PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Hissing sound behind Dash
  2. Wiper arms came off from wiper motor
  3. Tachometer issues
  4. Help, fan and heat stopped blowing
  5. My Cab Shifted On Frame!
  6. Incase you guys wondered what our trucks looked like with Xterra 16's
  7. Upper Control Arm Mount
  8. Burning Oil at cold start
  9. Car looses acceleration and sputters when I turn the AC on
  10. a500
  11. Park/Neutral. Difference?
  12. interference or non-interference
  13. 89 Dakota v8 swap questions
  14. Octane booster
  15. Something broke and now won't start
  16. Help 95 Dodge Dakota V8 surging while driving
  17. Window weather stripping
  18. 89 dakota 3.9L horrible MPG
  19. 91 318 low throttle chuggg feeling
  20. NV4500 swap discussion thread. PICS!!
  21. Fuel check valve install
  22. Grill Swap
  23. Oil Filter Part Numbers
  24. no start on 89 sport
  25. maint reqd
  26. Odd oil problem
  27. wheel speed sensor
  28. Off-Road Bumper Design
  29. 96 dakota 3.9 Cant get pased 4k
  30. 1991 2.5 Becomes very sluggish/dies if given barely any gas[Video]
  31. High Idle After Sitting For A Day
  32. intermittant od issue
  33. 94 dakota stalls out when hot outside
  34. Ground Problem!
  35. New Dakota front end question.
  36. Afraid to Drive the Truck
  37. Temp gauge and 180 Thermostat
  38. Complete Brake Job - Need Pad, Rotor & Caliper Recommendation Please
  39. Engine swap
  40. New member to site and looking for help
  41. 1991 dakota sale
  42. Cummins 4bt swaps?
  43. 4lo problem
  44. 96 Dakota brake failure when vehicle is on
  45. Torque on Lug nuts??
  46. Beginning the paint job/Few odd Projects
  47. 92 Dodge Dakota V6 starting problems
  48. White Face Gauges
  49. Another adventure with my Dakota
  50. Need help locating part for 2.5. steel coolant line/hose that runs behind head! ?
  51. Help! randomly dies out.
  52. fuse diagram 95 dakota sport
  53. new head liner installed
  54. door panel/speaker removal
  55. gas gauge/fuel pressure problem help!
  56. Mopar PCM
  57. Starting issues. So far will start after 2-4 turn-key attempts.
  58. Will 2nd gen dak seats fit in my 1st gen dak?
  59. Holley TBI ???
  60. Talking to a friend
  61. A/c r12 ?
  62. Hey! Me and my 95 Dakota
  63. Need Some AC Specs.
  64. durango dakota compatability
  65. biggest tires on a stock 1st gen dakota
  66. Limited Slip Options
  67. My '94 keeps dying. Does anyone know why?
  68. ac removal
  69. Junkyard Compatibility
  70. 89 Dakota Shelby Tranny Q's
  71. Ammo can center console/lockbox write up
  72. Air Intake Temp Sensor issues
  73. drilling into the trans tunnel
  74. 1991 Dodge Dakota not staying running
  75. trans swap
  76. 96 with a bunch of stuff happening
  77. lighting problems
  78. No brake lights or turn lights
  79. Great Tire Deal. Help needed quick!!!
  80. 92' Problem with gauges
  81. Clutch position switch
  82. Hockey Puck Body Lift How-To
  83. Trans replacement?
  84. 3.9L performance upgrade help
  85. Bad Idling issues and MPG
  86. transmission
  87. Really hard brake pedal.
  88. Does my Dakota have trailer wires?
  89. stuck in gear
  90. Clear Headlights
  91. Spare Keys: Door vs Ignition
  92. 93, 318 "LE" CC project
  93. Tire Financing and Durango Rims
  94. what type of motor
  95. Painting chrome
  96. headliner
  97. The Beginning
  98. 4x4 issues
  99. 95 4x4 caster/camber
  100. Air Filter
  101. Leaf Springs: Broken Clips?
  102. wiring harness and cluster?
  103. DIY Auto tranny fluid flush
  104. My dak has to go see the shop :(
  105. 89 3.9 Auto 2WD wont shift from 1st into 2nd
  106. Idling Problems in R & D Only
  107. Daily driver/ fuel eco-box need help
  108. A/C bypass pulley
  109. Gen II mirrors on a Gen !
  110. Idle Air Control Problem? [VIDEO]
  111. best shocks for a 2 inch lift?
  112. New owner Dakota with some progress/issues
  113. 4x4 steering gear box 87-88
  114. 89 dakota alternator
  115. Bad PCM? No idle
  116. 1992 Dakota not shifting into OD
  117. 2.5l burning oil
  118. Electrical problem
  119. dimmer switch update
  120. Bosch 15704 Oxygen Sensor
  121. Fuel Filter
  122. stumbling, shuddering and misfiring
  123. Transmission issues?
  124. 95 318 surge at full throttle
  125. 88 4x4 with a999 AT
  126. WHat shocks are you all using?
  127. 92 Dakota - Work In Progress Pics
  128. 93 Dodge Dakota Transmission info request
  129. Np231 transfer case chain
  130. Idling Forward?
  131. 93 Dakota tranny help
  132. Tranny options
  133. light bar good deal?
  134. Intake Question
  135. k&n replacement housing kit question
  136. Max Cooling System
  137. Fuel pump access
  138. Intake Belly pan 3.9
  139. my 92 4x4 318 Dak
  140. bolt ons?
  141. Is there a driver's side courtesy light? If so where?
  142. truck update and ???
  143. driving me nuts
  144. wire diagram. elc. fan
  145. new look to my slt
  146. 1993 dodge dakota erratic idle 5.2 318
  147. The search for small rims
  148. 1990 2wd 3.9 v6 Build Thread
  149. 87 Dakota WILL NOT IDLE
  150. few questions
  151. Do I have Keyless Entry?
  152. bucket seat install
  153. seafoam on 3.9
  154. dash lights wont cut off
  155. skipping at high rpm?
  156. Possible 4BT swap
  157. Exhaust Y-Pipe
  158. Aftermarket Stereo/Head Unit Help, What works, pics?
  159. Code 32 trouble
  160. transfer case question
  161. 92 Dakota v6 5spd won't crank over
  162. 95 dakota with dead miss ..
  163. Tire recommendations?
  164. No Heat
  165. No oil pressure again
  166. This for all of you people who need to do a swap and no one on this site could help!!
  167. Timing question
  168. rpm gauge
  169. New Paint and Bedliner
  170. Sensors
  171. Replacement V8 Coil Springs
  172. Where is the plug for the odb scanner?
  173. Help picking HID lights please
  174. underdrive pulleys
  175. 1993 Dakota, 3.9L V6 Horrible Gas Mileage
  176. 95 2.5l Overheating
  177. A/C question.
  178. Questions about body parts
  179. No Reverse lights, NV3500 trans
  180. Future Reference
  181. new to the forum. new and improved with pics
  182. Bolt ons?
  183. A/C Compressor Clutch not engaging...Videos included
  184. Transmission slip/Loss of power
  185. Linkage
  186. Shifting and Overdrive issue
  187. how to clean fuel injectors?
  188. White Face Gauges
  189. need brake help
  190. Opinions?
  191. Throttle body conundrum
  192. 92 dakota 3.9 no start sort of........
  193. 1993 Dakota 2wd V6
  194. 88 dakota a/c question
  195. Intermittent misfire/power loss
  196. Gas Gauge Sampling Intervals?
  197. body lift installed, now issues putting in park
  198. Question About Dodge Dakota 95 speedometer?
  199. All things point to PCM
  200. V6 intake manifold wanted
  201. recent wiring problems
  202. 1996 Dodge Dakota
  203. Distributor help
  204. 98 Dakota 5 speed conversion flywheel sensor issue
  205. Am I running too rich?
  206. Automatic Transmission
  207. nv231 front output needle (pilot) bearing.
  208. Body question
  209. need help on tach install
  210. I think i need a fuel pump
  211. 2wd Auto to Solid axle 4x4 manual Questions
  212. body fillers or body gruads.
  213. "Lift" questions, Equal heights and shocks...
  214. struggling with rear brakes...
  215. New 1st Gen Dokota owner + Questions & Problems
  216. Putting on a carb?
  217. 94 Dakota tranny with t-case
  218. Fixed my transmission linkage and starter
  219. Moving Threads
  220. 1987 Carburated 3.9L running real rough, SOMETIMES..
  221. tranny problems!
  222. Swap options
  223. Auto tranny pan removal
  224. mopar pcm vs jet stage 2 / towing
  225. curiosity questions
  226. Ride of the Month! Vote Now!
  227. t case problems
  228. Idling Problems and Transmission Issues 94 Dakota
  229. Sway bar opinions please
  230. 5 Spd. shift light question?
  231. trouble codes
  232. High idle at startup
  233. Need help with OBD code 15 on 1991 Dakota
  234. 1993 Dakota 4x4 Problem
  235. installing an aftermarket tach
  236. Temp spikes & Fluctuations - heater/flow/hose diagarm 2.5?
  237. No Tail Running lights
  238. gear ratio!
  239. Decal Idea?
  240. Transmission issue?
  241. engine swap, OBDI to OBD II question
  242. ROTM Voting and Nominations!
  243. 1987 DAKOTA EGR Light on
  244. Limited slip differential?
  245. Gauge Help
  246. One Dim headlight...
  247. Door wont open
  248. Getting ready for 360 swap 94 v6 dakota
  249. Lift question
  250. Over Head Console Install
