- New bumper/brushguard!
- I got new toys
- DOTM Come vote!
- not dakota related but mopar related 2010 road runner
- 93 dakota turns over no start
- payload capacity? and disabling the ignition system for a compression test
- cross threaded spark plugs
- Some wheeling pics
- Gauge Pods
- 92 dakota major problem
- Speaker depth question....
- fuel pump
- Cleaning Oil Pan
- a little bored today so i camo'ed the truck
- Old gauge (dumby lights) to dash with all gauges?
- 95 dak 3.9 auto 4wd 1st gear whine, 34k miles
- IAC on 87 carb model?
- Looking for tan/doeskin interior plastic pieces
- Rusto paint job on my 88 dak
- 91 Dakota club cab big block swap
- Alternator upgrade....
- Transmission question?????
- 1994 dakota heater fan doesnt work (fan help)
- Starter solenoid contact replacement
- Various questions (Be prepared, big post)
- New gears and sure-grip question
- emblems
- Noise....
- Been Way To long
- Cold air intake?
- Almost Done!!
- Speedometer problem
- werid problem
- Nov. DOTM Nominations
- 4wd problem...please help!!
- sorry guys
- Got my cruise control issue solved!!
- Source for carpet
- Dakota interior replacement
- Windsheild wiper issue
- Sold my 94 Dakota
- HELP!!!!shuts off when it reaches operating temp
- Fuel pump/filter
- FAQ file downloads
- 91, 5.2, no spark...
- 93 Dak 4x4 axle hub nut size?
- Gas tank filler neck
- pulling tranny...need advice
- Traction Bars for 4x4s!
- bent...uh?...WTF
- 5.9 swap
- Man I wish I would've
- Forum issues?
- 1995 SLT 318 V8 exhaust question
- building a 3.9
- a little problem
- Turns Out There is a problem!!
- Water pump problem
- 91 Dakota 4WD problem
- New diff!
- Dayton Timberline AT II
- 1995 dakota 4x4 fuel issue
- Got my build sheet....
- Transmission fluid question...
- Will it all interchange?
- timing belt change ?
- Air in Brake Lines
- 92 dakota heater core swap
- Popping noise in the exhaust under heavy deacceleration
- Name that screech?!?!?!
- What Years Fit???
- Door Hinges Cracking apart, and I finally got it fixed (TONS of pictures)
- egr sys woes
- 1993 Dodge Dakota V-8 5.2L ignition coil problem?
- Idle is surging
- What Happened/did you do, to your truck today?
- question about 5 speed swap
- Got the clear lights
- seats....
- Synthetic Oil Dakota Question?
- rebuild
- Stereo upgrade/Electric fan help??
- FIRE!! Vacuum/Smog Sensor
- bench seats
- Fuel system? or fuel pump?
- Gas Mileage ?
- My Last Tire/Wheel question
- Stereo, Dome Lights, Hood lamp, Power Mirrors problem!
- TV Cable
- trans problem
- pulling codes????
- Need help with truck!
- DIY: Rebuilding a Trac-Lok LSD
- Tires on wheels question
- my wipers quit
- first dodge dakota
- Wiring Harness,
- local junkyard prices
- Need Big help
- Door Hinges cracking apart at Door
- '92 Will Not Idle When Cold
- 95 Dakota ASD fuse keeps blowing
- TPS Question
- 92 dakota ...drivin me crazy
- cv halfshafts
- Is it true that Mobil1 isn't true synthetic anymore?
- Anybody have this exhaust system?
- Clear Headlights
- Intake Holley Carburetor hissing??
- I can't seem to stop...
- pitman arm. 93 dakota
- Radio Power shuts off when i turn on head lights/dash
- EGR Tube Problems
- Question about truck I just bought
- Need some help...
- might sell my dak for a dodge ram 2500
- question about a ranger roll bar
- Same Problem?
- dakota skipping
- Air pump removal - 91 5.2ltr...
- Fuel pump???
- painting a muffler
- tires
- dakota brush bar--1992
- 92 dakota
- motor swap
- truck has no power
- hockey puck lift?
- dash lights went out a day after stereo install??
- Torsion Bar Question
- Rim and Tire sizes
- 93 radio wire diagram(4 speakers) colors?
- 93 parts replace question
- Gas Gauge
- Real time help heater core
- 1992 dakota wont stay running
- body work
- My 87 Dakota Express
- My 95
- Sway Bars??
- Motorvation spacer and K/N Filter
- powerbraking?
- wheel hub assembly
- Truck takes too long to start
- My 1992 Dakota
- How to disconnect fuel lines from fuel rail?
- Control Arms
- Few stupid questions
- 87 3.9 2wd vibration problem
- 2H or N on a 4x4 93'
- 1992 Dakota
- Fuel rail/line retaining clip.
- sway bar
- Engine temps....
- Stalls When Restarted
- code 15 help?!?!
- question..
- leveling
- I need mroe lift,
- odd issue
- Which manual transmission to use
- will 35's fit
- 93 Broke Shock bracket/TAB
- Radiator leaking
- New Dakota Owner, I need help with a few things
- Slave Cylinder?
- Okay heres a poser for you guys ABS
- Trucks been sitting 5 years... alive again!
- a few pictures after bath
- Ok help NP435 In 91 dakota 2wd
- 1993 dodge dakota Trans Rebuild (46rh)
- What size transmission do I need?
- I dont drink it, but I love beer
- pre-running a 1st gen
- 35" tires
- Turbo
- 93 dakota Failed Inspection help
- New guy with a problem
- Looking for rack and pinion or 93 Dak 2WD
- T-case slip joint
- New
- My new TOYS!! 10,000Lbs Winch
- Vacuum hose problem...
- Rear end
- front axle swap???
- speaker quextion....
- 1990 Dakota will not start when warm
- Bogging down problem
- squeaking sound
- No Spark
- Need info on a 1994 Dodge Dakota 4x4 transfer case
- Another new part!!
- 92 dakota - dies when put in gear while cold
- timing cover/harmonic balancer trouble
- 5 speed swap
- Awesome Junkyard Find!
- Sticky Rear End?
- Removing body trim
- MD Newbie w Question 1995 Dakota
- 318-360 swap help
- no brake pressure...
- '93 Dakota 5.2L starting problem
- Noise that i cant figure out!!!plz help.
- Temp gauge
- Linkage bushing?
- Clouded headlights
- Ignition Lock Cylinder replacement
- can't switch cold to hot (climate control)
- Control arms and ball joints....
- Front Differential Noise
- dodge heating system.
- 15" rim center caps
- Erratic Shifting
- first time wheel/tire buyer
- Random build opinions
- Aftermarket Gauge Install???
- Transfer case leak!!!
- 92 dakota stalls in reverse and while stopping
- Transmission oil change
- replacing clutch 93 dakota sport
- 87 aftermarket gauges?
- Dash board lights
- spedo/odo adjust for tire size
- 90 rear end
- 1987 dodge dakota
- clutch oddity
- steering Rack 1993 4x4 Dakota?
- flex plate issues
- DOTM Oct.
- 1992 Dakota choked
- transmission issue
- Just to make sure
- So close
- 1991 Dakota questions please
- spedometer
- 1993 Dakota Steering Problems
- Water Pump Question
- 93 v6 flywheel to 2000 5.9L
- WTF! no more overdrive!
- New member, need some FLUID info help.
- DOTM Oct. Nominations are open.
- Where can I find...
- PCM swap from automatic to standard?
- Vibration....
- 88 Sport
- need v8 torsion bars
- soild axle idea
- Rear end pushing
- Got new parts!!! :D
