View Full Version : 1st Gen Dakota Tech
- Engine dies
- 1996 dakota 3.9 v6
- Front End Clunk / Pops
- Tming Chain | How To Install It From Scratch??
- 95 dakota has me stumped.
- I'm Worried; 94 dakota gently rocks side to side
- 2wd suspension upgrades
- 95 Dakota 5.2 Troubles
- Tips to reach ~300 HP on a EFI 318?
- 1995 dodge dakota 5.2
- 93 Dakota Hard Starting cold
- Idling rpm
- AHHH!! Need help!
- Need help truck dies
- headlight nightmare
- Dorman intake gasket opinions
- Injector forced open with engine running
- 93 Dodge Dakota Sport V6 Question
- Compression Test
- 93 dakota 318 misses while maintaining speed
- Recall on the steering wheel back cover 94 dak
- Distributor 180 Degrees Off???
- Hello, I'm TragicTemper, and this is my Dakota
- 727 swap flex plate bolt patterns
- hard bed liner fitment ?
- Finally going to attempt to fix the non working gas gage.
- '91 Dakota 3.9: Wiring harness/no power to PCM
- '91 Dakota 3.9: Intermittent starting/dies while driving
- 6.5in. door speakers
- 91' Dakota 3.9: Serious issues, need help ASAP
- Finally got my new wheels and tires
- 89 dokota problem need help
- 1989 Dakota
- Stuck Injectors! - Best Way To Unstick Them?
- Aftermarket stereo
- Randomly Dies/No Spark/Starts later
- Heat damage from engine on Hood?
- Cost of rebuilding heads? 3.9L
- 96 Dakota transmission
- Seeking OBDI Performance PCM/ECM
- repain
- Newbie: 96 Dakota V8 Magnum 2WD
- 1993 dakota 4wd 5.2l runs rough at low throttle/rpm
- My Truck Is Not Starting - Video Attached
- Trans Swap Question for Crawler Hauler
- Think I Could Tow This Much?
- Some fuel system problems
- Windows and Ac blower
- wont start
- new member with starting issues
- 95 dakota 5.2-360/5.9 swap
- No Start Compression Issue
- Head/valve adjustments, serpentine belt.
- Will this motor work?
- reindexed keys --> rock solid ride
- misfire
- 96 Removing wood trim to replace lighter
- Dakota buying advice
- Headlamp buckets
- 96 2.5l sport -- full racing exhaust
- Looking for the "BEST" and most "DURABLE" 5 speed for a 2 wheel drive Dak
- ABS (or lack thereof?)
- Who has 15x8 wheels with 31s?
- front driveshaft for a 96 dakota
- blowin tranny line
- Emergency brake issue
- 5 lug swap help plz
- 5 speed swap
- Cluster Problem?
- Bucket seats to bench on 4x4
- Timing issue? popping.
- 92 Dak engine has got me puzzled
- Help identifying spring from throttle body.
- So this happened... (hint: need a new door)
- 95 Dakota Won't Start! - Overhauled
- what colors go to what? manual to electronic carb.
- what year went electronic transmission?
- gage compatibility
- what is the biggest size tires I can put on my stock 1993 Dodge Dakota?
- will run 10 15 mins then no spark 93 dodge Dakota 3.9 v6
- 96 questions
- 1995 Dakota 3.9 4x4
- VIN Number decoder/specifications
- Desperate for help!!!
- NO START, has fuel and spark. Getting frustrated.
- Noid light stays on, code 27
- supercharger
- Rough Idle, Occasional Stall, Sputtering, Loud Engine Popping and Shaking at 50+ mph
- 1992 dakota overdrive light stay on
- Fi air gap / m1 / cam timing ?
- a few a500 trans questions...
- Exhaust System
- HID Kit on a 1st Gen Dakota
- turbo for 1990 Dakota 3.9
- 95 Dakota Wont Start After Overhaul | Please Help!
- Catalytic Converter removal ??
- Need help 1994 3.9 2wd
- New member with some issues
- Infinity Stereo
- electrical system
- 4x2 lift
- Spark, Fuel, Crank no start
- My 1995 3.9 to 5.2 build/swap
- 2.5L and egr valve
- Rear Brake Grabs in the Morning
- Truck won't crank after transmission fluid change
- my t-case is shot and the dakota is stuck in 4 wheel
- misfiring after short drive
- Doing a 3.9-5.2 Engine swap. Will my injectors work?
- real low idle and stalling to high idle?
- Intermittent code 27
- 92 5.2L 4x4 Dakota totally random stalling
- I Mest Up! Please Help
- 89 dakota
- Help please!
- 318 reaching 125.000 miles...? is there something unusual I should take care of..?
- Keyless Entry - Greenhorn
- Alternator Help
- 94 dakota auto 3.9l torque converter problems.
- I'm Stumped, any suggestions?
- Sure Grip
- ax15 slave spacer to fix high engagement?
- IFS upgrade ?
- '87-'91 nv3500/ax-15?
- DIY Complete Body Mounts for the technically and/or financially challenged.
- 96 dakota 2.5 to lsx swap
- Light Ring Around ignition switch
- CB Radio installation - 1996
- 3.9 to 5.2 swap question...
- Need help
- jeep axle internals swap ?
- Dakota Stalling
- transfer case broke ???
- Need help with Sputtering/Chugging/Oil Consumption, and more...
- almost running hot
- 4WD Parking Brake Cable J-Hooks
- front drive shaft help plz
- Need Front Fenders,looking for Cheap sites
- brake problem?
- 92 dakota RWAL
- double din stereo
- timing gears ?
- Anyone done a clutch on their 4wd?
- 95 Dakota 3.9 4x4 Cranks but no start. Gets fuel and spark
- Negative Battery Terminal Ground??
- Light switch
- Replaced my starter
- 92 dakota 3.9 auto,,, backfire, stall, cold
- squeaky belt is driving me nuts!
- 1989 dakota tbi problem
- Alternator Ground Cables Help!
- crank sensor
- Advice on a 94 Dakota Purchase/Trade
- 1996 4x4 Build
- radiator replacement
- Question about Speakers
- Locking tailgate handle Gen1
- Dakota Rear leaf spring shakle...
- 1991 3.9L Timing Chain ??
- Trouble finding wheels
- New truck
- Thinking about buying a 1993 Dakota, what to look for?
- fuel pump change
- Bluetooth control of headlights
- Light around switch
- ax-15 question
- Seemingly unique problem involving water pump
- 89 shelby question
- those who have put a 5.2 in a first gen.
- nv2500 vs nv3500
- 2.5 hanging throttle and rough idle
- 1991 Transmission Problems
- headlights shut off while driving.
- wheel well molding
- Hood wont open
- 94 3.9 interchange to 2000 3.9
- Transmission speed sensor
- Stubborn 318 Crank Bolt
- 1994 Dakota Speed Sensor replacement
- 88 Dakota codes 22, 24, 45 help
- plastic headlight
- Dies / Cuts out while driving
- Tire size
- pics. of new wheels and tires
- caused motor to run better by accident
- 8.8 rearend
- '94 Dodge Dakota Fuel Filter
- 94 Dakota problems...
- Cylinder Heads Position?
- My Rocker Arms Are Not In Order... What Do I Do?
- 4'' TM suspension lift problems
- 1994 dodge dakota leaking
- Would love to see Aftermarket Wheels
- mpg drop, ideas?
- Help: Misplaced Rocker Arms Order
- Build For Boost or Stroked CI?
- 1990 dakota gets no fuel to throttle body
- lifter and push rod installation
- Aftermarket tail lights?
- Aftermarket Headlights need help finding a set
- Update
- should i trade?
- 1993 Dodge Dakota fuel injector issue
- $900 '91 Dakota Issues (Picture & Videos)
- What are the gear ratios in front Differential
- 95-96 Dakota shock towers rotted...can they be replaced?
- trans issue
- Brake upgrades, 1988 Dakota 2WD
- 1989 Dakota Sport Fog lamps
- OCD Project (Old Convertible Dakota)
- 94 Dakota power lock issue
- Needed ASAP. 4 Speed OD automatic trans
- 1994 dodge dakota od issues...
- Fat stack of shiny new hardware for my Dak!
- Picture request: 4x4 front suspension bumpstop
- engine surges at idle
- Leaning out high RPM issue
- TBI-3.9L Misfire When Warm?
- trans. problem on my 90 dakota 3.9V6 automatic
- 94 5.2 dakota transmission shifting problems
- Bleeding the brakes
- Front Axle Disconnect-ATTN: 4x4 guys
- Wheel Tire Combo Questions.
- anyone used the procomp carb intake?
- What torque converter does my 42RH use?
- Project: Krusty, 93 Dodge Dakota
- Help!! my Dakota is down...
- Stalls when hot @ highway speeds???
- 1992 Dakota 4x4 LE, Poor running
- 1996 dakota wiring problem
- Brake lights and flashers not working
- Rough start and bogs down if not warmed up
- Bed Liner
- 2'' body lift question
- Steering Column?
- which transfer case ?
- Front end bushings
- OD and cruise issues. Related somehow?
- Please help with front driveshaft removal
- Inner and outer tie rod ends
- Nobody helping!!!!!!
- transmission shifts late after driving on highway
- hurst competition short shifter equivalent ?
- front suspension swap ?
- 93 Dakota LE 3.9 Auto Problems
- 1996 dome light
- 94 dakota V6 won't rev
- Major Tranny Problem
- Transfer Case
- Where can i find longer shocks?
