PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Transmission shifting into 1st gear late?
  2. leaf springs + shackles
  3. PRNDL Indicator Vs. Neutral Safety Switch
  4. Brake line leak.....brake failure
  5. '99 3.9L hesitation & sputter?
  6. 03 4.7 Dakota stuck on full throttle after hard start
  7. 4.7L Headers
  8. 1997 4x4 transfer case interchange
  9. MY continuing sage re A/C
  10. timing belt has only one mark
  11. Over fueling problem
  12. HNTD: 99 Dak
  13. PO441 and a momentary rough idle just after startup
  14. 2001 Dakota SLT 4x4 4.7 Soft Brake Pedal
  15. cam/crank scope waveforms 1996 3.9l
  16. Oil and ATF change - rainy weekend
  17. A/C builds to high pressure???
  18. Alternator
  19. Catalytic converter
  20. 4.7 Header bolts
  21. 3.9 harmonic balancer questions...
  22. Shut my door and the window fell down
  23. Valve compression tool ?
  24. 2004 Dodge Dakota 3.7L 4x4 transmission issues
  25. Bulkhead connecter pin out
  26. Torque converter bolts
  27. 2000 Dakota Fuel injector circuit problem
  28. Air compressor method valve seal change (not building pressure)
  29. 2003 pcm
  30. Leaky T-Case
  31. Cant seem to get aliment done right.
  32. 2001 ABS module reset?
  33. Remove engine with lift plate?
  34. Cranks/no start P1389 code-Fried PCM
  35. Cascading Electrical Failure?
  36. Hard shifts when I restart the truck warm
  37. HELP!! Dodge Dakota will crank but wont start
  38. 4.7 HG Replacement - RTV?
  39. Will durango CV joint fix?
  40. 2000 Dodge Dakota losing oil pressure randomly. Sending unit is good
  41. Floor shifter possibilities?
  42. Rear diff type/info
  43. Transmission interchange
  44. wheel skins
  45. Need help no odometer stopped counting, no speedo, abs light and park brake light on
  46. 1998 Dakota Loss of Power
  47. Time for front wheel bearings?
  48. My 4.7L is leaking, what's common?
  49. No Compression No.1 Cylinder
  50. 03 Dakota Passager Headlight
  51. P1391 - Crankshaft no Crank Code
  52. Ye olde Head Gasket replace - or seal?
  53. Sequence number is worn off the ECM/PCM.
  54. Error code 303 455
  55. 03 Dakota with 22 gal tank OR DOES IT ?????
  56. 4.7 engine swap PCM
  57. 2003 dodge dakota engine
  58. newbie needs help with auto trans ? '99 Dakota
  59. Cannot find bleeder screws that fit
  60. DLC diagram
  61. Any Dana super 35 ifs owners .... im having some diffaculty with 98 ifs identity. ?
  62. blower motor resistor
  63. 545rfe trans low pressure
  64. 2004 Dakota will the 5-45rfe work?
  65. Dakota 4cyl/V8 Swap
  66. Running 265/75 instead of 265/70
  67. Upper ball joint
  68. 1997 and 1999 engine wireing different?
  69. Lights always on?
  70. 2002 Dakota 3.9 auto swap to v8?
  71. Bad Plenum Gasket??
  72. 3.7 SLT 2004 Major Problems
  73. 2000 4.7 rebuild
  74. Engine Swapped - orphaned connectors!
  75. Wet floorboards
  76. Tire wont lower, Really rusty
  77. 2001 Dakota blend door calibration?
  78. 2004 Brake Issues
  79. Looking for trophy/preruner fenders and box sides
  80. Please help misfire
  81. Window master switch lockout failure - 5 minute fix found
  82. Question concerning piston/rod orientation
  83. Noise/tensioner
  84. Electrical gremlins - blinkers, blower, headlights
  85. 02 4.7 overheating
  86. 2000 Dakota 3.9L throwing random misfire code
  87. 3.9 v6 2000 dodge dokota misfire code in bank 135
  88. Another Slave Cylinder Bleed Thread
  89. New tensioner pulley wobble?
  90. Lift kit advice?
  91. 1999 Dodge Dakota V6 2wd Oil pan help?
  92. Starter Bolt Question (3.9/5.2/5.9)
  93. 2002 ibd2 port
  94. 97 Timing Chain question
  95. Replacing my a/c system
  96. Trailer connector/wiring
  97. need e fan help asap
  98. 2001 3.9L questions
  99. HP?
  100. idle air control valve
  101. Detailed pic of 04 rear parking brake please!!!!!
  102. Won't Idle at Start but fine after moving
  103. V6 to v8
  104. Light bar
  105. 98 dodge Dakota no spark
  106. Transfer case motor
  107. 2000 dakota spare tire carrier winch
  108. electric fan help
  109. 04 Dakota 4.7 Auto Transmission acting funny...
  110. 2000 dakota belt tension installation
  111. Power Window Locks
  112. Think I'm missing something
  113. 44RE 5.2L TO 46RE 5.2L Swap
  114. Steering alignment
  115. Catalytic converter
  116. 01 dakota 3.9 quad cab rusted body mount
  117. Air Bags
  118. A/c not working 2002
  119. 2000 Dakota Sport 4.7 Doesn't run
  120. Preserving a Rust Belt Survivor | '97 Dakota
  121. 45 rfe
  122. Intermittent P0340
  123. Setting backlash and pinion depth
  124. Grinding transmission.
  125. 2003 Dakota window switches don't work.
  126. distrbutor removal,lol
  127. Another p1698
  128. Body mount bushings? Where to find them
  129. Transmission fluid
  130. 01 dodge dakota no spark
  131. 1997 Dodge Dakota
  132. dodge dakota 2002
  133. Rear tire locking after stopping then"service 4x4" light comes on
  134. Engine Noise - 2004
  135. Transmission moving tips?
  136. Flywheel Part Number 4.7l
  137. p0456pd... What are my options?
  138. power gains
  139. Coolant leak 2002 dakota 8 cyl
  140. 3.9L tuner
  141. Manual to power locks and windows
  142. Vacuum hose on front axle
  143. NV3500 Noise
  144. Head job, torque specs. 99 Dakota 2.5
  145. 02 dakota 3rd brake light/cargo lamp
  146. Advice on Buying 2nd Gen 2004 Dakota 4x4
  147. 1999 Dakota Transmission problem
  148. 01 dakota stuck in 4x4
  149. won,t idle all the time
  150. engine replacement on 97 dodge dakota sport 4 cylinder manual transmission
  151. LOW Brake Pedal.... FIXES Itself.... Now OK... WT* ?
  152. stalling in reverse
  153. Lost passenger control of power windows
  154. 2000 Dakota quad cab 3.9 4x4 not working
  155. Rear brake/drum
  156. idler pulley sizes?
  157. Rebuilt Transmission
  158. security light 2001 dodge dakota
  159. Stupid P0499 Code
  160. Anyone recognize this rebuild tag?
  161. 2000 Dakota , brake issues
  162. Troubleshooting Brakes
  163. RPM Drop
  164. 1999 Dodge Dakota 3.9, Turns over briefly then clicks
  165. Brake line fittings
  166. Ram trans swap to Dakota question
  167. Does my truck have ....
  168. 2001 Dakota 4.7 engine differences?
  169. Backfiring and shutting off in a 1998 dodge dakota 3.9 V6
  170. New Guy Here Looking Into Buying a '98
  171. Po307
  172. Rear brake question
  173. Burning Smell When Braking Hard
  174. Rear axle question:
  175. Electrical?
  176. 5.2 Magnum and 5.9 Magnum intake Q
  177. radiator replacement
  178. flasher bulbs
  179. Programming a key fob for 2001 Dodge Dakota
  180. Next problem - '98 Dak - Water pooling on Passenger Floor
  181. Someone with a 1999 Dakota...
  182. Dodge Dakota 2004
  183. 2001 Dakota 4x4
  184. 1997 Dodge Dakota won't Idle when cold stArt issue
  185. no idle?
  186. 2000 3.9L V6 oil pressure.
  187. autostart remote starter for 2004 dodge dakota
  188. Bumpers...
  189. trans fill plug
  190. heater intermittent
  191. Defective DLZ Ball joints - won't take grease
  192. NV 3500 transmission questions
  193. 4.7 Head gasket job
  194. 2001 Dodge Dakota 4x 4 transmission help
  195. 2004 Dakota 4.7 won't start p0688 please help
  196. Trouble diagnosing wheel bearing
  197. 03 durango pw work intermittently
  198. 2000 Dakota Sport 4x4 3.9L Lifter tap?
  199. Dash lights /headlights w interior
  200. Intermittent Cruise control got worse
  201. V10 magnum
  202. Hello, transfer case issue
  203. Cylinder 3 and 5 misfire
  204. Rebuild
  205. Blower resistor plug
  206. Body swap question
  207. headliner
  208. will the transmision from a 1997 1500 4x4 5.2l work in my 1997 dakota 4x4 5.2l?
  209. 3.7 remote turbo
  210. Dakota hood latch release relocation
  211. 97 Sport dash lights
  212. no spark / crank sensor
  213. 99 dakota engine swap please help
  214. high beams not working
  215. Getting these error codes 0645 and 1598
  216. Hello all I have a 2002 Dakota slt
  217. Hello all I have a 2002 Dakota slt
  218. 4x4 Dak trans trouble
  219. been installing a new stereo
  220. 2000 dodge Dakota CTM location
  221. Oil pressure gauge
  222. wondering
  223. '98 Dakota Starting Problem
  224. dodge dakota, shuts down only going into drive
  225. 5.2 and 5.9 interchangeable parts
  226. limited slip differential?
  227. How much should I ask for he motor?
  228. Caster allignment
  229. What is rear gear ratio difference for 5 speed vs automatic
  230. Daughter`s truck won`t get past 1st gear
  231. 03 Dakota 4x4 3.9
  232. Codes
  233. 98' Dakota tuning question
  234. 99 dakota 4x4 problems
  235. Coolant issue/ question
  236. post with out moderator review
  237. Dodge Dakota
  238. Where to find glass for my quad cab LEER cap?
  239. 02 Dakota tailgate does not latch
  240. LED headlights and bumper grill mesh
  241. 03 dakota r/t 5.9L dies after warm
  242. Are broken exhaust manifold bolts common ???
  243. O2 question .
  244. 2001 Dakota door locks
  245. No bus pls help
  246. 1998 Durango brake/ABS light on, no spedo.
  247. Dodge Dakota With a V-10 Viper Engine!
  248. Jumper for fuel pump to stay on continuously?
  249. Stuck spark plug advanced removal techniques
  250. 4wd problems
