View Full Version : 2nd Gen Dakota Tech
- grille guard
- Little to no power steering assist at idle, any ideas?
- HO manifold and cams
- Clear Corners
- 98 A/C issues
- HELP 2000 DAKOTA 4.7 OWNERS
- Coolant level
- Installing Traction Control
- Correct reading for temp gauge?
- want to install cruise
- Wiper delay
- timing
- New Rotors
- Good or Bad Idea? TIRES
- HELP!!! HEADLIGHTS OUT
- Modded Dakota...mine in two weeks(pics)
- bent driveshaft
- I'm new around here.
- Brakes feel like they are rolling/bumping..
- Large Coolant Leak!
- Im going to start building TB spacers, who wants one?
- 4x4 lights in dash dont work
- steering wheel noise
- shift points too high?
- Which A/C Evaporator
- Noise from the rearend
- Metal Flexing noise on U Turns
- TPS Question
- SXT rim width
- 2004 2wd dakota body lift
- What/Where can I do to upgrade the instrument cluster
- Where is the PCV valve???
- Cold Air Intake
- Bull bar 1stgen to 2ndgen??
- Speaker Options for the 2nd Gen Quad Cab
- please help!
- exaust vibration
- Who makes the Mopar soft tonneau cover?
- Torsion crank and MPG
- brake shoes 4.7 quadcab 01 dakota 4wd
- A/C compressor clutch
- mini-trip temp read out not responding
- dakota good-dealers bad
- Hi Guys.....New guy here...3" susp. lift ques?
- 3.9L 4x4
- A/C Blows
- broken bleeder nut
- disabling the horn "chirp"
- need a grille
- OBD-II Connector Pinout Help
- no oil presure!!!!!
- failed emmission test
- NO fire
- no hot air??
- surfing the net and found this...
- Headlight Question
- New here, a couple of Dakota questions
- need a tip about engine
- Urgent Advice needed Re rear axle!
- herculiner and its uses.
- fan clutch removal??
- bigger engine
- my crisis
- Code P0627
- Fab tech lift
- drilling out intake manafold
- shifter/chip
- power steering pressure switch
- New Body Kit
- 360 or 318
- No power
- Suspension lfit
- HELP! Past redline rev's
- FITTING ON 33'S
- Helicoil install
- new exhaust
- kill switch
- knocking/squeeling noise, 1999 dakota
- computer programs for 1999 dakota
- Tent Trailer
- Towing
- Intermittent misfire on #6 cyl...
- Over reving
- heater blowing cold
- weird startup
- Pics of My Truck
- Charcoal cannister in Emmisions
- weird noise
- NEW PICs
- What color?!?!
- i got a flowmaster
- New Tails!
- Speed sensor replacment.
- Fuel sensor
- Front Bumper
- stripped out caliper mount hole
- WHich Helicoil kit....
- Done searching need need fluid capicities
- Accelleration squeel
- Underhood Light
- NOTHING WORKS AAAAGGGGHHHHH
- 5.9 Headers and Exhaust set up
- Rear differential fluid
- '98 dakota specs...
- Tires for lifted 99 4x4
- Subwoofer Boxes
- Torsion bars or Springs?
- 2001 SLT Quad Cab rear power window regulator ?
- lifted offroad dakotas
- intake
- suspension durability
- weird ticking
- Starting my Dakota
- how to install a grill guard and a hitch
- throttle body spacer
- Free driving lights will Bull Bars
- 70mm throttle body
- 4.7L injector upgrade
- Glasspacks or FM 40?
- Sweet, I really feel like I'm joining the "club"
- ticking noise
- Winter traction
- PO456 error fix?
- slicks
- buzzing noise from 2000 CC 4.7 Auto
- What are some common inexpensive upgrades I can do to my QC
- What are the best shocks
- Help finding good bolt ons for the 4.7
- photos
- i cant drive at night HELP
- HELP
- 97 dakota
- block heater
- intake
- Help me pick some tires
- Speakers?
- SUPERCHARGER?????
- changing TB cables: any pre advice???tnx
- Need Dakota Help.....
- Dual exhaust for the 4.7L?
- next mods
- Rattling
- Hi everybody
- Engine Light on because of Vapor Leak?
- remote car starter?
- 4x4
- 00 dak 4x4 sluggish
- hello i'm new
- Another heater problem...
- Leaking
- Shift Indicator Light
- Turn Signal Question
- my 02 qc dak
- lighting issues
- heated mirror not working
- leaking problem
- Whats high mileage for a Dakota?
- Lowering
- Alignment / Power Steering Problems
- repair
- Picked up the 2002 Dakota I asked some questions about earlier.
- 2002 dakota 4x4 front drive noise
- Great just great....
- Hello all
- brakes...
- A Must Have
- Motor Question
- Dakota Power Vent Windows
- power mirrors
- Installing power windows?
- Whining from rear end
- 9.25 rear end/ mini spool
- Mods? What?
- thermostat, 97 dak, 5.2
- Body lift?
- What years are 2nd Gen - Dakota
- getting the truck back
- Slippage
- Keeping my truck
- valve springs
- Radio + Turn Signal Cut Out...HELP
- Widest Tires on a 17" Stock R/T Rim??
- corner lenses
- gas mileage
- Will be looking at a 02 4.7L Reg Cab 4x4 this weekend. Things I should look for?
- Exhaust Question 02 DD Quad Cab V6 3.9L?
- dakota quad cab miles per tank
- Intake Replacement
- 2000 4.7 2wd auto CC Lim/slip in snow
- Better traction to the rear end!!!!!!!!
- Brakes
- need some input
- Bed liner/cover
- 2002 Dakota reverse lights
- Space inbetween the cab and the bed?
- Stampede Kit??
- PLOWING
- lowering kit
- front brake spacers?
- Best oil for 4.7
- Thinking about selling my 99 Dakokta R/T
- P0300 and P0305
- Headlights, Power Locks, and Wipers won't function
- I'm stupid, help with rear drum brakes on a 97 dak
- I'm getting error code 051 any help?
- Interior Dome Light Fuse Keeps Blowing
- It Will Not Start....
- Transfer Case Help
- V8 Swap :)
- 04 Durango TCM on 00 Dak ??
- put on your thinking caps!
- 99 dakota Very, strange problem, very strange
- oem options
- Break drum size, how to tell
- front lights
- brake stand
- rear diff
- valve covers
- Any experience with this tire brand?
- New to forum..have a question
- cv joints or cv axle?!?
- HELP!!!
- suspension lift
- Truck battery dead, replaced, now stereo won't work
- underpowered
- suspension lift
- glasspack???
- CAI
- IDEAS AND SUGGESTIONS?
- gas gauge going?
- Variety of questions
- K & N versus Framm and other questions
- Ball joints again!? WTF
- Steering Problems
- Fastman TB for 4.7L
- Gallery updated. Check it out!
- seat adjuster knob
- my truck
- squeal
- front axle noise
- 06 Dakota R/T????
- A squeaking noise!
- roller lifters
- What else to do???
- subwoofer placement?
- whats a good muffler?
- I NEED HELP ASAP!!!
- 1997 Exaust help
- 01 cooling fan swap
- fault code 0175
