View Full Version : 1st Gen Dakota Tech
- Just another NV4500 swap
- truck started on fire
- filling grooves on caliper brackets with weld???
- Smog pump/Emission system
- So I'm looking for fender flares
- A998 Output shaft support
- Air pump pulley sticking out? Only thing preventing me from getting running.
- Rear bearing replacement?
- 93 dakota/s ABS and P-brake on
- Edelbrock/HughesIntake manifold replacement
- Driver's side exhaust glowing cherry red
- 1988 fuel pump quit
- blower motor not running
- The Repaint of my 92 Dodge Dakota.
- 92 dakota grinding noise
- About to roll it down a hill
- Engine cut out at speed. Backfiring?
- Shifter cover removel ??
- outcome of 15X8rims and 33X14R15 TSL Boggers and pics
- 1987 3.9 carb swap
- EGR code
- Let's Talk Cab Bushings.
- What engine should I get
- Dodge 10000 day Calendar
- 96 new fuel pump-wiring?
- rim question
- 87 Dakota Tranny numbers
- drivetrain question
- dead spot in the fuel pump?
- 1988 3.9 Pilot Bearing HELP!!
- Check Engine light question
- The Elusive 92/93 V6 MOPAR Performance PCM
- Quick rad question
- Idle issues
- holley 4150 throttle/kickdown bracket help
- Brake & ABS Light Flashing?
- Heater core
- how to remove the rear driveshaft
- Florida truck=no rust but lost of dry rot.(my to-do list)
- One Crazy Idea.
- trany question
- 3.9 to 5.9
- New tire time.
- crazy lights
- Dakota 1996 318 magnum head-swap?
- Special tools for timing belt & rear oil seal
- cat question
- Differential interchange
- 1994 Dakota Brake Problem
- 87 Dak with High Idle at StartUp......
- Won't Start Cold Only When Warm Out
- Why do factory radios blow?
- Rare Dakota motorhome?
- 1992 dakota water pump leaks
- 3.9 la to 3.9 magnum swap
- Shift indicator linkage
- new(to me) pcm gave up the ghost?
- More no-start madness
- LA 3.9 Modifications?s
- control arm bushing kit 92 Dakota 4WD
- Intermitant wipers
- Need help reading this code (video)
- Where does this wire connect? (pics)
- Manual Transmission fluid?
- squeeking from tranny problem! help!
- The dreaded solder joint!!! Please send me a link
- 94 v8 lights?
- '90 Dakota ASD Relay
- tie rod Q's
- no signals?
- Just installed an M1 and a Fastman, what a difference
- Dakota plow setup
- my new dakota
- Time to Purchase a Fuel Module Assembly
- 1992 Dakota steering column cover
- the debate ....
- new alternator and regulator.
- 96 3.9 Dakota transfer case
- Thinking about an R/T
- what tires should i get in the snow?
- Voltage Regulator
- No spark
- 1992 Dodge Dakota V8 5.2L Auto Transmission,started drove some and then it went dead!
- New dakota
- Barely runs, backfires constantly
- New Dodge owner - what do I need to know about my truck?
- 3.9 v6 to a 5.9 Cummins?
- Oil exploded in bed :(
- 1994 cruise control switch
- What carb should i get
- ABS control module '92 Dak 4x4
- Do I need spacers?
- 92 dakota v8 4x4 shifting weird
- Ways to lower 96 dakota
- Tranny TV cable?
- 93 dak v6 needs better mpg
- 1995 Dakota Clunking
- Please help
- 92 dakota 5.9 4x4 shifting weird
- Dodge Dekota
- Planning on swapping in a 5.2L to my 91 dak
- do i have a carb issue?
- Blacks sporty mirrors or big chromed?
- 95 jeep grande charokee coil springs ona 95 dakota?
- Wont start :\
- owner
- truck Not up-shifting if driven for long periods
- 93 dakota acceleration issues
- New head light issue
- '96 Dodge Dakota Overhaul
- 95 flex plate
- Bucket seats/stalling problem
- alternator engine mount broken!
- Locks for my fuel door?
- 94 dodge dakota
- Transmission help - no Drive, burnt smell
- 1993 Dakota Won't start in the morning.
- anyone have all data?
- A/C Drain, where is it?
- 4WD Vacuum Hose Routing
- 96 Dak, 4cyl, OHV starter replacement (giving a little back I hope)
- Starter replacement??? Killing me
- off Road Dakotas
- how do you change disc brakes?
- 94 Dakota 3.9 bolt sizes please help.
- '91 Dakota, 2.5L
- Brake Proportioning Valve?
- 93 Dakota idles rough
- Trying My Hand at a Little Bodywork
- Iac?
- Rubber, Aluminum, Steel or Polyurethane?
- simple question
- no blower motor!
- 1991? Dodge Dakota V8
- Dome light wont turn off?
- Power steering bracket hitting steering box
- NV3500 4WD trans mount?
- Extremely High Idle - Wants to keep going!!
- 91 Oil pressure question
- Gas in the Oil?
- Distributor Indexing/Timing?
- Tie Rod End Replacement
- 1994 Dodge Dakota Scotty--Any Issues?
- Control arms do not pivot
- Performance/Visual upgrade ideas?
- Foglight Bulb Question
- Any one have a modded interior?
- Worn Throttle Rod Swivel
- bed bar question
- 94 Fuel pump issues
- best exhaust for a 87
- Ahooooooga Horn
- auto to manual swap questions
- Crazy4x4... the pictures i said i would find you :O
- 35 inch tires?
- 95 Dakota Headlight Short
- Time to say goodbye as a moderator
- LA 360 swap in 88 dakota
- Oil Sensor Question
- Help me fix my 87 dakota
- A727 transmission pre-1978 on Magnum 360
- will a 93 dakota 6cyl trans fit a 96 6cyl dakota?
- results of a v8 tb swap onto a v6
- 1993 Dakota no fuel, no spark, lots of clicking
- 1987 dodge dakota carb issue
- First 1-2 Shift "Hangs" When Cold
- 93 Dak 5.2 CTS and PCM help?
- Cooler Line
- Learned something new yesterday.
- big plans
- New guy pica 1990
- Head lights & signal.
- Interested in where to find bucket seats
- My new truck!
- Fantastic site!!
- 95 RWD AUTO 5.2 starting issue
- New purchase - 1996 Dodge Dakota
- 92 dakota problem
- 94 3.9 new to me
- 3 inch lift w/ 32" tires?
- Won't Start When Cold
- Trying to remove torsion bars
- Heat and gauge problems
- 6cyl pcms connectors?
- Electric window dragging
- 94 dakota transmission leak by transfer case
- 160 degree thermostat
- 1994 3.9 V6 Dakota
- Secret PCM Unlock code????
- 1989 Dodge Dakota Convertible, what to pay?
- Rear brake hose.
- No Crank Condition
- 1996 Dakota running problems
- 93 dakota brake bleeding issue
- 1987 3.9 4x4 Starter Bolts
- Front wheel rotor stuck to hub
- Air Dam Question
- Need help with transmission lines and part numbers
- Blend Door Question
- quick release steering wheel
- AX15 Trans
- Aftermarket fender flares ?
- What glue should I use for the side strips?
- 1990 Dakota Speed control Solenoid circuits
- Electrical problems 90 dak 3.9 (pics)
- Magnum V10 in a 1993 Dakota?
- 5.9 Intake
- Overcharging repaired!
- Still won't start; new fuel pump
- Lifting truck need opinions
- 1996 Dakota 2.5 performance questions
- engine swap
- shredded tire off of rim
- Steering Box Recall?
- tailgate
- Intake Manifold Gasket?
- steering gear removal
- fusible links?
- Pour-in urethane for motor mounts
- Test/Tune Convertible Dakota
- 1st gen dakota suspension lift
- Fuel gauge
- Overcharging still
- Missing a little
- Upper ball joints on trail master lift
- Weak Brake Booster Upgrade?
- Wire diagrams
- Overcharging
- Drifting
- Steering Coupler - '89 Dakota
- Wiper Linkage
- Question on supports above headliner
- 5.2l tb on 3.9l install
- Polishing egal alloys
- 94 dakota 5.2 engine shutter
- Fuel Pump Petered?
- 1992 dakota fuel lines
- New 90 Vert Owner - Engine Swap
- the case of the mystery coolant leak
- Top dollar headlight bulbs. Are they worth it?
- Getting clear parking lights have a few Q's
- 94 Dodge Dakota Sport 4WD
- Dakota starts runs great for about 20-30 seconds then slowly dies
- Dual cold air intake?
- 96 dodge dakota rear axle
- Damaged rear diff question
- motor mount issues ????
- valve gaskets,intake gasket 3.9
- 1990 Dakota - No Spark or power at coil
