View Full Version : 2nd Gen Dakota Tech
- wiring lights to one switch (on, off, on)
- air intake ideas and problems NEED OPINIONS
- radio
- Headers
- possible new ride, what are your thoughts...
- 98 Dakota Fire order
- nitrous
- rear bumper
- Oil Pan Removal
- Squeaking?
- Door Speaker size?
- build sheet
- cel 1,3,5 misfire
- lowering FAQ
- 2004 Dakota Quad headliner down
- Lowering
- Summer upgrades
- Where is my coolant going?
- Quick CEL question
- Car vent/airconditionign smells like coolant...
- another engine swap question
- new to the site
- 02 dodge dakota slt panic button?(keyless entry remote)
- Wont Idle, Stalls Out, After Replacing Intake Manifold Gasket
- steering problem/ wierd noise..
- Engine Ticking
- wheel bearing
- 97 Dakota NEED TO KNOW HOW TO PROGRAM A NEW DOOR REMOTE
- Spark Plug Help!! Mine dont match.....
- Track times
- My $200 Dakota.....
- What do u think?
- Service 4WD Light
- another new post about mpg
- Gear ratio
- Radiator question
- Man. trans. fluid ???
- quick throttle body question
- Keep the tailgate UP for best mileage...
- 97 dakota 3.9
- rack and pinion issue
- Advice for my Dakota
- No oil pressure at idle when warm or stopping
- 3.7L and autolite 3923 dont fit help!
- hard starting
- 2000 Quad 4x4 wont start
- auto dim mirror
- Thinking about getting a CAI
- good mud holes/trails
- Skid Plates
- 3.9 to 5.9 Swap
- max hp out of 4.7L
- ssbc rear disc brake conversion kit
- manifold -> y-pipe bolts
- speedo help
- 2004 DODGE DAKODA 4X4....JUNK!
- steering wheel
- front driveshaft....help!!
- swapping auto tran to manual? add your .02
- bat-exaust clip
- thinkin about getting a dakota
- This Bites! (Exhaust)
- shackle
- Someone on here was looking,..
- E85 Conversion
- PCM
- Engine hesitates when accelerating
- 318 to 360 engine swap
- tire sizes???
- truck stalled when driving
- engine replacement
- Projector light problems
- Rear sliding window removal
- Buying from an Auto Wrecker
- Aluminum Driveshaft?
- where to buy a 180 thermostat
- Strange Noise
- what the hell is this?
- Two questions (stereo, suspension)
- ELECTRIC FAN
- '04 QC brake question
- slipping around corners
- air bag light fixed
- recalls
- New Rims yo!
- Amsoil Engine Flush
- trailer brakes
- tb lift question..
- Lower ball joints gone bad
- Where does your temperature gauge run?
- Rear Axle Lube Weight
- Power steering pump
- Power Door Lock Problem
- need quick answers on superchips!!!
- rear end
- sold the dak for this
- torsion bar mod?
- 2003 quadcab sport 4wd awd what to look for?
- milky oil cap
- Cold air intake
- throttle positioning sensor problem?
- why only 11mpg in 4.7?
- Auburn Differential Upgrade Cost
- Loudpedal45 i found something for you
- Plasmaglow?
- where to find painted grill and bumper
- Looking for stock airbox
- Buying advice
- my 4.7
- Website for bushing
- production numbers on 99 RTs
- NEED A HUGE FAVOR...CARFAX
- Tried K&N, back to stock
- 4x4 front diff
- Question bout synthetic oil
- Serpentine Belt?
- Aftermarket headlights
- MSD
- Dropped doors
- remote door locks
- tire size
- Thinkin about dropping the R/T
- Is this possible?
- P0443 DTC Fix (and note about Alldata)
- Throwout bearings
- 04 Dakota
- Tranny Problem
- Front Wheel Bearing? Shocks? Brake/power steering Line?
- Differences in turn signal housings?
- new pics
- Guess what i broke!
- Hello and intro
- 42re
- Question about spark plugs
- More Codes
- THink I might buy
- More Power
- Speedometer Correction
- any good photoshop work??
- Weird heater problem
- lookie what i found
- anyone good with photoshop?
- boat trailer lights
- What do these codes mean?
- Front Driveshaft-CV joint
- 1997 Dodge Dakota SPEEDO NOT WORKING HELP!
- bored project
- Alarm and remote start kit.
- Stereo upgrade with stock Look?
- Replace a 3.9?
- 3" Body lift.
- Hood mounted CB antenna
- Looking for a rear Diff cover
- Fording question
- More info/what is it?
- Transmission & Rear End Noise
- got a little stuck but got out ok.
- hey all.. NEW TRUCK!!
- Realistic curb weight on a 4x4 5spd 4.7
- Body Lift Noise
- starter wiring issue
- NEW SEATS
- Turbos or supercharger
- Custom paint, looking for ideas and pics
- billet grill
- Speed Sensor?
- Comment on this truck?
- interesting hood/intake idea iv been forming
- Manifold
- time to sell
- lookin for rims
- engine stalling....????
- Knocking sound coming from Engine...
- DOT question
- Rev Limiter
- this is what i should do to my truck
- Shocks
- What trans do i have ?
- best dakota grille???
- i cant find my question about jet chips help!
- Diag code 2317
- dragging can sound in 4x4
- flat towing behind dakota
- 3.9 headers
- Upper Control Arm replacement
- FLUCTUATING IDLE SPEED
- Hurray for our rears!!!
- side decal question
- quick electrical question
- ABS
- 4.7L cams
- lowering need tire size
- Straight pipe
- Transfer case clicking
- Hesitation at start
- steering???
- Exhaust advice: what is best?
- Instrument Cluster on Dash
- Nerf Step and Cab Mounts
- Reisntalling Drums
- 2004 Dodge Dakota spark plugs
- That new guy with lots of dumb questions
- weird noise
- Y-pipe solution
- 2002 Dakota 4.7?
- Rear speed sensor removal
- Suggestions on products please?
- parking brake rod removal
- rear differntial
- New Decal
- 45RFE problems
- Looking for a dakota...
- Tires,tow hooks,lift,2004 dakota 4x4
- burn outs in a v6???
- Need some advice
- Squealing
- heres what im going for
- 11" drum swap?
- 2.5L Manual tranny noise
- Car wont stay cranked
- New Decal Installed (THANK YOU KLINGS :) )
- torsion bar keys
- tire pressure debate
- need help with cel
- TSBs & Recalls
- What has yours been costing ?
- SCT tuner at a great price?
- Brake conversion
- 97 Dakota starts then quits
- truck wont go over 3000 rpms
- Standard Emblem Poll, which will you buy?
- 99 Dak 2WD Wheel bearing replacement...
- Nurf Bars
- Dakota...now with 20"s
- Dual exhaust exit Pipe Diameter
- Looking for NIPPLES!
- Thermostat
- v8 Throttle Body
- 4speed or 5speed automatic transmission
- Keep it???? or replace
- Whats up with the 2004's
- Performance Upgrades?
- question on awd 2002 quad 4x4
- CEL
- cab lights
- intake question
- congrats to me!
- Interested in replacing hood emblem?
- Hello
