PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 99' Dakota Fuel Pump Line
  2. Need a final answer, please.
  3. Lower Control Arm Bushings
  4. A long shot
  5. 2000 Dakota 4x4 auto trans problems
  6. 0 oil pressure
  7. Setting the timing, marks right no compression stroke.
  8. Lost Crankshaft Sensor - CO Dakota
  9. Vibrating Bucking and Knocking, 98 3.9 5spd 2wd
  10. CV axle compatibility?
  11. help: 1998 magnum won't stay running
  12. Rear 2" Blocks and 3" Torsion Keys Questions
  13. Power steering
  14. Tonneau cover lift supports
  15. truck bed lined trim?
  16. 2.5 4 cylinder engine
  17. Where can I find a 16 tooth reluctor wheel for a 4.7V8?
  18. Dakota 3 inch lift
  19. V8 Swap question (I know..not another one right?)
  20. ECU or not ECU that's the question
  21. Away from home - Need Help with 3.9L Engine part identification
  22. 1998 2.5L 5spd Reg Cab, Worn out clutch or input splines, Other tranny??
  23. 2000 dakota bogging down
  24. Advice on a used 1997 SLT
  25. Trans Tune Up Help
  26. lift kit helppppp
  27. Doors
  28. 02 dakota quadcab..5.9 sport... also r/t?
  29. Exhaust manifold gasket leaking '04 dakota
  30. Is my transmission shot or going bad?
  31. P0440 and P0441 fixed?
  32. Aftermarket Headlight Housings
  33. '99 V6 auto bogs occasionally
  34. lights stay on
  35. Adrenaline 3" Lift Kit
  36. What Would You Do To Increasing Durability
  37. interior - head liner
  38. exhaust bolts
  39. Dodge Dakota 5.2L V8 Mag
  40. Regular Cab 5.2 short bed tow capabilities?
  41. 2000 dodge dakota v8 Magnum 4.7 not starting
  42. 3 rd brake light on shell
  43. Antifreeze drip
  44. Soft First Gear Shift
  45. Help fixing reclining lever
  46. 3.9 oil pressure issues
  47. 5.2 throttle body on a 3.9
  48. engine swap
  49. Another 42RE Problem - FSM lookup request
  50. proper numbers?
  51. Supercharging a 5.2
  52. 4.7 build mods
  53. Transfer Case Leak
  54. Door Lock Actuator
  55. Quad/4 Door Toppers 2000
  56. 98 Dakota 5.2 motor swap
  57. 98 dodge dakota throwing a p0171 code
  58. Center seat console
  59. Steering Hum
  60. Adjusting shift points
  61. Redlining before shift
  62. ticking sound on cold starts
  63. do i need a pinion shim?
  64. Re-setting power doors remotes.
  65. roll pan bumper for 2004 dakota
  66. door hinge pins
  67. Horn Problems
  68. Removing 3.9 exhaust manifold help!
  69. Exhaust Manifold Leak Fixed!
  70. Fixed my leaking Heater-core
  71. voltage guage gone wild!
  72. wheel bearings or ball joint help
  73. front receiver hitch
  74. trans fluid leak!
  75. Fixing P0152
  76. Torsion bar won't install
  77. screwing with my rear suspension
  78. How Much Horsepower
  79. 3 inch body lift 2wd 2000 Dakota
  80. My 97 3.9 in dire need of attention
  81. To awesome not to share
  82. How much can our beds hold?
  83. 1 st gear trans problem
  84. REWARD.........Hugs
  85. look what i did against a ford
  86. changeing headlight bulbs
  87. 5.2L Swap to a 3.9L
  88. Ahoy! Another problem..
  89. Help, 2001 AWD Dakota 4.7 auto, slight kind of grinding noise after it shifts.
  90. Idle Problem leads to kill problem.
  91. shifting problems
  92. Nice Racks With Pix
  93. 2000 SLT fender rust
  94. Squeaking all over
  95. throttle body
  96. LED Turn Signals
  97. Opinions on some mods
  98. Lifting....
  99. p0132 fixed now back again
  100. 2 wd lifts?
  101. hid light kits
  102. Transmission Fluid
  103. interchangeable
  104. Engine swap 3.9 to 5.2
  105. 3.9 to 5.2 swap PCM problem
  106. Cruise Control Problem
  107. Please help BIG BLUE
  108. Front Differential Help
  109. Parking Brake and ABS Lights on constantly
  110. Low beam headlights not working but high beams work
  111. friend giving bad advice?
  112. Overhead trip computer not working
  113. purge flow ? and upgrade questions
  114. 2001 Dodge Dakota Accelerating problems
  115. Very, very inaccurate gas gauge!
  116. Looking for Headliner Push Pins
  117. Difference between lift and level?
  118. Heater/AC fan
  119. I Had To Share This...
  120. how bad is this?
  121. question about engine repair
  122. Clearing 35s on a 2wd?
  123. Climate Controls
  124. check engine light / stall
  125. Bearing Hub Size Difference
  126. Transgo shift kit TV cable adjustment
  127. 2003 Idle skip and low power
  128. body mount bushings
  129. 2001 dodge dakota crew cab subwoofer boxes
  130. Lighting problem
  131. brakes suck
  132. 98 dakota
  133. Best muffler for 98 dodge dakota v6 with stock pipes?
  134. Opinions on 1/2 Impact
  135. modern Magnum block vs LA block vs SBCh
  136. Squeaking
  137. 2004 dakota Transmission fluid question
  138. computer issues!
  139. Sons Dak out of whack
  140. Cargo Light Question
  141. Wheel hub/bearing replacement
  142. '04 4.7 muffler options
  143. Alingment Specs
  144. New Shock Help 2000 Dakota 4x4
  145. Engine ping?
  146. dakota 4x4 issues
  147. brake line diameter and lenght?
  148. Bad Wheel Hub... Again?
  149. Anti-freeze
  150. Marine Grease
  151. No brake lights
  152. Dakota Fender Flares
  153. R/T compatibility
  154. i have a 2001 dakota 4.7 slt with a 45rfe trans
  155. 3, 4 Gears not engaging in Dakota 5 Speed
  156. 01 Dakota engine codes P0551
  157. Best 4.7 Headers
  158. New paint job complete.
  159. Fix or upgrade
  160. Please help
  161. 1998 dakota
  162. General Questions
  163. flatbed
  164. Engine almost died when i was parking?
  165. A diamond in the rough
  166. Mpg of running in 2x4 vs 4x4?
  167. 5.9 Oil Use
  168. Dodge Dakota 2000 door locks
  169. Truck Bed Is Tweaked?
  170. valve cover
  171. Leaking fluid spread by fan
  172. Bed Extender Security DIY
  173. Ignition Fuse Keeps Blowing ???
  174. What is this piece called?
  175. popping ratching sound from front.
  176. 2002 Dodge Durango SLT
  177. Dakota R/T Oxygen Sensors
  178. winch bumper
  179. Bull bar question
  180. How much lift to fit 35s
  181. Potential Dakota Purchase - is it lifted? plus other q's
  182. Anti Theft Tailgate DIY
  183. RPM Jump
  184. rear axle question??
  185. floormats
  186. clutch pedal adjustment????
  187. collecting all the supplies
  188. dodge dakota 2003 CTM
  189. how much plasti-dip spray
  190. Towing with a 3.9
  191. sheared exhaust manifold bolt
  192. Need ideas for my truck
  193. Nerf Bar
  194. picture request: cruise control servo
  195. '02 Dakota headlight problem
  196. Traded Dakota for Silverado, now vice versa
  197. Pinion nut
  198. new belt walking on pulleys
  199. Feels like choke is stuck
  200. Anyone swap a V6 for a Hemi?
  201. Changed plugs, runs strong again, coil packs looked bad tho...
  202. Please help (Desperate/Frustrated) Dakota 2002 Idle/Acceleration problem!
  203. 1999 3.9L auto 1-2 delayed shift issue
  204. Help!!
  205. Inside lights failing
  206. PCV grommet removal
  207. Hard start?
  208. Well CRAP
  209. Checking the coil...
  210. Help on what lift kit to go with to fit my new rims and tires
  211. wipers come on with radiator fan????
  212. Wiring Harness
  213. 4.7L new hesitation occasional misfire
  214. 4X4 Rear Axle Offset
  215. Shocks in front or rear?
  216. 2004 V6 tune up gave reduced fuel economy
  217. posi update
  218. 3.7 Thrashing
  219. Stock Wheel Specs
  220. Intermittent oil pressure gauge
  221. 1999 Dakota 5.2 2wd auto
  222. rear diff leaking
  223. bad starter? or park/neutral switch?
  224. How do I know if I have RKE?
  225. Spider gears are they OK?
  226. 8.25 rear end ID tags
  227. 44re OD unit CARNAGE.........
  228. hughes plenum kit/ springs
  229. best true HID projectors
  230. Lowered guys i need help
  231. dakota heating problems
  232. Holy Shat
  233. improving mpg
  234. V6 Performance
  235. Mod Questions
  236. 04 Crew cab 4x4 4.7 torsion bars
  237. Front diff fluid change
  238. Purge Control Solenoid guestion
  239. old guy w/big Qs please for give
  240. 2004 Dodge Dakota 4.7L V-8 4x4 front driveshaft
  241. tryng to find out what tranny I have
  242. rear differential going out
  243. 360 R/T Dakota Engine
  244. please help with idle problem..i guess!
  245. Where to buy/confusion
  246. BOOM....ouch....that hurt!
  247. Differential Fluid Change?
  248. Which To Believe?
  249. Bleeding brakes, 99 Dakota
  250. 97 Dakota Radio Swap
