View Full Version : 2nd Gen Dakota Tech
- are magnum heads different?
- see if i can get some ideas
- its in!
- Supercharger.....
- Dakota Sport transmission
- Need help!
- Whining Noise
- Shorty or long headers
- front springs
- Door ajar light
- Door ajar light
- pics of the dak & test
- so yeah i compeltely forgot
- 4.7 v8 r/t???
- so what would this be better for?
- New grill on the Dak, pics.
- low mpg
- v6 dakota help
- leaf spring bushings
- More info on blower fan resistor
- What exhaust setup would be louder?
- Cat replacement!
- blower fan resistor
- dakota common issues
- Voltage Problems
- Paint Question!!??
- ANOTHER Sub Question
- oil pressure
- Knock sound from rear of engine
- squeeellll
- Anyone Use The Chrome Centercaps?
- Cam Position sensor help!!!
- transmission problems
- subs in a regular cab
- 33's HELP!!
- ROTM Nominations / ROTY Voting Open
- Noob
- Thinking about mufflers...
- raising 2000 4.7 v8 dak mgs
- 2003 Dakota Malfunction Light
- 2004 Dakota
- Lookie here....
- Stereo Speakers
- Transmission Sensors
- 3.9 to 5.9 swap what need to change
- For sale!!!!
- 04 Dakota 4x4 Trans.problem
- CAI whistling
- Another tire question
- 99 dakota randomly stalls
- o2 sensor
- 2000 Dakota Trans Issues
- center caps. 20 BUCKS FROM DEALER!!!
- Tranny
- I raced a colorado!
- Exhaust!
- looking for some specs on brake lines...
- Poor Heat in 98 Dakota - Blend Door?
- a bad rattle coming from right front
- noob here....please don't flame....too bad
- mufflers
- transfer case install
- High Oil Pressure
- Anyone Run Projector Headlights?
- headlights mess guages up
- 1997 3.9l efi convert to carburator
- 4x4 to 4x2 conversion?
- Sub location options
- Maximum Tire Size - 2004 Dakota Sport - 4WD Quad Cab
- disk brake conversion
- Would these be street legal in Ontario?
- C t m
- For sale 01XLT Rim and tire
- To fix or Not to fix
- Whine when it's cold outside
- Swap Rear for Front Window Regulator?
- 2002 dodge dakota ctm module
- radiator cap
- more things on my dak
- Heater Core replacement project
- 3.7 swap to 4.7 or 5.7?
- dodge vs chevy
- what could this be?
- Thermostat Replacement 2003 Dakota
- A call to all you Off-Road Dak owners...
- ATTN Batman
- TB modification
- did the seafoam thing
- if it's too loud, your too old
- 2002 V6 dakota wont start.. Help
- Coolant Leak
- it won't come out
- Off road Rims
- Normal amount of four wheel grinding?
- Whats name of part that controls a/c temperature?
- Front end issues Still!
- Got my Mitchell OnDemand Running, Anyone needs Info?
- Parking Brake left side linkage
- More headlights for sale
- Installing the CalTracs.. not fun...
- 3.9 to 5.2 Swap
- how about this???????
- diesel conversion kit
- wheel bearings 2002 dakota
- Pics of CalTracs Spiderman and I got.
- Best roll away bed cover
- caltraks traction bars!
- Pulling motor... Wiring harness help
- 2003 Dakota 3.9l 4wd Issues
- HEADLIGHTS for sale!!!!!!!!!!!!!!!!
- Sweet Deal
- Changing CPS
- Headlight issue?
- Does Anyone Have An Opinion?
- more thoughts on a swap
- christmas came early
- 4th Trans in one month.
- I have Mitchell On Demand 5.8 anyone need anything?
- Magnaflow VS Flowmaster!!!
- Front Differantial oil burnt?
- New member here!
- Buying used dakota...need help! (wheel bearings, no 4x4 LOW, and PS leaking!)
- Lighting upgrade
- Need some help with cylinder heads
- i need help from a 2002-2003 dakota durango owner
- Coil spring height specs?
- air bag light/ switch
- Throttle body spacers, tornado intake
- 2nd gen Dakota in TOTM
- Tranny resistor mod
- 4WD issues
- Some new parts i got in, and on the way. Pics inside
- line lock
- Throttle body spaces...
- Rear sway bar?
- Posi installation
- Charging problem 2000 Dakota Quad
- Fog lights 2001 Dakota
- Differential question....
- Belltech
- Eliminate fog lights...what to do with holes?
- Okay last one I swear
- 2002 dakota 4.7 to 5.9
- body mount question
- need some opinions
- water temp ?
- oh my god
- my new project
- I found it!
- Why no heat with remote start?
- Paint my Dakota bumper black gloss or dull?
- Confused!!!!!
- Help removing Fan
- New Parts and a Deal
- Transmission 3.9 to 5.2 help
- Transmission Noises?
- Motor Swap Question
- 3 cats?
- Wheel question
- I got a present with my new part!
- DAk meet and greet update
- security on 2000 r/t
- go i ended up getting "new to me tires"
- 1st...2nd....3rd.....?
- turbo 3.9L?
- Overheating...
- Reset PCM
- 3.9L magnum parts
- 4wd grinding noise
- Help finding R/T engine for 3.9L swap
- Seafoam on a higher mileage engine
- Help!!!
- help belt is screaming
- paint code
- i just keep having q's
- new owner with question
- Replacing a torsion bar
- Does anybody
- 4cyl dakota problem
- w00t for new parts!!!!
- Yokohama tires
- Heater Core? I'm guessing so...
- was playing under the dash...
- Some stuff ending soon on Ebay
- Looking at a 1999 R/T
- 3.9 idle
- Throttle body swap...3.7 not 3.9
- Please help with 02 dakota sport
- Squeeky belt
- what is this dakota worth?
- ok ok so my mind is wondering
- Imm backkkk!
- Need brake help now...
- Where are they made.
- Preferred Dakota Meet and Greet STATE Location
- How hard to pull HVAC housing?
- a/c question...
- V8 to V6 throttlebody
- First snow!!!
- 2003 dodge dakota block heater,where is it?
- Engine just Dies
- Loop hole!
- Nitrous for your Dakota
- 3.9L reliability question
- Power steering leak...cheap remedy?
- heat smells like......
- Heater question
- DIY Questions- Fuel pump, tie rods, shocks
- 2000 Dakota 3.9 whines/screams
- Moog ball joints--Pressed or bolt-in?
- 4WD question
- turn signal issue & quick tire pressure question
- Power window busted due to freezup
- Pic of the NX Kit i just got.
- Wth
- Looking for advice before I buy
- Help with ABS
- srt 8
- cold start idle issue
- Weird speedo issue...
- Need a couple of parts for my 1997 Sport
- Price quote for ball joints and bushings
- Which programmer is best
- Clear corners
- being a 97 what would you choose?
- 440 oppertunity
- Superchips Max Tuner 3715 for sale.
- well i finaly got some pics of the truck
- I need some help with maintenance!
- Question about Disc Italia brake pads
- Pictures of the Wrecked Yellow RC R/T
- i need a new front fender
- tires rubbing
- 99 Dodge Dakota Engine stalling in Cold Weather
- low rpm power
- New toys and big plans for the Dakota R/T!
- i got a new truck finally
- Finally finished (HID with halo) :)
- Squeaky Suspension?
- I can't believe how dumb people are
- Hit and almost run Incident
- A/c compressor on
- 98 Sport 5.2, Auto trans swap?? or stay auto....
- Tire Humming?
- Heater Problem! I'm freezing...
- P1740 ????
- Dakota Collectable Question
- Dana 70's for Dak
- Idle cold problem?
- Engine shutoff?
