PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Power Locks
  2. AWD Dakota Question
  3. Cold Air Intake for 3.9 motor 2001 dodge dakota
  4. wheel speed sensor
  5. Will 30" tires fit on stock suspension? '98 dakota
  6. forward facing vents
  7. Pump the gas to start
  8. I can't drive 35 in my 98 sport 2wd
  9. ohh my gosh.... how freaking cool is this??
  10. 2002 Dakota Sport 4WD 4.7L engine swap
  11. I got one for you guys to figure out,..
  12. Rough ride while driving
  13. Cut bed to fit chest ?
  14. 2001 5.9l Rebuild
  15. Thud/pop in steering column when braking.
  16. Bed Box
  17. Gauge light ?
  18. Bhp?
  19. Lesson: Don't park in streets.
  20. Rebuilding Fuel pump?
  21. Control arms
  22. Dakota race truck
  23. Installing a power seat
  24. Control Arm Help
  25. 99 V6 Dakota 180 Thermostat opening too soon
  26. 2001 Dodge Dakota Dash Bezels
  27. The section where my brake pads slide is deeply grooved.
  28. 1999 Dodge Dakota does not start
  29. Tuner for the 2.5L
  30. Spare tire dangling
  31. v6 powerful?
  32. A lift kit
  33. 1997 Dakota Short bed/reg cab for sale (northeast)
  34. oil pump or gauge error?
  35. 97 Dodge dakota won't start
  36. 2000 dakota sport power window/door lock conversion
  37. Small accident
  38. Code 36 rear sens sig missing
  39. Heater core replace 2001 Dakota
  40. oil pressure
  41. CJ-5 for sale
  42. Headers for the 2.5L
  43. Transfer Case HELP!!! Manual to Electric
  44. Swapping out stock vibration dampener
  45. Dakota rough cold start in UK!?
  46. Brake Questions
  47. my buds truck
  48. Heres a new one
  49. '98 Dakota keep dying
  50. Picked up some new tires and rims today!
  51. puddle on front passenger floor under floor mat
  52. Motor swap help!
  53. Been awhile since been on
  54. 04 Dodge Dakota Tilt Wheel Assembly
  55. Update! 4.7L H.O, *Video*
  56. My A/C Is Acting Up....
  57. serpentine belt squeal
  58. Looking To Add New Seats
  59. lost....please help
  60. High coolant pressure causing high idle.
  61. high pitched noise
  62. Weird little gremlin
  63. A/C flush
  64. iac, tps, or ?
  65. This may mean nothing but here goes
  66. oil gauge dropping
  67. A/C delete?
  68. tuner and PCM
  69. To paint or not to paint that is the question.
  70. New Red Valve cover going in my 2.5L
  71. Radiator removal with pictures how in the heck do i ?
  72. Electrical Gremlin
  73. hard shifting
  74. Does it have antilock brakes? towing capacity?
  75. roll pan!
  76. 2001 Dodge Dakota Tailgate
  77. Steering Wheel Radio Controls?
  78. AC / Heat weird smell
  79. A sound i can't figure out
  80. water pump pulley is shot, do I need a whole new water pump??
  81. 2000 Dakota Sport - want a center seat
  82. 02 Dakota Drive shaft issues "HELP"
  83. i dont understand
  84. Need advice on how to replace 3.7 Fan Pulley
  85. camo headliner
  86. Rear sway bar
  87. Coolant leak help
  88. here are some pics of what i have got installed alot still left
  89. Got the bed off!
  90. Coil over rear shocks
  91. Adding Cruise Control
  92. Please help!
  93. carbrator on a 318 mag?
  94. again back
  95. Trying to help my boss his 99 dakota shifts at 5000rpm
  96. intermittent miss
  97. I hate my truck...
  98. 11.5mpg....
  99. 450hp '97 Dak 4x4 drive train requirements
  100. Paint Job recommendation?
  101. Power Window Problem (or worse)
  102. Magnaflow Cats
  103. transmission problem
  104. Mph's dropped 5mph, blue smoke out tailpipes, pulled over and now wont start
  105. Troubleshooting Transmission Problems Maybe
  106. Yet again, I am back...
  107. just not my week
  108. cold...heat
  109. 4.0L Throttle Body for your 2.5L has someone done this?
  110. Designing Sub/Enclosure/Amp setup
  111. Thumbs up to MBS Exhaust! (4.7L soundclip/video inside)...
  112. Steering Issue Gearbox or Pitman?
  113. Right rear axle seal going, now what
  114. 2002 02 sensor heaters
  115. Air cleaner housing 97 Dakota
  116. How many bolts are on bed of truck?
  117. random speedometer issue
  118. 99' 5.2 Power Loss
  119. 2002 Dakota SXT
  120. 2003 dodge dakota heater core
  121. Is my MAP sensor bad Help ?
  122. Does the back seat lean forward?
  123. 99 dakota...wont start...
  124. wheels & tires
  125. Four wheel drive motor and module
  126. Help identifying a connection
  127. Turn signal issue.
  128. Performance chips...
  129. Some hard driving
  130. $2000....!!!!
  131. Power steering pump, or rack & pinion?
  132. shaft mount roller rockers vs stock pedestal mount
  133. Smells rich what o2 would cause this
  134. What's Next?
  135. Custom Flatbed - 2000 Dakota Quad Cab SLT - Whattaya Think So Far
  136. Output speed sensor location???
  137. P0601 ***
  138. 99 Dakota timing
  139. cargo box bolt question
  140. p0201-p0208
  141. About to drop some more $.
  142. Alignment issues!
  143. In a pickle yet again :/
  144. Fender Flares
  145. Can you swap out the 9" back brakes to the 10" brakes?
  146. Time to hit low idle.
  147. Aftermarket Bumper Options
  148. lost fuel pump?
  149. 97 Dakota 3.9 No Spark
  150. 2 part quest. i get a thump after dealer replaced upper ball joints when i turn.. and
  151. Hughes Engines question
  152. rear brake question part right above differential
  153. coil springs
  154. No "Check engine" light but memory shows P0551
  155. Ball Joint Question... (and other front-end issues)
  156. Cant Take this anymore (01 dakota starts sometimes)
  157. Anyone need engine parts?
  158. 97 dakota 5.2 running horrible and need advice !!!!!
  159. New Exhaust Manifold Smell
  160. snorkel???? anny ideas
  161. Why is my truck suddenly revving at idle by itself
  162. Have some Gen 2 Dakota parts - where do I find their value?
  163. Engine Head rebuild best way to get it done
  164. will HIDs keep my switch alive???
  165. P0753 Shift Solenoid A Electrical
  166. 5.2 running rich, injector issue
  167. 97 Dakota Engine Swap... Tin plate
  168. cold operation temp in alaska need help!!!!!!!!
  169. Pulsing headlight only when on high beams
  170. 97 Dakota Gauge Issue (all gauges)
  171. 98 Dakota V6 Best Practice?
  172. Lube points on '99 Dakota
  173. Post CAT 02 Sensor and blown cat
  174. Help for the love of god
  175. I feel its a good deal but could use some guidance. 2001 SLT Club Cab 5.9
  176. Rotors or something else
  177. Chicken lights
  178. fuel pump removal?
  179. Blew motor finally...
  180. Brake line union block cracked
  181. ABS & cruise control in mountains
  182. ****ing good tire
  183. Low idle/stalling/no power
  184. Ball joints, A-arm bushings, power steering ???'s
  185. Help. I have a wiring problem
  186. 97 Idle Fan CFM
  187. drive shaft?
  188. Hey Guys two things
  189. posi rear end?
  190. No power to coil no spark
  191. Where to buy a replacement wheel hub
  192. please help me
  193. Connect radio to fuse box
  194. Spark Plug Question
  195. Ceramic Brake-Binding feeling
  196. 01 dakota interior light problem
  197. Dakota 2004 dashboard lights very dim
  198. Clutch Probs
  199. Transmission Problem?!?
  200. OE aux trans cooler P/N ??
  201. Code P0420
  202. its that time again, tires!
  203. Intermediate shaft
  204. Help-Tranny/Torque Converter Problem
  205. Malfunction Indicator Light
  206. How much weight can I tow....
  207. Selling Poly bushing kit for 33mm bar on 4wd dakota 2k model.
  208. Driverside Taillight and Turn Signal Problem
  209. And another one bites the dust
  210. H.O Engine Swap
  211. Oil Gauge Fluctuation?
  212. Where's the best place to buy OEM parts?
  213. 99 Dakota Check Engine
  214. Is there an easy " fix " to get the power windows to work with the key in the acc pos
  215. Steering Extension Needed?
  216. Malfunction indicator light
  217. trick the computer
  218. '97 Dak 4x4 3.9L V6 to 5.9L V8 engine swap question
  219. Front body panels same as Durango?
  220. 2001 quad 4X4 5.9 problems
  221. where to buy the steering wheel controls for 2004 dodge dakota sxt quad cab with
  222. 2001 dodge dakota ignition lock cylinder removal need help!!!
  223. Painting valve covers
  224. Stereo Help?
  225. 2001 Dodge Dakota Sport Flares
  226. 04 dakota Have flashers brake lights but no turn signals
  227. valve covers all finished up
  228. Raging at 5:30 AM
  229. Street/race dakota or lifted/off road?
  230. Power Steering Loss
  231. Headlights issue
  232. 3.9 fuel filter
  233. Flasher relay buzzing after an long drive at night.
  234. P0031 and P0037 after o2sensor changes
  235. body lift kits
  236. 1998 Dakota Sport 3.9 5 speed Build Thread
  237. 02 3.9l
  238. reprogram speedo
  239. Alarm goes off when unlock is pressed
  240. 98 Dakota Fuel Pump
  241. is ther interest in a bolt in front tow hook?
  242. Anybody have a video on how to remove coil springs on 2k dakota 2wd?
  243. Problems with wet floor board
  244. AC weep hole
  245. pinging?
  246. Neutral Safety Switch
  247. Gunk engine flush wow
  248. High Side AC Service Port Question
  249. Monroe Reflex Experience
  250. Need quick A/C help - Thanks
