View Full Version : 1st Gen Dakota Tech
- Truck tries to die while driving
- 1996 Dodge Dakota SLT 3.9 Magnum
- 2wd Coil size Is 2nd gen different than 1st gen?
- Roll pan help
- 2wd and fitting 30X9.5R15
- 12,000 Mi tire update
- Cold "Hard starts" Better Now Since I.....
- Overheated now runs horrible
- Annoying Rattle
- green horn
- Update on my problem.
- tps issue or no?
- Rear End Carrier
- oil light question
- vacuum hose kit?
- 1990 dakota while doing 70 mph died.
- steel wheels for 33in tires?
- Replacing fuel line on a 94 Dakota V6 3.9
- ecm interchange
- '91 3.9, sky-high idle, IAC?
- 95 3.9 v6 mystery miss fix
- suspension lift and shock help
- 93 Dak 4X4 grinding/binding
- 2.5L TBI to Carb Conversion
- Plenum Gasket
- Stereo malfuntion. No power
- Project help needed
- auto shut down fuse
- My Cruise Control is HAUNTED
- steering box tightened? Bushing kit?
- 94 dak hard shift on rebuilt trans
- Starter moter help - help!
- 1994..delay wiper and fuel gauge...
- lift combo help?
- 89 Dakota engine problem
- Wiring
- Issue Starting
- Headlight's turn off while driving
- Constant moaning coming from the drivetrain...
- trade questions?????
- muffler help plz
- 92 dakota cranks but no spark
- master cylinder lines to proportioning valve
- Changing transfer case fluid.
- 3.9l to 5.9l swap question
- Another code thread
- 93 Dakota 4x4 3.9 Mount question
- 92 Dakota 5.2 PCM?
- Single cab subwoofer
- Tuning options?!
- Clunk?
- New Electric Fan install.
- how correct is this site.
- I need air
- starting problems
- Plenum Fix
- Removing Cab and front Fenders?
- What are the dimensions for our bumper/air dam
- Interior Work
- HOORAY!!!! I get to spend more money.
- A few questions about scoops
- posi gears wanted for , 94 dakota 2wd
- i think i can rukke out the IAC
- stalling problem 1989 dodge dakota sport
- Optima Yellow Top batteries
- Tail lights
- Dodge Dakota for first car?
- 1990 v6 power drop outs and stalls
- Brake Master Cylinder Question
- 1994 Dakota....grrr
- Wheel Spacer ?
- Need 1991 Dakota Door Window Belt Mouldings and Channels
- 94 dakota with code 11 and oil lamp on, wont start
- 5 speed swap
- what would it take.
- need another opinion
- Need help, upholstery and interior work.
- need a little help, does anyone know
- can ni lift a 1995 dakota 4x4 with the 318 v8
- 1995 dodge dakota
- 92 3.9l Died and wont start - code 11
- My first 4x4
- 1992 5.2 dakota current draw
- 90 dakota exhaust
- Water Pump Question
- check engine light?
- turbo the 5.2
- 89 dakota v8 project
- 92 5.2 with some small issues
- 93 Dakota V6, A/C blows from defroster on throttle
- Alternate options to carpet?
- 5.9 Motor
- 95 4WD Ext Cab Parking Brake
- Need assistance with NOx on emissions
- 42RH Transmission issues 95 dakota 4x4
- rollbar
- Cam help
- 89 3.9L timing
- exchange 1992 A500 for other A500
- transmission info
- Open Air Filter
- I'm New , and I did try and search
- need quick advice on fuel gauge/new sender
- 1995 rear end and heads
- Please put year,model & engine when posting
- Plenum gasket
- What do I need to do and check to start up a Dakota thats been sitting
- Timing Chain Question
- Cutting bed to access fuel pump
- door wont open outside
- 2.5 to 3.9
- Bench Seat Removal
- 5.9L confusion
- 95 dodge dakota
- 1988 3.9 surging then dies
- Service manuals in FAQ
- 6-pack scoop
- 93 Dakota Paint Repair
- Starting and idle problem
- Truck intermitantly wont start.
- Swap question
- 88 dodge dakota np535 to an ax15
- Diff tags?
- Blend Door
- Replacing rusted fuel lines along frame engine to pump in tank Help??
- cam and crank bolt torque specs..?
- Hard tonneau vs. canopy
- Wiper Help
- Stalling after starting, only after starting.
- 1992 brake problem -
- Need some help
- 87 no start
- Lowering a 93?
- just wondering
- e.g.r. system elimination?
- Oil Pressure Help
- 1993 dakota code 27 troubles
- Info needed on 46re trans swap!!
- Cruise Control
- How can I check my AC refrig?
- 3.9l magnum timing cover HELP!!
- Parts Truck
- AC
- shock lift??
- Tranny swap in 94 dakota
- Engine turns, no spark...
- Pronounced "clunk" when shifting from Park to Drive or Drive to Reverse
- 95 SLT Ring & Pinion Stock to Towing?
- Soon to have reproduction 88 and 89 Dakota Sport decals!!!!!
- new spindle?
- burning clutch smell from brakes
- sounds like i have a big cam
- Trans finally gave up!!! Death of a 42re!
- 94 Dakota loses all electrical power
- Best tires for SNOW!!! 31 inch
- Fusible Link Delete
- Also just wanted to say "What a great Dak site!"
- Looking to install hood scoop OR Snorkle on my truck
- 3.9 to 5.9 swap ?s
- Transmission
- Not running smooth
- 92 Dakota 318 to 360 conversion/flex plate
- Odd engine problem
- ANTILOCK and BRAKE light
- 1996 dakota sputters then runs fine
- Fuse Problem? 4 birds with 1 unknown stone!
- 1996 Dakota front differential
- 94 Dakota EGR system help
- New Dakota owner
- 91 Dakota Shaky shaky rear end with noises
- please help
- finally back in a Dak....
- clunking noise when spinning tires
- Paint job prices?
- What are some really wide rims?
- Canopy Question?
- Add-A-Leaf
- How many miles does your dak have on it
- Need help wiring DVC subwoofer
- torsion keys????
- Dakota Door Handle / Latch
- Tranny question on a 89 (5spd)
- 93 Dakota v8, fi, automatic
- Trim piece
- 93 dakota sport body lift ?'s
- gauge cluster
- Problem with fresh clear coat
- Is your 4x4 like this?
- Leveling kit
- Brakelines
- Ignition Switch
- 1989 3.9L no oil pressure
- New electrical problem...dome light, map lights stay on
- clear tail lights
- Battery Gauge fluctuates
- Anyone need parts!!!!!!
- 93 318ci 5.2l 2wd auto. expansion valve leak...
- 1992 Dakota LE -- no headlights, except on HIGH beam
- 1995 Dodge Dakota SLT 4X4 Fuel Injected 3.9L Magnum V6
- Removing injector wires from 94 3.9
- Fuel Pump / Filter?
- Transmission advice
- Strange Rear Light Issue
- Torque Converter woes! need some assistance
- Few problems I need to fix.
- Revamping 4X4 to engage by cable
- where to find...
- Need an 87 2wd v6 auto trans bracket
- Power Steering Leak
- will it fit?
- 02 sensor blows asd fuse?
- Up and Coming
- Looking for a door
- Fuel gauge sending sunit
- 1991 Dakota is driving me nuts. Randomly dies.
- Error code 32
- auto to manual swap questions
- Pre Cat O2 sensor
- will tires fit?
- axle splines?
- Rough Country 2 inch suspension lift
- 91 dakota 4x4 question
- Brush Guard/Light Bar?
- headlight problems
- Mileage versus power versus efficiency
- 87 3.9 Carb Adjustment
- 94 Dakota Leaking Rear window
- How To: Fix Gas Gauge
- thoguth i would ask here
- Dakota Badge
- Argh I'm so angry right now. (Another Rad issue)
- Performance computer
- 3.9L Non-Magnum Engine Swap
- plans for after the truck dies
- stupid tranny question?
- little questain. nothing major just wondering.
- lound noise? help
- shocks for my 93 sport
- V6 information
- lowering block kit
- Will 89 bumper fit a 94
- 96 4x4 problems
- 4x4 Steering Stabilizer
- new truck, help with codes
- Base timing for 92 w/3.9
- 33's on 1st gen dakota?
- suspension lift? plz help anyone
- Loose shifter
- Gas Tank Straps
- 3.9L V6 crank bolt - size?
