans fluid Leak
  93. np 231 compatiblity
  94. fuel line problems
  95. 87 4WD Problem
  96. '99 Grand Am GT seats in my truck...
  97. gear drive
  98. concerning engine noise
  99. noises
  100. Taillight problems
  101. Good Morning
  102. Tanneau Cover
  103. More light issues
  104. periodic engine power loss among other things
  105. Stumped
  106. fuel line problems
  107. Still more problems with my 2.5
  108. Need help with this quick!
  109. need some help
  110. 1996 3.9L Going after the head gaskets...
  111. driving lights.
  112. was NOT expecting that...
  113. Part Numbers for light bulbs?
  114. 32 RH Trans. swap?
  115. 2.5L wont start
  116. Lift Kit Install.
  117. engine swap
  118. 93 fuel pump
  119. 1991 Dakota LE 5.2 Brake Light Switch Location
  120. Roof mount light bar
  121. 93 4x4 5.2 LE Dakota drum brake to disc?
  122. Dakota brakes pinching
  123. Problems with a 318. Maybe a fuel pump?
  124. Questions about Overdrive
  125. HELP! - Need wiring schematic
  126. Leaking rear Brake Cylinder
  127. Stupid Question
  128. Tire help
  129. A short, informative story
  130. Low RPM
  131. 95 Water in headlight
  132. Checking a Cat?
  133. Speedo calibration
  134. Over drive question????
  135. 96 dakota trans question
  136. 46RH question
  137. V10 anyone
  138. seafoam help?
  139. '95 46RH - DIY or $1.4k Shop Repair?
  140. gen 2 rims
  141. 93 le 2wd control arm problem
  142. '93 DD running bad sporadically.
  143. Erratic voltage problems…
  144. whats this hose called?
  145. EGR location plz?
  146. Transmission "Clink"
  147. Front Suspension Bushings...what do I need?
  148. Transmission Speed Sensor
  149. Alternator rebuild anyone?
  150. code help
  151. 92 dodge dakota heater core replacement
  152. Need a few new guy questions answered
  153. killin my battery
  154. 94 4x4 318 Magnum
  155. Steering shaft removal
  156. front shaft u joint straps
  157. rough start
  158. Compression test with motor on a stand?
  159. speedodmeter not working
  160. Will this programmer work?
  161. Hesitation
  162. hesitation
  163. Problem Getting the correct Motor Mounts
  164. anyone have a big block?
  165. been over everything
  166. Runs terrible in cold weather
  167. 96 dakota slt gauges not working
  168. Push Bar
  169. 1992 with 45000 miles
  170. need stock rear susp pics
  171. Faq question/update
  172. Low power on acceleration
  173. Muffler Problem??
  174. '92 3.9 Oil Pressure Sending Unit Location
  175. $3.30 to paint my hood
  176. Dakota Stalling.
  177. How hard could it be? Trailer brakes
  178. New IAC?
  179. '89 Dakota Main fuible link questions
  180. 1500 software.
  181. Long bed to short bed swap info..
  182. Clunking noise near trani
  183. Power windows/locks install ideas..
  184. TRANSFER CASE/Drive Shaft HELP
  185. 46rh vs 47rh
  186. No lights
  187. I have a 1994 Dakota 5.2 Mark III having problems getting it to pass emission in Ga
  188. 94 Dodge Dakota wiring protection
  189. New open air filter
  190. Round 2 of "Can my day get any worse!"
  191. Solid axle kits?
  192. 93 4x4 tranfer case
  193. Will these tires fit?
  194. 1995 Dakota- Hard Starting-Help
  195. Gas gauge Update
  196. A535 / NP2500 5-spd transmission thread
  197. The Exhaust Thread
  198. Incorrectly identified transmission
  199. Replacing Rack&Pinion on 95 Dakota
  200. Gas and Tranny shifting isues...?
  201. whats it worth 88 dak long bed 2wd
  202. Anyone parting out a 1st gen?
  203. Double DIN Radio?
  204. Distributor?
  205. header help
  206. Chrysler infinity radio wiring help?
  207. 95 Optional Gauge Cluster ??
  208. Power door locks 94 Dakota
  209. differential oil
  210. Bogging down...
  211. How much to do with a CL engine?
  212. headlight problem.....pls help
  213. 90 Dakota Auto v6 hard shifting. Help?
  214. A few things.
  215. got some new sounds that just don't sound right...
  216. Just installed a new heater and evaporator core in my '95.
  217. Did you wipers stop working?
  218. Looking for help with electrical issues. Details inside
  219. Engine noise
  220. Yeah its me AGAIN!
  221. Power Loss?
  222. Shock Installation
  223. gettin ready to sell the dak
  224. 87 Dakota, bad starter, can't find relays
  225. Hearing strange noises from rear axle
  226. quick engine question
  227. rear end
  228. Got my wheels done!!
  229. Selling heavy duty brush guard...
  230. Horn
  231. Looking for Cruise control Stalk 89 Dakota
  232. thinking its not worth it......but
  233. Muffler Question
  234. Tire Size
  235. Can anyone tell me ecm #??????????
  236. Were is the Diagnostic plug on a 1993 3.9
  237. Painted wheels?
  238. Manual transmission won't go into gear. Bad slave cylinder?
  239. 93 Dakota 5 speed squeal
  240. 3.9L barely running, looking for ideas
  241. wiring harness section question. Help identifying part
  242. Water Leak on Passenger Side
  243. Plenum Fix
  244. v8 ecm help
  245. 4wd question on 1995 5.2L
  246. Trouble code 41?
  247. Engine Oil Pressures with pics
  248. 89 dakota progress
  249. No heat, no AC
  250. no overdrive no check engine light..but stored trouble codes
