View Full Version : 1st Gen Dakota Tech
- upgrades ?
- Front Diff Problem !!!
- Giving a more youthful appearance (interior)
- Still a couple questions
- 2wd spindles on 4wd control arms
- new guy
- 87 Dakota 3.9 Running Rich
- Seeking advice on replacing wiring harness
- how do I remove starter 1993 V6
- 1995/96 Dodge Dakota won't stay running in gear
- Belt squeak after front engine rebuild.
- Removing my E.G.R valve on my 1990 Dodge Dakota. 3.9 V6 2wd
- CAD Question
- Did work in Coolant System now Thermo won't open?
- Help! Need tips on changing brake switch on 91 Dakota
- Loose mirror arm
- Mopar PCM?
- 93 dak 3.9 needs new fan clutch
- 95 Dakota SLT 4x4 Front Drive Shaft
- Starter
- Question/opinion
- What size are rubber hoses on transmission?
- Lot's to fix, need some help
- 3.9 dakota with V8 throttle body help
- Dodge dakota lift plan
- '95 Dakota w/throttle surge
- 94 Dakota - Engine Dies While Driving, Restarts in 10 Minutes or Less
- Finally! 5.9L
- Is this too rusty??
- 3.9 Dakota OverHeating
- Really low dakota
- 1995 Dakota Idle Problems
- Timing question for 318
- trans issue
- Front Axle CAD Question
- 1994 Dodge Dakota HELP!!!!!
- Ram/Charger Taillights Fit 87-96 Dakota?
- 1990 Dodge dak 2wd
- Brake Booster
- Bent Mirror
- 89 magnum 318 swap COMPLETE!
- 3.9L True-Duals?
- Steering gear
- Lock up Torque Converter problem?
- Dakota Rebuild
- erratic idle
- v6 headers needed
- OMG this is frustrating!!!! help please
- Stripped out caliper bolt hole...help!
- HELP!! 1989 Dodge Dakota Shelby 15k miles
- loud crunch!
- need to ask a question
- A518 trans help
- No spark to plugs
- Value of my 89??
- your opinion on the wheels
- 93 dakota will not start
- Steering problems
- Make All Dash Lights Come On?
- v6 idling to low?
- 94 4x4 5.2 Dakota lift help
- Radio wiring
- Transmission Swap '95 to '97
- Gas Guage issues on 1988 Dakota
- 4x4 Shift Lever Rebuild: How to....
- 1993 Dodge Dakota LE Extended Cab 2x4
- 3" suspension lift, questions/concerns.
- starting problem 1990 dakota
- Clutch recommendations
- Towing question
- Wheel spacers?
- crossfiring
- Rear Diff Leak?
- 4x4 shift lever
- Who wants an easy $100
- 1992 2.5 cam!
- 94 V6 Lift Help
- Wont shift into o/d help!
- Need Help on Lifts!
- Can I add atf to dexron?
- 46rh won't shift from first
- performance pcm
- Wheel won't come off
- v6 dakota cams when cold
- 87 Dakota engine swap
- Weak Starter?
- 95 dakota 318 auto ?'s
- airbags question
- Tailight houseing screws
- 93 V8 Low Fuel Pressure
- power window and lock issue
- new from ky
- 96 Dakota Horn not working!
- Replaced IAC FOUR (4) times - it was my PCM :( - here is how I found out
- flow master super 40 and high flow cat?
- CODE 053-COMMUNICATIONS ERROR/PCM FAILURE - LOOKING FOR a 4886660 PCM - got one???
- Possible Rear Axle going out?
- dakota questions, need some help.
- Clunk noise when turning steering at low speeds?
- Transfer case removal
- '92 Dakota Brake Lights not functioning
- Tv cale
- Omg wtf ufb
- upper/lower ball joints wont budge
- Tranny fluid question
- 93 v6 Dakota Idle Ruff
- 87 Dakota overheating
- Ignition switch wires. which color does what?
- Hood scoops
- my 1995 dakota
- '93 Transfer case EMERGENCY
- speed sensor problems
- 5.2 coolant leaking from sensor
- "Searching" trans
- HELP Trans Issues
- Weird Steering Issue
- Convertable
- 89 dak with ???
- EGR question?....
- Window Sweeps
- Correct VIN for '94 Dakota?
- stay far away. stay very very far away
- Hi Everyone
- O2 oxygen sensor voltage - normal???
- what does a cold air intake do for my truck?
- Speedo issues
- Coil not getting power
- Got rid of that Nose Bleed
- Automatic tranny linkage retainer....gone.
- holley throttle body
- new transmission
- idle air control valve
- V6 to V8 Swap?
- Part # needed
- 1995 Dodge Dakota Wiper Linkage Problem
- misfire help please
- progress of my truck as of now...any suggestions?
- Bad frame rot
- 89 transmission problem
- seat and oil filter question
- 95 tran into a 92?
- 225/75/15 tire rub question?
- new too this
- Motor has miss
- 88' dakota, Steering column problems.
- Wont run
- very odd stalling question
- Brush guard?
- timing question
- 1992 5.2, intermittent starter issues
- A/C stuff.
- '90 3.9 Hesitation/Stumbling/Stalling
- timing chain skipped
- edit: Transmission Issues, please Help?!!?
- Help!! i need some reassuring here about the latest fix..
- 1988 3.9 Air Cleaner help...
- Front end lift 1995 rwd v6
- Bad experiences with my 95 Dakota V6 - no clue after multiple upgrades :(
- if your having slipping issues check here --->
- v6 timing chain rattle?
- How do you clear codes??? 95
- Control arm bushings?
- Fuel pump problems
- 1989 / 1992 fitment questions
- If your having stalling problems.. Look -->
- v6 cranks a lot before start
- Engine on the outs please help
- possible a/c switch
- 94 dakota 4x4 3.9 rough idle
- Performance ignition coil?
- improved gas mileage?
- fuel injector upgrade
- 94 dodge dakota 5.2l 4x4 stalls while driving
- 95 Dakota questions
- fuel line replacement
- RPM Pulsing
- Large brake leak 94 Dakota
- Crank sensor???
- 1993 Dodge Dakota needs more power without a swap?
- New Tires!
- axle questions???
- Engine help!!!
- Ford 8.8 rear into 1988 dodge dakota, 2wd.
- 4x4 steering gear adjustment
- adjusting transmission bands
- rear axle compatibility
- Half Shaft Removal
- Center Console
- 1996 4x4 42re tranny problems
- i need a really cheap gill/brush gaurd and wheel spacer
- Alternator Not giving 14v to battery
- cruise control swap
- high rpm power loss gets worse engines warms up
- Knock and Squeak
- 95 Dakota V6 - stuck in overdrive :(
- Alternator Died.
- Transfer Case, major noise.
- Not so cold air intake for 2.5L
- No fire 90 dodge dakota 2.5
- Radio Question
- Moved Distributor By Accident....
- 3.9L performance upgrades
- No body lift
- Not getting spark
- i need info
- 92 dakota died
- 94 Dakota 3.9l big green wire driver side
- 231 to 242 swap questions
- 94 Dodge Dakota dying at stop lights
- no spark when cold?
- ? Leaking auto trans at seal after transfer case swap??
- Help
- 95 Dakota 3.9 stalling when coming to stop
- 2001 NV3500 in 1st gen Dakota
- 220,xxx miles on original motor and tranny?
- front driveshaft removal
- Header wrap
- Getting new tires..
- 96 4x4 V6 autotrans problems
- Air Cleaners
- Ist Gen Rear Bumper
- Injector swap/questions
- Need help with alternator/charging
- Need Help Choosing Exhaust
- Code 27 and 5.0 Injectors
- notorious coolant leak found
- Front shock mounts rusted
- '93 Vacuum problem
- Error Code 32?
- 1st-2nd Gear Slip, Auto Trans, V6, Fluid Full
- Electric Fan Swap
- 94 2wd 5sp trans problem
- engine swap question
- hood mods
- In desperate need of help!!!! Electrical bull****.
- Stalling issue !!!
- Parking Pall
- 94 dakota lost 2nd and 3rd gear
- Convertible top pictures needed
- new steering wheel.
- July ROTM voting is open
- 4'' suspension lift question
- it stalls
- clock spring
- 1990 Dakota with a 12in Pioneer sub
- Which way do oil seals face?
- 95 dakota starter issues
- 5.2L Coil & Leaf Spring Alternatives?
- fuel line at rail removal
