PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59
  1. 1987 Dakota V8 Swap
  2. Anti lock and Brake light on
  3. pics of my new '92
  4. Code 16, please help!
  5. Need help
  6. car show
  7. Everytime it rains it doesnt want to start
  8. 94 dakota with 360 wont start
  9. High Performance Catalytic Converter
  10. thinking about rims
  11. Ugh, more problems
  12. Blown head gasket
  13. New Truck, take a look
  14. Just registered! Turning 92' Dakota, v8, into project truck, would LOVE help and guidance.
  15. TB/intake mainfold
  16. roll bar?
  17. Engine ticking
  18. 1994 V8 Auto trans
  19. 92 Dakota estimated weight
  20. Delete
  21. Billet Grill/ Hidden Hitch/ Clear Corners
  22. building the 1 gen dakota prerunner
  23. 89 dokota air conditioner problem
  24. Radiator Installation
  25. 91 Dak A/C
  26. Tranny problems
  27. Ram 2500 leaf springs
  28. question?
  29. turbo kit
  30. gasket sealer
  31. Fuel Injectors
  32. Painting Calipers
  33. got a question about my 92 3.9
  34. Can some body tell me the location of some houses???
  35. Sticky throttle valve
  36. V6 coil electronic suppression - why is it in my hand instead of on my truck?
  37. Tires
  38. Brake Master Cylinder question
  39. truck of death
  40. AC compressor removal
  41. Misfiring code?
  42. 4x2 rear wheel stud R&R
  43. spark plug interference on radio
  44. Trade Aero for non Aero H/L doors
  45. Fuel problem
  46. Body Work Time...Need patch panels
  47. High Idle
  48. Selling my '93 2wd V8
  49. Iginiton moduale
  50. cant believe it
  51. Oddball
  52. U-joints replacement
  53. 87 dakota trans/OD question
  54. 3.9 headers
  55. A/C compressor not cycling
  56. Wheel Spacers
  57. bolt pattern
  58. Number one plug wire on distributer cap...93 2.5l dodge dakota
  59. back leaf springs
  60. Noob stuff
  61. Torsion bars.....again! llol
  62. Exhaust
  63. Oil Pressure
  64. Headers to tailpipe
  65. E-85 and 93 3.9 MPI
  66. questions
  67. No spark - 93 dakota - no power to coil
  68. Oil Leak
  69. Mopar Performance Air cleaner P5249807
  70. 1993 dodge dakota just died lost power
  71. for sale
  72. 1996 Dakota Radio--maybe fuse?
  73. Motor Mount question
  74. exhaust
  75. solenoid coil circuit
  76. skid plate design
  77. 89 dakota sport/ 3.9 v-6 (I NEED HELP)
  78. 92 dakota flooding
  79. K&N intake
  80. 94 Dakota battery is sparking
  81. Common Transmission failures
  82. CB antennas mounted!
  83. '92 Dakota w/ V8 5.2L
  84. 3.9 to 318 swap info!!!
  85. bench seat to bucket seats
  86. 94 Dakota 3.9L WON'T START/ No Power To Fuel Pump...
  87. Clear Tails!
  88. Lights
  89. bumpers
  90. 89 to 91 what parts interchange?
  91. oops delete this please
  92. 318's
  93. New to Dakota
  94. 96 3.9 4x4 Dakota
  95. Help me Find out whats wrong with my truck
  96. New member
  97. 92 pops and backfires
  98. How can you remove the error code 33
  99. white face guages
  100. Damn Deer
  101. wheel fitment
  102. Transmission
  103. Did i ruin my engine
  104. Door Glass
  105. 1993 w/ 3.9 v6 sputtering (updated)
  106. 1st Gen Dakota In Petersen's 4wheel and off-road
  107. MOVED: Pattersons 4wd and offroad
  108. For Sale: 15" Alloy Wheels
  109. If You're Interested.
  110. Nitrous
  111. what do you guys think, PICS!
  112. Rear end swap, will rims fit?
  113. 94-96 wiring/electrical info needed
  114. 1992 dakota
  115. Toyota rims
  116. 94' Dodge Dakota (clock spring)
  117. air filter question!
  118. 87 3.9L AC delete?
  119. what rear end
  120. Rebuild
  121. 1994 3.9 won't run when warm
  122. 91 Dakota limited slip? hp differences 91 to 92
  123. 94 DAK LIFT
  124. T-case AGAIN!
  125. Parts
  126. Noisy Motor - Update
  127. 96 R/T Complete!
  128. Gas gauge
  129. 94 dakota project
  130. transfer case ...sloppy chain?
  131. crank sensor
  132. What is this?
  133. Pics of the engine
  134. k&n air intake
  135. 1996 dak help please
  136. brake light signal light problem
  137. transmission lines?
  138. need some help
  139. 93 Dakota ABS Brake light stays on
  140. new exhaust
  141. Exhaust and Front end
  142. Deactivate 15mph locks on a "98
  143. oil
  144. flowmaster super 44
  145. shocks
  146. New or Remade
  147. dakota sport stripe kit
  148. Dakota Tansmission Questions
  149. Which type do you prefer?
  150. Low Voltage to Coil
  151. pipe question
  152. 88 dakota sport lift
  153. quick question on exhaust
  154. 88 dakota transmission trouble
  155. Distributor no vacume advance?
  156. Lifting a 1994 Dodge Dakota
  157. need help please.......!!!!!!
  158. Loud noise during eacceleration
  159. 1987 dodge dakota need help.........please..!!!!
  160. hi people i have a 1987 dodge dakota....need help...!!!
  161. pulling my hair out!! HELP!!!
  162. Need some ideas?
  163. bad vibration
  164. Im new here!!!!
  165. power steering gear box leaking!!!!!!!!
  166. another wheel and tired question
  167. 94 dakota air intake
  168. Magnum engine
  169. 1992 Dodge Dakota 4x4
  170. 1990 dodge dakota-fuel pump
  171. said hi in the new ppl place so......
  172. Lucas Oil
  173. 93' tranny slips when cold
  174. Question about SMEC and SBEC 2
  175. Performance Chip
  176. Water pump replacement
  177. R/T Wheels?
  178. Engine Pictures
  179. damn
  180. injection help
  181. engine swap
  182. My truck before and after.
  183. My life with a v6
  184. Fire wall wire plug replacement
  185. 04 Dakota
  186. FOR SALE 1992 Dodge Dakota Ext. Cab 4x4
  187. Cluster Lights
  188. I want to tighten my tranny bands.
  189. 93/3.9 sputtering
  190. Accelerator Cable
  191. water pipes?
  192. Auto Trans 1990/2003
  193. throttle body spacer
  194. Need Rear Brake Lines - Broke an end while replacing wheel cylinders.
  195. Long Tube headers
  196. 4x4 make noise!
  197. 3.9 conversion
  198. 95 4x4 with a soft brake pedal.
  199. Lift a 2WD
  200. brakes
  201. Skid Plates - Help
  202. headlight trouble
  203. Just finished the 87's heart transplant !
  204. MSD ignition box
  205. Bench to buckets
  206. 2.2 L dosent want to run right
  207. 92dodge dakota stalls
  208. Help! no power to fuel pump
  209. MPIossible?
  210. Universal cruise control cables?
  211. how much oil?
  212. LETS HEAR YOUR EXHAUST!
  213. Have opportunity to trade 92 kota for 88 RC..any advice?
  214. COLD AIR OR OPEN ELEMENT
  215. exhaust
  216. 1990 Dakota Erratic Idle
  217. New dakota owner
  218. truck "bucks" when taking off from a stop
  219. difference in dakota's
  220. 5.2,3.9,2.5 engines
  221. HID help
  222. racing wheels
  223. Help me, Please, Code 42 I can't find reset
  224. Pretty pissed off here...
  225. 93 5.2 4x4
  226. Need Help. Engine stalls when put in reverse
  227. Valve cover gasket
  228. would you buy this truck
  229. help - battery over 20 Volts!!!
  230. electrical prob.
  231. idling question
  232. IAT resistor
  233. Differential Upgrade
  234. + plastic cleaning/painting HELP NEEDED !
  235. Hello, and THANK YOU!!!
  236. Would anyone happen to know...
  237. where is it
  238. 93 dakota vibration ,,no power
  239. MPG's ????
  240. 96 5.2L Magnum V8 Gas mileage??????
  241. 180* Tstat question
  242. want to buy an engine
  243. Torshion Bars?
  244. 3.9 ?
  245. transmission yolk
  246. 93 dakota fusible link
  247. New to the forum and have some questions..
  248. Electrical Problem! Please Help
  249. 94 dakota reliability...
  250. 1st Gen Burnouts SHOW US SOME SMOKE!
