View Full Version : 1st Gen Dakota Tech
- Power Steering
- wheels
- I've searched everywhere!
- 94 dakota w/blown motor
- Needed gear ratio for 1996 Dakota transfer case...
- Axles and the such
- rear-end woes
- another headlight ?
- P1391
- Proper plastic paint prep?
- Making headlights new again
- New K&N
- more power
- Paint project - input needed
- installed cd player. now no interior lights
- Turn Signals,Brake Lights & Hazards not working
- Fault Code 32 - EGR Related
- chips
- Best dual exhaust?
- Rear Brake Line
- inside Fuel tank
- ABS system
- headlight 90 dak question
- Fuse Panel
- Fues Panel Diagram 1992 Dodge Dakota
- fiberglass fenders
- 1992 3.9L parts for sales, becuase of upgrade
- mandatory insurance y or n
- project?
- diesel dakota ?
- what size tires?
- PCM
- What is the likelyhood.......
- No Heater Blower
- 1991 Powertrain Slippage
- Truck will move 4 feet then dies
- Tourque rating on the 238(3.9L) LA v6
- possible?
- Diagnostic units for a 1995 Dodge dakota
- and a 1st gen dakota sportUmmm Help?
- POSI?
- HEADUNIT QUESTION?
- 94 transmission question.
- How To: Heater Core Flush
- Will the stock computer work
- engines
- Needed help with clunking noise while in 4WD
- Heater core replacement
- parts
- hello everyone
- Noise in 96 4x4 dak please help
- heater
- computers
- i have a 1990 dodge dakota need help
- MAJOR HEAT PROBLEMS!
- starter relay?
- Front coil springs different?
- 4x4 Wont engage
- radiator cap
- Maint Reqired light
- siphoning gas tank on 95 Dakota
- quick 2"lift for a 94 4x4 dakota???
- Voltage and Transmission Problems?
- custom door panels
- Vin decoder and alignment
- FS dodge dakota 92 v6
- temp gauge
- ABS and Brake light on
- 96 Dakota 2WD Upper Ball Joint removal tips
- Some Lights On My Dash Stay On???
- '93 Speedometer quit, but mileage works...
- '91 Dakota 3.9L - NO SPARK (Please help)
- will the 97 - 00 wheels fit my 92 dakota 4x4
- Dakota Forums
- power window motors
- starter problems
- performance question
- Some Interior Questions
- 92 dakota heating problem
- radio installation
- 1989 Trans problem
- standard thermostat
- What type of Rear Differential?
- Dodge Dakota 4sale
- Dash lights not working
- Headlights not coming on.... Help!
- Gorilla Chipz
- Dakota for Sale on Ebay
- I have a 94 Dakota for sale
- new headache
- got free 92 5.2 dakota!
- MOVED: lultra low sulfer diesel
- what tranny Do I have?
- check engine light won't flash??
- drivetrain swap
- Fuel Tank Size
- Transmission mount
- Fuel pump issue
- transmission question
- big block dakota swap
- rack and pinion install
- 1991 Dakota 4x4 Transmission issues
- '95 dakota - how much lift from rear axle flip
- Ign Timing
- 15 or 22 gallon tank?
- trim levels
- Coil
- Subs in '95
- Engine swaps
- How to? Water Pump removal 97 3.9L V6
- First Gen 4x4 vacumn question
- Transmission Diagram (In Need Of)
- throttle body swap
- Fuel Injector Problem?
- 360 in a first gen dak.
- 88 vacuum hose
- Steering is loose...
- 1st gen on ebay
- headliner removal
- Dakota purchase tale of woe
- Emergency brakes stuck on
- 1995 Dakota Fuse Panel Diagram
- Brake Pedal Just stays on the Floor?
- 92 Kota - 5.2L - Trans Problems
- heater question
- how fast can you drive in 4 wheel high
- Looking to buy...
- stock ride height of a 92 4x4
- Rear Brake Line Length
- water pump
- torsion bars on my 92 4x4
- lift kits on ebay
- Dak 46RH
- Problem with wipers...
- PLZ NEED HELP FAST
- automatic to manual switch
- chrome rear bumper for roll pan
- Code 52 i believe?
- 31 - 10.50 x 15 on stock 92 4x4
- how big of tires can I put on my stock 95 4x4 dakota?
- wiring harness for a 318
- heater controls
- clutch master cylinder replacement PLEASE HELP
- Dakota Fuel Problem Please Help!!!
- what connection is this?
- Shaking
- Clutch Replacement
- manual trans fluid type?
- no hot air??
- A few questions
- More Brake Light/ Turn Signal Issues- HELP!
- Some opinions please
- easy way to gain some Dakota height?
- 1st gen low riders?
- 1995 Dakota 4cyl timing?
- MOVED: New here, almost bought 1st gen CTD!!!!!!!!
- Rusty cracked steering shaft, help please
- Installing Aftermarket Speakers
- Lift Kit
- Problems with '91 dakota
- motor swap ???
- foggy plexi glass
- pics of my $1 '89
- Am i asking to much?
- how many wiring harnesses are there?
- lookin for rolling chassis
- i want to post pics but can't?
- 93 Dakota Sport problems!!
- Poor performance after 1/2 tank
- Complete tranny fluid drain and change
- Need More Cold Air
- New B with oil pressure ?
- Where Is The Ignition Relay??
- Goodbye to a good truck.
- Serpentine belt tensioner
- what's the point of overdrive?
- 96 side mirror(s) conversion to power mirrors
- rack and pinion leak
- do you use any additives
- where is the fuel pump relay?
- 89 Dodge Dakota 3.9 Throttle Body Injection......
- 95 Dakota power door locks wont work
- 95 blower fix
- acceleration hesitation solved! WOOHOO
- heater problems
- Trans control cable
- Heater Control Light
- new problem with the "mystery machine" AKA 89' dak
- downshift problem
- radio in my 95 dakota wont play music or show the clock
- Good sounding exhauts?
- 89' v-6.....14mpg????? what gives?
- Few q's about my 92 dakota
- 95 dakota sunroof troubleshooting
- buddy needs help w/power steer pump
- wiring diagrams For Dakota 1987
- stearing problems
- tranny trouble!
- Coil spring interchange 2000 to 95
- Price check? 1990 3.9
- 73 truck headers
- Power/speed chip
- 96 Radio
- 360 swap problems
- what the...?
- 95 Dakota 2wd Lift Options
- Whats it worth
- New Owner
- 1993 Dakota Fuel Pump Problems
- Fuel pump electrical issue
- 96 dakota
- is my motor done for?????????
- I finally have my brakes fixed
- 95 4x4 catalytic converter replacement
- 95 4x4 starting issue
- Timing is 180 off, how do I fix it?
- v6 to v8 thottle body swap--idle problems
- 4wd front wheel bearings?
- tranny swap from 92 to 89?
- No brake lights
- Chrysler 8.25 oil etc
- 2 part oil filter ??
- Mopar HiPo Computer
- MOVED: 2005 dodge dakota
- might by new truck please help
- Midas Hp stainless welded muffler
- '93 Dakota, want to install 2" body lift, soon!
- will a 97 dakota transmission fit on a 93
- rough idle, sluggish when warm
- help after water pump install
- The Force is strong with this one!
- Clunk sound?
- Idle Problem
- idle problem
- Air Bag Light on,compass/temp out. 1995
- Infamous wire corrosion,No Start.
- Power Door Lock Install
- Dont you just love it..
- 89 4x4 m/t jerky acceleration
- 92 Transmission
- newby seeking help for 1988
- 88 Dakota blower motor resistor
- losing oil pressure
- speed&abs senor
- Tstat gasket
- instrument light rheostat
- oil pressure
- 95 dakota 318 cuts out at 3100 rpm's
