PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. longer drivershaft needed for suspension lift?
  2. Gettin' Ready For Winter
  3. need alot more help
  4. Backspace for 235/75R15 on 2wd
  5. Clutch job
  6. How to ID Tranny and Rear end
  7. helping finding yoke?
  8. Best place to ground an Amp?
  9. Loss brakes on 1989 Dakota sport
  10. Need help with my 93 dakota 4x4
  11. need to replace flywheel and starter
  12. 2wd to 4wd trans?
  13. '93 3.9 V6 - new battery, still won't start...
  14. Swappable parts 91 onto 87 2WD dakota
  15. Another 1st gen design flaw?
  16. External Overdrive 1987
  17. New tranny, remove t-case?
  18. My '94 Dakota V-6 won't start and run.
  19. strange 4x4 issue. pls help!
  20. what oil weight are you using
  21. No change in shaking
  22. coolant pouring all over
  23. 95 Dakota 3.9 Hard/no start good fuel pressure
  24. pedal and cab vibrations?
  25. 95 Dakota 3.9L New Heads Won't Start
  26. whos installed rear sway bar?
  27. TPS and IAC on 93 3.9
  28. Supercharger?
  29. oil pressure sending unit
  30. who needs parts?
  31. Stupid Question
  32. new anti-theft system?
  33. Misc. wire connector identification help
  34. Wire gets hot/Intermittent start
  35. 92 V6 3.9l - Ignition lock issues
  36. Clutch to stiff
  37. Repainted Edelbrock AC Cover!
  38. Oil Change Story
  39. Floor pans?
  40. '96 dakota 4x4 ball joints
  41. How to improve gas mileage
  42. 5 speed swap...which nv3500?
  43. Mpg
  44. Best All Terrain Tires?
  45. Ignition barrel
  46. Coil over shocks? Who makes em?
  47. 2wd/4wd and transfer case
  48. 1988 Dakota Starting/Running Issue
  49. larger off road tire on stock '93 4wd
  50. 87 Dakota V6 Trans. Swap Auto to Manual
  51. All for $152.75!!! =)
  52. Dead Dakota
  53. Gen 1, 22 Gallon Fuel Tank.. will it fit ?
  54. Question for you cold weather guys
  55. Brakes are squishy
  56. fuel gauge issue
  57. Fixing cruise control
  58. My Lifted Dakota!
  59. mopar performance ecu for obd1 ecu?
  60. 1987 Dakota 3.9L engine stalling
  61. beef up trans for 360?
  62. How big can I go for tires without a lift?
  63. Power loss with a small load in bed
  64. paint starting to peel on 94 dakota
  65. Does anyone...
  66. 1993 5.2L 4x4 supercharger project
  67. 93 transfer case
  68. solid motor mounts
  69. Evap manifold and ported check valves direction of flow
  70. No Overdrive
  71. finding 5.2 parts difficulty?
  72. Street/ Strip Dakota
  73. Howdy need some help
  74. Howdy
  75. 1994 Idle drivability issue
  76. Hockey Puck Lift
  77. 1995 Dodge Dakota fuel pump
  78. lemme get a list guys!
  79. Shocks
  80. magna flow or flow masters
  81. fuel sync issue
  82. 94 dakota wont start
  83. Changed ujoints but no difference
  84. Need Help! running out of time and money :(
  85. What does this molex supply power to
  86. not a mechanic please help
  87. Dropping fuel tank
  88. 91 dodge dakota v-6 starting problem
  89. 93 Dakota Q's: Leaking and Lifting.
  90. Random shutdown
  91. 93 4X4 wheel bearings/cv shaft
  92. Dakota Sport Stripes IN STOCK!
  93. Cooling
  94. Plenum Leak?
  95. good to bad day...
  96. 96 dakota
  97. whole truck violently shaking
  98. 96 3.9L misfire (no engine light)
  99. strange buzz coming from the pcm
  100. fuel line help
  101. Interior lights
  102. gauge questions?
  103. rear sway bar?
  104. power mirror swap!?!? wheels? new PicknPull!!!
  105. Front end
  106. Bench Seat Bolts
  107. Transfer Case; Rebuild, Replace, or Simple fix.
  108. My Door wont open!!!!
  109. Bolt size?
  110. Vacuum Canister
  111. Thoughts on misalignment
  112. Over-Drive Switch Wiring
  113. '92 Dakota ignition control module location?
  114. 95 v6 mag timin belt or chain?
  115. Smog vac line sizes
  116. Brake sensor in prop valve
  117. frame rot.
  118. Dealership says no dice.....
  119. Speedometer jumping
  120. Transmission out?
  121. 440 in 93 Dakota?
  122. Still down....
  123. lift question
  124. no spark!!
  125. project dakota
  126. Finally found the source of my electrical gremlins
  127. 92 computer bad?? anyway to test??
  128. Poor Fuel Mileage
  129. 94 hood latch spring
  130. Preformance help
  131. 96 dodge dakota trailmaster lift availability
  132. Interested in new cam... Valve springs?
  133. HELP!! No Start Issue!!
  134. Auto to manual swap
  135. Check Brake Light Question
  136. timing issue
  137. 91' no spark, HELP!!!
  138. Transmission leak
  139. Brake job
  140. Front Wheel bearings
  141. odd code
  142. Anti-lock Break light
  143. Combination of Trouble Codes
  144. Transmission downshifts with little gas pedal application
  145. 1993 Dakota code 27
  146. quick triler wiring question...
  147. brake line fittings
  148. Y Pipe
  149. Lift my dodge
  150. Need some help/advice. wheel bearing
  151. Seafoam
  152. No spark, No start
  153. speedo/tranny issue?
  154. Best head lite lens restore kit?
  155. i "Think" my dak is over heating?
  156. Single Board Engine Controller
  157. Dakota Six Pack Hood Scoop
  158. front brake help
  159. i want rumble
  160. Need help!
  161. Moper Performance Computer.
  162. 93 dakota won't start - no spark
  163. rack and pinion
  164. Deadkota...
  165. Headlight swap
  166. 95 3.9l 5 speed running rough codes 21,52,32
  167. dakota snorkle?
  168. Steering column?
  169. Eliminating the Front Drive Shaft on 94 Dakota V6
  170. 1991 dodge dakota la 318 5.2 cams and lifters
  171. 1993 dakota 3.9l magnum, poor gas mileage
  172. Plugs
  173. '90 Dakota Sport fog lights
  174. power rear view mirrors?
  175. Trying to decide on K&N
  176. steering columns
  177. Thermostat replacement
  178. driver door doesnt always stay shut?
  179. 318 Build questions
  180. Fuel Pump
  181. arm rest center console?
  182. tailgate wont open
  183. 318 & 3.9 Swap
  184. Engine dies error code 32
  185. tb spacer and k&n cold air?
  186. wheel cylinder,hardware kit help
  187. shocks/alignment
  188. Engine/Transmission compatibility
  189. My trucks last days....
  190. Engine Keeps Stalling Out?? (3.9L Carbureted)
  191. Cant find part
  192. Start, but no run. Eratic tach. Code 14, 21, 22.
  193. Start, stall, start, stall again
  194. CHEV-OTA. DAKOTA FRAME SWAP. tons of pics.
  195. wiring problem with fuse box...no lights
  196. dakota tranny
  197. gears and gas mileage help?
  198. Non working A/C
  199. 92 Dakota 3.9 standard trans. won't start
  200. Dakota towing hitch size?
  201. Transfer Case Drain Plug Removal
  202. Is it possible for my truck to run on propane??
  203. Help!
  204. shock recommendations
  205. wtb 96-98 2.5l
  206. ball joint replacement
  207. Horrible Squeal.
  208. Trans leaking
  209. 1990 Dakota troubles
  210. Dash and Tail light fuse keeps blowing
  211. Just bought a Dakota!
  212. iac question
  213. need names on theese parts,pics uncluded
  214. electric fan swap
  215. Electrical problem -_-
  216. Low Brake Pedal
  217. Grinding noise
  218. Transmission / torque converter slipping (1996, 5.2)
  219. My Auto-trans is dying.....
  220. 93 tuner
  221. 93 Dakota no start
  222. tire sizes
  223. Front end completion help! (crazy ES bushings...)
  224. Cooking my tranny?
  225. Another Plenum Gasket Question
  226. Transmission "ticking"
  227. 5.9 conversion
  228. Questions Lifting 91 dodge dakota 4x4
  229. Looks Like A Head Gasket Problem
  230. What would yall think?
  231. A couple questions..
  232. WTB part of wiring harness
  233. lower control arm torsion bar removal
  234. '92 3.9 Idle problem
  235. high beam clicking on and off
  236. Shaking real bad
  237. Intermittently dies
  238. M1 intake Q
  239. 1988 Dakota 3.6 fuel issue is making it take too long to start
  240. Bad plenum gasket experience! HELP!
  241. Best place to find an AX-15 input shaft
  242. need help
  243. Making a double inverted flair on Steel fuel line
  244. 94 Dakota 4x4 HELP!
  245. Steerin wheel swap?
  246. 92 Dodge Dakota 2 wheel drv. 5.2L V8
  247. help identify leak
  248. post seafoam gunk help
  249. 94 5.2L 4x4 starting issues and it was a run issue I think?
  250. 1996 3.9 stalling backfiring need help
