View Full Version : 2nd Gen Dakota Tech
- Truck running cold and figure it out.
- Follow up video of intake post- plen. fix.
- Air intake
- ecm help please!!
- Please help!! sent out ecm for repair now running very rough!!
- Overheating 2003, 3.9
- a/c problems
- HELP...01 Dakota, 4.7, auto, - Coolant Leak
- 98 dakota 2.5 Second bad Rack n Pinion in 3 years
- Power Steering Mystery
- Anyone use these Projector headlights?
- buzzing from nv233 motor
- Transmission Removal
- Transmission fittment questions?
- Distressed Dodge Dakota owner.
- No more Dak
- Cruise and a/c
- 231 D transfer case
- Hi all dakota owners
- 2003 Dakota Programming Updates
- Wheel Hub Assembly
- 97 dakota, tire and wheel help plz!
- Tonneau Cover
- Recently changed the drivers side fender and niw truck wont stay started help!
- 02 Dakota 4.7 RPM Issues
- 2001 Dakota 4.7 New Clutch issues
- Whats up with this friggin window
- Serpentine Belt Idler Pulley Metric or English
- squealing noise
- No turn signals...help!
- Small coolant loss - 4.7L
- Flush the fluid on a 545RFE?
- Gear box
- 2002 Dakota v6 2wd stalls uphill!
- 2000 Dakota Sport 4L air conditioning quit
- Stock Suspension Question
- info on 1998 Dakota
- Restored my headlights
- '04 SXT 4x4 front end alignment
- New Guy Questions
- Probable transmission problems?
- Front ext. Cab mount rot
- pcv valve location
- Can you tell if my '01 Dakota 4X4 has Tork-Loc by the VIN?
- Brief engine rattle at start up
- 04 dakota
- 4X4 Differential Swap
- Need help getting out fuel rail and injectors 2001 4.7L
- Led Dome lights
- 1997 transmission
- Buzzing noise when right directional is on
- exhaust question 2000 SLT Dakota
- Help! Tire Rub - Failed Inspection. Fix?
- cooling system
- Obd2 port won't connect for smog
- Anyone using Valvoline Synchromesh?
- 2001 Dakota SLT - Headlight question
- 01 Dakota won't start
- Steering issues 1997 dodge Dakota v6
- sway bar
- will this harmonic dampener/pulley long reach bolt work?
- Best CV axles?
- PCM Questions
- Anti-Lock Brakes on 2003 Dakota???
- Dodge Dakota O2 sensor
- Ms-9769 antifreeze
- 4x4 Ball Joints
- ABS and Brake light on Help
- Tire/Trans Question.
- A/C help Question
- 1997 Dakota Security Alarm Goes off on Passenger Door
- 1997 Dodge Dakota Headlights Problem
- dakota/durango door compatability
- 04 Dakota T-Case
- Torque converter
- 2003 Dodge Dakota
- What in THE h*ll were they thinking?
- tranny slippage
- no brake lights or reverse lights
- 00 dakota vibrations
- 4.7l engine swap to 4bt cummins
- Help,my fan is rubbing my fan!!
- How To Disable the Alarm Chime thingy ??
- Quality front brake Pads
- Differential Fluid Question
- 2000 quad cab 4.7l future plans
- 1998 5.2 running very bad
- 1998/2003 fuel tank swap?
- Losing power at speed
- any interchangeable spider gears? ??
- dome light flash
- 2004 Dodge Dakota CTM quit on me
- Half window leaking
- Torsion Key Removal
- Oil gauge whacky and knock.
- RT tire size question. Need help fast.
- 1998 Dakota Sport Decals
- Broken starter replacement
- Ground strap?
- High Idle Issue 99 Dakota (5-Speed)
- 2000 Dakota overheating
- 97 dakota in trans limp mode
- 4.7 tune up procedure
- 95 318 into 97 will it work?
- Bed topper/canopy advice, reviews, experiences
- Radiator which one too get
- 2004 Dodge Dakota 4.7 4x4
- Yes, cupholders
- Check engine light
- New air vents nice quality
- tps problems
- 5.2 V8 Questions
- Another SMP/BWD part fails!
- 2002 Dodge Dakota 4.7L Quad Cab A/C help
- 98 issues
- Clicking/knocking noise 2000 Dakota
- bad headlight switch?
- Whats your opinions on this
- "no bus" code
- driverside Power window problem
- Braking issues! Driving me insane!
- 01 dakota won't start
- 2004 Dakota parking brake issues
- 04 Dakota Stuck In Park P1776
- fuel pump asap
- Torque Converter
- 2004 Dakota Engine removal
- 2003 Dakota 5.2 swap is it possible???
- 2003 Dakota 5.2 swap????
- Help with 2000 Dakota
- 04 dakota
- TCM and gears
- P1740 Transmission Code
- Cost of steering shaft replacement
- grinding sound??
- Dimples in the steering shaft splines?
- 2001 power steering fluid leak
- Dakota .. Wont Start
- Transmission issues 46re multiple cel
- 2003 Dakota V6 Throttle Body cleaning dropped nozzle into intake
- 2003 Dakota iwth 65,000 - Tuneup
- hard steering problem
- Help!!
- Stalling and Starting Again
- Offset question
- ABS Lights back on
- Airbag light on and horn not working.
- air bag module
- maintenance schedule for 04 dakota
- Paint question
- 2002 dodge dakota broken shifter lever
- Transmission downshifts, hard, for no reason
- Radio staying of with key out.
- converting manual to power
- Fan Shroud Mod (For Mech fan w/ PA body lift kit)
- Fuel level sending unit
- exhaust manifold bolts
- Rough Idle after warmup
- 97-99 vs 00-04 control arm differences
- un expected engine shutdowns
- Help with Passing DEQ Please!
- 2001 dodge dakota timing chains
- Brake Upgrade Options
- 97 Dakota engine
- 01 Dakota - long crank on startup
- 4 Cyl 2.5 more power
- Identify this?
- 2000 dodge dakota o2 sensor
- 1999 Dodge Dakota 5.2L WILL NOT START
- 2000 dakota 4x4 lift question
- Torsion Bar Sag, Emergency Brake, and 4 x 4 Switch ?'s
- Transmission being swapped need maintenance advice
- Service Intervals
- Brakes are sticking
- o2 sensor
- 03 Dodge Dakota
- Freeze Out Plug Dripping
- Lifts! Lifts! What lift you got?
- What years are body's interchangeable?
- Wiring harness question?
- Club cab rear windows adjustment?
- 97 Dakota auto to manual swap
- need help passenger door
- Aybody in Denton Tx?
- Dropping transmission to swap the clutch
- 2004 Stock Largest tire
- Wheel adapter opinions?
- Lift coil problem
- Do we have room for one more exhaust thread?
- Spare tire solutions?
- Bake Noise (Dragging)
- 1998 Dodge Dakota Alarm Reset.
- odd sound from wheel well
- Stalling
- 2002 Dakota Breaking Shock Bolt
- Dakota R/T stalls
- 2002 3.9 Dring me Nutz
- 03 4.7 Rocker Arms & Valve Covers
- New guy
- P0700 Check Engine Code - Transmission
- Can't find Tailgate part name!!
- 44re to 46re questions.
- Replacement carpet? Vinyl?
- Heater core maintenance
- Does my Dakota have Infinity system?
- Leak at fuel tank
- P1899 Code
- Misfire but no CEL
- Motor swapping from 3.9 to 5.2
- Welding help needed
- ac clutch not engaging
- 2000 Dakota 3,9l Erratic starting and dying, Odd codes, ECM???
- Transmission drain plug
- truck running cold
- 2001 Dakota
- 2000 Dodge Dakota 4.7L
- Tires for sake in Michigan
- New 99 2.5 need help with upgrade options
- LED/HID conversion options 9007
- Electrical Issues
- Underdrive Pulley
- 3.9 Stalls after Cold Start
- Need some advice on 44re problems
- 33x12.5r15 on 15x10 wheels?
- 01 4.7 Dakota Wiring Catastrophe
- Bad Thermostat 3 times in less than 4 months?
- Uneven Idle, Stalling & Throttle Position Sensor
- Did my first oil change
- I need advice big time
- Vin code? where is it stamped on the frame?
- Do all numbers have to match for CTM module replacemnet?
- wet weather starting issue
- Front axle shaft seal
- 2000 4.7 Turns Over but wont start
- New to me 2003 Dakota - Tire and other advice
- 2001 Dodge Dakota Quad cab battery problem
- Power Steering Whining
- Power Steering Pump Replacement
- Possibly buying 97 dak with bad knocking
- Spare tire cover under the bed?
- Dodge Dakota AC information
- If you've got 4.7L, do not install lower temp thermostat
- Please help with advice
- 98 Dakota 3.9 Stalls
- Water, water everywhere!
- Manual transmission questions
- Wiring diagram
- 02 Dakota - Disable backup beeper
- Ignition problems...of sorts???
- what rear gear should I use?
