- 2003 Dakota 4.7 sport evap code
- Hydraulic Control Unit thread Stripped
- Ticking sound at startup
- Changing main bearings...
- Difference between 1999 front diff and 2000 front diff
- HELP! 2002 dodge dakota 4x4 problem
- 01 body lift
- General question about engine sensors.
- Dakota Security- Won't Start
- no spark no fuel no guages
- SAS questions
- Ctm??????
- t case question
- Trouble Shifting To 3rd
- 4x4 Question
- 2002 Dakota Door Handle
- I need a new bumper!!!!
- Key turn diagnostics shows code but no check engine light on.
- Strange humming noise
- "digital supplemental dash" project (need wire data!)
- Light strip on back panel/gate/bumper?
- extra fuel tank
- Truck Stalls from Reverse to Drive
- Remote Start Ignition Relay Help Needed!
- 02 Dak with 05 Hemi swapped, ECM questions..
- Tach wire access?
- headlamp lens cleaners
- Split flange?
- High pitch squeak, need help!
- Pathetic $27 for these at the Dealership
- Newish seats installed!!!!
- Protuninglab dual halo projectors with HID kit
- Switching Injectors
- Finding a HO cam
- 3.9 Got Nuff' Ponies for 33's?
- New owner
- Painting Interior Dash
- Tuneup items to improve mpg?
- Reverse and Driving Lights Not Working
- powersteering question
- Autozone duralast crankshaft sensor
- Timing chain replacement: Advice??
- Brake lights Inop Help
- Brake lights wont work help!!!
- Help with engine codes
- Transmission shift cable length
- 02 4x4 Sport HEMI swap!!!
- straight pipe???
- Bed extender and Tonneau Covers
- suspension / bushing updating?
- Need help
- 2001 EVAP Leak
- 1998 dakota build
- 4.7L Flowtech Headers?
- Problem draining Coolant for Flush/Change
- 2000 Dak restoration/rebuild
- On/Off Road tire pressure
- Humid and cold start and run problem.
- Changing ATF and Rear Dif Oil
- Ticking noise from fuel injectors?? on 2001 quad 4x4
- U-joints
- stalling
- My Lil' Truck is Finally Fixed!!
- Transmission mount bolt nut size
- Charging Issue
- 2000 4.7L 4wd recurring codes help!
- spare
- Map sensor
- 98 dakota 5.9?
- Please help!!!!
- 99 Dakota - Defrost Actuator
- Build Sheet
- a/c leak on floor(drip tube elbow mod already performed.
- Keyless Entry
- Rear end Clunking
- Rearview Mirror Mounting Button
- Can anyone please help me with this major problem?!
- Superchips
- New Hellas
- Ignitiion issue 01 Dakota 4.7
- Fuel Pressure Loss Woes
- 2000 Dakota 4.7 cold start tick
- help heater core change 2000 dodge dakota
- Radiator
- rim painting trick
- New Crank Sensor...now running awful
- Need votes for ROTM Oct
- Dreaded Gas Gauge - NOT the sending unit!
- HELP! VIN/Body issue in MASS
- front shock problem...
- new springs?
- Tune Up
- pinion seal.
- 99 dakota will not start
- Our new 2nd Generation Dakota Moderator
- oil pressure
- Trust your oil?
- P0443 - EVAP Purge Solenoid Circuit Malfunction
- Dakota 5.2l v8 stalling
- Shock recommendations?
- 2003 Dakota 4.7L ******HELP******
- Help! 1997 dodge dakota
- Cylinder Head specs??
- Help! 1997 Dode Dakota
- Raising front end
- A couple inner tie rod Q's
- Whats up with my shift lever
- Perplexing Starting Problem
- My truck doesn't exist!!
- 2003 Dakota engine problem
- 2004 Dakota QC 2wd Alignment specs.
- New guy question
- Fastest speed in 4wd?
- cam help!!
- 2003 4 dr head liner
- Help with rear shackle on 4WD dakota
- Engine help
- Question on aftermarket parts
- new to the forum
- headlight switch wont turn on dome light
- New car...
- So.. Suspension how bad is this
- Starting Probs, Basic O2 sensor questions on 4 cyl.
- My 03 4.7 V8 Dakota is making Knocking/Ticking Sound
- 03 4.7 V8 Dakota is making Knocking/Ticking Sound.
- Is this true?
- puff of smoke
- No power to fuel pump
- can I remove my tranny without removing my starter?
- Radiator hose preheater
- 1997 3.9L acting up
- P0440 check engine code!
- vapor canister purge valve
- High idle gets worse when warm
- Dam O2s
- where to get new shackles and hangers
- WTB - 02 3.9 ecm
- Weird Oil Pressure....
- 545RFE Oil Capacity?
- Missing Part to Overhead Console?
- Downpipe for 2.5
- putting 4wd shocks on a 2wd dakota
- brush guard
- 7" tablet in 2000 dakota
- suspension travel ??
- ax 15 tranny compatibility question
- Can I replace a 233D with a nv233 ? Transfer Case HELP please.
- wheels
- Help with mpg
- tire sizes
- Trouble with reverse and high idle
- Left Low Beam Headlight Problems
- All Kicker'd out!
- camshaft sensor 97 2.5 Dakota
- Dakota stalling in gear?
- Is this a bad u-joint? w/pics
- 2000 Dodge Dakota wont crank at times
- $800 dollar fixer upper rebuild
- overheating
- Need a few things fixed - prices?
- Emissions Leak
- Cross country drive
- Need for speed
- Checking in!
- turbo or supercharger??
- Need some help guys locating a transfer-case part,..
- Exhaust Manifolds
- Small cats removal?
- 2002 Dodge Dakota No Crank, No Start
- Airbag Light
- What could it be?
- Tranny flush or regular service?
- Transmission slipping
- alternators
- Double Din head unit in 2nd gen Dakota
- Side Marker Lights (Front) Fuse
- 2000 Dakota LSD HELP
- Transfer case
- compustar remote start 97 dakota
- How hard is it to replace the rear leaf spring bushings on the 2wd 98 Dak
- 1998 Dakota Stalls in Reverse
- AC question
- Airbag light
- New old truck with some issues
- tricky steering shaft question
- 1998 3.9 V6 fuel and electical problems
- Please Save My Marriage! 1997 Dakota-Money Pit
- Beautiful Lifted Dak
- Rattling noise when A/C on and foot on brake while in gear
- 98 Dakota ABS
- fuel pressure testing
- No Fire
- Transmission Fluid
- Rear brakes
- Flashpaq Programmer
- 46RE old style NSS trans convert to TRS switch
- Got [another] dakota! (pic enclosed) / brake problem
- Catalytic converter opinion. Magnaflow vs. Spintech vs. Any Others?
- New Here and loaded with questions!
- Scan tools
- Obd2 Scan tool
- 1999 Dakota manual trans code P0500 speedometer not working
- Does anyone here have Directechs.com access?
- Interior Work
- Mystery Plug
- Some advice needed.
- idea on rough idle
- HELP! Starter terminal Melted!!
- 97 Dodge Dakota Manual to power Windows?
- Bad dyno numbers
- gas gauge quit working
- Need buying advice 02 4.7
- Odd Blinker Problem
- 4.7 to 5.9 diesel conversion
- Lower control arms
- tranny flush?
- T Case rear extension housing
- Flex plate gap?
- Transmission fluid confusion and worry....
- 99 Dakota Sport 4x4 (i got some questions)
- throttle body spacer??
- Transmission change
- turn left and clack clack...please help
- Long time part out
- On Board Air
- What do you think.
- Lower back pain from stock '99 Dakota Sport seats
- paint help
- Interchangeable parts for a 2002 Dakota?
- 2000 Sport 2.5 - Check Gages - definitive answer?
- 3.9 V6 performance mods for under $1000
- Cummins ISF 2.8 drop into Dakota
- Need new tires
- New Dakota Owner - Couple Questions
- Question with installing a Remote Start on a 2000 Dakota Quad Cab (01SilverCC?)
- suspension upgrade/ update
- Buying 4.7 Maybe
- Can i bypass the a/c compressor with a shorter belt ?
- Snow tires worth it?
- chips??
- New to me 2003 Dakota
- New to the Forum & hard shifting
- Rear Seat
- 2004 Dakota Engine Light
- Cruise Control Troubleshooting
- replacement bucket seat
- New-2" Body lift
- 04 STX rear handle
- Will a 2004 5 speed transmission fit on a 2001? Newbie here...
- radiator help!!
