View Full Version : 1st Gen Dakota Tech
- Actron 9110 error message
- 1996 Dakota problem
- Trailmaster 4" lift kit knuckle/spindle gusset/extension
- Kill Switch Issue
- Just getting broken in
- 1990 Dakota Steering Knuckle (Front Left)
- 89 dodge dakota convertible upgrades
- 1996 5.2 Cranks, but fails to start
- 1996 dodge dakota 5.2 slt 2 wd
- Possibility???
- 408 in 1996 Dakota
- No spark from coil.
- Will whoever sent me the screwup fairy ..
- Fuel pump voltage issue
- Instrument Cluster Upgrade
- Steering intermediate shaft
- 95 Ball Joints
- SAE vs Metric
- Appliqué retainer clips 4357173 32743
- Wheel Stud Replacement
- Odometer
- Suspension Plus
- Fuel tank issues
- 89 dakota crank no start, please help
- Bent Rear Bumper
- Differential pin
- Driveshaft U-Joints
- Fuel pump connection
- 1987 wheel opening molding
- Ignition wiring
- Brakes
- Help I need some advice.
- 1995 Dodge Dakota 4x4 Sport, Control Arm Bushings!
- Wiring Diagram
- no start with key
- La swap in 87 dakota
- 91 Dakota head scratcher
- 95 dakota stake pocket are smaller than most
- After market sensor
- Brake pedal rod too short
- 1st gen Dodge Dakota Parking Brake Cable Coupler
- Trans/Extension housing part
- Rough Idle, Stumbling, & Stalling After Head & Intake Manifold Gasket Replacement
- 1993 dodge Dakota four wheel drive manual transmission
- 1996 5.2L to 1993 3.9L swap
- Trans fluid leak
- Dash swap now I have no turn signals or brake lights
- A\C System Restoration
- 91 2.5 manual swap to 5.2
- Dakota 1st gen in Denny Kannenberg's collection
- Oil pressure issues
- Speedo gear
- Dakota Head Liner
- Charging Rate Spec
- 1st gen rear end swap info to give
- Evaporator core and heater core
- Help
- 4wheel drive actuator
- Anyone needing a NV2500 4wd transmission?
- 97 Dakota no start
- Anyone needing a 3.9 out of a 87?
- 92 5.2 Extra Cab Performance & MPG Loss
- Lift/leveling kit 3" - Different shocks?
- Failing Smog California
- Vacuum lines
- Aftermarket Open Air Crankcase Breather vs. Closed Air Cleaner/Breather Assembly
- 4x4 rigged up as 2x4
- Body mount frame hole size
- Computer plug bolt spins
- Them's the brakes
- Two things
- Coolant Seepage - Front of Engine
- NP2500 fitting question
- Swap: pre 2003 magnum 3.9 v6 --> Dakota 1992
- Trying to find OEM temp gauge
- Update on my hemi Dakota
- AC gaskets and seals
- no codes......?
- So, who do you miss?
- Automatic transmission model ECM compatible with standard?
- My truck sounds like a train
- '94 Dakota Intermittent Stalling/Loss of Power
- Need help
- Another issue, distributer questions.
- Inner fender skirts?
- Are rear end assemblies interchangeable?
- radiator fan with shut off
- No crank with relay in
- Got it running....
- Evap removal
- Random Loss of Power (Fault1 Key-On 29)
- Looking for 92 dodge Dakota 5.2 computer!
- Go in 4wd...no go in 2wd
- Weird Stalling/Cutting Out Issue
- 3/8 vacuum filter
- 1993 3.9L v6 starter motor wiring
- 94 Dakota 5.2, rwd , transmission issues.
- 46rh into 87
- 95 Dakota 5.2L - What does this bolt do?
- Coolant leaks galore - 95 Dakota 5.2L
- Radiator
- Column Shifter Issue
- We've been working; The Turd's rebuild thread
- Temperature Gauge
- Fighting Brake and Stalling Gremlins (89 Convertible)
- 94 GMC 1500 NV3500 work for 92 Dakota?
- 1990 Dakota Convertible 4x4
- 1989 Dodge Dakota rear end.
- Dakota Body Parts, etc
- 92 dodge Dakota shut off while driving
- 97 dodge dakota sport 2wd metal in oil pan
- Thermostat?
- AC retro fitting from R12
- Dads 1991 Dakota SE LB/RC V8 4X4
- Broken rod upper control arm
- 89 Dakota 4x4 lift kit option
- Warrior
- To Catch a Thief - How to deduce make of a first gen Dakota
- 89 Dakota 2.5l charging problem
- '91 Dak Sport sinking pedal
- 1992 5.2L V8 Coolant Capacity?
- Air cleaner assembly
- Radiator interchange
- A/C o-rings
- Question: Options for Window Belt Weatherstrip
- Not running right. NEED help!
- Oil Leak
- HELP! whistling noise from engine on acceleration
- Turn signals cluster lights hazard lights not working
- Bucket seats in a stock bench seat truck
- Chrysler DRB Scan Tool & Mopar Diagnostic System Overview & FAQ
- Should I Buy This?
- Transmission Specs
- Like A Good Neighbor: The Movie!
- Need new fuel line
- Found elsewhere
- 92 Dakota. Need brake lines source
- Multiple engine wiring harnesses clips not connected
- Limp mode?
- Huge puddle of power steering fluid under car
- Headlight switch
- 93 dakota headlight issue
- Transmission question
- Where to buy Uppoer & Lower control arms
- V6 to v8 92 dakota
- Weight Capacity
- 95 Dodge Dakota 3.9 4x4 SLT turns over will not start. Can spray fuel in carb runs.
- Shifting issues
- Engine swap
- 1993 3.9L v6 Dakota ignition wiring help
- 1995 Dakota 2.5l won’t start
- HELP ! Fuel Sending Unit
- Where to buy new hood release cable?
- 1993 3.9l glowing headers
- 93 dakota hood release cable routing
- Advise on cam
- clutch slave cylinder
- 2wd Lift Control Arms?
- Dropped clutch rod inside bellhousing
- 1988 Dodge Dakota - Hissing From Brake Booster When Brake Pedal Is Pressed
- 1996 5.2 Dakota High NOx
- Mismatched control arms
- 94 RWD Coil Spring Compressor?
- For those that hate soldering in the car
- Stupid new guy questions,,, wiring
- 88 3.9L dakota
- Oil leak
- Looking for some ideas for V8 Upgrades
- Neat Idea for the Bed
- NV3500 from 4x4 to 4x2
- Front Drive Shaft
- Bumper quest
- Steering wheel from 02 & front seats
- Injector Upgrade
- Just an idea
- Do 6 bolt 96 stock rims work on a 92
- 1st Gen Dakota aftermarket
- More electrical gremlins!
- ECM tuned?
- 1989 dakota 4.7 swap
- blower motor issues
- air cleaner question on V6
- Swap Tach Cluster In
- For Your Information
- Fire wire problem
- [89 Dodge Dakota] Wipers not working
- No start
- '93 Dakota - Starting Issue
- Crank no start again.
- MPG's tank fillup
- LA 3.9 vs Magnum 3.9 Swap
- Random stalling
- Seat belt retractor question ?
- 95 SLT air bag warning
- 2001 Dodge Dakota
- Vibration and noice coming from rear end
- Transmissions
- 1996 Dakota losing power at hiway speed
- 95 Dakota 5.2 - Shifter Linkage Bushing
- Intermittent Rough Idle/Backfiring/Sucking Air
- 95 Dakota - Transmission Pan
- What 5-speed bolts to a 5.2?
- Code 42 and 27, Runs Great
- Grill ?
- Fuel tank repar - 1988 dakota
- Headlight Assembly
- 87 Dakota 2wd project
- LED Headlight swap
- 95 dakota - Code 45
- High pressure line poser steering pump
- 1991 Dakota
- 94 dakota front control arm
- Where to get MAP / Throttle Position Sensor Connector
- Throttle Kicker Solenoid/Actuator
- Throttle linkage/kickdown linkage help?!
- Noise after changing timing cover gasket
- All metal Rad, 42RH OD
- Experienced Help: 1996 Dodge Dakota Sport RestoMod
- got bitten by the splice
- How to find part# for my '95 PCM?
- for those who have converted to a carburetor
- T-Case swap
- Gas tank swap
- Head bolts?
- First Time Head Gasket 91 V8 5.2L 315
- 89 Dakota 4X4 Steering Stabilizer?
- Dakota 96 magnum slt clutch cylinder
- Nagging issue #436
- Where Can i Get A Rear Spring Support Brackets?
- New upper ball joints don't fit in control arms?
- 1988 Dodge Dakota - 6.2L Diesel Conversion?
- off-center rear end
- 93 dakota 3.9 auto backfire, bucks and misses when cold.
- Tire size effectiveness.
- 3.9 Black Smoke sometimes under load and at high idle RPMS
- 95 Dakota - Hood Latch Handle Broken Off Cable
- Ignition coil no power
- AC compressor locked up, sort of
- New '93 Dakota Owner
- Engine-Transmission install
- 93 project
- weird electrical problem
- New guy -- no headlights, brake lights, or horn!
- No crank, code 41, 91 Dakota V6
- Anyone still make a brush guard for this gen?
- Limited Time offer
- Transmission
- 1993 dakota tail lights
- mhubba '93 Dak Sport Repair Thread
- Help needed from someone with a magnum..
