PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Help!!! Water in tranny (quick rsp)
  2. Injector coil "F" circuit malf???
  3. I still can't figure it out...
  4. How to replace leaf spring shackles???
  5. Fan Clutch Going Out?? Help!
  6. this will stump you
  7. this is what happens when they don't give me anything at work.
  8. lowering
  9. Hard starting 2001, 3.9
  10. Window Tinting
  11. never owned, looking for advice
  12. Help with my 2000 dak troubleshooting in the dark
  13. Water Pump Bad Help?
  14. 265K on my '00 Dakota 4.7...replaced the headgaskets this weekend
  15. What Color Sould I Paint My Grille
  16. Vibration on acceleration
  17. Tranny electrical problem?
  18. wire hardness
  19. Where can I find OEM leaf spring shackles?
  20. Painting grille
  21. Stalling/Dying possible trans problem
  22. P0138
  23. are your tires really new?
  24. wtf is wrong with my dakota! fuel pump on its way out?
  25. PLEASE help??
  26. Purge Valve
  27. 2002 dakota
  28. Total overhaul!!!!
  29. Need Help
  30. 2001 2wd drivetrain fluid change
  31. Mopar PCM's?
  32. which soft 8's?
  33. 1999 Dodge Dakota, Sport 4x4 extended cab front and rear diffs.?
  34. 2000 3.9L won't start
  35. PS Pump replacement?
  36. Looking for a supercharger for sale
  37. Hitch Receiver prices?
  38. What do you carry in your truck?
  39. Finally a video of my 40 Flows
  40. A/C problems again?
  41. cant find tires.
  42. July 3rd Gen Ram TOTM - Go Vote
  43. brake problem
  44. 99 dakota ac not working?
  45. Duals on a '98 Dakota
  46. Best Practices for storage of a Dak
  47. TB spacer finally came in handy
  48. engine bucking
  49. Interior LED replacement lights
  50. Trying to get to know the dak community
  51. Floor Board wet
  52. I love aftermarket.
  53. Got the build sheet, now I have questions
  54. 03 Dakota 4.7LV8 no bus and gear indicator lights cycle
  55. Warning sound but no warning light?
  56. neverending problem
  57. my new ride
  58. Some new upgrades.
  59. another exhaust question
  60. Added some front end protection
  61. What ive been up to the last three months
  62. went to the track fri night .
  63. transmission ID question
  64. cabin filter
  65. Where to get rebuilt 42re?
  66. blinking checking engine light
  67. Blown Head Gasket
  68. Like going over rumble bars.....
  69. 5.9L Dak feels underpowered - Where to start with power mods?
  70. radiator support crossmember exchange
  71. Body lift question
  72. Personal Invitation for TOTM voting!
  73. Buying some stuff
  74. air bag light?
  75. CV Axle
  76. What is a Prerunner?
  77. How much weight will it handle
  78. AC / Vent control not working
  79. Disco Indicator
  80. what dakota to get for a wheeler?
  81. gas problem
  82. My new 02; bottle jack?
  83. Rough idle, P0306 (cyl 6 misfire) trouble code
  84. Another Tranny Question...
  85. Shifter doesn't match dash!! HELP!!
  86. Towing Question
  87. old shocks vs new
  88. Rack and pinion?
  89. 2004 dodge dakota lift?
  90. Having a problem...3.9 vs other tranny
  91. Where EXACTLY is the A/C orifice tube?
  92. Decided to pull the trigger.
  93. Cold Air Intake Question
  94. Evaporator core pics....
  95. What's that NOISE?? (Part II)
  96. resizing pics.
  97. what do you guys think?
  98. Drivetrain problem after mudding
  99. break parts = lift kit?
  100. 3.9 Superchips Flashpaq?
  101. What's that NOISE!!!!!??????
  102. Shift cable adjustment
  103. crankshaft sensor
  104. shocks
  105. Front diff locker.
  106. Ebay white face gauges
  107. Center Console...
  108. p0138 and p0141 still coming on HELP
  109. Installing subwoofer and feeling a little stupid
  110. new here
  111. painted my stock wheels with black PD (pics)
  112. Questions about replacing my radiator and usaradiator.com
  113. Need some AC help.
  114. Crank Pulley Question.
  115. 2001 Dakota OBD II Connector Pinout
  116. facebook
  117. Quick tranny application/swap question
  118. New Dak 2003 owner - Tonneau and other questions
  119. leveling kit questions
  120. Front Fender question.
  121. Build Sheets
  122. Catalytic converter oops
  123. 4.7l Code P0406
  124. F U Mobil1
  125. Knock
  126. Clunk in front end, in reverse only?
  127. 02 Dakota CC; will plastic bedliner from 08-09 Dakota fit?
  128. Transmission question
  129. Installing True Dual
  130. Rear wheel stud
  131. Blower resistor
  132. 2001 Dakota Front Axle Problem
  133. ABS and Brake light
  134. dakota problems please help
  135. 04 Dakota Quad Cab V8: 4 Wire Flat Plug install question..
  136. Good Idea?
  137. More problems with the I-4...(Oil pan/starter)
  138. First Off-road
  139. Overfilling oil
  140. tires to get with procomp crawlers 4.5in bs
  141. Multi switch or computer? Need help.
  142. engine swap info
  143. Thank you everyone...
  144. 04 trans trouble- Help needed!!!!!
  145. Another pointless question.
  146. 2000 Dakota tranny issues
  147. Yet another problem
  148. sheering lower shock bolts
  149. Transmission Problem
  150. Just installed a transgo shift kit
  151. Rocker Panel
  152. Replacing Carpet
  153. Odometer calibration?
  154. RIP my noble steed
  155. Durango rims on my Dakota?
  156. what shocks will interchange?
  157. Euro Head Lamps
  158. Goodbye old friend
  159. dakota r/t
  160. Keyless entry beep
  161. What gas station do you prefer?
  162. Has anyone "Built" the stock 3.9L V-6 in the 2001 modles
  163. Need a good set of driving lights
  164. more electrical problems
  165. Dodge Dakota shifter dial
  166. no bus in odometer
  167. Cab Stinks
  168. transfercase questions
  169. Another A/C question.....
  170. New member, 1st post
  171. frequent problems with 2nd gens?
  172. A/C Compressor doesn't run?
  173. 96 leafs in a 98 dak question
  174. 2000 Mopar Performance PCM-P05007205
  175. New Here
  176. Auxiliary lights
  177. Musty smell from AC
  178. power surge at steady speeds?
  179. Canadian website???
  180. i touch one little thing and my truck dies.
  181. rattle in rear end
  182. Trouble Starting When Cold
  183. Exhaust Question
  184. Stereo Budget:
  185. A/C Clutch not working
  186. At a Complete Loss... Power Distribution Center Content
  187. Lock out Hubs for Dakota
  188. oil pressure fluctuating normal?
  189. 1999 4X4 Dakota 3.9 liter Idling rough
  190. Best way to remove a 5.2/5.9 from second gen truck?
  191. Rear Wheel Bearing???
  192. diffrential probleme?
  193. 99 dakota
  194. Roll Call !! Post up your pics of your Dakota!!
  195. Automatic Transmission Fluid Change
  196. Front End Allignment
  197. Running rich multiple codes
  198. Bullydog System
  199. Multiple errors, and I don't know what they mean
  200. overhead computer thing?
  201. Clutch Fan removal/ E Fan questions
  202. torque converter stuck
  203. Replace Evaporator 99 Dakota
  204. Engine Swap Question
  205. Just wanted to share some pics of my 03 Quad Cab
  206. Fuel Sensor Question
  207. tranny information
  208. 3'' Body Lift
  209. 02 Dakota 3.9L V6 to 5.9L V8 swap
  210. Well yesterday sucked
  211. Went For a Drive...
  212. 2001 Dakota Drive Shaft
  213. Recently rebuilt tranny....major drop in mpg????
  214. what is wrong
  215. 2002 Dakota V6 upgrades
  216. Gas Mileage
  217. Spark Plugs
  218. TCM Mod
  219. clicking noise
  220. Trouble Starting...
  221. New plugs and seafoam
  222. Selling the Dak...no worries though
  223. Difference in fender between engines?
  224. truck misfiring
  225. Issue with heating/AC system
  226. Need help with rear drums
  227. Help me choose!
  228. Should I get a Body lift
  229. Dakota wont start
  230. A winch or a lift?
  231. Hey all
  232. Anyone change U Joints without a press?
  233. Clutch Fan Removal
  234. General question on 4x4
  235. speedometer problems
  236. just had the truck polished
  237. 98 Dakota vent smell
  238. LSD differentials for 4x4's
  239. What size rims is equivilent to a 31" tire?
  240. looking for a wide tire
  241. what size tires should i get
  242. 3.9l v6 redline
  243. 2000 dakota transfer case popping out
  244. Cuttin up a light bar
  245. Should i Put stuff into my truck
  246. New parts
  247. tire size
  248. climate control issue
  249. 4X4 question
  250. What should i do with my truck
