View Full Version : 1st Gen Dakota Tech
- reproduction air cleaner decal
- 1995 Dodge Dakota 2wd Upper Ball Joint? Help!
- Simplifiying carbed 3.9
- Aftermarket steering components ?
- 95 5.2L Code 27 Demon
- Off-key drain help please
- 1988 Dakota V8 swap
- transmission
- No Start issue
- 95 Dodge Dakota Problems
- obd 1 code 41, 15, 17 help please
- drive train swap
- 95 Dodge Dakota Rollover Valve hep urgent
- lift torsion key install
- Difference between 1987 2WD frame and 4WD
- trailmaster suspension lift
- '96 Dakota Brake Pedal Goes to Floor
- abysmal fuel mileage
- New to the place
- 1987 Dakota upgrading to 318 and 4 wd
- What diff locker should i get ?
- Truck is leaning to passenger side
- 96 DAK Sport 2.5L 2wd Cam sensor?
- 93 dak engine bay wire harness
- Shifter motor question 95 4x4 5.2 5spd
- fog lights and covers
- 92 Dakota Check engine light question
- 93 3.9 fuel line connections
- Battery Not Charging
- Bump Stop
- Taillight wiring help
- driver door
- Cab and box vibrating
- transmission issue
- ECM Out on 96 DAK Sport 2.5 manual trans ?
- need upper control arm for 92 dakota 4x4
- What runs the Fuel pump 96 DAK Sport 2.5
- Question on new wheels
- Transmission leak identification
- lower control arm question
- upper control arm question
- harmonic vibration at highway speeds
- 1987 Dakota inline 4 to 318?
- Left Clearance Light Lens 87 dakota
- Mileage question.
- Speaker problem
- Dead oil pressure gauge on '95 Dakota 6L
- side mirrors
- Baja fenders
- 1993 OD button flashes on and off
- Trailer Brake Wiring Help!!!
- Tires
- Flares What year are they
- Questions about 93 dakota.
- 92 Shuts Down
- Supercharger on 1993 5.2l?
- Jba y pipe plz help
- Jba y pipe ?
- 94 dakota issue
- anyone put a drain plug in trans pan?
- adjusting the kickdown cable???
- Paint matching "Light silver star metallic" on 93 Dakota
- jump shifting
- 87 Sending unit retainer
- Coolant leak problem
- Transmission fluid Flush or Change?
- suspension rebuild questions
- maintanence required light flashing while moving
- Where to find aftermarket parts bed bar brush guard, etc.
- DAKOTA SPORT 1995 4X4 5SPEED Four wheel drive problem
- Got my truck painted
- 92 5.2L running rough. Ideas?
- Windshield Wiper Not Working
- S.o.s. Help post 3.9 rebuild
- replacing timing chain
- '92 Dakota, squeal from rear end.
- have to add fuel to tbi to start 89 3.9 Dakota 4x4
- Twinkling gas gage
- 239 3.9 v6 performance
- 94 Dodge Dakota No Spark
- Twitchy battery gauge needle after new battery
- Update-94 2wd 3.9L
- Heavy Duty Wheels?
- Daddy's pride and joy
- 94 fsm
- 95 Dakota Headlight Probelms
- Shift lever has spongy feel - 92 dakota
- Will a 2nd Gen grill guard fit my truck?
- 87 new process 207 and 1988 np231 difference
- no high beam
- Brake lights not working.
- Wierd Brake Problem
- what would be better/cheaper?
- 42rh/a500 transmission experts please chime in...
- 1991 Dakota very high idle when started
- 91 Dakota - Overdrive Probs
- 93 Dakota y-pipe removal?
- Fuel guage
- 1992 Dakota 4x4 LE, No start
- Headlights randomly cut off???
- '92 2.5 Won't stay Running
- Fan hitting tranny cooler line
- Seat Belt Replacement
- 1996 5.2 cranks but won't start.
- Headlight Adjuster Screws
- 94 Dakota 318 5.2 L has a running problem
- Injector sizes?
- Corrigated rubber tie rod boot leaks
- FREE: Rear drum brake parts (esp. 1996 owners)
- fuel pump not working
- Anyone have a 4x4 5 speed transmission cross member?
- metal skid plates?
- Removing pins from gauge cluster connectors?
- trans cooler line questions..
- No brake pedal at all
- 95 dakota coil problem?
- What is OE brand for..
- 1995 SLT ext cab Door removal
- carb to tbi
- 95 dakota auto two wheel drive idle and speedometer fluctuations.
- Have you had problems with AutopartsWarehouse?
- Mopar Ball Joint Socket?
- 1990 dodge dokota 3.9L
- Bad A/C coil... HELP!
- Humming/vibrating??
- Brake Controller
- 1995 Bed Removal Help?
- 90 won't crank
- Looking for FSM's
- R12 to 134A conversion.
- burnin up light switches ?
- Looking for FSM's
- Ignition or Fuel system?
- Need some help with identifying vacuum lines
- Modded 42 or 44 mm EGRg throttle bodies?
- 1995 Dakota won't turnover
- WHat does this indicate
- 30 amp air conditioner fuse blows when turned on
- Code 11, won't start
- Bogging issues.. Misfiring..
- 1993 dakota 5.2L idle and fuel problems?
- timing chain cover R and R
- Spark plugs
- 77-78-79 360 in a Dakota
- Steering damper install
- 1994 Dakota overdrive issue
- Distributor getting wet?
- 96 2wd manual. replaced clutch and now won't start
- Codes on a 1996 dodge Dakota
- Worst plug wires EVER!
- OBD1 Codes? Need Help?
- Oil Pressure
- What's that tab on the O2 sensor supposed to plug into?
- '94 Dakota Auto Transmission Issue
- Resistor maybe?
- Motor swap, no clutch!!??
- pre filters and moving stock air intake hose.
- Starting issues
- no o/d after lockup switch
- What does this Oil Pres. reading mean and do the codes affect it?
- ignition lock cylinder in a 95 Sport
- time to build
- Wheel spacers? Do I need them?
- Easiest way to install shifter linkage?
- Ultra power o2 sensors
- 95 Dodge Dakota v6 4x4 transmission
- HELP!? 89Dodge Dakota 3.9 v6 misfre
- Swapping back to carb?
- Timing Chain ?s
- Repair Manuel
- 4WD and V8 swap
- Engine swap for 1995 dodge Dakota
- Ruff at low rpms
- Fun with the 4WD Lower Control Arm Bushings
- Where is my Crankcase Breather Filter? '95 2.5L
- Code 41, Draining battery, and frusteration
- 93 4x4 whinning roar
- Third brake light on 94 dakota
- Tranny question
- 9.25 disc swap?
- 93' Magnum heads on an '87 block?
- labor cost
- Air temp sensor question / OL stall
- ??????!!!! wat size ball joint socket
- 92 dakota 4x4
- where does this connector go.
- 93 Dakota Electrical issue
- Rt rims question
- Just water pump?
- free 1st gen truck bed/gate covers a bug guard. houston, tx
- A-500/A-518 transmission questions
- Selling the 87 Dakota
- my CPS broke while replacing torque converter.. got spark back but it keeps stalling
- 93 coil arcing fire
- Transmission interchange issue.
- Where to mount off-road lights?
- transmission interchangibility question
- Diagrams
- Cut off my cat now code 32
- 93 Dakota turn signal/wiper lever
- fuel filter replacement
- Has anyone installed new TV Cable?
- StanDon
- 1991 dodge dakota stalling
- 93 Dakota 5.2L Exhaust Setup!
- Dodge Dakota keep dieing
- Shudder at 1500 rpm and above (trans fluid?)
- Does anyone have a transmission oil temperature lamp?
- 1991 Dakota
- No Overdrive
- Back Up light socket (bulb holder) for my '92 Dakota
- Timing Chain Replacement Questions
- control arm compatability?
- front suspension help...
- Cyl 8 misfire help
- Emissions Test (Texas) fails
- Just got Tranny serviced..How normal is this?
- Help please!!!!
- Shifter linkage removal
- 1994 dodge dakota, doesnt turn over
- Symptom: Engine sometimes increases revs by itself. 95 2.5L Dakota Sport.
- 7.25 to 8.25 rear axle swap...will 2wd work in my 4wd?
- sas help
- M1 or ked mod ?
- idle too high
- 1995 - Inside door panel removal (manual windows/locks)
- doing top end work info needed !
- Now what have i gone and done?
- Early Gen 1 4x4 swaybar bracket mounting method ?
- Compatible transmissions?
- Removing Torsion Bars from their sockets
- 89 no spark seems no one knows!!!!
- Overdrive and Cruise Control Troubleshooting In Progress
- Autolite Plugs!?
- 95 Dakota 3.9L running poorly
- 89 dakota V8 swap?
- Brake Shoes Wear Unevenly
- Code 21
- 93 dodge dakota snorkel and stack
- 3.9 LA (Pre-Mag) Mods Revisited
- 89 Dakota Sport Concept i stumbled across,
- 1991 Dakota high idle when started hot or cold start
- under drive pulleys ?
- Power issue
- Need transmission help
- 92 dakota stereo problem
- Beltline on 1990 Dakota
- 95 Dodge Dakota Automatic Transmission Problems
- new doug thorley headers ! want to run true dual
