PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. gear ratio!
  2. Decal Idea?
  3. Transmission issue?
  4. engine swap, OBDI to OBD II question
  5. ROTM Voting and Nominations!
  6. 1987 DAKOTA EGR Light on
  7. Limited slip differential?
  8. Gauge Help
  9. One Dim headlight...
  10. Door wont open
  11. Getting ready for 360 swap 94 v6 dakota
  12. Lift question
  13. Over Head Console Install
  14. 93-96 dakota rear end ratio?
  15. Wanting these rims...
  16. ASD and Feul Pump Relay?
  17. engine identification v6
  18. 91 dak 4x4 318 add-a-leaf install
  19. Transmission Growling Noise in Overdrive
  20. Stalling, possible fuel pump
  21. 88 3.9l idle and bad hesitation
  22. Trans Removal
  23. Front end...ALL OF IT!
  24. 87 dakota
  25. 1989 Dodge Dakota Question
  26. Vacuum leak?
  27. '91 Dakota Air/Smog Pump Issue
  28. 3.9 Modifications and Economy
  29. 94 dodge dakota fuel pump
  30. 2.5L manual transmission, help...
  31. Checking Splace ang Spark Plug gap and Fuel pressure
  32. 96 4x4 auto tranny kaput
  33. Need injector advise for 92 Dakota
  34. Where to get set of Alloys for Dodge Dakota 1989
  35. 1996 Dodge Dakota Sport- Fuel Gauge issue
  36. what would you do?
  37. Plenum Gasket Failure Questions
  38. No start, and other things. All/Any help!
  39. c clip removal
  40. Question on bypassing A/C compressor.
  41. Truck unexpectingly dies, will not start sometimes
  42. No Hot air coming out of vent
  43. Tires.. Bang for your buck?
  44. Fender flares?
  45. Cab swap on my 91'
  46. Headliner Recover Demo - Illustrated!
  47. Like my new dash?
  48. 95 Dekota 3.9- still a mystery
  49. What Type of Tire Should I Get?
  50. fog light placement?
  51. 4 Wheelin stories anyone?
  52. mpg questions
  53. Bell housing help
  54. Trans/Engine Question
  55. Rough Idle - 93 5.2 Automatic
  56. 1995 Dakota 2.5 EGR HELP!
  57. 95' Dakota Speaker Help
  58. 95 Dakota 4x2 318 auto trans slipping
  59. true duels
  60. carb help
  61. Break warning light
  62. Tips On Wiring?
  63. 95'dakota K&N stamp under hood
  64. Nasty Squeal
  65. Cowl weatherstrip?
  66. Wipers, removal and rebush them.
  67. Relay Wire Help Please
  68. Cannot go over 35 Mph.
  69. wheel and tire question
  70. 4x4 shift knob
  71. '94 Wiring problems
  72. "No Start" help needed
  73. Ignition Upgardes
  74. What's the chance my transmission is gone?
  75. Windshield Wiper Issue (not motor)
  76. 94 Dakota code 32
  77. 2.7L motor swap question...
  78. truck doesn't start, help fast please
  79. Tranny problem help!!
  80. Caliper Bore size
  81. replacement driver's side floor panel
  82. splice like symptom.
  83. 96 dakota 3.9 Head Gasket Question
  84. Very bad gas mileage?
  85. rear brake parts quality and contact area!
  86. Transfer case rebuild
  87. Transmission Search
  88. What gives better performance?
  89. how to remove body mounts
  90. Newbie Help Needed - 95 Cranks barely
  91. wanted lift pictures and cool mods
  92. found a beauty on craigslist...convertable
  93. Bell housing help
  94. electrical gremlins
  95. 92 Dakota Electrical Issues!
  96. Backfire/popping.
  97. Inop Fuel gage ,FYI & ?
  98. gear ratios
  99. Tire size with lift
  100. Junk Yard CAI
  101. 89 Dakota, 3.9
  102. Temperamental Dakota
  103. Dakota 3.9 Fuel Economy
  104. Sounds like a coffee can?
  105. How can i get a good exhaust note from my v6 ?
  106. Air cleaner lid
  107. What is Shock Stroke?
  108. My '95 2WD won't start
  109. '96 Dies While Idling
  110. Locking Tailgate?
  111. Tail lights blowing fuses
  112. aquired the build shhet for my dakota
  113. Random Stalling
  114. bout to make a long trip
  115. 3.9 cranks but won't start
  116. Getting code 17*
  117. OBDI code **34 help
  118. 1989 dodge dakota sport. No power at key
  119. 93 Dakota Losing power on long climbs.
  120. 318/360 swap in 87
  121. Tires stock height/lift.
  122. Finally only one code!
  123. long single driveshaft, factory
  124. Timing order?
  125. headlight problem
  126. 1993 Dakota 4wd
  127. drive shaft shortening
  128. Abs?
  129. Damp Starting
  130. Better fuel economy?
  131. Computer chips??
  132. No Headlights
  133. Center link?
  134. 2.5 to 360 swap in 95, needed input or experience
  135. Anti Ice Spray!!! GREAT
  136. Cheap Engine Upgrades
  137. 94 Dakota Doesnt Turn Over
  138. Heater Fan motor question?
  139. Dodge dakota 1996, fuel consumption.
  140. 95 4x4 radiator replacement
  141. Longbed to shortbed?
  142. 6 lug Rim Compatibility?
  143. horn and rear lights.
  144. Couple Quick Questions...
  145. Power mirror problems
  146. 95 2wd 4cyl: 2wl ABS or 4wl ABS?
  147. question about the demon splice
  148. Auto to Manual Conversion help!
  149. HELP!!! 4x4 no work!!
  150. how do you post pictures?
  151. Brighter backup lights
  152. Fuel Tester Gauge
  153. Need front end help on 92 dakota
  154. Transmission help
  155. Runs rough hot
  156. Dual Exhaust
  157. 1994 Dakota 4x4
  158. Westin FEY Chrome Step Bumper
  159. HF Ham Radio Gen 1 Dakota
  160. 91 5.2 abs/brake light on
  161. CPU temperature sensor pigtail?
  162. 1993 Manual Transmission Problem
  163. *UPDATE* 89 dakota O/D issues
  164. Hood latch cable frozen?
  165. 89 dakota parts
  166. Great news, then sad news. 36in tires!
  167. 1989 dakota TPS, O/D, and electrical issue ?
  168. Bought 2 new tires
  169. My Early Dakota
  170. Sort of same problem. VSS, O/D, and code
  171. How does your 2wd Dakota do
  172. Dakota randomly dies out
  173. 1992 318V8 Engine dies ?
  174. transfer case removal
  175. 1993 dakota headlight switch connector terminals
  176. '90 Dodge Dakota Sport. Help please :)
  177. Transmission interchange
  178. Confused about speed sensor
  179. Battery Charging Problem
  180. Transfer case upgrade
  181. Plenum Gasket Issues
  182. Fender Flares Restoration?
  183. Tranny Fluid
  184. Parts Discontinued
  185. Problem really bad now
  186. rear sway bar mounting
  187. Can a truck not be a morning person? (Miss issue)
  188. Dixie Dakota!?
  189. New member
  190. Trailmaster Removal
  191. 91 5.2 dakota sport oil questions
  192. 1st gen PCM intelligence?
  193. Vacuum Leak?
  194. change wheel studs
  195. Installed my wheels.Didn't have to grind
  196. Odd situation
  197. oem parts website
  198. Mph
  199. Timing Chain Parts - Duplicates?
  200. 95 5.2 head gaskets gotta be done...
  201. Oil pressure sender location.
  202. Clearance lights\cab markers on my Dakota!
  203. lower valance
  204. Over Heated
  205. steering adjustment
  206. 95 dakota, 4 banger, need some help
  207. Clunk noise in the front when I accelerate
  208. Dakota frame
  209. Emergency Brake Handle
  210. How to: Painting Rear Drums
  211. 1994 dodge dakota signals and brake lights messed up
  212. Parking brake dilemma.
  213. bad cold weather start.
  214. Glove Box Lock & Seat Belt Mounting Locations
  215. 93 Dakota engine codes...
  216. Clamp on bumper light brackets
  217. 318 V8 cooling system question
  218. Need help with tire / wheel size
  219. Fuel rail ?
  220. No taillights!!!
  221. quick question
  222. engineand transmission swap
  223. 94 dakota 2wd no overdrive
  224. first post need tranny help sorry
  225. Riveting on new rocker panels
  226. How to keep overdrive on
  227. new hydro clutch parts
  228. Sorry, Another Offset Question
  229. Wanna Redo my Headliner, Again
  230. EXtra Space for Speakers!
  231. How to: Hanger Flip, Dodge Dakota
  232. 94 dakota restarting issue
  233. New Clue 92 Dakota
  234. Trim pieces on the side delete help
  235. Accomplishments and Issues
  236. Canister under passenger door
  237. Nemesis158's Build/question thread
  238. 3.9 runs rough until warm
  239. Free Chilton library online!
  240. Spark plug gapping
  241. Right turn signal won't blink
  242. Truck won't start. Lots of symptoms
  243. 92 Dakota with a soaked floorboard
  244. 1989 "Sleeper"
  245. How to post pics?
  246. No power to fuel pump when cold
  247. Start issue
  248. lift kit help..?
  249. Carbonated engine Questions
  250. change door
