PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Engine
  2. ok guys i want your opinions
  3. 1995 Dakota Transmission help
  4. Got a twitch.
  5. Do you guys think its worth getting
  6. Hinged the cab at back, tilt cab
  7. What makes the fuel pressure
  8. Body mount fix
  9. BIG Block Swap
  10. a518, 46rh, 46re driveshaft
  11. License Plate lights not working...
  12. Oil pressure problem.
  13. Fuel pressure regulator ?
  14. Why wont my truck start!!!!!!!!!!!!!!!!!
  15. Cosmetics?
  16. Inspection Question for other Pa. guys.
  17. 2wd to 4wd hanger swap
  18. Gearshift linkage
  19. 1994 5.2l v-8 runs rough and sputters under load and wont go past 3000rpm
  20. 93 Dakota V8 Low Idle and Stalling
  21. Bogs out going up steep hills.
  22. Running rough/Pops
  23. no start no check engine light
  24. 94 Dakota Mud Truck
  25. Hard starting when cold
  26. 1989 Dodge Dakota Rust repair
  27. Strange tranny when cold.
  28. 4speed manual trans question
  29. monster dakota
  30. transmission question
  31. Broken side mirror
  32. easiest way to remove a push bar
  33. Firewall wiring
  34. 88 3.9l
  35. Periodiclly runs rough/sputters
  36. OBD I to OBD II
  37. 93' 3.9 Ignition issues
  38. Rear Tires
  39. another brake fix
  40. Duel snorkel air cleaner
  41. new member with a story
  42. Rhythmic tapping. Auto Trans at stop.
  43. tranny issues
  44. my 1996 dodge dakota wont go in reverse
  45. summit sales.
  46. hazard lights
  47. weird studdering issues
  48. Help with 88 dakota engine check light
  49. dimmer switch replace
  50. Broke CV Joint help ASAP
  51. New PCM
  52. Weird RPMs
  53. Need fuse box diagram
  54. projector headlights.
  55. Greetings
  56. New to forum, have couple questions
  57. Rear Shackle Hanger Replacements
  58. Tranny shift kit and other issues.
  59. Can my truck tow horses?
  60. Help Im stranded in Portland
  61. 1990 Dakota 4WD Hub Seal?
  62. 4wd Vacume leak? Air hissing
  63. Dash cluster issue
  64. 91 dodge dakota sport...need help
  65. Under hood wire question...
  66. 95 2.5 dakota stalled
  67. Some advice on lifting.
  68. Help a kid out>>.
  69. I'm new here
  70. Side Mirror Styles? (Gen1)
  71. Ignition coil
  72. if your 1st gen dakota rolls over but wont start
  73. Cold Start Valve
  74. New owner-possible trans issue?
  75. Ride of The Month - ROTM!
  76. Need Clean 12V Circuit; PWR Doors Conversion
  77. free coil springs,
  78. 4x4 to 4x2
  79. I think I fixed it... but what did I fix?
  80. Source for engine dress parts and how to simplify the engine bay
  81. Who knows? Smoke and antifreeze everywhere - 3.9L Dakota Sport
  82. 95 Dakota 2.5 feels very sluggish
  83. Dipstick Tube O ring
  84. Front Brake Lines
  85. fuel issue?
  86. Blower motor issue
  87. Brake adjusting
  88. tranny seal
  89. Oil pressure lose
  90. Cheap repair - Broken door panel retainer slots
  91. Squeeling sound on a hard left from my steering???
  92. Jeep and Dakota radio interchange?
  93. valve cover gasket
  94. 94 dakota 3.9 code 17 and hesitation?
  95. Wanting to do a dash swap
  96. missing bolts
  97. Stalling/Hard to start
  98. 91 headlights
  99. Help code 27
  100. Cabin air filter
  101. Proprietary Positioning of TPS
  102. Another exhaust manifold option
  103. ABS Brakes
  104. 3.9l '95 dakota ignition timing jumpy and severely ritarded
  105. Want to Tighten up Steering
  106. Huge transnission cooler install
  107. EGR delete?
  108. Figured I'd post a question before scrapping or using my dodge for target practice...
  109. 95 Dakota Code 27 Help Please
  110. Where to find Original 'OE' Parts?
  111. too far forward ?
  112. 3.9L Choppy Start-Up? [VIDEO]
  113. help!!!! nv3500 swap
  114. tires
  115. Weird problem..
  116. Electric fan install
  117. ACDelco U-Joints?
  118. Dash OD switch
  119. Exhaust upgrade (3")
  120. Save 50% at Napa today and tomorrow
  121. overheating troubles got me down!!!! HELP!!!
  122. My 93 Dodge Dakota
  123. Don't know what size serpentine belt I need..
  124. '94 318 to 360 swap
  125. Code 21
  126. motor mounts for v8 dak
  127. Thermostat
  128. 95 Dakota starting problem
  129. Is it worth it? Your opinion please!
  130. Emergency fix !!!
  131. Just picked up '90 Dakota, thinking about some work to do.
  132. AH-HA!! Fixed it!!!
  133. Code17
  134. 95 Dakota ABS/Parking Brake lights
  135. following the codes
  136. Overdrive unit
  137. Sure Grip
  138. Serpentine Belt
  139. no heat at idle
  140. 1994 dodge dakota 5.2L fuel pump
  141. Replaced coil springs
  142. gear swap checklist?
  143. Little truck, big problems
  144. 4X4 low sticks
  145. Lowering both ends of rear springs
  146. Camo wrapped dak
  147. hole in oil pan
  148. Swap out 3.9 for 5.2
  149. viper transmission
  150. I need a speedo cable
  151. 3.9L engine rebiuld
  152. replacing the fuel pump
  153. 4 cylinder FAQ
  154. 94 dakota 318 engine timing
  155. Steering wheel locks up while driving
  156. Carpet Size
  157. 94 5.2l 5spd bad mpg's!!!!!
  158. biggest tires for v6?
  159. odd question
  160. Low Oil Pressure, Pulling FWD, Tips?
  161. Cant seem to find winter tires...
  162. transmission problems 93 318 2wd auto longbed
  163. click in steering pump?
  164. Removing the Pin striping around the truck
  165. restored my frame...
  166. 15's versus 16's
  167. I think my PCM might be bad...
  168. Speaker Mounting
  169. 89 no start runs if fuel poured into tbi
  170. Headlights won't turn on....
  171. Help: New Brakes Rub!
  172. OOPS, replacing front coils
  173. 5.2 Magnum backfiring problem
  174. 1990 3.9 Dakota stall/start problems
  175. Old Guy Backed Into Me
  176. Havnt posted any pics lately so here ya go!!
  177. not wanting to stop
  178. New fuel pump but still no gas gauge
  179. need a favor(4wd)
  180. Open Air Filter
  181. 1988 3.9L Tune-Up Advice?
  182. front hub assembly
  183. 1996 Dodge Dakota 4 cyl will not start
  184. Trail ride with pics/videos
  185. Manual Second gear issue
  186. Skipping fixed
  187. 93 Dakota, Mind Boggling Problem???
  188. Just out of curiosity
  189. Shelby Bed/Rear Cab Wedges??
  190. RPMs fluctuate, stuck accelerator pedel?
  191. need help with vacuum diagram or some pics
  192. need help im lost now
  193. Updated Gauge Cluster
  194. 1988 dakota fuse box
  195. Trans problems after sitting, then motor swap.
  196. Last resort fix...Valves?
  197. need some more help
  198. Need help FAST with ring gear question
  199. Injector splice location ?
  200. max weight in bed?
  201. All fixed. Almost double the mpg!!
  202. Help Please
  203. 1990 3.9 fuel injection???
  204. How to remove front rotors
  205. 88 dakota charging problem
  206. LED Dome-Light Conversion
  207. Need some friendly help...
  208. Reindexed torsion keys
  209. Front Bumper Overriders
  210. 33x1250 how much lift to fit?
  211. 1997 dodge dakota
  212. Front Bumper
  213. Changing the diff oil
  214. AutoZone Coupons
  215. Noob :-)
  216. strange starting issue and other problem
  217. Dodge Dakota 2WD and 4x4 questions/help?
  218. I want to reduce/eliminate drag on front disk brakes
  219. Please help me!!
  220. 93 v8 dakota idles at 250rpm and sometimes stalls
  221. vibrations start at 65...
  222. new water pump leak
  223. My Truck Has Bipolar Disorder
  224. Tranny Issues
  225. Tranny Problems??
  226. Irritating Fan Clutch
  227. More exhaust questions!
  228. Injector question
  229. obd 1 or obd 2
  230. Hot Start Horror Story -Please Help
  231. HOWTO: get the key in the cylinder at night
  232. radiator replacement
  233. O/D not working right and no heat, please help!
  234. Direct plug-in speakers
  235. Air only comin out the defrost
  236. No Heat, 93 3.9L
  237. Very bad shake fixed!
  238. 91 318 won't start, any ideas?
  239. Hissing sound possibly from rad?
  240. Engine Swap 5.2 LA to 5.9 Magnum?
  241. Just need to check with you guys
  242. Transmission Fluid Type
  243. 4x6 H4 HID's & Turn Signal LEDs?
  244. Transmission years?
  245. performance transfer case fluid?
  246. what spline count do i have?
  247. Rockauto.com?
  248. Ignition Timing
  249. t56 swap
  250. Ambient temp sensor location
