- Alternator question....
- Still not quite right....
- Check out this 1st gen
- ECM mixed with water ?
- Ignition Still not Right??
- Looking for Advice - 1991 Dakota
- Tire choices
- Propane tanks.
- Torsion Keys
- Roll Over Valve
- Newbie Intro and Question
- 93 dakota sport selling price
- Nv4500 thread
- Skid Plates!
- 1991 v6 dakota manual transmisson problems
- EGR cleaning
- seat options
- Scary run
- Bobbing fuel gauge.....HELP!!!!
- 95 won't start. Please help.
- differential lube
- 89 dodge dakota leaks
- Power windows won't work!
- 87 Dak, clutch wont' disengage
- factory pcm question
- Another harness question....
- v6 performance options.... and leveling kit options
- Wooo hooooo
- performance chips
- Need Opinions for bent frame options...
- 1994 dakota 3.9 fan clutch
- 1995 seats
- Early opinion info....
- 1996 fuel pump elec. plug.
- Contradicting info on 94 Dakota Trans interchange
- Another question....
- Benefit of Electric Fan
- What will it cost to replace brake lines on '94 SLT?
- Ok...
- Rear Shocks...
- Need help with 96 dakota stuck in 4W drive
- Need rear suspension opinions...
- Three Codes
- 1996 v6
- Front end alignment cost '94 ?
- Power locks wont work
- PS fluid....
- Stereo questions
- transmission trouble
- coolant temps with electric fans
- Tranny Problem
- Rear Differential Oil Change
- Fuel mileage and Performance chips
- How to "safely and correctly" remove and install a brake booster
- Truck sporatically loses power and dies
- Rust Prevention
- Need answer quick!!!!
- My Official 2wd Build Thread
- 3/4 ton difs
- questions...NON-Magnum...
- Redline?
- Clutch question
- need some help as usual
- Bad tranny how to remove
- R/T Wheels and Tires
- transmission temp guages
- Manual Transmission
- Leak & Swaybar swaybar questions
- Symptoms of bad PCM?
- 2000 Dodge Dakota Seats
- Welp....
- 1990 dakota lifts.
- Might buy a 92 Dakota, are they reliable?
- Blinker Gremlin
- New Caliper
- 1996 5.2 Dakota Trans. Problem
- For all of those that are wondering...
- Idle Problem
- take a look
- flex plate issues
- 3.9 or 5.2 Which way to go.
- ECU Error Code 41....
- door lock problem
- stroking
- Keyless Entry
- 1gen Dakota body kit
- Dakota of the Month!! VOTE!!
- Bumps 1 gen Dakota Build up
- Looking to buy - need quick answers....
- excessive steering play
- EVAP System ?
- something i haven't seen any talk about...
- Bumper question
- Dana 70 VS corp 8.25
- Custom Stereo
- anyone ever swap to a diesel?
- Need a favor
- '91 V8 Dakota 4x4 Tranny??
- part hunt
- Engine almost out!!!
- 1996 5.2 Dakota No Fuel Pressure
- Tranny cooler
- Brake Squeal
- bad bad news
- Sirius antenna installation suggestions 95 Reg Cab
- Performance parts
- need help
- !992 Transmission
- 92 dakota no power to starter relay
- ABS and Brake Dashboard lights stay on
- Anyone ever rebuild an auto tranny?
- Help me decide what drop height
- you know what grinds my gears
- 20 inch dodge ram wheels
- 92 dakota wont crank.
- 42RH behind a 5.2L magnum?
- OBD meters not getting readings
- 1995 dakota starting issues...
- Sept DOTM
- 91 Dakota Clutch safety switch
- lift??
- 1992 dakota,rack and pinion seal?
- 1/4" spacers for my new rims?
- Help! Fluid leaking into the cab of my Dakota
- Junkyard 5.2L
- 92 Dakota "High school project truck" questions...LOTS OF EM!
- '94 fuel filter
- Ball joint woes...
- 1992 Dakaota Low Beams don't work
- Roll bar compatability
- Little help for a newbie
- possibly a short?
- Nv244?
- Hesitation and stalling
- local craigslist find
- 90 3.9L 2wd dakota needs help
- needing parts to fix my dodge
- Brake Smoke??
- Dakota Of The Month September!
- Motor Question
- 2wd lift and locker options???
- Is a body lift somewhat universal?
- Lower Class Club
- Transmission died again!
- lift a 91 4x4
- Help with Gear shift
- Buying from ebay overseas (China, etc)
- Nice find.
- Posi or not?
- Non dodge question....help please
- engine pics please and no spark
- What Just Happened?
- lookin for an exhaust
- What do you guys think?
- 31" Treadwright ATB's
- 90 dakota idle problem
- Dak no spark, hall & crank no help
- hey guys need help
- 96' dak idler pully change help
- 93 Dakota 5.2L high idle
- New Engine
- R/T Rims and Tires
- 3.9 interchange question
- V6 - Another Rough Idle Issue
- exhaust question
- Porting And Polishing Heads
- Dual gas tanks?
- Guages
- Throttle body porting
- Body Lift question
- Gas Gauge Fix
- Afternoon Project
- Going to sell my V6 PCM
- 4x4 tailhouseing
- turn signal lever?
- Anyone need spare parts
- Removing EGR valve for good
- Babe the Big Black Ox
- Dakota - no headlights (fuse)
- DOTM Poll
- Custom interior
- torque converters
- Another new guy - puzzling start to '95 3.9L Auto
- sensor in distributor 91 dak
- floor shift autos
- 1994 dodge dakota no spark
- Help! My stupid radio, and stuff.
- Us 4.7 guys need help!
- '94 front end alignment question
- top end rebuild. now heater core problems
- My build thread
- fixing the headliner
- Column Shift Z Bar
- Tire question
- 3.9 hesitating/stalling at very low throttle
- Cut fenders
- 1992 dakota console ?
- 1992 dakota tranny line ?
- High Idle issue - HELP
- tranny fluid question..
- my baby finnaly laid down on me 318 guys unite on this one....!!!!
- got my 90 dakota running
- Vapour Lock?
- Dimensions???
- New guy here. Possibly purchasing a 1st Gen 5.2
- Mouse Versus Wiring
- Things to do while tranny/axle out
- Lift i found
- CEL trouble codes?
- 95 5.2L lack of power
- Truck heats up
- What happens when your truck sneezes.
- Swapping Motors on 87 Dakota
- V8 transmission problem
- EGR Problem? Help
- Promblem!!!!
- Reese receiver pin lock.
- pics
- hard starting after use
- Body Lift and Torsion Crank questions
- help 4 a new dakota owner
- Underdrive pulleys?????
- My v6 3.9 swap to 318
- Something different
- The death of a dodge
- Doesn't start after going in water
- help
- Late model half shafts in 1st gen
- burnt up erg valve question???
- Motor swaptions...
- A/C not working :(
- 1995 Dakota wiper arms
- picture whore :)
- dakota of the month!!! Now Vote!!
- body lift- steering rod extension?
- Some performance mods. Need some help.
- Fuel Gauge Problem
- Emergency! Electrical help needed.
- Brake upgrade?
- 1st gen to second gen engine swap
- Anyone else have similar issues? Popping, sputtering, stalling
- Squeaky ball joint
- ******* transmission spewing oil - unknown location
- Tires!!! ugh.....
- 1st truck...
- Where to buy
- Quick help please
- 90tbfi 3.9l v6 to 93mpfi 3.9l v6
- quick rad question - 97 to 95?
