PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Stealership Got Me with a BG Trans flush
  2. Need advice on muliple misfire codes
  3. UGHHHH someone got a stick of c4!!
  4. Turn Signal Issues
  5. I need help please
  6. Need stock air hat
  7. Larger tires
  8. Replacing the clutch
  9. NV 3500 shifting problems
  10. Sagging headliner... ?
  11. Speaker help quick please
  12. P0420 error code
  13. gasket questions
  14. Need a window
  15. governor sensor
  16. 97 dakota starts but wont idle. Need help!!!
  17. TOO MUCH air coming into intake? (4" vs 3" intake decision)
  18. Engine is knocking or has loud tick
  19. Heater / AC Blower Stuck in Defrost mode
  20. pre runner suspension
  21. got a few ram air tech questions
  22. Dakota got totaled out
  23. New Tires
  24. Sway bar questions.
  25. Looking for part, probe in evaporator core.
  26. working on a 97 dakota 3.9 auto P1764 code
  27. ac evaporator
  28. Air/Fuel Ratio Gauge
  29. 05+ Intake Manifold Rocks!
  30. Truck dies, no codes.
  31. P0500 fault code
  32. 99 Dakota, sport 3.9L, Vent Control knob issues..?
  33. somebody pissed off a ex
  34. Oil filter change trouble
  35. Spark plug problem
  36. Factory paint match ?
  37. Need to bypass factory amp
  38. 3.9L Available
  39. Check engine light on 01 Dakota
  40. One missing bolt to get heater core out on 2001 Dakota
  41. Back Fires through TB?!
  42. cherokee transmission in dakota?
  43. Wrong Cat, Muffler or something else?
  44. Procharger
  45. Bad cap and rotor
  46. SRT Hood, Hids, SS cowl, Deleted Wipers installed...
  47. just about overheated! while wheeling.
  48. problem with speedometer,abs light and brake
  49. front diferential broke
  50. Dreaming of this turbo truck.
  51. 2001-03 5.9 headers
  52. Fault code
  53. Donor truck
  54. driveshaft fixed, but having troubles shifting!
  55. Starts Then Stops immediately
  56. Fog Lights on 02 Dodge Dakota CC
  57. 5.2 Engine swap compatibility
  58. Dakota 5.2 Rear End Ratio
  59. Power steering lines
  60. Cat. response?
  61. Ghost in the drivers seat!
  62. slows down quickly while coasting
  63. weird blower motor/cig lighter issue
  64. Fuel pump adventure
  65. Help me out with coils please.
  66. Ball joints
  67. Manual Tranny problems
  68. Cheap vs. "quality" cold air intake. What's the difference!?
  69. Sudden Problem
  70. New Headlights Finally!
  71. ugh paypal changed there ways
  72. A C on my 1998 dakoda
  73. front sway bar bushings for sale
  74. Lift question for 99 dakota 4x4
  75. i need advice please read
  76. flowmaster 40 question
  77. Starting problems
  78. Clutch install gone wrong
  79. New sig...
  80. lift kit questions!!!!!
  81. Where to buy Snaps???
  82. Key Fob Help
  83. Truck Stops Running Suddenly
  84. ive got the offroad bug again
  85. Please help me
  86. Replacing Fan Clutch=ERRGG!
  87. body code plate
  88. wont shift to 3rd gear
  89. Shocks????
  90. dakota suspension lifts
  91. Euro tail lights for 04 Dakota...
  92. Surprise and Happy birthday to me!
  93. What do yall think?
  94. Poor Idle Quality
  95. just got a new hood
  96. Intermediate Shaft
  97. RED SPARK PLUGS???? #4 cyl misfire code
  98. Quick question about shocks.
  99. '01 dakota #4 misfire
  100. 4x4 question
  101. HELP!!! truck down and i need it asap
  102. 8.5 LSD broke part!
  103. No Horn or Cruise, even tried replacing clockspring
  104. Water leakage from AC drain
  105. Brake prob
  106. switching auto to manual trans
  107. changing rear axle shaft
  108. Fuel injectors 5.9 upgrade, to 4 hole injectors
  109. Brush guards anyone?
  110. Dual exhaust question
  111. Auto to manual tranny swap?
  112. new to dodge formum
  113. Pre-puchase: cabs, engines, alternative
  114. 4.7l ho turbo 540hp for sale
  115. excess exhaust
  116. Need Help identifying plug and wire
  117. Shift kit anyone ?????
  118. help with shocks
  119. Front CV axle seal HELP
  120. Short in electrical?
  121. PCI Bus Location?
  122. 2004 Dakota Transmission "shifty"
  123. 2003, V6, Rough Engine, Check Engine
  124. start up problems.
  125. 98DakotaSLT Build Thread
  126. 99 Dakota V6 keeps shutting off
  127. 2002 4.7l Quad Cab Info
  128. Stearing pump making vaccume sound?
  129. GF washed my truck :]
  130. Low vaccuum at idle and running very rich
  131. Replacing rusted/ semi damaged fender
  132. NEED: Rear axle Corporate 9 3.55 gears 4wd
  133. gauges dont work?
  134. I need your brain cause mine an't working
  135. driver's side turn signal failures
  136. rear speaker install
  137. ordered more toys
  138. Hello, new to forum
  139. Strange turning sound???
  140. ASAP driver side valve cover.
  141. Brake Pedal rubber does not fit, 2002 Dak.
  142. Coil spring
  143. type of oil
  144. TPS CEL goes on and off
  145. dynomax exhuast
  146. Fuel Economy Drop
  147. Dont use www.factorymoparparts.com
  148. Help me decide...
  149. Idle Air Control Valve ( IAC )
  150. I need Transmission Advice !!!
  151. Tire Size
  152. Manual Transmission Issue
  153. Truck Pings worse than a pin-ball machine,..
  154. Open Vacum Inlet On Plenum
  155. Video Of my dakota, Sorry about my neglect.lol
  156. Rough running 4.7
  157. which engine do i have
  158. Kenne Bell s/c on ebay for $200
  159. Narrowed it down to three
  160. 42re overdrive info
  161. looking to get a bit more power out of my truck.
  162. truck wont start
  163. 206 cam ??
  164. 3.9L V6 magnum head rebuild question
  165. Truck pissed me off this weekend.
  166. Early Water Pump Failure?
  167. Power loss
  168. Auto Trannys.... Worth it?
  169. Can anyone identify this bumper?
  170. V8 Tb install?
  171. New Headlights Photo
  172. light problem
  173. Check Engine Light On, could it be from fuel injector cleaner?
  174. difference of 2wd and 4 wd recievers
  175. Swapping out interior and need advice...
  176. Thunder 98xxx ?
  177. cant get socket onto spark plug
  178. School Me on Dodge Dakotas!
  179. remove leaf spring help
  180. DIY Leak Down Tester
  181. Syncing Injectors
  182. Loud Noise in 4wd
  183. Steps i can skip for my 3" PA body lift
  184. Can't do my own rear brakes lol.
  185. H/O Cams
  186. My 1st Truck
  187. Ac cooling
  188. Deep knocking
  189. Looking for a computer geek!!
  190. can somebody get a measurement for me
  191. P 0455
  192. ATF 4+ in power steering?
  193. Passenger side of motor hotter
  194. clear coat, what can i do?
  195. speaker problems
  196. help
  197. Tires
  198. Aftermarket performance parts?
  199. Transmission or TPS?
  200. AC Condensation?
  201. 2002 Dodge Dakota 3.9L V6 oil change
  202. Power Steering Pump seized up
  203. Cut fenders for bigger tires?
  204. 1999 sport 4x4 5.2 ext cab-towing
  205. Looking for 15 in rims
  206. 2003 dakota fully charged battery won't start
  207. Truck engaging starter even without key
  208. new guy
  209. Long Motor Company
  210. Need New Headlight Suggestions
  211. Leaf Spring and Front Lift Question
  212. Oil pressure issues PLEASE HELP!!!!
  213. New guy with SCT Tune questions
  214. wont start / nothing ?
  215. leaking wheel cylinder
  216. CV Half Shaft Issue
  217. novice+mudding+mud down intake=bad
  218. Refilling ATF on 2000 3.9L
  219. Name these parts?
  220. 2 speed to replace carrier?
  221. Update on 04 Dak, Touch Screen
  222. Transmission Dipstick Tube
  223. taillight fuse
  224. One of you 4x4's wanna take a measurement?
  225. 99 dakota 2.4 starting problems HELP
  226. Cold Morning Revving
  227. A/C recharge
  228. Help Choosing Headlights
  229. my new dakota
  230. glowshift gauges isnt that good
  231. birth day burn outs!
  232. My R/T was just assasinated :( so its good bye
  233. Wheel spacer help
  234. anyone looking for h.o. cams?
  235. How to unsubscribe from threads
  236. 2000 dakota cab mounts?
  237. engine to transmission bracket
  238. Blower works, but not out of air outlets
  239. o2 sensor help
  240. What ohm reading should i get from my TPS
  241. B&M Transmission Cooler/Gauge.
  242. crooked body - 2000 dakota
  243. hesitation problem
  244. Horsepower master list
  245. Adding Power Windows
  246. Headlight Relay
  247. Hardbody offroading pics
  248. Another goodbye
  249. Brake Pressure Switch
  250. Torque Specs clutch/pressure plate
