View Full Version : 1st Gen Dakota Tech
- Trouble with ABS and Shutoff
- anybody in the market for a kenne and bell?
- from a 6 to a 5 lug
- 6 wheel motor home dakota???
- VHT NightShades for tailights
- adjustable proportioning valve install
- Project Ideas?
- 1993 Dodge Dakota Engine Problems
- transmission temp gauge
- front brake question
- temp guage stopped working
- Manual Brakes.
- problem with my truck
- I need your vote!
- Couple of Problems
- Totm voting!
- Dodgey's Project (many pics)
- 88 Dakota-No headlights, no tail lights, no brake lights-help
- 96 Dakota starts and stalls when warm
- I have an emergency! Plz help
- changing diff fluids...need to know thursday at the absolute latests-thanks
- 96 Roaring after fan clutch replacment
- Fuel pump
- compression
- 89 4x4 blown 8.25 rear any easy swaps??
- Hi performance plug wires
- does anyone know where all the fusable links are in a 90's dak?
- 1994 dakota club cab speaker wires and radio
- Recall Question?
- need a fast responce... question about 9.25 axle swap
- Replacement Seat Belts
- help
- Fuel Gauge
- p/s rack seal
- Roll call! Post up Pics!!!
- How Hard is it to convert...
- Escapades of the Cursed Dakota
- stereo swap
- A.I.R. Pump
- 1991 Dak 3.9L wiring issue
- oxygen sensor
- DFW Dakota Meet Nov. 22nd at Hooters Denton, TX
- HELP!! 3.9 acting crazy
- Dakota section meet and greet?
- ac compressor
- 92' Dakota problems
- water pump and tensioner
- Recent pics & Recent problems
- Carburetor Vacuum Hose Diagram
- any truth behind these?
- box fitment
- Coolant Leak
- steering shaft u-joint is sloppy
- trans swap
- electrical connections?
- 1994 dakota replace cigarette lighter element and housing
- body lift issues?
- '98 V6 into '93 Dakota?
- 93 Dodge dakota, brake problems
- Fuel Pump Assembly to Tank Gasket
- home made posi trac?
- Audiovox Prestige aps-3
- 93 Dakota Transmission Problem?
- Anti Freeze Leak, can't find it
- fuel gauge always reads "E" and low fuel light is on
- Cursed truck giving me more grief....
- speed sensor
- 318 to 360 swap. 360 upgrades?
- Truck wont start
- Error Code 32
- smog pump?
- 3.9 fuel injected to 5.2 carb.
- Idle speed and emissions
- front differential drop
- engine swap from 95 dakota to a 93 3.9 v6 engines on both HELP!!
- Where to buy brake proportioning valve and master cylinder?
- '94 Dakota Interior
- 9.25 rear end swap
- 318 swap
- 93 Dakota Chugs Under Load
- 3.9 to 318 swaps???
- startup problems and shifting issues
- need help with durango rear end conversion
- 95 dodge dakota 3.9 v6 error code 27 help!
- truck does not stay running.
- 92 no heat
- 17" R/T wheels
- Unusual start and stop problem... Help would be appreciated
- Electrical Problems
- 95 Dakota - Mystery Problem
- 95 Dakota Fuel Gauge acting up....
- Finally!
- Rumble Bee??
- 3.9 to 5.9
- 93 dakota running problem
- Coolant Flow
- 95 dakota 2.5L start up issues
- starter replacement
- Ride of the Month is up!
- 87 4wd starter replacement
- What weight oil to run??
- '93 dakota 2.5 won't start, no fuel.
- v6 to v8 questions
- TBI Fuel Injector CC
- 180 Deg Thermostat
- engine problem for the pros...............help!!!!!
- Tow Hooks
- Am I worrying to much
- 91 dak fuse issue
- Street/Strip Fuel Pump question.
- Possessed truck doesn't run...
- '88 3.9 engine making a terrible noise
- Scored some wheels, now questions
- Dakota 4x4 Convertibles
- '93 V6 auto band adjustment
- Basic modification
- Dodge Dakota cruise control and truck not shifting gears
- outlandish supercharger question
- odd shifting when cold
- Cursed!
- 90 Window Replacement
- Truck won't start
- '92 V8 Dakota with Fuel Pump Issues :(
- coolant leak
- '94 cruise control
- Mopar Action Dak. 5.9 Swap "Pics"
- Need help with Frame Corrosion
- weird speedometer problem
- cold air intake
- update
- Squealing drive belt. Tried Everything!
- Finally got it going right
- 93 5.2L towing?
- 1994 dodge dakota lacks power
- Cheep lift!
- 90 Dakota with no power distribution center?
- Auto trans problem
- computer question
- need some quick advice easy....
- easiest way to get to the wiper mechanism
- No spark, no fuel
- transmissions for 318s... need help
- 90 Dakota dies for seemingly no reason
- coolant mixing with oil
- 92 dakota 3.9l oil pressure light
- Please weigh in with your opinion
- Low rpm bog
- Mystry grinding noise when turning left
- Engine Swap Info
- Dual shock kit
- 93 won`t run
- bought a 318 for the dak
- engine runs hot
- return to the forums
- More laughs
- 89 dakota 3.9 error code 36
- Trans Swap 1993 Dakota
- rebuild your 4x4 wheel bearings
- buring oil?
- Need a good laugh?
- wiring help
- question
- Current problems (starter & wiring)
- 3.9 mpg's
- years that will fit 93 dak 318 swap engine
- Used Computer programming ???
- 1988 dak. runs rough before warmup
- Emissions?
- 96 dakota caliper pins
- trans options
- Ignition coil
- proper 2 inch lift
- What would be the odd of this happening?
- coil over?
- Just bought
- Sparkless
- 3.9 to 5.9 in Mopar Muscle Mag.
- towing
- Timing Chain vs. Gear Drive?
- 1991 Dak 3.9L back firing?
- synthetic oil/leak
- 4x4 wont engage
- 200,000
- need advice.....!!!!
- Power window/lock swap! HELP!
- speed sensor
- timing cover issues
- 92/v8 tach?
- not moving
- Does replacing ECU require VIN burned into new one
- Why I Disappeared.
- running problem
- '92 Dakota starting problem
- Problem getting new engine in my 93 dak 4x4
- gas hand
- 95 Dak automatic
- 95 question...
- Dual Exhaust or cat back on dakota?
- brakes
- cab swap to 2nd gen
- 4wd front driveshaft
- Rear brakes locking!
- Inner tie rod replacement on 1990 Dakota?
- Starter problems?
- towing question
- Selling motor mounts to put pre 92 v8 in dakotas
- low fuel light ?
- 1995 Dakota Interior Trim
- maintenence light
- 1993 dodge dakota problem
- Comp cams Thumper cams
- Bed Lining
- 1994 dakota 2x4 axle flip , what needs to be changed?
- No start, no spark, plus braking issue
- Is there a four barrel conversion for my 3.9L 2 barrel
- Driver's outside door handle quit - advice please?
- DF Video!
- 1992 dakota fuse ?
- Put a 87 rear end into a 89 dakota
- torsion bar preload
- F. Brakes locked up
- Help help help!!! Proportioning valve issues
- Lifter knocking question
- Durango 9.25 swap?
- 92/v8 starting issue?
- cat, replacement or a muffler in its place?
- my uncle's 340
- 1989 Dakota V6 Missing/Hesitation
- Moving SALE!!!
- Problem with my 4x4...
- Need help finding baja fenders......
- Near disaster with '90 steering gear detachment from frame
- Height sensing proportioning valve
- 87 indy 500 dakota
- tranny service? whaa
- Tranfer case swap
- 95 Dakota with a host of issues
- running crappy
- 1993 Dodge Dakota Please Help?
- bought another dak, 89 trans problem
- Rear end swap. 95 in a 89. yoke too big
- Oxygen sensor Question and Ac/ Heating Question
- help with an engine swap.
- Trany problems
- installed new computer,fixed charging problem
- what axles
- carberator adjustment tool
- front differential problems again
- new wheels
