View Full Version : 2nd Gen Dakota Tech
- '98 pcv confusion
- Radiator ID + trans cooler confusion
- Missing and popping noise at exhaust.
- Reverse, park signals for Pioneer headunit in 2004 Dakota
- Bigger tires/Body lift
- Dies in gear
- Horns
- Fan Shroud for my truck
- Ooof… how screwed am I?
- 1999 dakota 3.9l manual transmission
- All neutral 04 dodge Dakota
- Linkage
- No starter operation.
- @Magnethead... question
- Early to 05 and later 4.7l compatibility
- 2004 3.7 2wd engine replacement procedure
- Torsion Bar Removal (lower control arm replacement) - 2003 Dakota 4x4
- Replaced tstat, sensor, radiator and pump gauge is off
- Inoperable cruise control.
- Low oil pressure at idle when hot
- Slight advance at stop
- Cooked underhood fusebox 01 QC Dakota
- Weird vibration
- Shocks for 03 Dakota
- Cheap Performance Bump
- Engine time...suggestions for supplier?
- 1997 Dodge Dakota SLT hail damage from 2016
- Hard shift to drive, no power in 4x4 lo after front driveshaft replacement
- 1997 Dodge Dakota SLT Receiver Dryer replacement
- New tires
- 1998 Dakota sport no start after clutch
- The biggest tires possible
- Dakota 3.9 manual
- First Time Buyer (2000-2004 Dakota)
- Head gasket
- air flow from outside to inside?
- Window Issue
- Motor bogs down when shifting
- 1998 Dakota won’t start won’t crank
- Question about the transmissions for the 2nd gen dakotas
- Everything has stopped working
- Exhaust Headers Leaking
- 1997 Dodge Dakota SLT suspension rebuild
- Advice for bust proportioning valve
- 2003 3.9L Crank No Start
- Shifting issues.
- 2002 3.9 to 4.7 swap
- Overdrive control
- Question about disconnected connection
- 97 5.2L coolant temp sender not hooked up
- 2009 4.7 swap into a 2004 Dakota
- Bed swap?
- Need a part that's discontinued
- 3.9 remove and install pistons
- Dakota rear axle swap 8.25 to 9.25 & front ratio change
- Transmission not shifting after body swap Dakota 3.9L 2001
- 03 turn signal hyper flash
- 1997 3.9 distributor and injector timing.
- E brake woes!
- 1999 Dodge Dakota Seats
- 1997 Dakota 318 Magnum Crank, hard start issues
- Radio single dash line
- Replacement Headlights 1999 RT
- Which tires will fit dodge rims on my Dakota?
- 1999 Dakota 5.2L P1391
- 2003 Dakota cylinder misfire
- White (C1) Clockspring Connector Assembly Instructions
- Upper radiator hose hard as a rock
- heater core size
- 2002 Dakota No Bus No start po920, 921,999
- Published manuals
- 4th set of front shocks 144K miles - HELP
- Possible To Replace "Base" CTM With "Highline" CTM?
- Rebuilding brake hub on '99 Sport, 5.2L, manual, 4x4
- front negative camber+caster issue
- 3rd time rebuilt has blown oil out driver side gasket..4th time new engine
- JY PCM, ran then it did not
- Temp gauge, just marks without numbers
- 1999 Truck Bed Tiedowns?
- need help electrical issue
- New Clutch won't disengage
- Cat code/ same odd p2000 again
- Flex plate
- I'm clueless need help please 01 dakota
- High beams - CTM or mutifunction switch
- TSB 18-34-97 death flash and smog test HC
- Tuff Country Diff Drop Advice
- 1997 dodge dakota won't stay running
- Steering column problem causing door alarm to ring continuously
- Question about PCV valve 2003 Dakota
- 2000 Dakota 4.7L 4x4 random stalling problem
- 2002 Dakota No Back Up Lights
- Left Turn signal Issue
- Proper thermostat to use?
- Radiator swap in progress...
- rubber molding
- OEM sensors discontinued
- Proper coolant for the 4.7
- Long Tube Headers
- No bus
- Starter motor compatibility
- Dakota 2002 gear lever failure
- Selling
- Ignition lock
- 2000 5.9 Factory Thermostat.
- 4.7 cranks, then dies
- Help!
- Squealing from clutch?
- Parts
- HVAC question
- Intermittent Tinny/metal grinding noise in 2003 Dodge Dakota SLT 4.7L
- Swapping Durango parts to Dakota
- 02 Dakota stalling/dying NO BUS error
- Coolant Leak,Heater Core Placement,Firewall drain line ? 1999 Dakota Club Cab R/T
- Looking at a 2003 Dakota
- Help! I lost reverse
- Fog lights
- Oil Consumption/PCV issues
- 2001 Dakota 5.9L AWD - Headlight Issue
- Oil pan gasket
- 17x9 R/T Wheel Rim Centercap Paint Color
- Radiator replacement
- 4.7l can chain tensioner brands???
- Transmission question
- Tire wear
- HELP!!! 98 Dakota 4cyl Manual Clutch CRISIS
- Tire size
- 2001 Dakota Sport CV Issue
- Noise only when in 4WD
- Tranny
- Tips on Auto Transmission Fluid & Filter change - 2002 Dakota 4.7 45 RFE
- Fuel gauge not fx after on jacks
- Acceleration issues 1997 5.2L v8 mag
- 2000 4.7 V8 Magnum and 2003 4.7 V8 Magnum
- 2004 Dakota 4.7l Engine 1 fuse keeps blowing
- 2004 Dakota 4.7 L won't Idle AIC??
- Heater core tube seal
- No speedo and in “limp mode” 99 R/T
- Transmission oil pan leak
- 97 Dakota flickering Led headlights
- persistent misfire in the 1st cylinder
- Potential Purchase: NEED HELP!
- Rear differential questions .
- parking brake cable removal
- 5.9 swap
- Add OEM remote radio switches for use with After market head unit
- Woodruff Key 99 239
- Lighting question
- 2003 sway bar questions
- Intake manifold question
- A/C Diagnostic
- Hard to shift in 4HI
- No Air Through Vents when Engine is Under Load.
- 02 Dakota 4WD- Low range without 4WD?
- Console lid sizes
- Torsion bar removal
- 2003 lower ball joints
- No gages with a "No Bus" message
- 8.25 Trac-lok Differential/Locker replace
- Random misfire code
- 2004 Dakota 4.7L P0172
- transmission codes P7128 and P0760 any help?
- quick question about rear end sizes
- HVAC LEDs
- Spark plug EOL
- what size inner tie rod tool will work?
- 98 Dakota follow up
- 98 3.9 Dakota wiring harness problems
- Tranny issues
- Rough idle and vents not workin
- Reverse lights not working
- 4.7 oil preference
- My 02 4wd suspension is shuttering a Lot at slow speed w/o breaking
- 98 Dakota limp mode
- 02 DAK Overhead Console Display Does Not Update
- 02 DAK Mystery electrical connector under the dash
- 2001 Dakota 4.7 Timing ?
- Truck Build Ideas
- Ignition Switch AC Blower Short
- fuel line size
- Standard cab question
- No Feedback Steering
- My hunt for a Dodge Dakota
- The rear gear ratio of my truck, in all its glorious bizzarity...
- 2004 Dakota 3.7 quad cab 130k miles
- Howdy to all here on the DF.
- 2001 Fuel Lines
- Where to find a steering knuckle
- transfer case help
- paint color
- What sensor is this by the distributor?
- limp home mode trany problem or result
- 97 Dak - AC Stuck in Defrost Mode -
- 2004 3.7 almost entire 2nd bank of engine is missing
- mild tuning of the V6 engine
- AC Clutch Squealing
- New Member from Central KY
- Another tranny post. No reverse.
- Plastic (potentional) takes out rear end ?
- 2003 dome light
- air problems
- Good bye
- 99 Dodge Dakota 4x4 3.9l transmission issue
- HELP 99 Dakota V6 4wd 3.9L
- Interchangeable parts
- 99 Dakota won’t start
- NO START 1999 Dakota V6 4wd
- change Speedometer in Transmission
- Rust incursion
- 5.7?
- Lost gears after transfer case replacement
- AN?!?
- Ignition/starter fuse keeps blowing
- Transmission Cross Reference
- Radiator Fan Shroud with Coolant Resevoir
- On Here Again Seeking Guidance Oh Great Dakota Gods
- Oil pressure issue 2004 3.7 magnum 260k
- Rear end swap Diff guts swap
- 1997 5.9 R/T 40K miles
- Need some electrical help - A/C control of a pwm fan controller.
- Frame Swap
- Pulls right hard after alignment
- Ignition problem 2001 Dakota
- 4.7 Misfire
- Need Rear DIF/complete axle for 1998 2WD Dakota, 5 speed
- 1997 Dodge Dakota 2.5 L conversions
- air charge temperature sensor
- 2.5L AC Compresor a DIY Job?
- Not sure where to turn next? Help please!!!
- 2001 dodge Dakota shift problems no codes.
- Center Console is way too far down
- 1997 3.9 vaccum problems
- Neutral safety switch problem
- CV axle with major clicking
- 15" Factory Rims how big of tires can I go???
- Just bought my 97 5.2L V6 Magnum Dakota used from a private seller
- Need help with 97 Dakota 5.2 V6 Magnum
- 2000 4.7 under powered?
- 02 4.7 dakota
- JTEC OBD2 Protocol Question
- Do I have a bad ECM/PCM ? I'm desperate! HELP!
- Stupid Evap! CEL Code P0442
- dakota battery drain
- I have a 2002 dodg dakota pick-up
- Start up/oil pan/ timing
- Squeal when engine warms
- OBD2 connector
- Data link (OBD2) connector
