PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. problem!!
  2. 95 Won't Start - Code 11 Displays
  3. ABS/parking brake light
  4. Headlights and Taillights
  5. Which oil pan? Engine? or Transmission?
  6. Can a 360 LA engine swap into a 1993 Dakota?
  7. 93 Dak Fuel Pump Problems
  8. Transfer case top nuts
  9. Trans temp switch/speed sensor
  10. Shocks/Plugs/Wires/Cap/etc
  11. Won't Start
  12. 96 dodge dakota sport 3.9 HELP!!!!!!!!
  13. Spark Plug Heat Shields of doom!!!! (halp)
  14. engine rebuild questions.
  15. anybody else have this?
  16. Speedometer sensor--- cruise?
  17. Can`t find the miss
  18. Torque over Horsepower?
  19. Need to know more about Dodge trucks
  20. Transmission Dipstick scalding hot?
  21. what to modify next
  22. Rancho shocks shearing bolts
  23. 3.9L magnum V6 to 5.2L magnum V8 swap
  24. New Exhaust!!
  25. 95 dodge dakota Lift
  26. Name That Part!!!!
  27. 1991 std cab rear end on a 1996 ext cab possible?
  28. exhaust leak- JB weld?
  29. level kit
  30. Top End Power Loss
  31. Custom 1990 dakota for sale!
  32. Steering Wheel Swap?
  33. 1995 Dakota Vacuum hose diagram
  34. time delay relay?
  35. Tranny on it's way out?
  36. clunking noise help!!
  37. 94' Dakota v6 not starting
  38. dash and steering column
  39. i have 96 dakota and doin the 3.9 to 5.9 swap...
  40. looking magnum valve covers
  41. 6 of 8 plugs replaced and can't change the oil
  42. Small AC leak
  43. Heater Core
  44. Back in action! (sort of)
  45. Selling 94 Dakota
  46. HELP please! =]
  47. 2 oil cap?? which one to fill?
  48. SELLING 90 dakota 3.9
  49. i dont have headlights
  50. 3 random issues unresolved...
  51. Code 51
  52. 88 torsion keys lift
  53. dakota fuel issues
  54. what tranny??
  55. '92 won't start
  56. Does anyone know?
  57. NP231 problems
  58. what's included in the price?
  59. Rain Guard Removal
  60. Code 46
  61. Front bumper
  62. 46rh tranny
  63. Cost to replace brake lines on '94 Dakota?
  64. Which Fastman TB?
  65. 2wd mudding tips?
  66. my dak build info
  67. Muffler!!
  68. Replacing heater core in 95 dakota slt
  69. New guy here, with 92 3.9L 2WD with low-key rust paint job!
  70. 92 5.2 Will Not Idle
  71. Fuel issue help
  72. beach pull???
  73. How do you hotwire a 93 dakota 5.2?
  74. No spark
  75. summits 2in body lift? torsion bars?
  76. v6 on 30in tires, 8-10mpg city-hwy????
  77. Overdrive Again
  78. Thank god for standards
  79. 1989 Dakota Project
  80. Fuel Pump replaced and still no start. Please help :(
  81. Why is my 94' Dakota dying on me?
  82. Bedliner
  83. E-Brake Adjustment help?
  84. door panel
  85. '91 Lil Red Express - Have a few questions
  86. Painting the flatbed need help
  87. Help troubleshooting Codes 12, 41, 51 & 55.
  88. To old for a build sheet BS?
  89. Shelby Dakatoa
  90. HELP! I want to swap the tranny on my 94 Dakota 4x4
  91. time for a rebuild
  92. Check out the general discussion subsection!
  93. bad news everyone
  94. Tie rod? Alignment?
  95. Parting Out..
  96. Northern Utah, southern Idaho?
  97. yeeee-haaaawwww
  98. my u-joint retainer fell off!
  99. Fuel gauge or tank float?
  100. Clutch pedal Adjustement
  101. Sun Visor
  102. 95 2.5 will NOT start
  103. Obd 12 14 1 37 55
  104. no spark problem
  105. Seafoam? Why and is it worth it?
  106. Prepping for repair. looking for pointers
  107. Under the Hood Light
  108. Stupidest question ever.
  109. Fuel Pump & filter....
  110. 1995 ext cab 5.2 to a 5.9
  111. 1995 Dakota V6 3.9 - Rough Idle + Occasional Stalling
  112. electric fans
  113. my dakota spec sheet
  114. Sputtering issues
  115. Injector control circuit failure
  116. 89 Dak in 3 pieces
  117. 1991 Dakota no Check Engine Light
  118. Look what I did today! :-D
  119. 15 Gallon or 22 Gallon?
  120. 95 Auto with Reverse "whine"
  121. brake too hard, break something (help)
  122. Flatbed
  123. fuel cap question
  124. diy brush guard/bull guard (poor man diy)
  125. Need Help! Truck wont start.
  126. parking brake problems
  127. Overdrive Issue/Governor Replacement
  128. Made soap with antifreeze. Weird
  129. 92 dakota nv 3500 swap
  130. N00B question, PCV Valve, Sorry :-0
  131. Here I go again!!!
  132. 1995 Dakota V6 towing capacity
  133. Oil/Filter Recommendations?
  134. Cherrybombs or Flowmasters??
  135. window problems
  136. 1990 dodge dakota 4x4 sport fuel pump issues!
  137. 92 blower motor.
  138. need some frame parts
  139. Planning my "weekend" lookin for advice on what to do to the truck
  140. 91 dakota with 3.9l timing issues
  141. Shock removal?
  142. a few questions.
  143. New Mopar Performance computer
  144. Paint Problems
  145. 89 dakota, tranny stuck in 1st when cold
  146. Heat/Air Conditioner problem
  147. 95 Dakota Engine Problems
  148. 1988 3.9L won't start
  149. fuel pump
  150. 1993 V6 radiator in a 1991 V8? Need to know asap!
  151. Anyone in or around Omaha, Nebraska with a good radiator V8?
  152. Ecm needed
  153. Timing set recomendation
  154. Intermitent stalling issues ??
  155. Looking for some body work insight
  156. Bypass EGR valve AND get CEL off?
  157. To say hello to all
  158. oil pan removal
  159. Lower radiator hose spring?
  160. what wheels fit? 6 lug
  161. Front wheel hubs oozing grease
  162. flywheel
  163. Radio problems
  164. Need some quick info please.
  165. need help. checked EVERYTHING
  166. Seatbelt Buckle torx bolt question
  167. 1994 Dak MagV6 Won't Start, need advice
  168. plastic valance removal?
  169. Need serious HELP with my 94 dodge dakota (wont start)
  170. sorry newbish question please bare with me
  171. help with info on 92 dakota 5.2L 4x4 rear end
  172. Rear Cab Sliding Widow
  173. 96 3.9L Wont Start
  174. Another question. Motor swap
  175. Radio Removal
  176. Radiator Swap?
  177. 91 Dakota 3.9 Idle Issues
  178. After Market Shifter
  179. Complex HVAC question
  180. Dakota 3.9L injector problems, please help ASAP!
  181. 8.25
  182. truck acting weird?
  183. Humming sound at 40 mph +
  184. Rear diff question
  185. Smog Crap Removal?
  186. help my 93 dakota 4x4
  187. Center Console
  188. Overheating problem, need help
  189. rock or pressure plate?
  190. AC blows weak when I step on the gas...
  191. finally done with replacing the engine
  192. Radiator/Oil Cooler Line
  193. new here few questions :)
  194. tire question
  195. jeep seats
  196. How many sq ft of Dynamat to cover cab and doors?
  197. Ok So I'm new to the forum and need to ask the age old questions all over
  198. Mix and match questions.
  199. Mopar Lubricant Equivalent?
  200. 1995 Dodge Dakota - Throttle Body Question
  201. Fan not working, and I bet i know why.
  202. PLEASE help! code p0340
  203. oil pressure issue
  204. Trailmaster 3" body lift
  205. Look what came home with me today.
  206. Instrument Cluster swap from no Tach to with Tach (1st Gen)
  207. drum brake question
  208. trans hesitates when shifting under light throttle
  209. Weekend Pampering!
  210. Strange Whining-like noise when accelerating
  211. V-belts to Serp swap?
  212. Cruise Control - Steering Column Position
  213. Fastman Throttle Bodies
  214. Np231d
  215. New Member Question - Alternator?
  216. AC issues
  217. Timing issues (replaced Timing Belt and Tensioner)
  218. OMG saw a Lil' Red Express today!
  219. Strange running issues
  220. I'm clueless and needing help Pic included
  221. Strange Noise coming from under the Timing Belt Cover of my 95 4 cyl
  222. bed accesories
  223. Replacing Manual Door 95 Dodge Dakota SLT
  224. No Fire
  225. DTC 35 on 3.9L 1994 Dodge Dakota
  226. Where to find an Owners Manual for a 1995 Dakota online?
  227. dakota 360
  228. Need help with Electrical Issue..Please
  229. 95 4x4 Wheels and Tires question
  230. AC Experts!!
  231. i have the worst luck
  232. Transmission Leak - Cracked Case
  233. turn signal
  234. New Member/Dakota owner with a faulty Fuel Gage question.
  235. vibration
  236. new member with ignition problems (I think)
  237. Dash pads
  238. Tranny Wiring Question
  239. AC belt problem...
  240. Great articles!
  241. my engine rebuild thread
  242. JET Performance Module
  243. Performance Computer?
  244. pulling the engine
  245. brake problem
  246. Stupid Tailgate Question
  247. Fuel Gauge Problems
  248. 95 3.9L to 5.2L 46RE
  249. Pulsating Brakes
  250. found the issue with my dashlights...
