PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 1998 Dakota body
  2. Turd!!
  3. 2001 Dakota 4x4 Starter removal
  4. low idling and stalling issue, Need Help! 2002 Dakota 4.7Liter RWD Sport
  5. 4.7L - Tested the new valve stem seals
  6. 03 Durango - 04 Dakota Brakes
  7. Difference in OEM headgasket kits
  8. driver side low beam not working
  9. Allen key size
  10. Speedometer and A/C stopped working
  11. Metal handles
  12. Transmission
  13. 98 Dakota
  14. P/n switch
  15. 1999 dodge Dakota 3.9L automatic how do you change the heater core and what tools ?
  16. Abs 78
  17. Odd gauge behavior with check gauges light?
  18. How to install valve cover gaskets with no glue or RTV
  19. Several codes on my 03 v8 Dakota
  20. Coil packs
  21. 1998 Dakota 5.2 4wd
  22. high beams come on when i turn on fog lights?
  23. Need some advice pertaining to an '03 R/T
  24. Leakage along the bottom
  25. 2000 3.9 idles up
  26. Dakota Idler Arm Question
  27. Booster or master?
  28. Ignition coil issues
  29. Need help or advise please
  30. PO203 COde trouble shooting
  31. Looking for bed pictures
  32. 3.9 to 5.9 2WD swap : What do I need from the boneyard?
  33. Speedo Calibration for 2004 Dakota 4.7L
  34. Tuner
  35. 4.7 Abysmal Gas Mileage
  36. 97 Dakota rear diff 4WD
  37. Ford 8.8 in dodge dakota
  38. Truck issues
  39. Nasty heads
  40. 2004 dakota 4.7L coolant leak?
  41. 4wd not working
  42. 2000 4cyl Sport Oil Pressure Sender
  43. 98 dakota
  44. Which is better cai or a stock air intake
  45. Which is better cai or a stock air intake
  46. Manifolds
  47. Auto trans shifts only with weight in truck bed
  48. Transmission problems, Maybe?
  49. 2004 Dakota 5 speed will not go over 2000 rpms
  50. 1997 Dakota clicking transmission
  51. Need to find a roll bar
  52. V8 swapping my v6
  53. 2000 dak 5.9 rt stockish need help with wiring external pig tails for trans
  54. Driver side carpet soaking wet
  55. Reprogramming with a clone
  56. 2000 Dakota
  57. 02 dakota infinty radio harness schematic?
  58. 97 Dakota Starts, Runs 2 seconds then Dies
  59. Horn not working, checked all the usual suspects
  60. Driveshaft Swap or Lengthen? - Auto to Manual 2003 Quad Cab
  61. Hydraulic lifters - soak or not soak?
  62. Weather stripping for sliding rear window
  63. P0500
  64. Fuel Vapor lines
  65. Missfire cylinder number 1
  66. Wild vents, the redneck way
  67. Transmission taking off in third after transmission been replaced
  68. 46re line pressure adjustment
  69. 46re tune basic
  70. Torque specs
  71. 1997 Dakota Transfercase Questions??
  72. Leaf spring shackle, using the same bushing
  73. 4.7 Running Extremely Rough
  74. 1 of 4 body mounts rotted with rust.
  75. No Bus error but truck starts perfectly
  76. Control arm bushings
  77. Truck starts, no bus on odometer
  78. upgrading wheel size
  79. front brake problem
  80. '98 Starts by Itself When Installing New Battery
  81. P0118 code and temp gauge issue
  82. 2002 Dakota Transmission Maintenance
  83. 98 steering knuckle- will 2000 fit?
  84. Impossible Evap Leak??
  85. 06505828AA. Need specs on this bolt please.
  86. 2003 dakota 2wd lifted guys/gals please help
  87. '98 3.9L Cranks, No Start
  88. Rebuilding engine
  89. Ecu ?
  90. Hello
  91. Just a timing cover bolt?
  92. Front Diff Grenaded
  93. 2004 Data Plate info
  94. 01 Dakota Noise in Drivetrain.
  95. Tranny oil change follow up
  96. 4.7L Misfire codes on Cylinders 1, 2, 3, 5, 6, 8, but appears to run fine
  97. 1998 dodge dakota 5.2l oil pan removal
  98. Torsion Bar is the same?
  99. Transmission oil change.
  100. Towing Side Mirror
  101. Wheel Spindle
  102. band adjustments
  103. 2000 Dakota Engine Swap
  104. 4.7 Coolant draining
  105. New guy here, Fixing up the 2002 Dakota
  106. 313K - first major engine issue.
  107. 99 Dodge Dakota anti theft security system
  108. Blown piston
  109. Factory repair manual for sale
  110. Power window switch
  111. Parasitic draw
  112. 01 Fuel line check valve mod.
  113. Horn relay issues
  114. Overheating issues
  115. 97 5.2 Starting problem
  116. ABS Module [CAB] removal
  117. 04 dodge dakota V8 4.7L
  118. Can this massive tie rod angle be right?
  119. Door lock
  120. What did you do to your Dakota today?
  121. Stalling w/Power Steering AND 2 Different Warmup Temps
  122. Electrical issues
  123. POSSESSED 01 turned on 4wd!
  124. 1998 Dodge Dakota
  125. Suspension Question
  126. Injector differences between the 2002 and the 2003 Dakowith 4.7 engineta SLT
  127. Pressing ujoint out without removing driveshaft
  128. hose check engine ?
  129. High Pitched Whistling
  130. 03 Dakota AWD trans bang ?
  131. Inner and Outer Tie Rod Torque Specs
  132. Strange noise ive never heard before, vid posted
  133. Eaton Detroit Lockers
  134. Production numbers
  135. Overheating 5.9l V8
  136. rear traction ade
  137. Anyone know where this little gem goes?
  138. Airbag light
  139. ABS programmer
  140. Suspension lift kit
  141. Swap out
  142. Crank sensor gap?
  143. Which is the Correct Transmission Speed Sensor and Location?
  144. Transmission Clunking Sound Help
  145. Front suspension noise
  146. Head gasket repair
  147. Trans lines
  148. 44re with no computer?
  149. Transmission Valve Body Bolt Torque?
  150. Drb3 emulator
  151. Which Headlight To Use??
  152. Convert "98 Dak lights to LEDs, Maybe?
  153. 2000 Dodge Dakota heater not working!
  154. Converter compliance question
  155. Rattling in engine area
  156. 45rfe valve body
  157. Diablosport Predator 2
  158. 1999 Dakota 3.9L v6, P0118 code
  159. 99 Dakota carrying Harley Electra Glide in bed?
  160. 97 Dodge Dakota Issues
  161. Drb ii / iii
  162. bumper guard for 96 dodge dakota
  163. Dakota CTM/BCM
  164. 98 Dakota trans swap
  165. Parking brake help.......
  166. Different tire sizes in AWD
  167. 2004 5spd upgrade for 5.7
  168. Intake manifold leaking air!
  169. Great find worth sharing/odd
  170. Common Issues - 2004 SXT, V6, 3.7 Liter, 2WD
  171. Baffled by Random Warning Chime on 98 Dakota
  172. Stalling out
  173. Woo Hoo! Found a set of matching rims...
  174. 9.25 axle shaft 3rd to 2nd gen?
  175. I’m so lost! Please help!
  176. Cold start sound
  177. 2004 Dodge Dakota ABS Code 78
  178. Gen 2 4.7l v8 dakota with a p0725 code
  179. ABS flashing and no speedometer
  180. No dome lights
  181. Parasitic Drain traced to Security/Cluster Circuit
  182. Mpg
  183. Axel/stop
  184. Dodge Dakota 2002
  185. New wheels
  186. front camber on a cheap budget
  187. 1999 Dakota 5.2- Major Smoke - Help Please
  188. Leaky fuel injector.
  189. Fuel gauge erratic
  190. Front Body Perches Rotten - '04 Dakota
  191. Spark plugs
  192. front diff starting to leak
  193. SXT, Sport, Sport/SXT, Sport Plus?
  194. Wiring diagram
  195. 99 5.2 dakota radiator
  196. 2003 Dakota Blower Ground Wire
  197. Defrost Issue
  198. 99 5.2 dakota radiator
  199. 2004 Dodge Dakota P0344 code keeps coming up
  200. Dakota R/T trans shift prob
  201. 03 Dakota 3.9 4x4 5spd pcv valve whistles during cold weather
  202. 03 Dakota 3.9 4x4 tie rod ends too short after install, possible caster angle issue
  203. 03 Dakota 3.9 4x4 tie rod ends too short after install, possible caster angle issue
  204. 03 Dakota 3.9 4x4 tie rod ends too short after installation
  205. 4x4 noise... Still
  206. 2004 dodge dakota.
  207. click,click,click crazy
  208. Cat delete
  209. battery gauge
  210. Dodge dakota
  211. 01 Dakota Front end swapped to charger
  212. Tow Mirrors
  213. Forced Induction for a 4.7L
  214. 1998 3.9 No Crank/No Start.
  215. Transmission Error Codes
  216. Blower won't work
  217. batt temp sensor
  218. drive shaft for the 4x4
  219. Brake line
  220. Something new
  221. Trans fluid info
  222. Anyone care to estimate repair costs? '02 Dakota vs chunk of concrete.
  223. PO302 Error
  224. CTM question
  225. Almost cooked the 4.7
  226. Questions about steering shaft
  227. No Alarm Key Fob
  228. 3 injectors not firing
  229. Axle or hub?
  230. 01 dakota 5.9 stalls after it reaches normal temp.
  231. coolant problems
  232. Need Help!!!!
  233. Head Removal on a 2004 Dakota with a 3.7
  234. Need help
  235. O2 sensor difference
  236. aggravating unkown
  237. Common dakota?
  238. setting timing
  239. Ticking When Accelerating
  240. Rear diff gear oil change
  241. correct O2 sensor
  242. What lift kit to get?
  243. Rear end
  244. Front sway bar
  245. Squeaking Duck
  246. Help with my Dakota
  247. 4.7 to 5.7
  248. P0700 code 45rfe
  249. Want to put all my fuel in the truck
  250. 04' 4.7L 5 speed clutch replacement?
