View Full Version : 1st Gen Dakota Tech
- NC get together
- wants to die
- throttle body swap/ cheap mods
- Transmission swap
- Tune up!!
- Autolite 3923 not for 1990 V6?
- I Need Help Again
- Turner signals?
- Alignment......
- Has any one got these parts?
- What are good Mud/splash guard flaps?
- You Guys Are Freakin' Amazing!
- Question about replacing oil pan gasket
- brake problems
- while installing the tranny cooler
- Off Road Bumpers
- Orlando get together Feb. 28th
- 4x4 Indicator light.....
- Just to say hi to everyone and some pixs of my truck
- Your wish list.
- New transfer case question...
- column shift slipping Helps Please
- instrument panel lights
- **FAQ2 ----Modification Ideas: Lifting/Lowering, Performance, Swaps & More**
- starting problems
- Not wanting to start at gas station....
- Service Manual
- Idler arm......
- 1995 dakota 5.2 4x4
- jack/lug wrench location
- Brake bleeding rwal combo
- pully in place of exhaust pump
- Finally got it back from the dead.
- map sensor
- Dome light and glow light around key
- 3.9 won't rev past 4000
- Please help code 27
- Check this out! Convertible Dakota!
- Hub and Axle...
- My 1988 Dakota 4x4
- Wandering!!
- 95 dakota fuel gauge problems
- oil pressure
- IAC or VACUUM Leak?
- 32RH/Torque converter splines
- Code 34
- Transmission leak
- '94 Extended cab Dakota Climate Controls?
- front end ?
- The lack of info on early 1st gen Dakota 318 Magnum swapss
- blow through turbos
- tire size
- 94 Dakota 4X4 Extended Cab U Turn Troubles
- aftermarket motor mount bushings
- Body lift!!
- Thinking of scrapping the 2wd
- Tire Rubbing!
- Accessories
- ball joints?
- Lets talk chips!
- Transfer Case Question
- 90 Dakota.
- 4" lift for a 4X2
- Power Window/Locks wiring harness removal
- Hi!
- 5.2 performance or 5.9 engine swap
- torison bars
- Interior Panel Removal
- code 21 again???
- no turn signals or brake light
- Starter stuck on even when running
- drag/off road dakota
- oops.
- Help
- New Exhaust!
- Dodge 18" cabiler rims on my dakota
- 87 3.9 problem
- Any idea?
- 93 dakota ecm
- Help have a rear end noise
- '92 Dakota Manual Trans. Rattle/Grinding noise...
- 95 dakota Transfer Case issue
- heator core
- 93/97 Dakota Bad Centering Yoke?
- 4HI and 4Low problem.
- bumper replaced
- Camshaft question need help please
- 1994 Dodge Dakota 4X4 Auto Trans Trouble
- 93 dakota fuel issues
- 3.9 motor swap
- 91 Dakota Neutral Safety Switch
- Code 42 on a 1996 3.9
- Help Diagnose Stuttering
- Roller Rockers 96 Dakota 5.2L
- 4 wheel will not engage
- most likely selling or trading my truck
- Interior and Exhaust
- cruise control
- Rear speed sensor testing?
- Shifter Boot Anyone?
- changing a pump unit for a mechanical pump
- Cold air intake for a 93 dakota
- How?
- Where Can I Get 3.9L Perfomance Parts
- cranks but no start
- Got the exhaust thing figured out!!
- Ignition switch actuator rod broke!
- Seats??
- 96 Dakota SLT drums and rotors 9" or 10"
- 318 Timing Question?
- 1993 dakota aftermarket rocker arms
- 2wd to 4wd
- quick, easy and cheap mods
- Pipe Size, 93 Dakota?
- What you love about your Dakota.
- dome light issues
- My next mod.
- Need wheels and tires, need input.
- 92 Usual issue backfire through intake stutter die
- Pin stripe removal tips?
- 125mph Speedo Swap?
- torsion bar how to?
- Trailer tow rating Chart
- 3.9 question
- 3.9 engine kits?
- wiper problem
- rough idle, accelerating/decelerating on highway...
- along went a spider...
- New guy here with a great project
- Interchangeable parts
- What did you do to your Kota today?
- Fuel Problems with 93 318.. help!
- How to remove trip meter adjuster
- truck seems to be wobbeling
- anything look weird in this pic
- Catalytic Conver/Exhaust System
- Dakota transmission help?!
- Transmission Cold Last Thoughts?
- Fuse maybe blown? Which one? No owners manual...
- clunking noise from front on decel/coast
- 96 dakota instrument cluster self-test
- New Tires New PSI
- Turbo Dakota! Tons of Pics!
- Rusty Questions, Help!?
- shifter boot :Crazy4X4RT
- Fuel Gauge Not Working
- 2.5L head grounds
- Small lift for 1996 Dodge Dakota 2wd
- Cheap part prices
- 91 dodge dakota throttle body problem?
- dodge 1991 dakota stalling
- Turn Signal in my speakers!!!
- 1990 dakota heater
- Rust Problems?
- 92 Dakota project
- Any Suggestions Would Be Awesome !
- Lift questions for an 88 dak
- 95 2.5L will not start
- 94 dakota wont start
- vacuum diagrams
- weld diff
- 1988 dakota gas and oil questions.
- o2 Question
- 92 Kota 4X4 5 speed trans plug
- 2-3-body lift
- no electrical power
- Hesitation issues
- 5.2 magnum from gen2
- so close
- 92 truck customization
- '92 318 Longtubes???
- Intake gasket locator dowels?
- 1st gen 408ci
- Clunking noise on take off or braking
- Engine Cleaning Tune Up?
- Changing Thermostat - RTV Sealant
- 95 dak 3.9 2wd
- Need some help/advice
- Just hit.....
- Finally Painting over that Ugly Wood Grain!
- problems opening hood
- Dome Light blows bulb in a few days...
- 96 Dakota pull cup
- Quick noob question
- Will I need to change out my axle if I swap the motor?
- 96 dakota
- Cb/Pa Speaker question
- Newb Question !!
- Low fuel warning light quit working
- Dash light dim
- Steering wheel not straight
- Need help, runs for a bit then dies!
- Update on turn signal problem
- 93 Dakota Gauges move?
- Need help with a '96 to earlier 5lug swap
- Buying a Dakota; Advice?
- 3.90 gears
- Problems with OD (noob learning)
- turn signals and brake lights not working
- ujoints
- WTB: 94-95 Dakota vehicle speed sensor
- Lift Kit for a 93 Dakota
- My 1993 V8 Dakota
- Blower switch
- Help me diagnose my truck. (dies mid-traffic)
- wiper motor
- manual tranny swap and lifting advice
- ok so explain this please someone!!!!!!
- Steering shaft spacer
- Jan. DOTM Come Vote!!
- Some interior questions
- Badass dakota... weird problems... help?
- strong coolant smell
- before and after 3" body lift and 33's
- No start; no click; no dimming of dash lights
- New diff mounts..
- Tilt lever
- gas milage is getting worse
- Turn Signal/Hazard flasher problem
- Head Scratchers.....
- V8 Swap to Dakota?
- Sudden shut off while driving!!
- 93 dakota 5.2 flexplate auto trans
- codes 22 and 21
- Ground points
- Need interior parts
- Brief grinding noise with acceleration!?!?
- Heater control backlights
- Need help again with truck!
- Dome Light Door Jam Switch
- starter grinding, wont start now
- Air Bag Question
- 360 vs 318
- swap trans
- '92 3.9 4x4 Wont shift into OD
- engine swap, what fits?
- Semi new to dodge
- New guy here QUESTIONS QUESTIONS!
- Transmission Whine
- Fault Codes OBD question?
- 96' belt issues
- Parts shopping and need an opinion...
- Jan. DOTM Nominations
- 93 Transmission Shifting Problem
- Removing my swaybar
- dodge is sick...need help ASAP
- Real quick question
- Work out for the dakota!
- Get it runing??????
- 87 dakota light clunk in front mystery
