PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 03 dakota help PLEASEEEE
  2. 4.7l Plastic radiator hose clamps?
  3. Replace Pre Cat o2's now rears throwing code.
  4. HVAC control switch will not open floor actuators
  5. 45RFE Parts Supplier
  6. 2001 CTM shopping
  7. 2000 Dodge Dakota RT A/C problem
  8. 2001 dodge dakota 4.7 overheating problem need some help
  9. How long did your water pump last?
  10. Rubber Guard?
  11. Dodge Dokota-2001 Air control switch for heat and Air will not actuate floor vents
  12. 2000 Dakota V6
  13. Changing Power Steering Fluid
  14. Anyone supercharged a 5.2
  15. Fog/driving lights
  16. High/Low Beam Switch Setup
  17. Finally done!
  18. looking to lift
  19. 45rfe swap
  20. Looking likes it times to change control arm bushings...
  21. What to check in junkyard diff?
  22. Lower 1 or 2in?
  23. Which throttle body fits on 2k dakota 3.9?
  24. What the crap?
  25. Comon causes for bad fuel economy
  26. switch switch / relay test
  27. Catalytic converter
  28. @!@***$@! help, break pad troubles on road trip
  29. snorkal
  30. Blower motor pigtail
  31. rockers
  32. 4.7 rebuild?
  33. 2002 dakota sport stalling...HELP
  34. transmission control over-ride
  35. re-gear $$, fuel mileage
  36. Rough Idle
  37. Dakota Rear Dually Awesome.
  38. 4.7 engine swap??
  39. power steering whine
  40. Dakota 4.7 P0208 code
  41. 5.9 done 30 over?
  42. M1 intake install
  43. Check my wiring plz
  44. Want a Dakota Quad Cab
  45. AC condenser, pressure switch, accumulator
  46. 275/70/16 Tires
  47. power window
  48. my truck for sale, low mileage, near mint
  49. 3.9L to carb 360ci and 727auto swap...
  50. AC/Heater control panel bulbs
  51. Help! I need a lift kit
  52. A/C problems.........again
  53. Odd brake noise
  54. starts but wont stay running
  55. Looking for advice/suggestions on performance parts.
  56. Strange Clunking Noise
  57. Speedometer and odometer not working, replaced both sensors...?
  58. 99 dodge dakota
  59. Dakota listing craigs list
  60. Anyone running the 4in rancho lift?
  61. home made heat shield/box
  62. New here with my '04 V6 Quad Cab. Few questions. Ideas?
  63. Exhaust Manifold Heat Shield
  64. GiSM Fuel Rails for sale. 5.2L/5.9L
  65. rear window clarification
  66. Im haveing starter issue`s (sorry - long read )
  67. lifted or not?
  68. Lifting my 2000 4x4?
  69. For you electrical guys
  70. My 01 Dakota AC stoped blowing.
  71. what should I use for my next oil change?!
  72. So...Big WTF moment today!
  73. Couple questions about '97 Dakota 4X4
  74. 3.9 engine strength
  75. '97 Dakota 5.2 won't start, allergic to moisture.
  76. 1-2 shift problems
  77. 97 dakota o/d not working
  78. What is Chrysler doing wrong to make their paint so crappy?
  79. Rebuilding my 1998 3.9 - any cheap performance mods?
  80. Dodge Dakota A/C PROBLEMS
  81. replace CTM?
  82. New deck...
  83. Question about rims on 1998 Dodge Dakota
  84. 2 questions
  85. Winter Tires...
  86. Led tail lights
  87. Uniroyal Liberators
  88. another no start
  89. Squeaky squeaky suspension!
  90. 2000 dakota 4 door tranny issue
  91. Spotlight on a 01 Dakota
  92. 2.5 wont start, what am I missing
  93. Transmission problems after rebuild
  94. Rancho shocks shearing bolts
  95. Possible Transmission problem (5spd)
  96. Planning on vacuuming AC tommorrow
  97. 02 sensors causing possible limp mode?
  98. steering gear box myth?
  99. Pics of my new Sony deck
  100. gauge cluster problem
  101. Emergancy Parking Brake assembly Help
  102. Getting hot in here!!!!!!!!!
  103. Loud Cooling Fan?
  104. Where to get Clockspring?
  105. Gear ????
  106. Dakota stalls when shifting into reverse
  107. my water pump issues
  108. speedo/abs/brake problem. changed tires
  109. cant afford any more problems
  110. 2001 Dakota Problem
  111. Oil Pan Replacement
  112. stuff for sale
  113. 01 dakota lights randomly flashing
  114. problem with my 99
  115. Dakota Transmission problems Help please
  116. ok i have an audio issue ,, any audio experts would be helpfull here
  117. Why are Toyotas so cheaply made but so expensive to fix?!?!
  118. hardly any power in 2nd... or so it feels
  119. new to fourm an dodge dakotas
  120. Speed Sensor?
  121. Alpine deck and Ipod interface for sale
  122. Try to figure this one out!
  123. CB Coaxal Feed, Help!
  124. Bad CTM questions
  125. I want to try shocks that might ride a lot smoother.
  126. Rear axle
  127. 2001 Dakota Steering Rack
  128. differences?
  129. p0442 again.......
  130. reving issues
  131. Seat swap- 00 bench fit in 02 w/buckets?
  132. Air intake - forced induction
  133. Vacuum line?
  134. Bed size!!
  135. Different Water Pumps?
  136. 2003 dakota ground wire
  137. spider gears shattered
  138. Transmission issues 2nd gen
  139. Advice before buying 2001 Sport 4.7L 4WD
  140. Washing a cone filter
  141. 3.9 engine interchangabliity
  142. Door replacement Question
  143. PCM is toast
  144. Overheating issue
  145. 3.9 won't idle
  146. 2000 Dakota a/c cuts out
  147. New Here, have a question?
  148. Two Part Question
  149. block heaters for a '98 Dakota
  150. 98 fuel filler neck
  151. Any of you live in denton tx? I'm gonna need help lol.
  152. clock spring
  153. Where do our truck pull in air for the heater?
  154. 4.7L engine revs right before a stop
  155. wiring
  156. WHAT SIZE GAS TANK 22 or 15
  157. Injector replacement
  158. What's this wire? (Also: Spark plug Q)
  159. 99 Dakota 5.2 fuel pump keeps running
  160. 3.9 to 5.9 swap
  161. Tranny help, fast REPLY!
  162. Wanting To Buy: AC Compressor Clutch
  163. Check out the general discussion subsection!
  164. water pump leaking
  165. Ram guy trying to help a buddy out.
  166. installed headers today .
  167. 2000 Dakota Speed Pulse Wire location
  168. Big Plans for the 4.7 Dakota!!
  169. Opinion: air intake manufacturers...
  170. stuck on defrost
  171. more power?
  172. Just introducing myself...
  173. arching sound around 60mph and above
  174. 99 vs 03 differences
  175. power door lock question
  176. Superchips help
  177. what upgrades to do to my 5.2 magnum?
  178. super chip dakota 3.7 5.2 5.9 4.7
  179. Secret to removing water inlet tube?
  180. AC Condensor removal on 97 (2nd Gen) Dokota??
  181. Bought water pump.. just can't remove old one.
  182. What engine is in my truck?????
  183. Steerimg Intermediate Shaft
  184. Help on turbos please
  185. Does anyone know about this turbo kit?
  186. The weekend is here!!
  187. Head Gasket?
  188. New member question
  189. Leak from front of Diff??
  190. New slippers
  191. Blower motor resistor fried cable clip
  192. i hate everything chrome.
  193. Did a little cleaning...
  194. Sound from possibly the differential
  195. window issues
  196. Started the tranny rebuild
  197. Brake Light Wiring Diagram
  198. Body- colored front/ rear bumper?
  199. debadging issues
  200. Winch/elictrical help
  201. Increased rpm's question
  202. Window regulator 2000 Dodge Dakota 4WD 4.7 V8
  203. Totally almost S'd myself today.
  204. New Rear Drum brakes rubbing 2002 V6
  205. Check engine light on. code 138
  206. couple questions
  207. Wheel Studs 2004 Dakota
  208. Check Engine Light Question
  209. No power to the starter
  210. tmr mod update......ftw!
  211. ac issue
  212. JL Audio Stealthbox
  213. 1999 dodge dakota suddenly dies
  214. tmr mod
  215. Is it easy to replace the water pump?
  216. 180 deg. thermostat and lower shroud
  217. Performance truck shops. where!
  218. Looking for shocks
  219. Tire Fitment question
  220. Q about the throttle body swap
  221. Maybe they were forum members
  222. 42re, 44re, 46re
  223. Rough Start
  224. My truck got used as a truck today! (pic heavy)
  225. anyone know where i can get this wire?
  226. Fan relay went out.. now i'm lost.
  227. 97 Dodge Dakota shuts off - HELP PLEASE
  228. Currently Changing Waterpump.
  229. efan cfm requirements
  230. Are they the same??
  231. Blacked out taillights, any way to make brighter
  232. Painted fender before & after pics
  233. timing a 4.7L motor
  234. Coil MALF in my 4.7 dakota
  235. Reverse problem
  236. 2003 dakota kills intermitantly
  237. re-gear?
  238. Should i spray paint my fender flares
  239. Just got done Painting my grille.
  240. Check Engine Light
  241. HID Conversion help?
  242. Looking to buy
  243. Help!!! Water in tranny (quick rsp)
  244. Injector coil "F" circuit malf???
  245. I still can't figure it out...
  246. How to replace leaf spring shackles???
  247. Fan Clutch Going Out?? Help!
  248. this will stump you
  249. this is what happens when they don't give me anything at work.
  250. lowering
