View Full Version : 2nd Gen Dakota Tech
- replacing rear speakers
- Rust
- Muffler change
- 2000 Dodge Dakota 5-speed
- Looking at a good deal on tires; will they fit? Help!
- 97 Dakota solid axle swap
- 01' Dakota Will Not Crank
- 2004 4x4 engine swap
- 2001 Dodge Dakota Sport 4.7L ground wire locations?
- Dakota won't start
- 99 dakota parking brake question
- What Transmission’s will fit my 1997 Dodge Dakota
- door won't unlock with key
- Tips for bleeding 3.9L cooling system?
- Wrong Transfer Case??
- 2001 01 Dakota 3.9L Crank no start No fuel No spark Replaced PCM, TPS
- PO123 on '98 Dodge Dakota. 3.9L, V6
- 2004 Dakota short help
- rear carrieer
- 2000 Dakota starts but dies without throttle
- Starter going bad?
- Running and dash lights/radio won't turn off!
- p0340 issue
- what size are the thermostat bolts on a 2001 ram van 1500?
- Heater on floorboard=cool
- 1999 Dakota 4x4 SLT Extended Cab 3.9L V6 PCM/Trans issues
- '99 Dakota 3.9 Radiator Fit
- Need some info
- Climate Controls Not Working
- jumping drivers door window switch
- Radio trouble
- Another interesting no start post
- 2005 Dakota
- Code p0306
- Dash Brace locations
- Any idea what is causing this?
- '00 dakota "r/t" half reverse issue
- Mike from California
- P0420 & P0302 code
- 00’ dodge Dakota v6, starter engages with battery!
- R/T Springs on 3.9 Dakota - Will it Work?
- 45FRE p0740...?????
- four wheel drive parts
- Having a problem finding a coolant leak
- '95 Posi Trac rear in 2000 Dakota
- number of valves
- Fuel Tank Venting Fumes Through Cap
- 2002 3.9l Quad - Difference between upstream o2 sensors?
- How to remove and replace AC compressor clutch bearing
- Plug and play LED headlights?
- Timing????
- 1997 Dodge Dakota 5.2
- Plausible 1st to 2nd gen swap?
- Question Factory stereo no sound,'99 Dakota.
- 2000 4.7 eng will it interchange in a 2003 4.7 Dakota?
- 545 RFE transmission filter keeps falling off
- 04 Dakota Rear open diff so Posi swap
- ABS brake litei go thr
- 97 3.9 dakota no heat
- 2004 Dodge Dakota No Crank No Start
- 2008 Dakota backup light not working
- Prop Shaft CV Joint Extremely Hot
- Dakota noise on 2wd
- Need help. Heater core problems antifreeze leak
- 2000 Dakota Seat Swap
- In Search of 1.7 Rockers - Magnum V6
- Idle issue
- Torsion bar raise?
- heater blower fuse shorting out
- Transmission clunk on hard acceleration
- Annoying shift indicator
- black heater core box vacuum line
- 2001 dakota trans lines to radiator routing
- Take off delayed shift from 2nd to first
- 5.2l 44re Dakota swap to a ram 1500 3.7l nv3500
- Replacing map lights
- Engine knock/click. HELP. videos included.
- Need a little help
- Low oil pressure
- Need help with CV axel / differential
- 99 Dakota 5.2l RPM issue, replaced sensors, reflashed, replaced transmission, help!
- ‘97 Dakota NP231D issues
- Fan Clutch for 2001 Dakota V6
- engine oil in radiator
- Abs sensor location....
- Front to rear brake line
- 2001 Dodge Dakota 4.7L Head Gasket and Timing Chain Job (pictures included)
- Starting and other issues
- leak/lbs/pressure.
- 2001 Dakota won’t start
- p0750 need advise
- Computer code issues
- Wheel Alignment
- 2004 Wheel/Tire backspace ?
- Temp Gauge Problems
- 1997 dodge dakota clicking noise on glove box
- Truck turning over, but not starting.
- Front drive (propeller) shaft
- 2000 dakota 4.7 cranks on second try to start in cold weather
- Engine roars
- 04 Dakota RWAL bleeding questions
- High-beam Indicator Always on
- 2001 Dakota 4X4 help
- need some help
- 3.9L to 5.2L
- 2002 4.7l dodge dakota issue.
- eating antifreeze
- Front band anchor help
- 1999 Dakota with 5.2L
- Please tell me what this plug is for.....
- change out positive battery cable
- Adding Cruise
- 01 Dakota wiring issues
- 2002 4.7l build
- Dead in the h20
- P0303 and 05 auto-clear?
- Tires
- fender flares
- Noise in front
- Need help with 02 Dodge Dakota .
- Not a simple blinker problem
- Lack of gauges after yard ecu change.
- Looking NV231 transfer case
- Remove Steering Wheel Lock Plate?
- Will It Run With Driver Airbag Unplugged?
- Engine swap
- 97 v8 2wd
- Vacuum line possibly open?
- adding a supercharger, should i upgrade stock pistons as well?
- Dakota ABS issue
- 2003 power heated mirrors on a 99
- Oil gauge is whacky?
- 2001 Dodge Dakota 42RE transmission oil pan gasket?
- 2000 Dakota 3.9, P0132 Code
- 01-04 Dakota rear end compatibility
- Can anyone help? Unheard of cab vent problem
- 98 Dakota Sport Cranks but won't start
- 01 Dodge dakota / 04 dodge ram 1500 Interchangable
- Dakota body on 2500 frame
- 97 Dak Trans Problems
- Crankshaft angle sensor
- Radio shutting down
- part # for o2 sensors?
- Interior heat not working.
- 2000 Dodge Dakota Should I buy?
- 1999 dakota ideal surges
- 04 dakota wont start
- torsion bar dodge dakota
- 04 dodge dakota
- One dime light barely on
- Blower motor /resistor
- 03 Dakota part out
- Scanner readiness O2 N/A
- Replace original speakers??
- Clutch bleeding
- Hvac, power windows and wipers gone
- 99 Dak Power Steering Issue
- How to tighten emergency / parking brake
- New Code After Cat Delete
- LIMP IN Please help
- How to replace parking brake lever handle
- Can someone show me emission vacuum hose routing
- At a loss on this issue, please help
- Bad Compression
- Need help
- Engine Swap - 2004 4.7L vs. 2008 4.7L
- What transmission
- P0455,p0456 and P01494 2002 dakota sxt
- P0500 2002 dakota sxt manual
- No key. How do I remove the cylinder or options around it?
- Do I *really* need to TDC piston #1 when reinstalling the rockers?
- Biggest tire with 3" body and T/S lift
- seat belt shoulder height adjuster locked
- Newbie. 2002 Dakota help
- 2000 dakota 4.7L v8, overheating
- Spare tire on a ram
- Power boost
- radiator cooling fan
- Transfer Case Questions '97 NP231 D
- Better gas milage
- 1998 Dakota Fuse F9 blowing
- Possible engine swap
- 2004 dogs Dakota transfer Case swap
- alarm
- serpentine belt
- Looking for some help with reverse issue
- 2004 Dodge Dakota Ebrake
- How many quarts of transmission fluid does it take for a overhaul on a 44re
- Oil change - now running 0W-20 in the 4.7L
- Engine swap question
- Another blower motor resistor thread.
- Can someone identify these wheels?
- P1491 Error code?
- runs rough
- 2003 Dodge Dakota Transmission Codes P0700, P0755, and P0846
- The project Dakota
- Newbie here, oil in sensor
- Oscillaiting RPM
- oil pressure drops
- remove broken spark plug
- 2000 Dakota loud whistling humming at speed
- Coolant system
- 3.55 vs 3.92 With NV3500
- Have a RPM Question
- Best stock suspension parts
- 98 dakota 5.2 question about current to coil.
- 97 Misfire Codes
- Why the hell do Dakotas rust out so badly?
- 01 dakota idling rough, bogs down
- Won't come out of gear
- 2001 Dakota Stalls when backing
- Truck turns over but will not start
- Wipers are comming on with the right turn signal.
- starter bolt size
- Need to replace the engine on my 2001 Dodge Dakota 4.7 L 4x4 Auto on a super tight bu
- 4bt in 2wheel drive dak
- Hello Folks New to the site Preacher Rob here
- "Sucking" sound and poor mileage
- water in cylinder 2000 dakota 3.9 v6
- stalling
- front driveshaft
- swaping parts
- ROLLER ROCKERS questions
- Is thia possible??
- 1999 dodge dakota 3.9 ltr
- clicking/popping underload..
- 2002 Dodge Dakota busted head?
- 3.9L Timing Chain
- 2003 Dakota top transmission bolts...
- Ideas for the Gauge Cluster PRNDL Slot
- 46RE compatability
- A question about plenum pans
- Help with Cheap and "Free mods"
- Last resort for snapped lower t-housing bolt
- Hey People
- Any heater core replacement tips?
- Single clunk noise
- 1998 Dodge Dakota stalls, backfires, and sputters
- Transfer case motor
- hub assembly
- Axle Identiifcation - not in truck
- Random sputter
- '97 Dakota Slave & CMC issues
- replace rear passenger brake lines, leaking
- Tranmssion swap p0731
- DIY for 2004 Dakota 3.7 V6 Transmission Service?
- Issue after rebuild HELP
- 2003 dodge dakota
- I have an oil spot behind my front drivers side tire. And my trucks acting weird.
- Power Windows
