PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Blinkers randomly quitting
  2. Cruise Control "Issue"
  3. 99 Dakota RT P0152 problem.
  4. noise when on the gas..
  5. More Tow-Hook Talk...
  6. Fuel Pump Replacement- Is it worth it?
  7. Removing rear panel
  8. Has anyone made an air dam for their truck?
  9. COTM and TOTM vote now
  10. 98 5.2 Dakota P0420 stumped
  11. sensor problem??
  12. Winter setup
  13. Newbie From Erin,Tn. and need help
  14. 2.5 won't start
  15. Recall Info
  16. I promised better pictures....
  17. transmission question????????????
  18. new tire question??
  19. Heater Core
  20. Supercharge or Turbocharge?
  21. Noise inside the dash
  22. v8 throttle body swap
  23. Hey check this out...
  24. Front bearings question. 2k dakota.
  25. No Power windows, need help
  26. 1999 Dakota Factory Service Manual
  27. 2001 Dakota Sport
  28. Is there a post on how to drain differential?
  29. Belt Tension
  30. Few questions bout a 3.9 w/ a V8 TB
  31. Lost power windows and heater blower
  32. 31's on stock suspension
  33. 2008 Dakota SRT8
  34. OK I remember why VIP sucks
  35. Power out of a R/T
  36. problem with spedometer
  37. Looking to Buy my First Dakota
  38. Speed sensor question.
  39. 97 and 2003 Dakota Questions
  40. gonna need a new trans
  41. Better Brakes?
  42. Heater question
  43. Engine Hesitates and Pops while driving
  44. Best headers
  45. 03 R/T Info
  46. Mods???
  47. power steering
  48. Why is my 1997 dodge dakota 4x4 making two clicking noises
  49. I could use a hand... SRT/10 Swap
  50. Stock head unit
  51. engine compatability
  52. Heater resistor or heater core problems
  53. ?Rock screen? for front bumper openings?
  54. bad burnouts, crappy hip hop, and some big mexican guys
  55. this thread is for 4x2 guys who deal with snow...
  56. new here need help PLEASE
  57. New | Hello
  58. I hit skid plate gold for my 03 Dakota!!
  59. Headlight Testing
  60. Just had to tell ya'll
  61. experiences with superchips 3815?
  62. Anyone looking for an exceptionally clean dakota?
  63. Altitude Factor
  64. 2000 4.7L transmission pan gasket?
  65. No start after battery reset..?
  66. 1 wheel nonsense
  67. fuel problem?
  68. from a 6 lug to a 5
  69. Hauling
  70. P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained abo
  71. 98 dakota 4x4 axle sliped out........
  72. O2 sensor readings don't make sense 98 Dak
  73. drive line
  74. Buying new bearings question.
  75. R/T tires?
  76. Heater Core.
  77. new mods added
  78. Removing power steering rack 2000 dakota 4x4
  79. 4.7L Valve Covers (Aftermarket)??
  80. I need your vote!
  81. Manual Transmission Fluid
  82. new brake lines
  83. Totm voting!
  84. quick bed length question
  85. Need tire/suspension help
  86. Can an "AWD" dakota be run in 2wd mode?????
  87. da-tada!
  88. Camber help pls
  89. 1997 Dodge Dakota Transmission Trouble
  90. New Front Brake Setup on Order. EBC Brakes
  91. A newbie with a ninety-nine
  92. need some help lowering the dak
  93. 03 4x4 Front End Grinding/Squealing Noise
  94. Selling a 2002 TB
  95. upper ball joint
  96. Which bearing is bad now??
  97. Aftermarket Remote Starter/Keyless Entry Install
  98. Lift kits/accessories for '03 Sport SLT?
  99. Heater core......
  100. Which of these two trucks??? Need help deciding!!!
  101. How to turn off child protection door locks
  102. P0455 code
  103. Dakota 4.7 electric fan
  104. 99 Dakota Won't Start
  105. Procomp Xtreme A/T
  106. Batman...
  107. brakes done
  108. brake thread? again?
  109. Speedometer Inoperative
  110. 3.9 Exhaust Diameter
  111. 4x4 frame ?
  112. Best investment
  113. engine swap 3.7 to 4.7
  114. Issues finding fog light bulbs
  115. keyless entry lock horn beep
  116. speaking of bumpers
  117. custom bumper
  118. muffler myths...... this one sounds true.
  119. almost died, what did i miss?
  120. Ratchet Shifter for 5.2L
  121. Supercharger
  122. Official 2nd Gen OT Thread
  123. tb question
  124. Which Brake Pads?
  125. Never have a transmission problem
  126. I love ebay!!!
  127. Butt plug in rear differential?
  128. Fuel Injector Cleaner?
  129. Too much oil?
  130. Do I need to adjust the bands?
  131. To add or not to add LSD additive
  132. what kind of rims should i get
  133. How can you tell?
  134. 2001 Dakota
  135. Clutch Question.
  136. Better shocks?
  137. Pooched the tranny
  138. I need your opinion
  139. new muffler is ON
  140. How can i tell if i have 4wheel abs?
  141. OEM/Aftermarket Body Parts
  142. doin a little 408 research.......
  143. Fixed
  144. Electric Water Pump
  145. Lifting a 98 Dakota
  146. Emissions Question
  147. 1998 dakota with 318 engine temp
  148. HHO and O2 Sensor
  149. pic of my ole' '04
  150. remote starter/alarm need help!!
  151. Whistling sound/wining sound when ac is on.
  152. Tune up?
  153. door ding ding ???
  154. Spark plug question?
  155. O2 sensor help
  156. Synthetic or not?
  157. Dakota Model Abbreviation? Hmmm
  158. 2003 trim questions??
  159. What'ya think about this exhaust?
  160. P-0158 code
  161. Problem 911 urgent !!!
  162. Driver's side head lamp?
  163. Front bumper on "04"
  164. K&N Air Filter
  165. When bearings fail...
  166. Dakota section meet and greet?
  167. sxt ??
  168. 2004 4.8l "broken lower rod bearing"
  169. Alarm help
  170. Pics of the new truck
  171. re-set button
  172. couple new pics for you guys...
  173. What rear gears
  174. Why am I smelling gas?
  175. 2002 4.7L Intake Mani on 2000?
  176. gotta love old tires
  177. My "New" Headlights
  178. Painting Stock rims
  179. Throw out bearing or CAI?
  180. dropped a cold $1000 on the dak today....
  181. more power out of a v6
  182. Rear End
  183. Winter tires
  184. Engine questions?
  185. Want to gain 3mpg or more?
  186. Towing question
  187. Is this a good deal? 2003 4x4 v6 130k mi. Is it the truck for me?
  188. 97 Dakota ?'s
  189. Exhaust questions?
  190. CAI Installed!
  191. Free Hood
  192. Blaster coil
  193. is it worth it?
  194. 97 Dakota Auto Transmission Problem
  195. Replace fan clutch, and HOWLING noise
  196. i really want some head.........s
  197. Removing stock airbox, PLEASE HELP!!
  198. 93 Dodge dakota, brake problems
  199. New truck finally!!
  200. CAI just came in, 2 quick questions!
  201. 205MM front axles suck balllllls
  202. Cold/Wet weather stalling issues.
  203. What plugs with a MSD ignition box?
  204. Truck Smoking on Deceleration?? HELP!!!!
  205. MPG info
  206. DFW Dakota Meet Nov. 22nd (depends on weather) Hooters Denton, TX
  207. Engine swap?
  208. Can you fix a caliper?
  209. autolite 3923 gap?
  210. How much is she worth?
  211. help! how to tune a 03 r/t kennebell supercharged dakota without optimizer!!
  212. eBay never..
  213. 3.9L is for sale!
  214. 03 dakota 5.9 supercharger
  215. Seeking plastic wheel bearing cover.
  216. New (used) 2002 Quad Cab 4x4...key questions
  217. fuel problem
  218. What size tires!!
  219. sometimes you just need a drink and a cigarette.....
  220. Cooling system problems
  221. code: 0442 EVAP leak
  222. Gearing, LSD, Lockers, speed sensor,
  223. Transmission not shifting well
  224. Rear bumper plastic
  225. Help please!!!
  226. 4.7L CNG conversion?
  227. exaust/intake gasket done...with stipulations...
  228. lowering an R/T
  229. Climate controls
  230. Unknown Problem?
  231. Sway bar upgrade
  232. chatter
  233. Vacuum line
  234. Another race thread
  235. Transmission Problem.
  236. Manual
  237. Exhaust Leak-Mission Accomplished!
  238. 2004 Dakota 3.7L V6 question?
  239. CAI Installation on 04 Dakota 3.7L??
  240. Intermittently Noisy transfer case
  241. Hurst Shifters??
  242. SR. pix ideas?!?!
  243. 02 sensor question
  244. Cold air intakes and water??
  245. 1998 Dakota Wiring help
  246. fan removal
  247. Gibson exhaust
  248. Superchips now available for 04 4.7
  249. factory electric fan
  250. 87-91 Edlebrook Headers on a 99?
