PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. AC belt problem...
  2. Great articles!
  3. my engine rebuild thread
  4. JET Performance Module
  5. Performance Computer?
  6. pulling the engine
  7. brake problem
  8. Stupid Tailgate Question
  9. Fuel Gauge Problems
  10. 95 3.9L to 5.2L 46RE
  11. Pulsating Brakes
  12. found the issue with my dashlights...
  13. 1990 2wd 3.9 v6 auto abs and brake light
  14. Transmission question
  15. Radio losing time when truck not running
  16. AC mystery solved
  17. I keep popping the 30 amp a/c clutch fuse! Help!
  18. Anyone here do their own AC work?
  19. Issue with rough running/missing
  20. need a little help
  21. Probly really stupid question. Just frustrated.
  22. Post Pics of the biggest and or baddest 1 gens you have seen
  23. lift kit
  24. problem
  25. High-flow Injectors?
  26. Again tearing motor apart!!!!
  27. Fuel Injection conversion to carburetor
  28. Throttle body temp sensor
  29. Amazingly stupid/easy overheating fix
  30. 1993 dodge dakota part out.
  31. 92 Cruise Control
  32. I finally found it... But?
  33. Pointless Question lol
  34. Cruise Control works 1 day but not the next
  35. Cracked braket
  36. Parts interchanging
  37. Need info on Dakota engine swap!
  38. OK, I have to ask.
  39. New wheels
  40. stock exhaust piping, 1992 5.2
  41. Dakota rewiring
  42. Clockspring
  43. hooking bumpers
  44. On a small hump flexin a little!!
  45. truck pics
  46. driving lights
  47. Anyone ever rebuild auto transmission?
  48. rack and pinion/steering gear leak
  49. Newbie with a question
  50. gear ratio's
  51. Seatbelt Torx Bolt
  52. What years?
  53. oil pressure problem
  54. will a 2nd gen d
  55. Both high beams and low beams?
  56. Cant keep it running :(
  57. can someone idendify this please?
  58. Fuel Pump???
  59. AntiLock Light....
  60. AC/Heat Control Assembly Question
  61. Valve cover gasket
  62. Help with TBI rebuild
  63. Mopar Performance Computer
  64. Intake and Shifter Ideas?
  65. OEM radio
  66. AC - Air Conditioning Inside Cab Issue
  67. Transmission Cooler??
  68. High Volume oil pump... ?
  69. 1993 Dodge Dakota 4x4 4wd problem
  70. Hello All and I have a question: 92 318 goes lean on acceleration
  71. monday stroll gone wrong
  72. I need some more help
  73. Missing Timing Marks
  74. Front ends well again
  75. Anybody racing a 1st. gen Dakota?
  76. What is this rattle???
  77. 87 <> 91 head swap
  78. popped a seal on the motor
  79. '91 3.9 no-start issues, typical frustrations :)
  80. Periodic Squeak
  81. Truck still not right
  82. This is inconvenient...
  83. 1988 tbi 3.9l constant throttle idle surge
  84. rims
  85. Please Help Fellow Dakota lovers! Tranny Problems!
  86. Another Gas Gauge Question
  87. 2 Tone anyone??
  88. 1996 Tranny question
  89. new update on my truck
  90. Shopping a 92 = A little hard to shift into 4X
  91. 91 318-95 318 transmission
  92. New Member from East TN
  93. Hockey Puck Lift
  94. Squeak
  95. Dakota manual tranny and transfer case
  96. Help! 92 w/ 318 randomly dies
  97. trany gone t case?
  98. 93 Dakota Steering
  99. Engine swap: '87 Dakota 2.2 replaced with '89 LeBaron 2.5, can it be?
  100. Need advice
  101. A few flex pics, and tire air!!
  102. air intake on a pollution control 5.2
  103. Rust where rubber bumpers are above control arm
  104. dash lights went out
  105. Need help with bracket locations and vacuum lines
  106. this might be my last thread for awhile
  107. Oil Pressure issue
  108. Dash Question
  109. need fuse diagram for 1995 dakota 5.2L slt
  110. Windsheild wipers
  111. Which Brand is Best Trailer Hitch
  112. Rear end temperature?
  113. Any advice would be great!
  114. 92 dakota 4x4 engine swap
  115. can anyone name this sound
  116. Starting problem
  117. Extra fuel tank
  118. Steering prob's
  119. 1993 Dodge Dakote 3.9
  120. Possible wheel bearing problem? (crackle up front)
  121. Annoying Tapping
  122. 93 Dakota Trans. return line issue
  123. General BS Thread
  124. $%&^%$@%^ ouch!!!!
  125. orienting orifice tube
  126. 94 Dak wont start after driving
  127. 96 dakota no power to coil
  128. Is it time for a rebuild or what, tranny or engine...
  129. Halogen Headlight High Wattage Output Install
  130. Best Forum Around
  131. modified t-case
  132. my truck is like a teen...jk
  133. Upper ball joint slipped out of control arm!
  134. headliner
  135. Still looking for new carpet
  136. starter swap?
  137. rusted rockers
  138. what ive done..
  139. I need some info
  140. 44RE Transmission
  141. cv boot
  142. 1993 dodge dakota tranny problem
  143. 4wd to 2wd!? (i kno...)
  144. Help please!!
  145. Hey im new here. few questions?
  146. why does this always happen
  147. 92 V8 4x4, wanting lift
  148. Tow packg needed?
  149. Question about low fuel light...
  150. Bounce???
  151. We have a howl..
  152. 2 questions
  153. Select Pages From the
  154. Summit Racing ~ Air intakes!!!!!!!!
  155. Drums to rotors
  156. Linkage question
  157. 1994 dodge dakota Overdrive Issues please help
  158. V6 truck is here. Quick question.
  159. Modifications and Custom Work
  160. Idea's for a teenager?
  161. what are your plans for your trucks
  162. Selling the Dak
  163. No Spark at Coil or Distributor 1994 Dakota V6 -3.9 litre
  164. Battery Question
  165. Bulletproofing the engine
  166. changing out the dash
  167. 93 not running right, need help.
  168. Poor man cold air intake idea...
  169. clutch problems
  170. oil problem fixed
  171. bent frame at the rear
  172. Tranny question.
  173. Turn Key, all power, No Start?
  174. blinker bug
  175. Windshield wiper problem
  176. Air Conditioning question
  177. Camshaft Selection for daily driver
  178. Am I being dumb or ambitious?
  179. 1 more project to add to my list of projects...
  180. Lift!!!
  181. Got the Truck figuired out!!!!
  182. speaker size for 95 extended cab
  183. Shifting Question
  184. New Guy with a couple questions
  185. Quick question!!
  186. oil pump and seal
  187. How to get wiring diagram download on FAQ?
  188. master cylinder question
  189. New muffler!!
  190. back glass
  191. lookin around..
  192. Front axle disconnect
  193. is it normal
  194. Code 27, Bad Idle
  195. Power steering
  196. need advice!!
  197. NV3500 rebuild question
  198. Rattling at 3k+ RPM
  199. No Electrical Power...93 5.2L
  200. Want to replace old V8 radiator with alloy Radiator Help!!
  201. Won't rev past 3500
  202. 95 318 V8 swap into 93 4x4
  203. exhaust for a 4 banger?!
  204. wide rims and tires?
  205. 89 manual rack and pinion
  206. 92 Dakota Axle Bearings / Seals / Brakes
  207. just a quick question
  208. useful LA/magnum info
  209. Long time no post for me! got some questions and pics
  210. 89 3.9 LA to 99 5.2 Magnum.. Please Help!!!
  211. 93 dakota 5.2L distributor gear/bushing
  212. ground clearance issues
  213. Low Oil Pressure?
  214. 95 dakota 5.2 5speed
  215. Broke a cv shaft
  216. MAY 30th Lake/BBQ/Potluck Meet, Grapevine Texas
  217. 1994 Dakota 2wd auto...not starting...
  218. 3rd gen ram totm! Yall come vote
  219. Power Steering Pump
  220. Any options for a fuel kill switch?
  221. Summer upgrades to commence soon!
  222. glove box wont stay closed
  223. Euro/clear tail lights?
  224. Finally finished my rebuild!
  225. Help with my '89 Dakota
  226. 93 dakota towing hitch to 97?
  227. 440 swap???
  228. 1994 Dakota Overdrive Issue
  229. Looks like one of our section mods has a birthday today (4/25)...
  230. Ignition Switch!
  231. code 17
  232. got my new flywheel today
  233. 2.5 Dodge Dakota Tranny
  234. Power Loss Issues
  235. lifting in the furure
  236. Audio question
  237. TCC lockup question
  238. Newb Advice
  239. Starting problem
  240. Gas Tank Size 93 Dakota V8
  241. Junkyard Parts
  242. It's new to me, where do I start?
  243. deep knock ?
  244. Please help me welcome a new section mod.
  245. its finally done
  246. Swap question`
  247. Weird sound when im pressing the gas
  248. New Here - Love my truck not my mirrors
  249. Truck Stalled at a stop light
  250. Summit Racing/Accel ignition parts
