PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. sudden stalling issue
  2. What a day
  3. computer issue??
  4. i'm ready to buy my first dakota!
  5. Breading slave cylinder for clutch....wtf
  6. wanna sell stuff
  7. Spring color?
  8. Bucking
  9. Ticking Sound
  10. Ticking Sound
  11. touching up or painting body panels
  12. Cant find a lift kit
  13. 03 Dakota sounds like a farm tractor
  14. Abs
  15. Urethane Bushing Kit
  16. LR tire locks up when wet....???
  17. New exhaust, please help
  18. Won't Start When Raining?
  19. Hot Dakota
  20. selling 20in rims
  21. Ethanol...
  22. Strange droning noise?
  23. Quick wheel question
  24. Best Tuner for 4.7?
  25. highway mpg
  26. 03 Quadcab Heater question
  27. Happy easter to me!
  28. Seafoam Question???
  29. Transfer Case compatibility question
  30. missing EGR Valve?
  31. Fun! Fun!
  32. funky fuel gauge
  33. 02 QC Suspension
  34. dodge dakota front bumper help
  35. CAT on the way!
  36. dodge dakota
  37. Gage cluster light prob
  38. shift problems
  39. Noise from steering column?
  40. coil question
  41. new sticker!
  42. 45rfe and 545rfe upgrade whos done it
  43. Fog light question
  44. HELP gas in oil
  45. What exactly would a throttle body spacer do and is it a worth-while addition??
  46. 4.7 and 3.7 tech info
  47. Mopar Performance PCM (Oh Crap)
  48. manual locking hubs
  49. Well, Im not sure is a HO
  50. O2 Sensors
  51. Baffled
  52. Newbie with a few ?'s
  53. passenger door project
  54. Add on Backup lights/ Reverse Camera
  55. FW1 Racing Formula
  56. would not go into park?
  57. Bad TCCM causing ABS module to run?
  58. hood scoop
  59. update on stalling
  60. whats everyone think
  61. Permenantly disabling the alarm.
  62. Summer is in the air!!
  63. 2003 Dakota - Sway Bar Bushings
  64. Replace caliper pins
  65. whos installed factory navigation
  66. Transmission problems limp mode. No 1st, No Overdrive 2004 Dodge Dakota
  67. I'm Back!!!!!
  68. better brake pads?
  69. trany question
  70. 22's
  71. Paint
  72. Radio or something else
  73. Brake Lights
  74. sensor on top of my rearend?
  75. Painting ugly plastic bumper inserts- Pics to come soon
  76. fuel problems
  77. Looking to add brush guard, any suggestions?
  78. Dual Exhaust Kit Advise?
  79. The h.o intake
  80. New-ish Pictures
  81. 98 Dakota
  82. 99 dakota trans band adjustment HELP!
  83. motor swap pics
  84. Oil Pressure & Overheating Help!
  85. ideas for new wheels?
  86. wheels
  87. 2000 dodge dakota RT
  88. Injector ticking?
  89. cobra injectors
  90. Help...
  91. dakota 5.2 ram air
  92. Fuel Guage
  93. 4bt Swap
  94. 00 ticking noise?
  95. A Pillar gauge pods
  96. Sanding/Dent Repair and New Paint cost?
  97. replacing rear axle help.
  98. power accessory/cigerette lighter problems
  99. Simple, Budget Winch Mount
  100. need help engine or trans problem?
  101. power window not workin
  102. Leaf spring shackle flip. Easy 3.25in lift!! With pics
  103. Bad u joint/ drive shaft
  104. Need Some Towing Help
  105. Trying to Stall....
  106. Recommended Parts?
  107. Stock Speaker sizes
  108. Big Brake Kits
  109. Universal Step Bumper Install?
  110. Heated Mirrors stopped working
  111. sonnax electric line booster
  112. Trans fluid change questions
  113. front bumper
  114. Quick Lift Question
  115. offroading in nj
  116. fastmanthrottle body ?
  117. Opinions/ideas for spare tire rack. tranny question.
  118. dakota fuel pump
  119. Hello My Mopar Brothers and Sisters!!
  120. Head Unit wiring diagram
  121. Spring is back....finally.
  122. efan ?
  123. torsion bars help
  124. Help with 1999 V8 dakota mileage
  125. rear axle
  126. new truck
  127. 3rd brake light for canopy
  128. Whats normal oil pressure 01 dakota? Is this normal?
  129. Parked for a month, started, and now ticks?
  130. 02 front drive shaft from 01 thru 06?
  131. My 1999 Dodge Dakota
  132. New Goodies!!
  133. installing Remote entry, need help
  134. front end squeaking?
  135. 05 intake manifold for sale
  136. haven't touched the truck in weeks, so i dumped the exhaust
  137. H.O cams for sale. possibly
  138. Universal blew up
  139. Tune Up time need some advice
  140. Lookin for a motor???
  141. Shell Gas = Pooh
  142. Fuse panels, and relays
  143. 2000 Dakota Street/Strip.Show Tech Info
  144. Space under front bench seat
  145. BFG tire pressure
  146. Advice on wheels
  147. Does any body know the thread sizing for dakota brake caliper pins
  148. 2003 Dak QC acting bizarre
  149. you snooze you loose. core charge $ back.
  150. Recharging A/C 97 Dakota Issues
  151. 4HI 4LO and AWD?
  152. what size donut gasket for stock 4.7
  153. High RPM'S ?
  154. Spark plugs
  155. Custom tow hooks
  156. Dodge Dakota Wind Whistle
  157. Anyone looking for a ...
  158. P 0442 Evap Code
  159. Something strange with brakes
  160. Did some wheelin today
  161. Hot to improve power
  162. Reprogram PCM
  163. code P0207 and P0307 on 4.7L
  164. So long
  165. 02 Dakota SLT Fog Lights
  166. viper brake swap whos done it
  167. A/C hose Assembly 2002 4.7l
  168. Just searching for idea's....
  169. Under oil cap
  170. 97 Dodge Dakota 174k
  171. 2000 Dakota ( P0455 & P0442 )
  172. Help with winter Rims
  173. why would i need this?
  174. Throttle RPM varies when using cruise control
  175. dodge dakota 2004
  176. Interchangeable Parts?
  177. What fan belt should I be using?
  178. Front Molded flaps
  179. fog light mount bolts
  180. ABS/Brake light
  181. New to forum
  182. 97-04 Dakota Shaker Hood
  183. Should i buy this?
  184. 2wd-4wd coversion with 1500 axles?
  185. 318 best performance parts?
  186. 1999 Dakota Sport Tranny Problems
  187. my dak made me proud!!!!!!
  188. Anybody ever replace their steering shaft?
  189. 5.2 engine swap
  190. weird problem with my 01 Dakota
  191. speedo calibration
  192. HO motor has arrived!! *pics*
  193. 2001 Dakota barely running
  194. whos wanting a HO motor cheap
  195. rear end gearing
  196. ball joint replacement
  197. The famous P0300 misfire code.
  198. Lost wire
  199. Fed up with my brakes. Any help would be nice.
  200. Is this a good drop kit?
  201. need help with 99 dakota headlights
  202. 4x4 swap
  203. ABS & Brake light comeing on after start up ,, ?
  204. Grrrr Dang LEDs
  205. No spark
  206. Tank straps plz help
  207. Eaton M90 Supercharger on 5.2L
  208. Whinning noise from clutch
  209. Well, I did it...
  210. aftermarket transmission pan
  211. 5.2-5.9 swap
  212. Dont know whats going on
  213. 2001 Dakota needs lifters replaced
  214. went mudn and took some vids :)
  215. 99 king cab tweeter advise
  216. 1998 Regular Cab V6 3.9 Dakota Cup Holders?
  217. 05 4.7 intake mani 25$ on ebay.
  218. starting more upgrades any opinions
  219. Aftermarket stereo and the Infinity system...
  220. 02 QC 4X4, replacement key, no transmitter, will it run?
  221. Help! P0751
  222. Misfire Cylinder 5 - Questions
  223. Wet Carpet - Where's the Leak
  224. Aftermarket headlight problem.
  225. Smittybilt G.E.A.R. in a Dak?
  226. Help with noise
  227. Door Trim
  228. Power Steering Fluid instead of break fluid?
  229. 98 v8 sport chugging problem
  230. Growling transmission???
  231. Power door lock retrofit
  232. valve lash
  233. new front driveshaft
  234. Push Start
  235. chip help
  236. Bellhousing Differences?
  237. new code?
  238. Crazy Squealing
  239. Please Help Before I Take It To The Shop
  240. Rear shackle replacement
  241. A/C Compressor / clicking sound
  242. Weird Running
  243. torque index lift on 2003 dakota 4x4
  244. checking tranny fluid
  245. interior dome changeout
  246. what is tmr mod?
  247. Check Gauge comes on when braking
  248. Rear diff fluid change
  249. E-3 Spark plugs
  250. Auto side steps
