View Full Version : 1st Gen Dakota Tech
- Brake Lights
- ext cab quarter pannel body work
- New owner of a 94 Dakota
- rubber coil spring lift
- injector question
- Steering Knuckle flat rate
- Pulley Bypass & Loose Shifter
- Which front end should I get
- 95 4wd shift / select probs
- canvasman
- Driveshaft woes...
- Anyone need custom vinyl graphics??
- Air blend not working at all
- 35's!!
- Steering gearbox alignment
- Alternator rebuild kit for 2.5?
- torsion bar replacement Dakota 4x4
- NV2500 bearing retainer
- Just a couple of 42re - 46re questions
- 93 Dakota 318 FI to Carb
- 96 dakota stalls
- Parts Resources Request
- 89 dakota 318 swap
- lifting 94 Dodge Dakota 4x4
- Dodge Dakota Fuse cover 1996
- Rear axle is clunking in automatic trans
- Which other year 3.9 engines will fit an 89 dakota transmission?
- Whole truck vibrates above 65km/h
- name of the piece that goes between the pitman arm and tie rod?
- New guy needs a sanity check
- New engine is in, quick question..
- No power to coil, help!
- What Is a Nice Stall Speed for Stock 3.9? (Shopping for Torque Converter)
- 96 Dakota oil pressure problem
- tie rod ends
- power window help
- Transmission not shifting?
- 93 dodge dakota ecm issues
- transmission temp....
- Bearing Noise? Or something else
- Transfer Case Noise
- Push bumper question
- Rear Windshield Question
- Dakota 3.9 sputtering and loss of power
- Raw Fuel in Exhaust
- what just happened?
- 92 dakota cranks wont turn
- Rough start
- HELP 95 dodge dakota v8 wont pass emission test
- 95 dodge dakota v8 wont pass emission test
- 318 Magnum swap and build
- 96 Dakota 2.5 stalls when stop giving gas
- Proper way
- Bench Seat to Bucket Seats??
- 1994 Dodge Dakota has no spark
- Replaceing seats
- '93 3.9 water pump leaking?
- Leaf Spring replacement
- First post, buying a 94 on the cheap!
- help
- Adjusting air pump/water pump belt.
- good dakota wheel bearing video
- 96 dakota o2 heater code
- 96 dakota high voltage on o2 sensor please help
- Good old 89 dakota swap
- Is it worth it to keep going?
- performance parts?
- breather size?
- alternator bearings making bad noise
- front suspension question
- hot 5.2 won't idle, HELP
- Advantages of a 5spd?
- I blew it, really need help with waterpump bolts.
- Need help locating wiring harness
- 1995 Dodge Dakota. Help.
- rear brake drum question
- Tape Deck wont disengage until heated
- Hey guys.. a few questions? brand new here, and brand new to me Dakota
- nv3500 shift tower
- short bed help
- 1996 dakota 3.9l died on me and now wont start
- Quick dumb converter question.
- help please 1994 dodge Dakota 4 cylinder
- urathane engine/transmission mounts
- Intake questions
- Some quick questions...should be an easy answer....
- Where'd my CAD go?
- Truck bed removal and weight
- Oil catch can - do we need this?
- tranny crossmember
- Lift Kit and Exhaust
- 1995 dodge dakota infinity speaker system
- Considering Power Locks...
- 96 4cyl no start
- P0171 - Engine Shaking/Low Power on 4 Cyl on 96 Dakota.
- New motor for the dakota
- Compatibility
- Front air dam/valance/spoiler
- Custom Body Mount Bushings?
- 89 Dakota - No 4WD - Clogged Vacuum line?
- 5 speed swap help!!!!!!!
- Change from auto to manual transmission in '93 V6?
- body washers
- Tire and rims
- Electric Cooling fan info
- 96 Dakota crappy brakes and off idle shudder
- Dry squeak, coolant leaks?
- Help with Brake Booster Vacuum hoses
- Just got a 93' Dodge Dakota V8
- EGR valve system diagram
- Rear speaker wiring has no power.
- iac cleaning gone bad help!!!
- lift problem
- ECU? Not working (computer)
- Gauges all suck
- Overdrive explanation please ?
- Brake and ABS light on
- whats this wire?
- Auto Trans. swap
- newer dakota 16" rims
- 1996 Lift kit
- 2nd gen dakota rims on a 96 dakota rims rubbing tie rods
- Parking lights, console lights and right turn signal problems.
- Can I put1st gen engine in 2nd gen truck
- lookin 4 alittle dakota 3.9 4x4 1993 info
- Spinning Key.
- 93 Dakota wont fire up!
- Transmission fill hole
- Blower style scoop ?
- 4x4 Vacuum Lines Freezing
- 96 dakota ac clutch turns on randomly
- Compression test - max PSI
- Radiator Questions
- Dodge dakota conversion problem
- Dim Headlights - 92
- Dashboard removal
- '96 3.9 Low RPM Stall and Jumpy Gear Change
- 8.5 mpg in a 3.9?!? no thanks! help me please!
- V8 Plenum torque?
- 3.9 issues! help
- 93 dakota fuel pump questions?
- Help!!!!!!
- Head Bolts
- dodge stock radio
- 4 cyl drive train, v6 engine?
- Moding my bed.
- 50 Amp Relay
- Help!!!
- Door handle or lock problem?
- Dakota Suregrip Options?
- Door seals leaking ??
- Egr?
- driver door wont open
- Best HID Kit
- Incorrectly seated plugs
- AC compresor tick noise
- talk about productive
- Engine Code Question
- 1995-97 suspension?
- nv3500 to straight 6 jeep
- 180 t stat?
- Diesel gears in 46rh?
- Shelby Bumper Skirt?
- engine stalling on cold start up
- Switching cam shaft to fix fuel pump?
- Engine and Transmission Swap
- long tube headers issue
- looking for wheels.
- random stalling 95 dakota
- Egr
- need help clutch?
- code 21
- Replacing front end bushings?
- 96 dak 4x4 sas & 4bt swap
- help opening hood
- Give Me peace of mind!
- 5.2 tb on a 3.9?
- Camber on wheels out
- Engine swap 1995 Dakota
- No brake lights
- Finally getting started
- Engine Stalling/Possible Vacuum Issue Help
- Replaced Fuel Sending Unit
- wiring harness?
- brake line?
- e fan swap?
- A Parking Brake cable ?
- Tires- beating a dead horse
- Thinking of doing some restoring on 92. any tips or advice?
- rear axle trouble
- Hard Shift
- Who has the supply?
- got the play out of my steering shaft this this is safe?
- windshield wipers going too far
- Question about my Build Sheet
- adapters?
- Error Code 24
- '94 Dakota heater fan not working on high
- Frozen doors
- dodge/jeep Q
- EGR Delete
- Transmission swap
- u.s wheels any good?
- 318 build up disappointing
- Ultra wheels 50/51
- stock height
- 2nd Gen parts on a 1st Generation
- Bump shift problem
- newbie witha a special problem
- 89 dakota 318 swap d250
- how much torque/power will this give my 3.9l
- Parking brake
- 1994 Dakota Sport 4WD light doesn't work
- Throttle Body Spacer
- Fuel Supply Problem
- engine wireing harness
- Tachometer maxed out, high voltage level
- One can Hope..
- Emergency brake cable too short???
- Brake Line Fitting Help
- clear turn signal lenses
- need articles
- 3.9l ideas & help
- 92 Dakota gauge issue
- front shock absorber bushings
- V8 Torsion Bars
- Warm up tranny issues.
- More problems- maybe crossed wires somehow?
- 3.9l cams?
- First mods on my Cream Puff - Exhaust
- New Guy with New Buy - Modding my 93 Dakota LE Cream Puff
- shake and stall dakota
- oil leak
- How screwed am I?
- Rear Brake problem/question?
- error codes??
- Generation 1 inner fenders, fender wells... anyone know where I can buy them?
- 96' Complete Overhaul - any advice before I start?????
- 93 3.9 sport key tumbler/module
- oil pan
- old dakota with newer brain
- Ball joint just slides out of control!!
- Service Manual info
- Cutting cutting coil springs?
- Dash Vents NO AIR
- Changed some exhaust.. opinions?
- ball joint replacement questions
- Third times a charm..
- 46RE 1996 5.2L Swap with 46RE 1998 with a 5.9
- 95 Dodge Dakota problems please help
