PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Brakes Pedal Pulsing
  2. Evap Line Cap question
  3. FYI, info on light bulb under the dash
  4. Flashing Check Engine Light after service
  5. 3.9 automatic stalling
  6. Goodbye friends
  7. lift kit quality
  8. 97 Dakota steering box seal. Help please.
  9. Ball Joints and Bushings fixed!!
  10. 02 Dakota Quad rear speaker replace
  11. Front Right CV axle replacement
  12. Throttle Body Spacer
  13. rough idle,getting and iac code.
  14. a/c compressor will come on
  15. Reverse lights not working properly
  16. Headlights staying on
  17. New Dakota owner w/ Problem
  18. transmission cooler??
  19. '04 Dakota stereo wiring diagram??
  20. Transmission problems only sometimes
  21. Dakotas without fender flares
  22. Thermostat housing 4.7
  23. Aftermarket stereo install help
  24. transmission problem
  25. Rough Idle/Intermident
  26. Flare removal...
  27. Rust Rust and More Rust
  28. Wheel Bearing & Hub Assembly
  29. Thrust alignment 4wd '02 Dakota quad cab
  30. 7 MPG Highway!
  31. What trans, Transfer case and axle do I have?
  32. mis-fire adaptive numerator at limit
  33. Rpm's jumping around and almost dies
  34. 2004 Dakota Turn Signal Relay location?
  35. Best type/weight oil for a 4.7
  36. Reflecting
  37. 02 Dakota Quad 4X4 4.7 Front Drive Shaft Length
  38. Need Audio Help!
  39. K&N Filter Drying Time
  40. Cabin filter replacement?
  41. Help with turn signals
  42. Need Help!!
  43. 2003 Dakota hauling dilemma..
  44. Rear seat speakers
  45. Rotm??
  46. My Blue Magic Headlight Restorer Review
  47. '04 Sport radio wiring diagram?
  48. valve covers seals
  49. multiple misfire on odd # cylinders
  50. Anybody get rear to shimmy through bumps?
  51. safety warring
  52. Quicker Responce
  53. 02 4.7L front diff 3.55 ratio swap
  54. 3.9 replacement exhaust?
  55. Exhaust answers!
  56. Alternator Amps
  57. 42re transmission help.
  58. Electrical ISSUES Please Help
  59. Need Help W/ upgradeing my A/C Condenser please
  60. CheckGaugesLight/Not starting
  61. First car! 1999 Dakota 4x4 102k
  62. Just bought '02 with 133,000 miles- to do list?
  63. auto to manual transmission swap.
  64. 4.7L Performance Upgrades... Advice/Help Wanted
  65. Transmission Flush
  66. 2003 Dakota Body Lift Problem...
  67. Rotella T6
  68. Lift Kit options
  69. help with blower motor
  70. Rough Idle under load/ Poor Gas Mileage
  71. 1st gen engines fit 2nd gen?
  72. 2000 Dakota 4x4 SLT towing / general performance
  73. OEM Brake Upgrade Question
  74. Read Here: Chevy HHR Fan MOD! READ if your thinking of doing this!
  75. Might be getting back into a Dakota!
  76. $1900.00 later still trannie issues
  77. Tattooed my town
  78. Want better A/C one trick
  79. new headlights
  80. clicking and pop sound in steering
  81. new emblems
  82. Need Help with Ball Joints and other Suspension work-02 QC 4WD
  83. R/T Ecu swap, is it worth it, what are the issues?
  84. AC/Heater Control Bulb replacement
  85. 4.7l h.o. Emblems $11.98 shipped
  86. new motor?
  87. how to wire chicken lights the correct way?
  88. bmw 525i goes kaput
  89. 02 Sport 5.9, can I swap the ecu for an 01 R/T ecu
  90. O2 Sensor for Dakota
  91. The Fastman Throttle Bodies
  92. damgoodtruck
  93. new rims and tires
  94. Brake fluid leak?
  95. Trans flush
  96. This time it is for real... I hope.
  97. Anyone double din there kota yet?
  98. Where can I buy seat foam for a '99 Sport?
  99. Incredibly pissed! Suggestions?
  100. Long drive with a trailer. Problems?
  101. What Tranny Will Work
  102. Power Steering Leak
  103. Stripped spark plug
  104. found trans filter
  105. Little boom in CC?
  106. Reason for bouncy rear end?
  107. Unofficial Sub/Amp Install For Regular Cabs
  108. Tranny quit working then worked today
  109. Tranny Problems
  110. Towing wires
  111. Single chamber muffler 3.9L
  112. Sipe your tires?
  113. Headlights won't go off
  114. Exhaust rebuild (Cat, dual pipes, muffler)
  115. Upgrade suggestions and help
  116. Place to get rear shock bolts?
  117. 02 transfer case
  118. swapping transfercase in a 02
  119. Dyno day results
  120. Paint question
  121. What do I need from J-YARD for elec fan swap
  122. Is it Hard fo find these wheel Caps/covers
  123. Had an accident, but I didn't.
  124. Transmission slipping - P1756 code
  125. Speedo Correction?
  126. rear differential hum?
  127. 2001 Dakota rear fender replacement
  128. motor swap
  129. Broken Lug Nut
  130. Speed sensor location
  131. Tire rubbing frame
  132. got alittle more work done
  133. Front brake lines
  134. Cold air intake
  135. v6 pushing 35s
  136. 97 dakota will not start unless....
  137. Truck running horrible after start, sometimes wont start
  138. E Brake Doesn't Work... At All.
  139. question on interor trim.
  140. give ya boy some help
  141. Bumper Prep Help
  142. Pilot bearing or kevlar bushing????
  143. Hood lift shocks?
  144. What could it be??
  145. Interior Lights Don't Go Off
  146. Weird turn signal/brake light problem
  147. cranks fine in morning but long crank all day
  148. Turn signals not working; hazards work
  149. 04 Dodge Dakota, 3.7L P0302
  150. 2.5 Shorty Header Install
  151. taurus or HHR fan? (current draw)
  152. 6 speed manual
  153. Transfer Case
  154. quick noob question
  155. OBDII Compliant?
  156. Last issue to fix on my list: Upper vents do not blow air…
  157. Body Lift Question...
  158. Best exhaust for 3.9L Dakota?
  159. Rod knock.
  160. Bought my first Dakota today. I think I got a great deal
  161. Thought it was a base model but maybe a Sport/SLT?
  162. rearend whine
  163. Been awhile. Little update
  164. Clutch fan to electric fan conversion question
  165. Transmission?
  166. update
  167. Cooling it off
  168. ram air cold air intake
  169. P0121 Code
  170. 99 dakota need help
  171. Aftermarket Camshaft Options - 4.7L
  172. Does your Dak have an upper windshield seal?
  173. cruise control help please
  174. Shock question for '03 quad 4x4
  175. Well here we go again A/C fan
  176. 02 3.9v6 Idle, shifting problems
  177. DIY Bedliner questions
  178. Tranny? Electrical? Module? 98 5.2
  179. Pics of my 97 Dakota
  180. 4.7 dual exhaust
  181. Spare tire yes or no?
  182. 4.7 oil pressure acting up
  183. dakota dead in its tracks
  184. Brake Lights not working
  185. 99dakota obd/overheadconsol wire problem
  186. Possibly Selling my Kota
  187. Vibration and Groaning noise
  188. Opinions on Performance Mods for a 3.9 V6
  189. tach hook up
  190. Help, 01 dakota quad buying
  191. dakota cutting out
  192. CD is stuck
  193. Lower front bumper
  194. hooked up battery backwards now all kinds of problems
  195. motor replace
  196. All you 3.9 owners
  197. Quick exhaust question
  198. Got my truck back... kind of
  199. Tickin' Noise
  200. Help-Electric Fan Controller Wiring
  201. 2000 dodge 4wd conversion
  202. Any Recomendations for Roll Pans?
  203. Transmission Problems getting expensive!!
  204. Possible Alternative to a SAS
  205. Imobilizer Question.
  206. 5.2/5.9 Longtube headers for 2wd
  207. Transmission/shifter issue
  208. Tranny leaks only idling in park
  209. trouble w/shifting automatically
  210. Catalytic converters
  211. DIY bumper build
  212. Custom exhaust setup
  213. Sale price for 04 Dodge Dakota V8?
  214. looking to swap a cummins 4bt into a dakota HELP!!
  215. 3.9 4bt cummins swap into dakota
  216. Can someone that likes to play around with photoshop help me?
  217. Viscous Fan Clutch Rebuild?
  218. Home made tonneau cover?
  219. Got a F*rd
  220. Ignition tumbler/cylinder replacment questions...
  221. I said I'd never go
  222. Bull bar questions
  223. 97 dakota rear end air bag setup
  224. 04 Dak CC 4wd 4.7 auto tranny vibration
  225. Instrument Cluster W Wrong Oil Pressure Reading
  226. Flywheel question
  227. Pricing used 03 quad cab
  228. Rear Leaf Springs
  229. Tranny filter change, drop and refill
  230. new HID Conversion sucks
  231. Bed organizer
  232. Popping threw steering wheel
  233. O2 sensor codes
  234. Best shocks for lifted dakota?
  235. New motor now transmission fluid leak?
  236. My official 1st Dakota 3.7 to 3.9 swap
  237. 2nd Gen Dakota (2004) Instrument Cluster LEDs?
  238. AX15 to NV3500 Questions
  239. Question about gas tank size.
  240. Cleaning the throttle body tomorrow!
  241. Window regulator compatablity
  242. What is a sport?
  243. Regular Cab Fitting Questions
  244. 2004 Dakota Quad Cab
  245. Is it wise to lengthen CV axles?
  246. Plugs and wires?
  247. Humming sound? Can it be as simple as the rear diff?
  248. Tool box with ladder racks?
  249. p0300,p0301,p0303 dakota 3.9
  250. Bosch Oxygen Sensor Problems in Dakotas?
