View Full Version : 1st Gen Dakota Tech
- Bell Housing Bolts
- Ac issues
- 95 dash
- Help please v6 first gen 95 dakota
- Rear End swap
- V6 to v8 with manual transmission swap questions
- recharge a/c
- Lock up converter stuck
- Stalling Issue 91 Dakota
- 1994 Dakota fuel pump issues
- 1995 318 Magnum Club cab auto 4x4 good alt battery dies
- 87 Dakota radiator
- 1987 Dodge Dakota - Early edition - V6 - Won't Idle - End of the line?
- Need 1996 Dakota PCM part number
- 2001 dodge dakota 3.9 liter v6 ac clutch isn't engaging
- Smog Orifice
- High oil pressure in summer
- Speedometer issues
- what size tires can be used on a 92 Dakota
- Update
- I drove it this morning
- 1990 Dakota Ignition Key Light Bulb
- O2 Sensor Wire Burned
- 93 Dakota 5.2L LE needs an ECM
- New Timing Set Slack
- 96 Dakota no radio or hvAC controls.
- Bad clutch or pressure plate?
- How to repair broken Throttle Cable Linkage?
- 89 with 2.4 litre and 5 speed
- Cruise Control
- 89 Dakota buzzer runs whenever door is open
- Rear Brake Drum To Disc Conversion
- Trans problems help stuck on side of road
- Trailmaster control arm bushing
- Driveshaft UV Joints problems with transmission
- Electric fan??
- Ignition key switch wiring colors
- How often do you....
- 1993 dodge dakota, no crank and no power/spark
- 1995 Dakota body swap 2.0
- Acting like timing is off after engine swap
- 1st Gen Brake Upgrade
- Odd new noise
- 94 Dakota fuel guage not working
- Fog Lamp Replacment Options?
- ECU problem
- Ps pump brackets
- Need Upper control arm mounts 96 4x4
- 1991 Dodge Dakota 3.9 EFI
- Speedometer Bounces Around
- Brake Shoe Drag
- Np Surprise: Broken Brake Spring
- Factory Option list for 1996 Model Dakota?
- Radiator Reservoir mounting
- Drain Radiator?
- Repost: Instrument Cluster for 88 swap
- Anyone have an engine harness for a 5.2 ?
- 1989 Dakota ECM
- '92 Dakota 360 Swap
- Adding to Coolant Reservoir every 1000 Miles
- 1989 Dakota 4x4 convertible 4x4 light works but not the 4wheel drive
- Oil in a Rebuilt 360
- 04 Durango and 07 Durango brakes
- Plastic in oil change
- 1992 dakota pcm
- Crankshaft position sensor bolt specs
- '91 Wiring Harness Interchange: 3.9 to 5.2 Swap
- Instrument cluster swap
- Low fuel light
- Weird running issues... please help!
- 31s on stock 93 Dakota
- Tach
- Spintech Y Pipe on a First Gen 4x4
- 1992 Dodge Dakota 5.2 2wd transmission removal tips??
- NV3500 Behind a Mild 360
- Strange Rattle
- nv2500 to ax15 t-case linkage
- 1991 dodge dakota coolant temp sensor problems
- Mild 318 Bolted to an AX15
- Help! Trans questions!!
- Crank Won't Start..?
- Lifting my 96 2wd Dakota
- Headlights Go Out
- Help With Gauges
- Tail lights and hazard lights not functioning
- Seeking help with ‘87 Dakota AC servicing
- 1991 Trim Logos
- Wiper motor
- Hi Dakota people, my name is Richard . I'm new to all this so bare with me .Thank
- '93 OBD2 swap
- U joints
- 93 Dodge Dakota New Fuel Pump ran for a week till got cold out
- Side Mirror
- Windshield
- Code reader/scanners
- Issues Running
- 92 Dakota 318 Mods
- Fuel/running/restart issue 1989 Dakota
- 93 Dakota Sport Transmission Swap
- Fuel Pressure...1988 Dodge Dakota...3.9L/Auto
- Battery Cable
- Taller gear for my rear diff.
- Won't Start, Codes 11 & 54, '92 3.9L v6
- Exhaust Stud/Manifold Assembly Question...
- Converting 1996 3.6 rwd to 5.2
- 98 dakota trans prob
- Shelby Dakota Radiator
- Stand alone ECU or Carb swap ?
- 93 dakota v6 water pump
- fuelhose/connections to fuel pump 1989 3.9Ll
- 87-90 steering column repair
- No Spark
- Outer belt line mouldings now available
- Omg its alive again...my fix to the crank, no start issue...read this!!!!
- Fuel pump Relay location 1989 dodge dakota 1989
- refvving up and down
- Can't find a stupid PCV hose !!
- 1989 dakota fuel pump install
- 1988 Dodge Dakota motor swap
- 1991 318 V8 harness conversion to 93
- 93 5.2 front seal replacment
- 5.2 automatic tranny upgrade
- Heater Core Issues
- left ignition on, now no power, battery is charged, HELP!!!
- 1991 dodge dakota unstoppable misfire PLEASE HELP
- Maintenance required light reset
- 1991 Dodge Dakota 3.9L
- 93 Dakota 3.9 no start
- Master cylinder install
- Factory electrical plugs?
- Timing chain sprockets?
- Fab Rats Dakota SAS
- Steele Rubber Products Universal fit outer belt line mouldings
- 94 5.2 dakota help!!
- 1993 Dakota parking brake pedal assembiy
- 1988 Dodge Dakota 3.9 L/Auto No Start
- External Voltage Regulator (Diagram)
- Steering Knuckle 4WD
- 1987 Dakota Engine swap
- 1990 dakota fuel mix
- 96 Dakota 360 la swap
- Swapping 318 Magnum for 360 la
- clutch fan delete
- Help me source 96 5.2 auto engine harness?
- Control arm bushings
- 1992 Dakota Cutout
- Options for ECM replacement required.
- Filler Neck...Part Diagram...Please help.
- Ac issues w/1993
- recirculating air door
- AC Compressor Bearing
- Had to let her go 😒
- 1993 3.9l running rich
- What's the name of this part? (rear shock mount)
- Pcm damaged?
- PCM bolt just spins, can't unattach wiring harness
- Help!
- Starting Issues
- Sealed Beam Conversion from Aero Package
- Tiny vacuum lines
- Let me fix er boss.....
- Clear Headlight Housings for Projectors
- 95 dakota 3 9l crank but no start
- 1988 dodge dakota
- 1996 3.9, 42RE Stuck in second
- Crank no start
- Help with part.
- Going Full Custom?
- Speedometer Not Working
- 93 Dakota
- Ac recharge
- Thermostat Temp (180 or 195?)
- Wiper Spindles
- 92 Dakota early shift
- Fuel pump not always coming on
- Fog Lamp Replacement?
- 92 5.2L leaking Oil and ATF, tips on finding leaks
- 1994 dakota
- AT-205 Works!
- Transmission interchange
- AC kicker solenoid wiring for 1987 3.9L Calif emmisions
- ok guys I need help again
- Fuel gauge erratic (fuel slosh)
- V8 transplant
- 1992 Dakota tranny swap\
- Overhead console
- oil seal on crankshaft sensor
- 1993 Dakota 4x4 linkage is bound up
- Carburetor wiring help request for 1987 3.9L carburetor
- 1989 Dakota LE electrical issue?
- electrical issue, headlight switch/radio connection?
- Hello all, very happy to find this forum
- what is the problem
- Rough running, hard shifts, weird oil pressure…
- Can't find new valve covers
- Trail Master lift kit problem
- 1994 Dodge Dakota cannot get it to run right
- 1995 Dodge Dakota 3.9L intermittent code 27-fuel injector circuit
- Limited slip avail for 93 Dakota?
- Side Mirror
- Why won't it start...
- Truck stalls when cold in reverse
- 1990 Convertible Top Alignment Pins
- Rough idle and stuttering (miss?) at steady speed.
- Speedometer stuck at 120
- Good quality headers needed
- Tail light rats nest
- Body panel insulation
- Tires
- The quest begins: Intermittent Stall.
- Windshield Wiper Bushings
- Mystery Code 15
- Steering Column
- Does anybody Drag race there Dakota?
- Rear Window seal
- 1996 Dakota 3.9 SLT - fuel pump not working - troubleshooting?
- 1st gen '95 RWD reverse mounted rear wheels?
- V8 Magnum kegger intake without EGR port
- Coolant temp gauge
- 1994 4x4 issues
- Engine stumbles when warm
- Electrical Stuff
- Dash lights and gauges going haywire
- 2 1/2” header crossover
- Knuckle swapping 1st gen dakota with 2nd gen
- 1993 Dodge Dakota display light not working.
- Rebuilding the Manual Steering Rack (guide)
- wiper spine issue
- Mopar performance pcm
- '93 Dakota 3.9 exhaust manifold bolts
- What kind of coolant?
- New member with a crank no start 1995 dodge Dakota
- Manage attachments function failed
- No power to fuse box under the hood
- Advice shopping for a First Gen?
- Wire Harness Problem
- 94-95 Dakota 318 4X4 auto to manual swap
- 1995 Dakota Ball Joint question
- Rebuild 3.9 Transmission or 318 Swap?
- Having weird problem please help
- 89 Dakota code 16
- 2.5L Coolant Fill Plug Thread Type/Size
- Dodge Dakota (immediately) shuts off while driving
- Brakes done but still no peddle
- Seat belt buckles
- Rear brake lines
- Emissions purge valve
- Hi I have a 1999 doge Dakota with the 5.2 and a auto trans
- Error Code Help
- 96 Dakota 2WD Bump Stop Source
