View Full Version : 1st Gen Dakota Tech
- 91 5.2L throttle body spacer, were at?
- 318 to 360 swap
- two part question
- how much fluid?
- starter sticking
- Automatic floor shift kit
- 318?
- another tire question.....
- 93 transfer case different to the rest?
- Hello, and first issue.
- Trouble with 4Low
- BURRNING LOTS OF OIL
- largest tire on a 2wd?
- 91 dak front speakers
- Dakota cuts out going uphill
- Steering
- headers!?
- Exhaust
- Speedometer not working after crash
- New to Dakota got a few questions
- jet performance programmer
- sptting sputtering and backfiring
- carb or FI
- Once in awhile this happens...
- heated seats?
- well damn....
- Comments on TCI Transmissions?
- p0300 & p0304 Help
- Really High Oil Pressure
- Motor Mounts?
- What are the common tranny problems?
- 90 Dakota - Weird electrical gremlins
- MSD ignition
- 426 HEMI ??
- wiring diagrams!
- Rear break shoes
- air cleaner
- '96 dakota doggin out?
- Question about bagging a dakota
- Shift lever indicator loose
- WARNING: JET modules
- master cylinder issues
- master cylinder isues
- 360 in a Gen1 answers
- Problem with rear end....
- 95 DAKOTA WONT START!! HELP
- Cheap Transmission
- 5.9L R/T Heads on 5.2L
- mopar performance computer
- Strange hiss that seems to be coming from the engine
- speedo adapter seal leaking
- Lights dulling and dimming, engine bogging and back to normal, at the same time
- fuse panel
- oem shoe sizing question
- 50a blower fuse popping..FIXED
- cat removal.....
- Transmission...
- 96 and older exhaust ?? any sound bytes also
- 87 Dakota Windshield & Instrument Cluster
- 360 dakoa
- no lights-1988 dakota
- newer rims on older truck
- i did it!!! gas mileage!!!
- Transmission Problem
- Transmission problem
- Anybody ever done this
- what's going on w/ my truck?
- intrested buyer - got a few questions
- Fuel pump woes
- Manuel Valve Body
- Rims
- i have a coolant leak
- 96 3.9 dakota
- battery, alternator, or ??
- 5 lug converson
- Seats
- no lights- 1988 dodge dakota
- Wiper Linkage Help
- Ball Joints
- 1992 dakota wont start
- Turning Radius on 1st Gen
- Any parts that can be used from 1st gen dakota?
- 8.25 axle
- A/C Relay
- Spare tire cable broken
- Lift Kits for a 1st Gen.
- BIG PROBLEM! HELP
- brake wiring
- no heat no nothing
- emissions woes
- ceramic coated headers
- replacement seats
- Front axle problems
- rear end help
- fully built 318 swap
- Check EGR light on after timing chain replacement
- My Truck Eats O2 Sensors
- 4.7L in 1st Gen?
- ebay precut tint
- 93 Dakota
- Another 440 Dak
- chrysler 8.25
- Timing Chain Replacement tips...
- A500 upgrades (new guy)
- '87 3.9 Automatic Transmission Fluid
- 89 dakota door handle repair?
- 96 Dakota dies
- new at the site
- Rear end Q's
- Replaced Water pump on 94 Dakota
- roaring fan clutch
- want to hear about electrical probs.
- axle under susp. lift
- Difficult to add posi?
- Code 13-Bad MAP sensor??
- What the difference?
- demand it.
- 87 dakota 2.2 ehaust manifold ?
- ebay headers
- carb. magnum...
- I think I have a "Rare" Dakota
- Transfer case
- Help! Headlights?
- tapping noise sounds like timing chain slap?????
- Odometer for '93 Dakota
- Interior parts sources...
- Clutch question
- Upholstery repair recommendations
- oil water
- paint estimate
- Cutting springs.
- Lift for 2WD Dakota?
- vibration
- Can't Find a Tonneau Cover for a 92 Reg Cab Short Box
- bad compression
- Fuse box diagram for 1993 dakota !?!?
- Positive Temperature Coefficient (PTC) in an 87 2.2?
- 318 build
- TBI to MPFI conversion??
- CHeck engine light codes
- losing my mind help please
- starter wire question?
- Problems w/oil pressure and strating somrtimes
- 93 dodge dakota 3.9L V6
- carb rebuild didnt prime it up w/ fuel?
- 87 dakota starter problems
- manual hubs!!
- Saxon tires??
- What sensor is this?
- I need a link for leveling kit
- Is my fuel pump dead ?
- fouling plugs...
- VOTE
- 87 carb adjustment
- Dakota Door Interchange
- Zimmer Dakota?
- post your pics!
- About to lose my mind
- rear end question
- Tranny swap
- windshield wiper problem
- Tie-rod ends
- Why do dakotas have 6 lug nuts?
- 92 Dakota won't start
- Found a killer deal
- 87 2.2 manual carb replacement
- Greetings!
- Broken bit on the cooling system, no idea what its called, help!
- bodylift,torsion bar key, or suspension lift
- 4 by 4 dont work
- 96 4wd jumps out of 4wd
- Some questions
- How to adjust the idle on 87 3.9?
- Distrbutor
- 92 3.9l to 92 5.2 swap
- damsel in distress!!!
- transmision when warm turns of when put in reverse
- Tranny mount question
- Rear Differential
- 91 dakota v6 4d stuck in first gear?
- Help with DX codes please?!
- air temp sensor
- Battery/Voltage Problem PLEASE HELP!!
- It gets wet
- Smoke fumes coming from vents. PLZ HELP!!
- catylitic converter
- Vacuum Line Schematic 3.9 V6 (1992)
- 91 headlights...what fits?
- Fuel Sending Unit Problem
- What you do to get traction in the snow/rain?
- gas gauge problem, anyone else?!
- vacumn question
- Truck stalls after 15 mins
- Tranny switch
- V8 2WD Lift!!
- will not start
- Engine and Trans Swap
- tranny hestitation from 1st to 2nd on 87 3.9 4x4
- Transmistion, Govenor?
- 91 V8 4x4 not working...
- 87 check engine light
- Fuel Filter
- Headers
- brakes
- cant find od selinoid
- eBay headlight door review
- Gen 1 Euro Light
- Tonneau Cover
- Wierd Heat Problem
- 375 ft torque
- Crap.....
- Just purchased a 1993 dakota and already having problems...
- code 12.... what to do
- Weird Headlight Problem
- Idler arm
- Need TPS specs, and codes
- pre-magnum peformance help
- overdrive problems
- FACEBOOK
- Stock Rims
- dakota posi-lok
- hesitating
- swap questions
- how do i get my brake light off ? (in dash)
- Wheels or Tires, or both to gain some height?
- What can i use from the swap?
- new to the forum- just got 94 dakota sport
- Big Block in 1st gen Dakota
- brake pedal problem
- Brake lights and dash lights
- Dakota soon to grow some balls!!!!
- which trans do i have??
- Driveshaft Center Support
- Squeking
- New Member
- Grrrrr
- paint and trim data plate??
- I think this is a new question
- weatherstrip source
- Smells like Fuel
- Grille Guard for 88 dakota 4x4
- 1996 Ext.Cab 3.9L
- new member ride
- 94 lift kit? how high
- Gas Mileage
- '91 3.9 V6 revving up & down on its own HELP!!!
- remote door locks/starter
- Stroke and Bore
- Question for Crazy4x4RT
- Crazy Idling
